10-11-2016, 23:37 | #16936 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Selected model: SM-J700T Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-J700T Android version: 6.0.1 Product code: SM2J700TZWATMB Phone version: J700TUVU1APF2 PDA version: FA60_J700TUVU1APF2 CSC version: CSC country code: CSC sales code: HW version: REV0.5 Phone SN: R58H80SF5WR Modem board: SHANNON310 RF cal date: 20160805 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.26.9 |
10-12-2016, 00:23 | #16937 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | Operation: Patch Certificate Selected model: SM-G925T Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.1.1 Product code: SM2G925TZDATMB Phone version: G925TUVU3DOJ7 PDA version: G925TUVU3DOJ7 CSC version: G925TTMB3DOJ7 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R5xxxxxxxxxx Modem board: SHANNON333 RF cal date: 20150726 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.26.9 |
10-12-2016, 11:03 | #16938 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Samsung s6 edge g925f DRK repair done REPAIR INSTRUCTIONS: Reset EFS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Operation: Repair DRK Selected model: SM-G925F Software version: 26.9 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash interface... COM47 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXS4DPIK Platform: exynos7420 Boot serial: 1215fc21d1503805 Product board: zerolte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.26.9 |
10-12-2016, 17:19 | #16939 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | g531F imei repair done Code: Checking CERT file... OK KEY ID: 0001 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FXXXAMO Phone version: G531FXXU1APB2 PDA version: G531FXXU1AOF7 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: R58G706VDDJ Modem board: RF cal date: 20150704 IMEI: Checking Super user right... true Reading NV data... OK Analyzing SEC file... OK Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0001 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.26.9 |
10-12-2016, 17:30 | #16940 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | THIS ALSO IS DONE UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SM-J120A Software version: 26.9 Searching Samsung modem... detected COM133 Reading phone info... OK Model: SM-J120A AP version: J120AUCU1APC8 CSC version: J120AATT1APC8 CP version: J120AUCU1APC8 Product code: SM2J120AZWCATT Phone SN: R58H71Z78LK Unique number: CFN0032F9238263 Reading IMEI... OK IMEI: 35626------ (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 I LOVE THIS TOOLS Z3X THANKS |
10-12-2016, 23:59 | #16941 (permalink) |
Member: 2428732 Status: Offline Thanks Meter: 22 | FRP AND UNLOCK N920P BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read SEC' button to read security area backup or 'Write SEC' to restore it or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC' (ignore it, if not available). Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Reset FRP/React/EE Selected model: SM-N920P Software version: 26.9 Searching Samsung USB Flash interface... COM4 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 .................................................. ................ UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock SPRNT Selected model: SM-N920P Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-N920P Android version: 5.1.1 Product code: Not Active Phone version: N920PVPU2AOI6 PDA version: N920PVPU2AOI6 CSC version: N920PSPT2AOI6 CSC country code: USA CSC sales code: SPR HW version: N920P.03 Phone SN: 00000000000 Modem board: MDM9635M RF cal date: 2015.07.24 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-13-2016, 10:17 | #16942 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | g928tf frp reset done Operation: Reset FRP Selected model: SM-G928F Software version: 26.9 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G928F Android version: 6.0.1 Product code: SM-G928FZDANEE Phone version: G928FXXU2BPF1 PDA version: G928FXXS2BPF1 CSC version: G928FNEE2BPB6 CSC country code: Nordic CSC sales code: NEE HW version: MP 0.500 Phone SN: 00000000000 Modem board: SHANNON333 RF cal date: 20150923 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' |
10-13-2016, 11:10 | #16943 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK DONE [ 13-Oct-16 4:53:00 AM ] Waiting ADB device... [ 13-Oct-16 4:53:00 AM ] Please, allow USB debugging on phone... OK [ 13-Oct-16 4:54:00 AM ] Reading phone info... [ 13-Oct-16 4:54:00 AM ] Model: SM-G925P [ 13-Oct-16 4:54:00 AM ] Android version: 5.1.1 [ 13-Oct-16 4:54:00 AM ] Product code: Not Active [ 13-Oct-16 4:54:00 AM ] Phone version: G925PVPU3BOJ7 [ 13-Oct-16 4:54:00 AM ] PDA version: G925PVPU3BOJ7 [ 13-Oct-16 4:54:00 AM ] CSC version: G925PSPT3BOJ7 [ 13-Oct-16 4:54:00 AM ] CSC country code: USA [ 13-Oct-16 4:54:00 AM ] CSC sales code: SPR [ 13-Oct-16 4:54:00 AM ] HW version: G925P.02 [ 13-Oct-16 4:54:00 AM ] Phone SN: 00000000000 [ 13-Oct-16 4:54:00 AM ] Modem board: MDM9635M [ 13-Oct-16 4:54:00 AM ] RF cal date: 2015.06.23 [ 13-Oct-16 4:54:00 AM ] IMEI: [ 13-Oct-16 4:54:00 AM ] Writing AT RIL... OK [ 13-Oct-16 4:55:00 AM ] Initialization AT RIL... OK [ 13-Oct-16 4:55:00 AM ] Unlocking... OK [ 13-Oct-16 4:55:00 AM ] Rebooting phone... OK [ 13-Oct-16 4:55:00 AM ] Unlock done [ 13-Oct-16 4:55:00 AM ] [ 13-Oct-16 5:00:00 AM ] Operation: Unlock SPRNT [ 13-Oct-16 5:00:00 AM ] Selected model: SM-G925P [ 13-Oct-16 5:00:00 AM ] Software version: 26.9 [ 13-Oct-16 5:00:00 AM ] [ 13-Oct-16 5:00:00 AM ] Waiting ADB device... [ 13-Oct-16 5:00:00 AM ] Please, allow USB debugging on phone... OK [ 13-Oct-16 5:00:00 AM ] Reading phone info... [ 13-Oct-16 5:00:00 AM ] Model: SM-G925P [ 13-Oct-16 5:00:00 AM ] Android version: 5.1.1 [ 13-Oct-16 5:00:00 AM ] Product code: Not Active [ 13-Oct-16 5:00:00 AM ] Phone version: G925PVPU3BOI1 [ 13-Oct-16 5:00:00 AM ] PDA version: G925PVPU3BOI1 [ 13-Oct-16 5:00:00 AM ] CSC version: G925PSPT3BOI1 [ 13-Oct-16 5:00:00 AM ] CSC country code: USA [ 13-Oct-16 5:00:00 AM ] CSC sales code: SPR [ 13-Oct-16 5:00:00 AM ] HW version: G925P.02 [ 13-Oct-16 5:00:00 AM ] Phone SN: 00000000000 [ 13-Oct-16 5:00:00 AM ] Modem board: MDM9635M [ 13-Oct-16 5:00:00 AM ] RF cal date: 2015.06.23 [ 13-Oct-16 5:00:00 AM ] IMEI: [ 13-Oct-16 5:00:00 AM ] Writing AT RIL... OK [ 13-Oct-16 5:01:00 AM ] Initialization AT RIL... OK [ 13-Oct-16 5:01:00 AM ] Unlocking... OK [ 13-Oct-16 5:01:00 AM ] Rebooting phone... OK [ 13-Oct-16 5:01:00 AM ] Unlock done THANKSSSS |
10-13-2016, 13:42 | #16944 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung Galaxy S7 EDGE FRP Reset Done... Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 26.9 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash interface... COM32 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDABTU Phone version: G935FXXU1APB2 PDA version: G935FXXU1APAW CSC version: G935FBTU1APB2 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.801 Phone SN: RF8H51HAAAA Modem board: SHANNONAAA RF cal date: 20160516 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.9 |
10-13-2016, 14:42 | #16945 (permalink) |
Freak Poster Join Date: Jan 2016 Age: 34
Member: 2516015 Status: Offline Thanks Meter: 100 | Samsung E1200R Flash done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. Choose flash option if needed: -'Re-write NV' - Warning! This option will erase all calibration data! -'Single file firmware' - if you have *.pac firmware 3. Press 'Flash' button. 4. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Operation: Flash Selected model: GT-E1200R Software version: 26.9 Waiting phone... detected COM14 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\NV\nvitem_ GT-E1200R_13-10-2016_14-39-49.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:01:19) Done with Samsung Tool PRO v.26.9 |
10-13-2016, 23:16 | #16946 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE N920W8 UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-N920W8 Software version: 26.9 Searching Samsung USB Flash interface... COM68 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 |
10-14-2016, 02:10 | #16947 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE G920P Operation: Reset FRP/React/EE Selected model: SM-G920P Software version: 26.9 Searching Samsung USB Flash interface... COM69 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 THANKS |
10-14-2016, 09:48 | #16948 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Karachi, Pakistan Age: 28
Member: 1785307 Status: Offline Thanks Meter: 112 | Succefully Unlocked FRP S7 Edge G935FD UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 26.5 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash Interface... detected COM150 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDUXSG Phone version: G935FXXU1APEQ PDA version: G935FXXS1APG3 CSC version: G935FOJV1APF1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.801 Phone S/N: RF8H40GHV8H Modem board: SHANNON335 RF cal date: 20160406 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.5 |
10-14-2016, 10:05 | #16949 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | g925f unlock done (no root ) Code: Searching Samsung modem... detected COM178 Reading phone info... OK Model: SM-G925F AP version: G925FXXU4DPGW CSC version: G925FOXX4DPH1 CP version: G925FXXU4DPGW Product code: SM-G925FZKAXEF Phone SN: RF8H51M9R0L Unique number: 02160228D6B142E3 Reading IMEI... OK IMEI: 356420076925551 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-14-2016, 11:26 | #16950 (permalink) |
Freak Poster Join Date: Jan 2008 Location: philippines
Member: 669596 Status: Offline Sonork: 1657504 Thanks Meter: 136 | SM-G531F/DD Unlocked DONE... Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G531F Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FZADINS Phone version: G531FDDU1AOK2 PDA version: G531FXXU1AOH1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: RZ8GA081RGT Modem board: RF cal date: 20151007 IMEI: Checking Super user right... true Reading NV data... OK Analyzing SEC file... OK Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
