Old 12-01-2016, 11:48   #17251 (permalink)
Member: 1479334
Thanks Meter: 4
Repai imei G920F failed wath is wrong.
MODEL G920F
Bootloader : G920FXXS4DPJ2
Build Nr. MMB29k
Andr: 6,0,1
Operation: Repair
Selected model: SM-G920F
Software version: 27.3
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... Ok
Reading phone info...
Model: SM-G920F
Android version: 6.0.1
Product code:
Phone version:
PDA version: G920FXXU3DPCA
CSC version: G920FXEG3DPC3
CSC country code: Germany
CSC sales code: XEG
HW version:
Phone SN: RF8GB1VX9VD
Chip name: EXYNOS7420
Modem board:
RF cal date:
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... Ok
Initialization zTool... Ok
Running zTool, please wait...
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data from phone...
Exception: Format 'error (%s)' invalid or incompatible with argument
Done with Samsung Tool PRO v.27.3
Old 12-01-2016, 12:24   #17252 (permalink)
Member: 71269
Thanks Meter: 44
j320fn ney security 2016 read code ok with out root
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 11111111
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Read Codes
Selected model: SM-J320FN
Searching Samsung modem... detected COM83
Reading phone info... Ok
Model: SM-J320FN
Version: J320FNXXU0APK2/J320FNOXX0APK1/J320FNXXU0APK1/J320FNXXU0APK2
Product code: SM-J320FZKNXEF
Phone SN: RF8HA2N5FWV
IMEI: 3527180xxxxxxx
Unique number: CQN0033E8C453A3
Reading codes... Ok
Please wait, calculating codes... OK (time - 00:00:45)
Freeze code: 04794837
NET lock: 25816361
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Old 12-01-2016, 13:38   #17253 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 361
G930F Frp reset done
Operation: Reset FRP/React/EE
Selected model: SM-G930F
Software version: 27.2
Checking local file... Ok
Searching server... Ok
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM47 detected
Setup connection... Ok
Reading data from phone... Ok
Sending data to phone... Ok
Model: SM-G930F
Product code: SM2G930FZKAXSA
Phone version: G930FXXU1APDN
PDA version: G930FXXU1APDN
CSC version: G930FXSA1APDN
CSC country code: Australia
CSC sales code: XSA
HW version: MP 0.700
Phone SN: R58H63CMJZY
Chip name: EXYNOS8890
Modem board: SHANNON335
RF cal date: 20160623
IMEI:
Erasing FRP... Ok
Restoring kernel... Ok
Rebooting phone... Ok
Reset FRP done
Done with Samsung Tool PRO v.27.2
Old 12-01-2016, 17:07   #17254 (permalink)
A4L
Member: 2014742
Thanks Meter: 157
Samsung S5 Neo Read Cert
SIM card must be taken out.
Operation: Read CERT
Selected model: SM-G903W
Searching Samsung modem... detected COM119
Model: SM-G903W
AP version: G903WVLU1BPF1
CSC version: G903WOYA1BPF1
CP version: G903WVLU1BPF1
Product code: SM-G903WZKARWC
Phone SN: RFxxxxxxxxxx
Unique number: C0xxxxxxxxxxxxxxx
Reading IMEI... Ok
IMEI: 354xxxxxxxxxxxxxx (SIGN: OK)
Modem board: SHANNON310
Calculating... Ok
HWID: E5 7C 6A 38 60 79 6D F4 EE 73 39 BD 4A 82 F6 82
Certificate file saved to C:\Program Files\Z3X\Samsung\SamsungTool\backup\Cert\SM-G903W_RFxxxxxxxxxxx_354xxxxxxxxxxxxxx_1-12-2016_11-3-20.cert
Old 12-01-2016, 19:04   #17255 (permalink)
Member: 2428732
Thanks Meter: 22
[ 12/1/2016 8:22:00 AM ] Operation: Read CERT
[ 12/1/2016 8:22:00 AM ] Selected model: SM-J120A
[ 12/1/2016 8:22:00 AM ] Software version: 27.2
[ 12/1/2016 8:22:00 AM ] Searching Samsung modem... detected COM210
[ 12/1/2016 8:22:00 AM ] Reading phone info... Ok
[ 12/1/2016 8:22:00 AM ] Model: SM-J120A
[ 12/1/2016 8:22:00 AM ] AP version: J120AUCU2APJ2
[ 12/1/2016 8:22:00 AM ] CSC version: J120AATT2APJ2
[ 12/1/2016 8:22:00 AM ] CP version: J120AUCU2APJ2
[ 12/1/2016 8:22:00 AM ] Product code: SM2J120AZWBATT
[ 12/1/2016 8:22:00 AM ] Phone SN: R58XXXXXX
[ 12/1/2016 8:22:00 AM ] Unique number: CFN009881A15853
[ 12/1/2016 8:22:00 AM ] Reading IMEI... Ok
[ 12/1/2016 8:22:00 AM ] IMEI: 356XXXXXXXXXX3 (SIGN: OK)
[ 12/1/2016 8:22:00 AM ] Reading data from phone... Ok
[ 12/1/2016 8:24:00 AM ] Modem board: SHANNON308
[ 12/1/2016 8:24:00 AM ] Checking NV data... Ok
[ 12/1/2016 8:24:00 AM ] Calculating... Ok
[ 12/1/2016 8:24:00 AM ] HWID: A4 9B 35 5A 91 7B 87 99 16 E2 94 5B 3C A5 8E A3
[ 12/1/2016 8:24:00 AM ] Certificate file saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-J120A_R5XXXXXXX_356XXXXXXXXXXX_1-12-2016_8-24-23.cert
Old 12-01-2016, 19:57   #17256 (permalink)
Member: 2428732
Thanks Meter: 22
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
2. Enable 'USB debugging' in
'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore.
7. Press 'Write NV DATA' if you need to restore NV backup.
Operation: Unlock
Selected model: SM-G550T1
Model: SM-G550T1
Product code: SM2G550TZKATMK
Phone version: G550T1UVU1APF1
PDA version: G550T1UVU1APF1
CSC version: G550T1TMK1APF1
CSC country code: USA
CSC sales code: TMK
HW version: REV0.4
Phone SN: RVXXXXX
Chip name: EXYNOS3475
RF cal date: 20160630
IMEI:
Initialization AT RIL... Ok
Reading IMEI... Ok
IMEI: 35XXXXXXXXXXX (SIGN: OK)
Unlocking... Ok
Unlock done
Old 12-01-2016, 22:46   #17257 (permalink)
Member: 2655426
Thanks Meter: 5
Model: SM-G930F
Product code:
Phone version: G930FXXU1APD1
PDA version: G930FXXU1APD8
CSC version: G930FOJV1APD8
CSC country code: UAE
CSC sales code: XSG
HW version:
Phone SN: 00000000000
RF cal date:
IMEI:
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Patching CERT check... done
Old 12-02-2016, 01:04   #17258 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 837
Samsung Galaxy SM-J320AZ Unlocked w/Z3X Box :-)
4. Press 'Unlock' button.
Operation: Unlock
Selected model: SM-J320AZ
Software version: 27.1
Searching Samsung modem... detected COM47
Reading phone info... ok
Model: SM-J321AZ
AP version: J321AZTUU1APD1
CSC version: J321AZAIZ1APD1
CP version: J321AZTUU1APD1
Product code: SM-J321AZDZAIO
Phone SN: R28H33KASXK
Unique number: CQN00EFFAC4B123
Reading IMEI... ok
IMEI: ........................... (SIGN: OK)
Reading data from phone... ok
Unlocking... ok
Rebooting phone... ok
Unlock done
Done with Samsung Tool PRO v.27.1
Old 12-02-2016, 09:46   #17259 (permalink)
Member: 2534499
Thanks Meter: 2
g925i IMEI repair done
android 5.1.1
thx z3x team
Old 12-02-2016, 16:36   #17260 (permalink)
Member: 2656164
z3x box samsung express modal imei not support bro help me plz bro...
Old 12-02-2016, 23:03   #17261 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,457
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
5. Press 'Unlock' button for direct unlock.
To read security codes:
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
4. Press 'Reset FRP' to deactivate Google account activation lock.
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
Selected model: SM-G928T
Searching Samsung USB Flash interface... COM35 detected
Reading PIT from phone... Ok
Searching FRP lock... Ok
Erasing FRP... Ok
Searching Reactivation lock... Ok
Erasing Reactivation lock... Ok
Searching EE lock... Ok
Erasing EE lock... Ok
Reset done
Old 12-02-2016, 23:35   #17262 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,457
Operation: Unlock
Model: SM-G928T
Android version: 5.1.1
Product code: SM4G928TZKATMB
Phone version: G928TUVS2COKC
PDA version: G928TUVS2COKC
CSC version: G928TTMB2COKC
CSC sales code: TMB
HW version: REV1.0
Phone SN: R58G71TZ9RD
Modem board: SHANNON333
RF cal date: 20150728
IMEI:
Reading IMEI... Ok
IMEI: 353753070604324 (SIGN: OK)
Unlocking... Ok
Unlock done
Old 12-03-2016, 01:00   #17263 (permalink)
Member: 1930570
Thanks Meter: 82
UNLOCKED DONE J120AZ
Searching Samsung modem... detected COM370
Model: SM-J120AZ
AP version: J120AZTUU1APD2
CSC version: J120AZAIO1APD2
CP version: J120AZTUU1APD2
Product code: SM2J120AZKZAIO
Phone SN: -------
Unique number: CFN00CC16C65B93
Reading IMEI... Ok
IMEI: 3564190--------- (SIGN: OK)
Checking hash file... Ok
Calculating... Ok
HWID: 4F 11 86 98 21 C1 8C D8 F9 6D E8 89 02 87 DD F4
Please wait, calculating codes... OK (time - 00:00:07)
Freeze code: 31936175
NET lock: 86040947
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
S.G
Old 12-03-2016, 02:13   #17264 (permalink)
Member: 2656321
plz help me why samsung E2252 not connection box for unlocking sim how body know say samtang plz be fast
Old 12-03-2016, 10:21   #17265 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 213
Wink SM-G361F unlock
Operation: Unlock
Selected model: SM-G361F
Please, allow USB debugging on phone... Ok
Model: SM-G361F
Product code: SM-G361FHAAVOD
Phone version: G361FXXU1APD5
PDA version: G361FXXU1AOG1
CSC version:
CSC country code:
CSC sales code:
HW version: MP 0.100
Phone SN: RV8G91R090B
Modem board:
RF cal date: 20150926
IMEI:
Analyzing SEC file... Ok
Writing AT RIL... Ok
Bypass MSL... Ok
Unlocking... Ok
Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1802 12-23-2019 14:44
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.54166 seconds with 9 queries
