12-08-2016, 08:37 | #17296 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Turkiye-Konya
Member: 2199727 Status: Offline Thanks Meter: 217 | j700H 6.0.1 imei repair and imei patch ok Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700H Software version: 27.4 Waiting ADB device... Ok Reading phone info... Model: SM-J700H Android version: 6.0.1 Product code: SM-J700HZKDMID Phone version: J700HXXU2BPG1 PDA version: J700HXXU2BPG4 CSC version: J700HOJV2BPG1 CSC country code: Iraq CSC sales code: MID HW version: MP 0.401 Phone SN: R51H31T0V3X Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20160322 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.4 |
The Following User Says Thank You to bulutiletisim For This Useful Post: |
12-08-2016, 17:28 | #17297 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | G935F Unlock done Code: Operation: Unlock Selected model: SM-G935F Software version: 27.4 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDABTU Phone version: G935FXXU1APEQ PDA version: G935FXXS1APG3 CSC version: G935FBTU1APE2 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.801 Phone SN: R58H748BL7E Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160726 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: 6C AF 3D DE B4 EB F2 32 56 ED 81 37 1F 37 EB 4C Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.4 |
12-08-2016, 18:02 | #17298 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | sm-g850a write cert successfull BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G850A Selected port: COM37 SAMSUNG Mobile USB Serial Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0793 Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-G850A Android version: 4.4.4 Product code: Not Active Phone version: G850AUCU1ANH8 PDA version: G850AUCU1ANH8 CSC version: G850AATT1ANH8 CSC country code: USA CSC sales code: ATT HW version: G850A.00 Phone SN: R38F90E3XEW Modem board: MSM8974PRO RF cal date: NONE IMEI: 35454xxxxxxxx Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0793 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.4.2 |
12-08-2016, 18:20 | #17299 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Samsung Rugby Unlock Operation: Unlock Selected model: SGH-A836 Selected port: COM7 Z3X BOX Serial Port Software version: 27.4 Reading phone info... Ok Model: SGH-A836 Country code: ij³ª´Ù/RWC Cal date: 2010-02-23 Factory SW: UXHK5 Unique number: 55780000635502 Memory phone: TYAB0A11108(A837) Phone SN: RQGZ711318 Reading IMEI... Ok IMEI: 3520xxxxxxxxxxxxx Reading SYSINFO... Ok Calculating... Ok Writing sysinfo... Ok Reseting... Ok Unlock done |
12-08-2016, 21:33 | #17300 (permalink) |
Freak Poster Join Date: Oct 2012
Member: 1825048 Status: Offline Thanks Meter: 10 | hi i cant imei repair G930F give error here log Code: Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: Phone version: PDA version: G930FXXU1BPH6 CSC version: G930FDBT1BPH2 CSC country code: Germany CSC sales code: DBT HW version: Phone SN: R58H81K4S1F Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.4 how to solved???ğ Tapatalk kullanarak iPhone aracılığıyla gönderildi |
12-10-2016, 05:26 | #17301 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | SM-J200F unlock done Code: Operation: Info Selected model: SM-J200F Software version: 27.4.2 Searching Samsung modem... detected COM140 Reading phone info... Ok Model: SM-J200F AP version: J200FXXU1AOJ3 CSC version: J200FOJV1AOJ4 CP version: J200FXXU1AOJ2 Product code: SM-J200FZDDKSA Phone SN: R58H60DD6FB Unique number: C8G01192AE49A53 Reading IMEI... Ok IMEI: 357091076781051 (SIGN: OK) IMEI 2: 357092076781059 (SIGN: OK) Done with Samsung Tool PRO v.27.4.2 |
12-10-2016, 12:37 | #17302 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung Galaxy Gio S5660m Unlock Done Operation: Read Codes Selected model: GT-S5660M Selected port: COM10 Z3X BOX Serial Port Software version: 27.4 Checking phone at COM10 Reading phone info... Ok Model: GT-S5660M Country code: ij³ª´Ù / BMC Cal date: 2011-07-26 Factory SW: S5660MUGKG3 Unique number: 86300000462868 Memory phone: KAT007012C(S5660) Phone SN: RUEBB77880 PDA/CSC version: S5660MUGKG3/S5660MBMCKG3 Phone version: S5660MUGKG3 Phone HW: MP 0.600 Cal date: 2011.11.22 Reading IMEI... Ok IMEI: 357823041xxxxxxx Reseting MSL... Ok Bypass MSL... Ok Reading codes... Ok Freeze code: 91424709 NET lock: 72936183 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.4 Thanks z3x Team |
12-10-2016, 14:52 | #17303 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Samsung G361H/DS FRP Done Samsung G361H/DS FRP Done Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 27.4 Searching Samsung USB Flash interface... COM7 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.4 |
The Following 2 Users Say Thank You to unaiz For This Useful Post: |
12-10-2016, 17:44 | #17304 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | N920A Read Codes Done - NEW SECURITY Operation: Read Codes Selected model: SM-N920A Software version: 27.4.2 Searching Samsung modem... detected COM39 Reading phone info... Ok Model: SM-N920A AP version: N920AUCU3CPHA CSC version: N920AATT3CPHA CP version: N920AUCU3CPHA Product code: SM-N920AZKEATT Phone SN: xxxxxxxxxx Unique number: 05157DF5ADF2DA3E Reading IMEI... Ok IMEI: 3538xxxxxxxxxx (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 48 08 A3 CD 76 05 00 00 00 00 00 00 00 00 00 00 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 63062949 NET lock: 90382698 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.4.2 |
12-10-2016, 18:37 | #17305 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung S7 EDGE FRP Reset Done.. Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 27.1 Checking local file... ok Searching server... ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM32 detected Setup connection... ok Reading data from phone... ok Sending data to phone... ok Waiting ADB device... ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZKABTU Phone version: G935FXXU1APB2 PDA version: G935FXXU1APAW CSC version: G935FBTU1APB2 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.801 Phone SN: RF8H504T6AA Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160504 IMEI: Checking Super user right... true Erasing FRP... ok Rebooting phone... ok Reset FRP done Done with Samsung Tool PRO v.27.1 |
12-10-2016, 23:50 | #17306 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Reset FRP Selected model: SM-J700T1 Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-J700T1 Android version: 6.0.1 Product code: SM2J700TZWATMK Phone version: J700T1UVU2APK3 PDA version: J700T1UVU2APK3 CSC version: J700T1TMK2APK3 CSC country code: USA CSC sales code: TMK HW version: REV0.5 Phone SN: R58H8083B0A Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20160802 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.5 |
12-11-2016, 01:03 | #17307 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE G928T Operation: Reset FRP/React/EE Selected model: SM-G928T Software version: 27.5 Searching Samsung USB Flash interface... COM53 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' S.G Done with Samsung Tool PRO v.27.5 |
12-11-2016, 12:18 | #17308 (permalink) |
Freak Poster Join Date: Jan 2016 Location: UnderGround Age: 35
Member: 2509163 Status: Offline Thanks Meter: 77 | Samsung s6 edge+ (G928i) 6.0 FRP+DRK Fixed..... FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Repair DRK Selected model: SM-G928I Software version: 27.4.2 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM3 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G928IDVU3BPJ3 Platform: exynos7420 Boot serial: 0215394242354141 Product board: zenlte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... NG! Writing DRK... Ok Checking DRK status... Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.27.4.2 Regards. Bms-Xoder |
12-11-2016, 12:32 | #17309 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | S7 edge patch cert DONE... Operation: Patch Certificate Selected model: SM-G935F Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAVIA Phone version: G935FXXU1BPH1 PDA version: G935FXXU1BPH6 CSC version: G935FTEF1BPH2 CSC country code: Germany CSC sales code: VIA HW version: MP 0.801 Phone SN: RF8H31YW2LA Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160317 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.5 |
12-11-2016, 19:47 | #17310 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE MS550 LG 2-3G Tool v9.28 supported models: 1408 Port already opened! Elapsed: 0 secs. --> (v9.28) Mode: Emergency Model: MS550 Read info... Model name: LGMS550 Software verion: MS55010i Android verion: 6.0.1 IMEI: 358858072XXXXX Elapsed: 10 secs. --> (v9.28) Phone mode is DOWNLOAD Start reset Google Account Lock... Model name: LGMS550 Software verion: MS55010i Android verion: 6.0.1 IMEI: 358858072XXXXX Reset ... Reboot... Elapsed: 8 secs. --> (v9.28) S.G |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
