Old 01-05-2017, 09:50   #17476 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
Samsung J700H Full Flash Done
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-J700H
Software version: 27.6
Unpacking file... ok
File analysis... Ok
Total file size: 0x7F93FB60 (2041 Mb)
Searching USB Flash interface... COM31 detected
Setup connection... Ok
Reading PIT from phone... Ok
Sending sboot.bin... Ok
Sending cm.bin... Ok
Sending boot.img... Ok
Sending recovery.img... Ok
Sending system.img... Ok
Sending modem.bin... Ok
Sending cache.img... Ok
Sending hidden.img... Ok
Flashing done (time - 00:04:11)
Done with Samsung Tool PRO v.27.6
Old 01-05-2017, 09:51   #17477 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
Samsung G530H Unlock Done
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Unlock
Selected model: SM-G530H
Selected port: COM110 SAMSUNG Mobile USB Serial Port
Reading phone info...
Reading IMEI... Ok
IMEI: 358500060947378
Unlocking... Ok
Reseting... Ok
Unlock done
Old 01-05-2017, 11:49   #17478 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,701
SM-G928V write cert done
[ 1/4/2017 6:41:00 PM ] Checking CERT file... Ok
[ 1/4/2017 6:41:00 PM ] KEY ID: 0472
[ 1/4/2017 6:41:00 PM ] Waiting ADB device...
[ 1/4/2017 6:41:00 PM ] Please, allow USB debugging on phone... Ok
[ 1/4/2017 6:41:00 PM ] Reading phone info...
[ 1/4/2017 6:41:00 PM ] Model: SM-G928V
[ 1/4/2017 6:41:00 PM ] Android version: 5.1.1
[ 1/4/2017 6:41:00 PM ] Product code: Not Active
[ 1/4/2017 6:41:00 PM ] Phone version: G928VVRU2AOJ2
[ 1/4/2017 6:41:00 PM ] PDA version: G928VVRU2AOJ2
[ 1/4/2017 6:41:00 PM ] CSC version:
[ 1/4/2017 6:41:00 PM ] CSC country code:
[ 1/4/2017 6:41:00 PM ] CSC sales code:
[ 1/4/2017 6:41:00 PM ] HW version: G928V.04
[ 1/4/2017 6:41:00 PM ] Phone SN: R38G900ZV0J
[ 1/4/2017 6:41:00 PM ] Modem board: MDM9635M
[ 1/4/2017 6:41:00 PM ] RF cal date: 2015.09.02
[ 1/4/2017 6:41:00 PM ] IMEI:
[ 1/4/2017 6:41:00 PM ] Incorrect model selected. This may damage your phone. Continue?  Yes
[ 1/4/2017 6:41:00 PM ] Initialization AT RIL... Ok
[ 1/4/2017 6:41:00 PM ] Bypass SPC... Ok
[ 1/4/2017 6:41:00 PM ] Checking for compatible phone and cert... Ok
[ 1/4/2017 6:42:00 PM ] Phone KEY ID: 0472
[ 1/4/2017 6:42:00 PM ] Writing CERT... Ok
[ 1/4/2017 6:42:00 PM ] Checking CERT status... Ok
[ 1/4/2017 6:42:00 PM ] Rebooting phone... Ok
b.r.
Old 01-05-2017, 13:37   #17479 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung j3 (j320w8)2016 Unlock done by read code
Operation: Read Codes
Selected model: SM-J320W8
Software version: 27.7
Searching Samsung modem... detected COM170
Reading phone info... Ok
Model: SM-J320W8
AP version: J320W8VLS2APJ1
CSC version: J320W8OYA2APJ1
CP version: J320W8VLS2APJ1
Product code: SM-J320WZAAXAC
Phone SN: R28HA2AGGMM
Unique number: CQ30048C9F25F83
Reading IMEI... Ok
IMEI: 35899807xxxxxxx (SIGN: OK)
Checking hash file... Ok
Reading data from phone... Ok
Modem board: SHANNON308
HWID: 17 F6 B9 10 B5 C0 D6 94 C6 FF D0 77 A8 1D A0 30
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:05)
Freeze code: 51728474
NET lock: 61947370
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.7
Thanks z3x Team
The Following User Says Thank You to sr8787 For This Useful Post:
Old 01-06-2017, 05:01   #17480 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung j5 j500fn FRP remove done
Operation: Reset FRP/React/EE
Selected model: SM-J500FN
Selected port: COM3 Z3X BOX Serial Port
Searching Samsung USB Flash interface... COM111 detected
Searching FRP lock... Ok
Erasing FRP lock... Ok
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Thanks z3x Team
Old 01-06-2017, 05:20   #17481 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
note 5 SM-N920W8 6.0.1 UNLOCKED DONE
UNLOCK INSTRUCTIONS:
5. Press 'Unlock' button for direct unlock.
To read security codes:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' to deactivate Google account activation lock.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-N920W8
Software version: 27.3
Waiting ADB device... Ok
Model: SM-N920W8
Android version: 6.0.1
Product code: SM-N920WZKABMC
Phone version: N920W8VLU4BPK4
PDA version: N920W8VLU4BPK4
CSC version: N920W8OYA4BPK4
CSC country code: Canada
CSC sales code: BMC
HW version: REV1.0
Phone SN: RF8H417WYZN
Chip name: EXYNOS7420
Modem board: SHANNON333
RF cal date: 20160412
IMEI:
Checking Super user right... true
Initialization zTool... Ok
Running zTool, please wait...
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Calculating... Ok
HWID: 68 8B 85 2F 54 05 00 00 00 00 00 00 00 00 00 00
Unlocking... Ok
Writing NV data... Ok
Unlock done
Done with Samsung Tool PRO v.27.3
Old 01-06-2017, 08:03   #17482 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung j5 unlock done
Operation: Unlock
Selected port: COM75 SAMSUNG Mobile USB Serial Port
Software version: 27.4
Reading IMEI... Ok
IMEI: 358321070xxxxxx
Unlocking... Ok
Reseting... Ok
Unlock done
Done with Samsung Tool PRO v.27.4
Thanks z3x Team
Old 01-06-2017, 09:35   #17483 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 385
Operation: Unlock
Selected model: SM-G550T1
Model: SM-G550T1
Product code: SM2G550TZKATMK
Phone version: G550T1UVU1APF1
PDA version: G550T1UVU1APF1
CSC version: G550T1TMK1APF1
CSC country code: USA
CSC sales code: TMK
HW version: REV0.4
Phone SN: RV8HA0E5ANJ
Chip name: EXYNOS3475
RF cal date: 20161012
IMEI:
Start... Ok
HWID: 74 50 99 23 DD 9F 2B 75 04 18 87 12 EC 04 11 7D
Calculating... Ok
Unlocking... Ok
Unlock done
Old 01-06-2017, 14:52   #17484 (permalink)
perfect1's Avatar
Member: 511749
Thanks Meter: 335
SAMSUNG G935W8 6.0.1 Unlock By Perfect1
Selected model: SM-G935W8
Searching Samsung modem... detected COM7
Model: SM-G935W8
AP version: G935W8VLU2APK3
CSC version: G935W8OYA2APK3
CP version: G935W8VLU2APK3
Product code: SM-G935WZSATLS
Phone SN: RF8HB0RAPXB
Unique number: CE10160AD18ABE0105
Reading IMEI... Ok
IMEI: 3561XXXXXXXX739 (SIGN: OK)
Please wait, generating hash codes file, this can take few minutes... Ok
Modem board: SHANNON335
HWID: 9B 67 59 8D BC 5D E9 50 61 0F 54 44 7F 95 87 50
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:07)
Freeze code: 50641504
NET lock: 70572808
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Br.
Perfect1 Lokesh
Old 01-06-2017, 16:49   #17485 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 279
G920f drk repair done z3x
Old 01-07-2017, 08:54   #17486 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 385
Searching Samsung modem... detected COM402
Model: SM-G930F
AP version: G930FXXU1BPLB
CSC version: G930FOXA1BPLB
CP version: G930FXXU1BPJJ
Product code: SM-G930FZDABTU
Phone SN: R58H4192FGD
Unique number: 9886784E4E464D3341
Reading IMEI... Ok
IMEI: 359467072387093 (SIGN: OK)
HWID: 88 72 97 FE 3A E3 82 BC 56 6C 61 AC C1 36 DF 89
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:01)
Freeze code: 02474196
NET lock: 50282036
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 01-07-2017, 10:21   #17487 (permalink)
Member: 1732025
Sonork: 100.1615024
Thanks Meter: 329
J120f Unlock Done
Searching Samsung modem... detected COM94
Model: SM-J120F
AP version: J120FXXU1APJ1
CSC version: J120FOJV1APJ5
CP version: J120FXXU1APJ2
Product code: SM-J120FZWDKSA
Phone SN: R58HB179Y0M
Unique number: CFN004151DB00A3
Reading IMEI... Ok
IMEI: 352719088275861 (SIGN: OK)
IMEI 2: 352720088275869 (SIGN: OK)
HWID: C4 5D 3F 9D 3B A6 27 F9 7B 56 65 B0 27 C5 0C FA
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:03)
Freeze code: 20247150
NET lock: 71717502
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 01-07-2017, 13:59   #17488 (permalink)
Member: 914220
Thanks Meter: 206
n920t 6.0.1
Operation: Unlock
Selected model: SM-N920T
Model: SM-N920T
Product code: SM2N920TZKATMB
Phone version: N920TUVU4DPK6
PDA version: N920TUVU4DPK6
CSC version: N920TTMB4DPK6
CSC sales code: TMB
HW version: REV0.2
Phone SN: RF8H30P3RHE
RF cal date: 20160307
IMEI:
Start... Ok
HWID: 68 72 2D 4C 36 04 00 00 00 00 00 00 00 00 00 00
Calculating... Ok
Unlocking... Ok
Unlock done
love my BOX
Old 01-07-2017, 14:17   #17489 (permalink)
Member: 2607815
Sonork: 100.16758955
Thanks Meter: 44
sm-g361 multicore checksum mode successfully flash but mobile hang in checksum mode
Old 01-07-2017, 15:39   #17490 (permalink)
Shohag_bd's Avatar
Member: 1578627
Sonork: 100.1623412
Thanks Meter: 501
Samsung SM-G532F Successfully Unlock By Z3X Box
shohag_bd
The Following 2 Users Say Thank You to Shohag_bd For This Useful Post:
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.40967 seconds with 10 queries
