Old 04-05-2017, 20:02   #18076 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J106B 6.0 Read Unlock Code done by Z3X BoX
Without Root by Z3X BoX
 UNLOCK INSTRUCTIONS:
  1. Power on the phone.
  2. Connect the phone to PC with USB cable.
  3. Check Samsung modem in device manager, install drivers if needed.
  4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Read Codes
Selected model: SM-J106B
Software version: 27.7
Searching Samsung modem... detected COM49
Reading phone info... Ok
Model: SM-J106B
Version: J106BDXU0APK2/J106BOLB0APL2/J106BDXU0APJ2/J106BDXU0APK2
Product code: SM-J106BZWDXME
Phone SN: R21HB03WAQJ
IMEI: 354614081152654
Unique number: C8G010532D4D9A3
Reading codes... Ok
Please wait, calculating codes... OK (time - 00:04:01)
Freeze code: 94758094
NET lock: 50620795
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.7
The Following User Says Thank You to ripon074 For This Useful Post:
Old 04-05-2017, 20:08   #18077 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J500H FRP Reset Done
without Combination firmware
by Z3X BOX
  2. Type *#0808# and select 'DM+MODEM+ADB'.
  3. Type *#9090# and select 'DM/DUN over HSIC'.
     Or use 'Activate Diag' function from 'Repair' tab.
  4. Connect phone to PC with USB cable, install drivers if needed.
  5. Select diagnostic port in port settings.
  6. Press 'Unlock' button for direct unlock.
    To reset Google account activation lock:
  1. ADB must be activated in any way (you can flash sBoot from combination firmware,
     make sure, that you are not upgrade sBoot).
  2. Connect phone to PC with USB cable, install drivers if needed.
  3. Select device in ADB settings.
  4. Press 'Reset FRP' and follow the instructions in program.
  5. When process done, press 'Back' on phone and perform factory reset from phone settings.
   To reset Google account activation or Samsung reactivation lock:
  1. Power on phone in download mode (turn off phone, press vol.down + home + power).
  3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
  4. After phone reboot, go to settings and perform factory reset.
Operation: Reset FRP/React/EE
Selected model: SM-J500H
Selected port: COM1 Communications Port
Searching Samsung USB Flash interface... COM31 detected
Setup connection... Ok
Reading PIT from phone... Ok
Searching FRP lock... Ok
Erasing FRP lock... Ok
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 04-05-2017, 20:12   #18078 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J120F
without Root Device
By Z3X BOX
    To unlock NEW security type:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
    To unlock OLD security type:
  4. Press 'Unlock' button and select 'Unlock' for direct unlock.
    To read security codes (all security types):
  4. Press 'Read codes' button to read security codes.
Selected model: SM-J120F
Software version: 27.8
Searching Samsung modem... detected COM178
Model: SM-J120F
AP version: J120FXXU1APJ1
CSC version: J120FOJV1APJ5
CP version: J120FXXU1APJ2
Product code: SM-J120FZDDKSA
Phone SN: R58HB6LQSQD
Unique number: CFN007629F20CA3
Reading IMEI... Ok
IMEI: 352719089681547 (SIGN: OK)
IMEI 2: 352720089681545 (SIGN: OK)
Checking hash file... Ok
Reading data from phone... Ok
Modem board: SHANNON308
HWID:  70 D2 92 BE F5 7E 32 5B 29 A4 98 24 7A EE 12 6D
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:15)
Freeze code: 13918248
NET lock: 51405374
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.27.8
Old 04-05-2017, 20:14   #18079 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J710F 6.0 Read Unlock Code done
by Z3X BOX
Selected model: SM-J710F
Searching Samsung modem... detected COM185
Model: SM-J710F
AP version: J710FXXU1APLM
CSC version: J710FOJV1APJ1
CP version: J710FXXU1APH4
Product code: SM-J710FZDDKSA
Phone SN: RF8H92924CP
Unique number: CAJ033E24F04993
Reading IMEI... Ok
IMEI: 357412075180022 (SIGN: OK)
IMEI 2: 357413075180020 (SIGN: OK)
Modem board: SHANNON315
HWID:  36 00 00 00 00 00 00 00 00 00 00 00 94 E4 D1 71
Calculating... Ok
Please wait, calculating codes... OK (time - 00:02:18)
Freeze code: 85847026
NET lock: 07573815
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 04-05-2017, 20:15   #18080 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J106B Read Unlock Code done
by Z3X Box
Software version: 27.9
Model: SM-J106B
Version: J106BDXU0APL3/J106BOLB0APL2/J106BDXU0APJ2/J106BDXU0APL3
Product code: SM-J106BZKDXME
Phone SN: RV1J21ARLEW
IMEI: 355002084358735
Unique number: C8G013472C63A24
Reading codes... Ok
Please wait, calculating codes... OK (time - 00:03:31)
Freeze code: 72502919
NET lock: 83685393
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.27.9
Old 04-05-2017, 20:21   #18081 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J111F FRP Reset Done using J200F model
by Z3X Box
Old 04-05-2017, 20:24   #18082 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
SM-J320F Unlock Done
by Z3X Box
Old 04-06-2017, 01:00   #18083 (permalink)
Member: 2593809
Thanks Meter: 7
Operation: Repair
Selected model: SM-G313M
Software version: 28.0
Waiting ADB device... Ok
Model: SM-G313M
Android version: 4.4.2
Product code: SM-G313MHAHZTA
Phone version: G313MUBU0ANK2
PDA version: G313MUBU0ANK2
CSC version: G313MTFG0ANK1
CSC country code: OPEN
CSC sales code: TFG
HW version: MP 0.301
Phone SN: R21F85MHAMD
Modem board:
RF cal date: 20140826
IMEI:
Checking Super user right... true
Writing data to phone... Ok
Patching CERT check... Ok
Rebooting phone... Ok
Repair done
Done with Samsung Tool PRO v.28.0
The Following User Says Thank You to vinrkx For This Useful Post:
Old 04-06-2017, 08:19   #18084 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
Samsung sm-j500f frp done
Sorry wrong section post
Old 04-06-2017, 16:11   #18085 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 245
SM-J700F Network Unlock w/o root
Note: try with regular method (not new unlock)
Searching Samsung modem... detected COM9
Model: SM-J700F
AP version: J700FXXU1APA2
CSC version: J700FOJV1AOFJ
CP version: J700FXXU2APE1
Product code: SM-J700FZKDXSG
Phone SN: RZ8HA0TM7NE
Unique number: CAJ03E8CE424193
Reading IMEI... Ok
IMEI: 352347085217759 (SIGN: OK)
IMEI 2: 352348085217757 (SIGN: OK)
Unlocking... Ok
Unlock done
The Following User Says Thank You to aydin.gsm1 For This Useful Post:
Old 04-06-2017, 16:46   #18086 (permalink)
Member: 802298
Thanks Meter: 6
Model: SAMSUNG-SM-J320A
Android version: 6.0.1
Product code: SM2J320AZACATT
Phone version: J320AUCS2AQA1
PDA version: J320AUCS2AQA1
CSC version: J320AATT2AQA1
CSC country code: USA
CSC sales code: ATT
HW version: REV1.0
Phone SN: R28HB3P9L0A
Chip name: EXYNOS3475
Security patch: 2017-01-01
RF cal date: 20161125
IMEI:
Reading data... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Initialization zTool... Ok
Running zTool, please wait...
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data... Ok
HWID: 00 FD 40 9E 1B -- -- -- -- -- -- -- E9 E0 9F 5D 1D
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Unlock done
The Following User Says Thank You to bagi768 For This Useful Post:
Old 04-06-2017, 18:19   #18087 (permalink)
Member: 2661200
Thanks Meter: 6
Operation: Unlock
Selected model: GT-S5570I
Model: GT-S5570I
Android version: 2.3.6
Product code:
Phone version: S5570IXXLH1
PDA version: S5570IBGLH1
CSC version: S5570IXECLH1
CSC country code: Spain
CSC sales code: XEC
HW version: MP 0.500
Phone SN:
Modem board:
RF cal date: 20121007
IMEI: 353139058726778
Checking Super user right... false
Rooting phone, please wait... Ok
Unlocking... Ok
Unlock done
Old 04-06-2017, 21:51   #18088 (permalink)
Member: 2428732
Thanks Meter: 22
how to unlock g900t 6.0.1 pl1 without downgrade or RooT with Z3X
https:// www. youtube.com /watch?v= _OWfzqoEts8&feature= youtu .be
move the sp so you could see the video
the video by me
Old 04-06-2017, 22:52   #18089 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,463
Selected model: SM-G530T1
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Model: SM-G530T1
Android version: 5.1.1
Product code: SM2G530TRAATMB
Phone version: G530T1UVU1AOH9
PDA version: G530T1UVU1AOH9
CSC version: G530T1TMB1AOH9
CSC sales code: TMB
HW version: REV0.1
Phone SN: R28GA0WPMBL
Chip name: MSM8916
Modem board: MSM8916
RF cal date: 2015.10.13
IMEI:
Bypass FRP... Ok
Old 04-08-2017, 02:26   #18090 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 345
Operation: Unlock
Selected model: SM-J700P
Please, allow USB debugging on phone... Ok
Model: SM-J700P
Product code: Not Active
Phone version: J700PVPS1AQA2
PDA version: J700PVPS1AQA2
CSC version: J700PSPT1AQA2
CSC sales code: BST
HW version: J700P.03
Phone SN: 00000000000
Modem board: MSM8929
RF cal date: 2016.09.29
IMEI:
Writing AT RIL... Ok
Initialization AT RIL... root required
Initialization AT RIL... Ok
Unlocking... Ok
Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1802 12-23-2019 13:44
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.53582 seconds with 9 queries
