07-31-2017, 17:56 | #18811 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Thanks in advance | |
07-31-2017, 18:14 | #18812 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | SM-G935W8 unlocked Operation: Read Codes Selected model: SM-G935W8 Selected port: COM3 USB Serial Port Software version: 29.0 Searching Samsung modem... detected COM93 Reading phone info... OK Model: SM-G935W8 AP version: G935W8VLS2BQF1 CSC version: G935W8OYA2BQF1 CP version: G935W8VLU2API2 Product code: FMC Phone SN: RF8J430VH9J Unique number: CE011711E8F8E80504 Reading IMEI... OK IMEI: 356160074339377 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON335 HWID: 0C 0B 55 7C AA 64 92 C5 85 B5 A8 51 20 A1 CC 9E Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:06) Freeze code: 84728629 NET lock: 19609406 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
07-31-2017, 23:09 | #18815 (permalink) |
Freak Poster Join Date: Apr 2016 Location: the boss of samsung
Member: 2558211 Status: Offline Thanks Meter: 90 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G730A Selected port: COM142 SAMSUNG Mobile USB Serial Port Software version: 29.0 Reading phone info... Reading IMEI... OK IMEI: 357130053700476 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-01-2017, 00:57 | #18816 (permalink) |
Freak Poster Join Date: Jun 2008 Location: ivory coast
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | repair imei note4 n910c done z3x repair imei n910c succesful; BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Selected port: COM3 Z3X BOX Serial Port Software version: 28.9 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 4.4.4 Product code: Phone version: N910CXXU1ANL2 PDA version: N910CXXU1ANK5 CSC version: N910COXE1ANK5 CSC country code: Russia CSC sales code: SER HW version: Phone SN: RF8G10GQC0Z Modem board: DB7450R RF cal date: 1234.56.78 IMEI: 350050500009692 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.28.9 |
08-01-2017, 08:02 | #18817 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: GT-I9301I Selected port: COM78 SAMSUNG Mobile USB Serial Port Software version: 29.0 Checking CERT file... OK KEY ID: 0865 Waiting ADB device... OK Reading phone info... Model: GT-I9301I Android version: 4.4.2 Product code: GT-I9301MBZAFR Phone version: I9301IXXUAOD2 PDA version: I9301IXXUAOF3 CSC version: I9301IOJVUAOE3 CSC country code: Kenya CSC sales code: AFR HW version: MP 0.001 Phone SN: 00000000000 Modem board: MSM8228 RF cal date: 2015.03.06 IMEI: 352606060106364 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0865 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.29.0 |
08-01-2017, 08:18 | #18819 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G920F Software version: 29.0 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: SM-G920FZWAXSG Phone version: G920FXXU5DQA3 PDA version: G920FXXS5DQA3 CSC version: G920FOJV5DQA3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.800 Phone SN: RF8G4133E0R Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20150414 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 7F 55 8F 8C 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.0 |
08-01-2017, 08:21 | #18820 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920F Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: SM-G920FZWAXSG Phone version: G920FXXU5DQA3 PDA version: G920FXXS5DQA3 CSC version: G920FOJV5DQA3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.800 Phone SN: RF8G4133E0R Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20150414 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.0 |
08-01-2017, 14:09 | #18822 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | g925t 7.0 unlocked Operation: Unlock Selected model: SM-G925T Software version: 28.7 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM-G925TZKETMB Phone version: G925TUVU5FQE1 PDA version: G925TUVU5FQE1 CSC version: G925TTMB5FQE1 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G51H4RGB Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-05-01 RF cal date: 20150522 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 31 A3 0C B7 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.7 |
08-01-2017, 14:50 | #18823 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2739067 Status: Offline Thanks Meter: 0 | i need help i have a galaxy s7 edge with s8+ rom 7.0 and i cant patch it for my sim to work. it works fine when i downgrade to 6.0.1 but its old now and i wanna go back to 7.0 this is wot im getting .......... Waiting ADB device... OK Reading phone info... Model: SM-G950F Android version: 7.0 Product code: SM-G935FZDABTU Phone version: G935FXXU1DQF2 PDA version: G950FXXU1AQG5 CSC version: G935FAXX1DQE7 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.801 Phone SN: RF8H62A449Z Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-07-01 RF cal date: 20160623 IMEI: Checking Super user right... true 7.0 is not supported Done with Samsung Tool PRO v.29.0 |
08-01-2017, 15:14 | #18824 (permalink) |
08-01-2017, 21:45 | #18825 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Iran
Member: 2742255 Status: Offline Thanks Meter: 45 | Operation: Read Codes Selected model: SM-J710GN Software version: 29.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J710GN Android version: 6.0.1 Product code: SM-J710GZDUBRI Phone version: J710GNZTU1API1 PDA version: J710GNZTU1API1 CSC version: J710GNZZT1API1 CSC country code: Taiwan CSC sales code: BRI HW version: MP 0.400 Phone SN: RF8HB3F98RD Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-09-01 RF cal date: 20161127 IMEI: Checking Super user right... true [ 02/08/2017 12:38:00 ق.ظ ] Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 8C 07 00 00 00 00 00 00 00 00 00 00 B0 8C 3E 55 Calculating... OK Please wait, generating hash codes file, this can take few minutes... OK Please wait, calculating codes... OK (time - 00:00:02) Freeze code: 58570280 NET lock: 60407903 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
