Old 08-01-2017, 22:02   #18826 (permalink)
Member: 2742255
Thanks Meter: 45
Operation: Unlock
Selected model: SM-J710GN
Software version: 29.0
Waiting ADB device... OK
Reading phone info...
Model: SM-J710GN
Android version: 6.0.1
Product code: SM-J710GZDUBRI
Phone version: J710GNZTU1API1
PDA version: J710GNZTU1API1
CSC version: J710GNZZT1API1
CSC country code: Taiwan
CSC sales code: BRI
HW version: MP 0.400
Phone SN: RF8HB3F98RD
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2016-09-01
RF cal date: 20161127
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID: 8C 07 00 00 00 00 00 00 00 00 00 00 B0 8C 3E 55
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Old 08-02-2017, 07:28   #18827 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
Today i have tried to unlock express 3 sm-j320a, AP version: J320AUCU2APJ2
code will be generated by 28.2 z3x version
but 29.0 version not work for this model, its say security damage.
Old 08-02-2017, 09:38   #18828 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 367
Operation: Unlock
Selected model: SM-G928F
Searching Samsung modem... detected COM213
Reading phone info... OK
Model: SM-G928F
AP version: G928FXXS3CQF8
CSC version: G928FVFG3CQD3
CP version: G928FXXU3APH1
Product code: VOD
Phone SN: RF8GA17WX8Z
Unique number: 83F0465A3545424D
Reading IMEI... OK
IMEI: 352720075448685 (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.29.0
Old 08-02-2017, 12:20   #18829 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 437
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Write CERT
Selected model: SM-J500H
Selected port: COM101 SAMSUNG Mobile USB Serial Port
Checking CERT file... OK
KEY ID: 0241
Model: SM-J500H
Android version: 5.1.1
Product code: SM-J500HZDDXFE
Phone version: J500HXXU1AOF9
PDA version: FA51_J500HXXU1AOF8
CSC version:
CSC country code:
CSC sales code:
Phone SN: RV1H70GN6KZ
Modem board: MSM8216
RF cal date: 2016.07.18
IMEI:
Writing AT RIL... OK
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0241
Writing CERT... OK
Checking CERT status... OK
Old 08-02-2017, 13:48   #18830 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 443
Operation: Unlock
Selected model: SM-G610F
Software version: 28.8
Model: SM-G610F
Product code: SM-G610FZDDKSA
Phone version: G610FDDU1AQF4
PDA version: G610FDDU1AQE4
CSC version: G610FOJV1AQE3
CSC country code: KSA
CSC sales code: KSA
HW version: MP 0.300
Phone SN: R58J35085NP
Security patch: 2017-05-01
RF cal date: 20170323
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: 8F 07 00 00 00 00 00 00 00 00 00 00 C8 65 CD 06
Calculating... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.28.8
Old 08-02-2017, 14:13   #18831 (permalink)
Member: 2527142
hi all please
can you help me for unlock SM-J510FN A PHONE FROM (ITALY)
Old 08-02-2017, 16:36   #18832 (permalink)
Member: 2558211
Thanks Meter: 83
UNLOCK INSTRUCTIONS:
New Securiry Type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
6. Press 'Read codes' button and select 'Read codes New' to read security codes.
Old Securiry Type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
5. Press 'Read codes' button and select 'Read codes' to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Unlock
Selected model: SM-G920T
Selected port: COM166 SAMSUNG Mobile USB Serial Port
Model: SM-G920T
Android version: 7.0
Product code: SM4G920TZWATMB
Phone version: G920TUVS5FQG1
PDA version: G920TUVS5FQG1
CSC version: G920TTMB5FQG1
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R58G50M16VT
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-07-01
RF cal date: 20150511
IMEI:
Running zTool, please wait... OK
HWID: 88 02 D8 CC 8D 04 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Unlocking... OK
Unlock done
Old 08-02-2017, 16:51   #18833 (permalink)
Member: 2459652
hi guys
sorry for wrong thread
i have a question
if i repair j700f imei and then patch cert ,can update 5.1.1 to 6.0.1 or after update patch cert again?
Old 08-02-2017, 17:18   #18834 (permalink)
Member: 907534
Thanks Meter: 82
A510F unlock done
Operation: Read Codes
Selected model: SM-A510F
Software version: 28.7
Searching Samsung modem... detected COM101
Model: SM-A510F
AP version: A510FXXU3BPK4
CSC version: A510FOXA3BPK4
CP version: A510FXXU3BPK4
Product code: SM2A510FZWAXEO
Phone SN: R58J1316PFH
Unique number: C00008A4E1FF193
Reading IMEI... OK
IMEI: 356374083****** (SIGN: OK)
Please wait, generating hash codes file, this can take few minutes... OK
Modem board: SHANNON310
HWID: 3C 16 F8 85 94 C5 85 2F 41 B0 7A D8 44 2F 22 26
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 53159381
NET lock: 68251373
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.28.7
The Following User Says Thank You to ol1978 For This Useful Post:
Old 08-03-2017, 04:22   #18835 (permalink)
mtb116's Avatar
Member: 177568
Thanks Meter: 93
SM-N920S FRP done
Operation: Reset FRP UFS
Selected model: SM-N920S
Selected port: COM7 Z3X BOX Serial Port
Software version: 28.8.1
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM7 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (N920S)
Setup connection... OK
Reseting FRP... OK
Reset FRP done
Done with Samsung Tool PRO v.28.8.1
Old 08-03-2017, 08:47   #18836 (permalink)
Member: 1870532
Sonork: 100.1673711
Thanks Meter: 46
Samsung J2 SM-J200h 100% Read and write EFS or CErt by Z3X
https://www.youtube.com/watch?v=5p-YRtoLHc4
Old 08-03-2017, 08:49   #18837 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 602
FLASH INSTRUCTIONS:
4. Power on the phone in download mode (turn off phone, press '0' + power buttons 10 seconds).
Operation: Read User Lock
Selected model: SM-B350E
Waiting phone... detected COM35
Sending FDL... OK
Reconnecting phone... OK
Sending FDL2... OK
Reading data from phone ... OK
Phone lock: 99665 (ON)
Old 08-03-2017, 14:06   #18838 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 437
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 11111111
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J320FN
Searching Samsung modem... detected COM114
Model: SM-J320FN
Version: J320FNXXS0APL1/J320FNTSI0API1/J320FNXXU0APH1/J320FNXXS0APL1
Product code: SM-J320FZWNTSI
Phone SN: RF8HB2X3YBH
IMEI: 3540000000000
Unique number: CQN0064A4F260B3
Unlocking... OK
Unlock done
Old 08-03-2017, 14:58   #18839 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 369
g570f reset frp done
Selected model: SM-G570F
Model: SM-G570F
Product code: SM-G570FZKDTHR
Phone version: G570FXXU1AQC1
PDA version: G570FXXU1AQC2
CSC version: G570FOJV1AQC2
CSC country code: IRAN
CSC sales code: THR
HW version: MP 0.500
Phone SN: R58J56MCFQF
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-03-01
RF cal date: 20170529
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 08-04-2017, 11:59   #18840 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 367
Unlocking with original MSL code:
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation lock:
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
Operation: Read Codes via Server
Selected model: SM-J510H
Checking Login and Password... OK
Ballance: 45 crd.
Model: SM-J510H
Product code: SM-J510HZDDMID
Phone version: J510HXXU2AQD2
PDA version: J510HXXU2AQD2
CSC version: J510HOJV2AQD2
CSC country code: Iraq
CSC sales code: MID
Phone SN: RV1J40W1BDM
Chip name: MSM8216
Modem board: MSM8916
Security patch: 2017-04-01
RF cal date: 2017.04.25
IMEI:
Start... OK
Searching Ramdump interface... COM69 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 84605305
NET lock: 82814930
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1804 Yesterday 19:44
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.53389 seconds with 9 queries
