Old 03-08-2018, 14:32   #20236 (permalink)
Member: 2643730
Thanks Meter: 1,115
sm-c9000 v7.1.1 frp fail
Operation: Reset FRP/React/EE
Selected model: SM-C9000
Software version: 30.8
Searching Samsung USB Flash interface... COM151 detected
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... error
Done with Samsung Tool PRO v.30.8
Old 03-08-2018, 14:59   #20237 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 345
S3650 unlock done
Selected model: S3650
Selected com port: COM10
Selected speed port: 921600
Phone must be ON
Search modem ... OK
Search modem on:COM12
Model: GT-S3650
CountryCode: ATL
Factory SW: S3650BAII3
UniqueNumber: 91100000037943
MemoryPhone: K522H1HACC(S3650)
Phone IMEI: 35255204418248 /7
Phone S/N: RF9B478832
Phone Bluetooth ID: 54 9B 12 5F 6F AF
Phone SW: S3650XXIJ2
Phone HW: MP 0.605
Phone CalData ver: 20110428
Searching server... OK
Calculating security.... OK
Please wait decrypt code ... OK
[FREZEE]:25306424
[NET LOCK]:71947946
[Subset LOCK]:00000000
[SP LOCK]:00000000
[CP LOCK]:00000000
Decrypted time: 29 sec
Elapsed time: 42 second, sw ver: 3.5.0040
Old 03-08-2018, 15:43   #20238 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 573
Operation: Read Codes
Selected model: SM-G532M
Checking hash file... OK
Waiting ADB device... OK
Reading phone info...
Model: SM-G532M
Android version: 6.0.1
Product code: SM-G532MZKADOR
Phone version: G532MUBU1AQF1
PDA version: G532MUMU1AQG5
CSC version: G532MUWE1AQG5
CSC country code: DOMINICAN REPUBLIC
CSC sales code: DOR
HW version: MP 0.300
Phone SN: R58HC2866QB
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2017-07-01
RF cal date: 20161210
IMEI: 353109xxxxxxxxx
Rebooting phone... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM3 detected
Please wait, calculating codes... OK (time - 00:01:06)
Freeze code: 71913839
NET lock: 00000000
SUB lock: 00000000
SP lock: 00000000
CP lock: 97353792
SIM lock: --------
For check lock status: *#7465625#
Old 03-08-2018, 22:23   #20239 (permalink)
Member: 1537078
Thanks Meter: 573
LG 2-3G Tool v9.45
supported models: 1554
Mode: Normal
Model: LGMS210A
Build version: Dec 11 201712:10:47May 27 201713:00:00LGMS210A
SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1
IMEI: 3533410xxxxxxx-9
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
Elapsed: 1 secs. --> (v9.45)
Checking Login and Password... OK
Ballance: 45 crd.
You have 45 credit(s) left. This operation takes 10 credits.Continue? Yes
Searching modem interface... found COM30
Checking root rights...
Writing zTool... OK
Calculating... OK
Waiting for server answer... OK
Unlocking done
Elapsed: 412 secs. --> (v9.45)
The Following User Says Thank You to chipscell25 For This Useful Post:
Old 03-08-2018, 23:52   #20240 (permalink)
Member: 2367813
Sonork: wirelesstg
CAN YOU HELP TO UNLOCK j327p
Old 03-09-2018, 19:46   #20241 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 789
Samsung G610f Read codes done with Samsung tool pro
Old 03-09-2018, 22:44   #20242 (permalink)
Member: 1754209
Thanks Meter: 21
G920T Imei change Done
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Operation: Repair
Selected model: SM-G920T
Software version: 30.9
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Model: SM-G920T
Android version: 7.0
Product code:
Phone version: G920TUVS6FRA3
PDA version: G920TUVS6FRA3
CSC version: G920TTMB6FRA3
CSC country code: USA
CSC sales code: TMB
HW version:
Phone SN: R58G512W5NV
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2018-01-01
RF cal date:
IMEI: 350000000000006
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Running zTool, please wait... OK
HWID: 88 51 A4 1C 74 06 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Repairing... OK
Writing NV data... OK
Repair done
Done with Samsung Tool PRO v.30.9
Sent from my iPhone using Tapatalk
Old 03-09-2018, 22:45   #20243 (permalink)
Member: 1754209
Thanks Meter: 21
G920T Unlocking done
UNLOCK INSTRUCTIONS:
New Securiry Type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
6. Press 'Read codes' button and select 'Read codes New' to read security codes.
Old Securiry Type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
5. Press 'Read codes' button and select 'Read codes' to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Unlock
Model: SM-G920T
Product code: SM2G920TZKATMB
CSC sales code: TMB
HW version: REV1.0
RF cal date: 20151012
IMEI:
Calculating... OK
Unlocking... OK
Unlock done
Old 03-10-2018, 05:42   #20244 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
samsung SGH-T939 `T`... Mobile unlock done
[IMG][/IMG]
Checking phone at COM15
Reading phone info... OK
Model: SGH-T939
Country code: ¹Ì±¹
Cal date: 2009-10-24
Factory SW: UVIJ6
Unique number: 60550000473951
Memory phone: KBN00300HA(T939)S
Phone SN: R6YSB02722
PDA/CSC version: T939UVJA3
Phone HW: T939UVJA
Reading IMEI... OK
IMEI: 355078030930777
Unlocking... OK
Reseting... OK
Unlock done
Old 03-10-2018, 06:11   #20245 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Operation: Read Codes DIAG
Selected model: SM-G610F
Searching Samsung modem... detected COM80
Model: SM-G610F
AP version: G610FXWU1BQK3
CSC version: G610FOJW1BQK3
CP version: G610FXXU1BQJ4
Product code: KSA
Phone SN: R58K110JLTP
Unique number: C000033C4E8ED94
Searching Samsung diag port... detected COM79
CP build: Oct 13 2017 19:19:38
Modem board: SHANNON315
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:00)
Freeze code: 39369642
NET lock: 15846931
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 03-10-2018, 06:11   #20246 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Selected model: SM-J200F
Searching Samsung USB Flash interface... COM9 detected
Erasing FRP lock... OK
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Selected model: SM-G361H
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 03-10-2018, 06:12   #20247 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Selected model: SM-J106H
Searching Samsung USB Flash interface... COM13 detected
Reset done
Old 03-10-2018, 06:13   #20248 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Selected model: SM-J200G
Reset done
Old 03-10-2018, 06:13   #20249 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Selected model: SM-J111F
Model: SM-J111F
Android version: 5.1.1
Product code: SM-J111FZKDXSG
Phone version: J111FXXU0AQC2
PDA version: J111FXXU0AQD2
CSC version: J111FOJV0AQD3
CSC country code: UAE
CSC sales code: XSG
HW version: MP 0.200
Phone SN: RV8J40XQDFZ
Chip name: SC9830I
Modem board: SC9830i
Security patch: 2017-04-01
RF cal date: 2017.04.19
IMEI: 2515925302514f0
Bypass FRP... OK
Old 03-10-2018, 06:14   #20250 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 446
Selected model: SM-J320F
Searching Samsung modem... detected COM25
Model: SM-J320F
Version: J320FXXU0AQH3/J320FOJV0AQH3/J320FXXU0AQH3/J320FXXU0AQH3
Product code: SM-J320FZDDKSA
Phone SN: RV8J91P46SE
IMEI: 352414097764713
Unique number: CQN0033896A0B94
Reading codes... OK
Please wait, calculating codes... OK (time - 00:00:39)
Freeze code: 13637972
NET lock: 28272957
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.32439 seconds with 10 queries
