Old 09-07-2018, 14:03   #21016 (permalink)
Member: 195717
Thanks Meter: 54
J330FN network unlok
Operation: Read Codes via Server
Selected model: SM-J330FN
Software version: 33.7
Checking Login and Password... OK
Ballance: 15 crd.
You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-J330FN
Android version: 7.0
PDA version: J330FNXXU2AQK8
CSC version: J330FNXEF2AQK2
Phone version: J330FNXXU2AQK8
Product code: SM-J330FZDNXEF
CSC country code: France
CSC sales code: XEF
Phone SN: R58K13489QF
IMEI: 355730090239222
HW version: MP 0.500
RF cal date: 20180115
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-12-01
Boot Warranty bit: 0
Searching server... OK
Checking server answer... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Executing... OK
Reading data from phone... OK
Calculating... OK
Waiting for server answer... OK
Freeze code: 30382918
NET lock: 57182730
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.33.7
Old 09-07-2018, 17:07   #21017 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 332
Sm-g925f imei repair done
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Repair
Selected model: SM-G925F
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Model: SM-G925F
PDA version: G925FXXU6ERF5
CSC version: G925FVFG6ERF1
Phone version: G925FXXU6ERF7
Product code: SM-G925FZKFSIM
CSC country code: Slovenia
CSC sales code: SIM
Phone SN: RF8G60M46VK
IMEI: 359522060778016
HW version: MP 0.60V
RF cal date: 20150609
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2018-06-01
Boot Warranty bit: 1
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Running zTool, please wait... OK
HWID: 88 66 C7 74 55 04 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Repairing... OK
Writing NV data... OK
Rebooting phone... OK
Repair done
Operation: Patch Certificate
Model: SM-G925F
CSC sales code: SIM
IMEI: 356678686798870
Reading modem... OK
Patching modem... OK
Writing modem... OK
Patching CERT check... done
Old 09-07-2018, 17:08   #21018 (permalink)
Member: 1444462
Thanks Meter: 332
Sm-j700h imei repair done
Selected model: SM-J700H/DS
Model: SM-J700H
Android version: 6.0.1
PDA version: J700HXXU2BPG4
CSC version: J700HOJV2BPG1
Phone version: J700HXXU2BPG1
Product code: SM-J700HZDDXFA
CSC country code: SOUTH AFRICA
CSC sales code: XFA
Phone SN: RF1HA02S6AA
IMEI: 356567676500000
HW version: MP 0.401
RF cal date: 20161024
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2016-08-01
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Old 09-07-2018, 20:32   #21019 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 465
Operation: Unlock
Selected model: SM-J700P
Model: SM-J700P
PDA version: J700PVPS1AQD1
CSC version: J700PSPT1AQD1
Phone version: J700PVPS1AQD1
Product code: Not Active
CSC country code: USA
CSC sales code: BST
Phone SN: 00000000000
IMEI: 355628075294735
HW version: J700P.03
RF cal date: 2016.11.29
Chip name: MSM8929
Modem board: MSM8929
Security patch: 2017-04-01
Writing AT RIL... OK
Initialization AT RIL... root required
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Old 09-08-2018, 14:54   #21020 (permalink)
Member: 2659717
Thanks Meter: 185
g965u unlock done
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G965U
Android version: 8.0.0
PDA version: G965USQU2ARF7
CSC version: G965UOYN2ARF7
Phone version: G965USQU2ARF7
Product code: SM2G965UZPATMB
CSC sales code: TMB
Phone SN: R28K430HHBR
IMEI: 354644091663705
HW version: REV1.1
RF cal date: 2018.05.02
Chip name: SDM845
Modem board: SDM845
Searching Samsung diag port... not found
Waiting for device to become ready... OK
Start... OK
Rebooting to upload... OK
Searching Ramdump interface... COM32 detected
Calculating... OK
Initialization zTool... error (0.1)
Retry 1...
Start... OK
Unlock done
Old 09-08-2018, 16:12   #21021 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
Sm-g925f b6 frp ufs done
UNLOCK INSTRUCTIONS:
New Securiry Type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
6. Press 'Read codes' button and select 'Read codes New' to read security codes.
Old Securiry Type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
5. Press 'Read codes' button and select 'Read codes' to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset FRP UFS
Selected model: SM-G925T
Selected port: COM97 USB Serial Port
Software version: 32.7
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM97 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (G925T)
Setup connection... OK
Reseting FRP... OK
Reset FRP done
Done with Samsung Tool PRO v.32.7
Old 09-08-2018, 19:42   #21022 (permalink)
Member: 399404
Thanks Meter: 32
FRP ON J320A DONE USING G925T
Old Securiry Type:
Operation: Reset FRP/React/EE
Searching Samsung USB Flash interface... COM49 detected
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 09-09-2018, 14:09   #21023 (permalink)
Member: 2431049
Sonork: 100.1680262:hunnyck
Thanks Meter: 505
SM-J510F FRP Reset done v7.1.1
Old 09-09-2018, 18:19   #21024 (permalink)
Member: 2779090
Model: SM-G935F
PDA version: G935FXXU2DRC6
CSC version: G935FNEE2DRB5
Phone version: G935FXXU2DRB6
Product code: SM-G935FZDABTU
CSC country code: Nordic
CSC sales code: NEE
Phone SN: RF8HB2VS7AN
IMEI:
HW version: MP 0.801
RF cal date: 20161123
Chip name: EXYNOS8890
Modem board: SHANNON335
Security patch: 2018-03-01
Boot Warranty bit:
Incorrect model selected. This may damage your phone. Continue? Yes
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Done with Samsung Tool PRO v.33.8
This does not work for me at all. I have G935f and I tried this way you described incl that I even tried G935F and did this also and still doesn't work.
Old 09-09-2018, 20:30   #21025 (permalink)
Member: 419703
Thanks Meter: 116
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
Selected model: SM-J700F/DS
Software version: 33.8
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Model: SM-J701F
PDA version: J701FXXU3ARB1
CSC version: J701FOJV3ARB1
Phone version: J701FXXU3ARA1
Product code: SM-J701FZSDEGY
CSC country code: Egypt
CSC sales code: EGY
Phone SN: RF8J83VGGEH
IMEI: 351569098962912
HW version: MP 0.400
RF cal date: 20170831
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2018-02-01
Bypass FRP... OK
Old 09-09-2018, 20:30   #21026 (permalink)
Member: 419703
Thanks Meter: 116
SM-J700F/DS FRP Reset Done
Model: SM-J701F
CSC sales code: EGY
Bypass FRP... OK
Old 09-10-2018, 04:39   #21027 (permalink)
Member: 2604559
Sonork: Ventaslaredo
Thanks Meter: 117
G900T write cert done by z3x box
BACKUP INSTRUCTIONS:
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-G900T
Selected port: COM182 SAMSUNG Mobile USB Serial Port
Checking CERT file... OK
KEY ID: 0478
Model: SM-G900T
Android version: 4.4.2
PDA version: G900TUVU1BNH5
CSC version: G900TTMB1BNH5
Phone version: G900TUVU1BNH5
Product code: SM2G900TZKATMB
CSC sales code: TMB
Phone SN: R38FB07C3RN
IMEI: 35255806XXXXXXX
HW version: REV1.0
RF cal date: 2014.11.06
Chip name: MSM8974PRO
Modem board: MSM8974PRO
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0478
Writing CERT... OK
Checking CERT status... OK
Old 09-10-2018, 12:11   #21028 (permalink)
Member: 2396025
Thanks Meter: 53
A530F Unlock done
08.09.2018 17:35:40 ] Операція: Read Codes via Server
[ 08.09.2018 17:35:40 ] Вибрана модель: SM-A530F
[ 08.09.2018 17:35:40 ] Версія програми: 33.7
[ 08.09.2018 17:35:40 ] Checking Login and Password... Добре
[ 08.09.2018 17:35:41 ] Ballance: 25 crd.
[ 08.09.2018 17:35:42 ] You have 25 credit(s) left. This operation takes 5 credits.Continue? Так
[ 08.09.2018 17:35:43 ] Очікую на пристрій ADB... Добре
[ 08.09.2018 17:35:45 ] Читання інформації з телефону...
[ 08.09.2018 17:35:45 ] Модель: SM-A530F
[ 08.09.2018 17:35:45 ] Android версія: 8.0.0
[ 08.09.2018 17:35:45 ] PDA версія: A530FXXS3BRH1
[ 08.09.2018 17:35:45 ] CSC версія: A530FOXM3BRG1
[ 08.09.2018 17:35:45 ] Phone версія: A530FXXU3ARH3
[ 08.09.2018 17:35:45 ] Код продукту: SM-A530FZVDPHE
[ 08.09.2018 17:35:45 ] Код країни CSC: SPAIN
[ 08.09.2018 17:35:45 ] Код продаж CSC: PHE
[ 08.09.2018 17:35:45 ] Телефон SN: R58K5042LQJ
[ 08.09.2018 17:35:45 ] IMEI: 355624098965922
[ 08.09.2018 17:35:45 ] HW версія: REV0.3
[ 08.09.2018 17:35:45 ] RF cal дата: 20180502
[ 08.09.2018 17:35:45 ] Назва процесора: EXYNOS7885
[ 08.09.2018 17:35:45 ] Ревізія модему: SHANNON327
[ 08.09.2018 17:35:45 ] Security patch: 2018-08-01
[ 08.09.2018 17:35:45 ] Boot Warranty bit: 0
[ 08.09.2018 17:35:47 ] Пошук сервера... Добре
[ 08.09.2018 17:35:49 ] Checking server answer... modem required
[ 08.09.2018 17:35:49 ] Перезавантаження телефону... Добре
[ 08.09.2018 17:35:54 ] Очікую на пристрій ADB... Добре
[ 08.09.2018 17:36:23 ] Ініціалізація zTool... Добре
[ 08.09.2018 17:36:24 ] Запускається zTool, зачекайте...
[ 08.09.2018 17:36:24 ] Старт... Добре
[ 08.09.2018 17:36:27 ] Ініціалізація... Добре
[ 08.09.2018 17:36:29 ] Генерація та перевірка доказу клієнта... Добре
[ 08.09.2018 17:36:29 ] Перевірка доказу клієнтом... Добре
[ 08.09.2018 17:36:29 ] Читання даних з телефону... Добре
[ 08.09.2018 17:37:03 ] Перезавантаження телефону... Добре
[ 08.09.2018 17:37:08 ] Waiting for device to become ready... Добре
[ 08.09.2018 17:37:35 ] Читання даних з телефону... Добре
[ 08.09.2018 17:37:52 ] Пошук сервера... Добре
[ 08.09.2018 17:38:30 ] Waiting for server answer... Добре
[ 08.09.2018 17:39:21 ] Checking server answer... Добре
[ 08.09.2018 17:39:21 ] Ініціалізація zTool... Добре
[ 08.09.2018 17:39:22 ] Запускається zTool, зачекайте...
[ 08.09.2018 17:39:22 ] Старт... Добре
[ 08.09.2018 17:39:25 ] Ініціалізація... Добре
[ 08.09.2018 17:39:27 ] Генерація та перевірка доказу клієнта... Добре
[ 08.09.2018 17:39:27 ] Перевірка доказу клієнтом... Добре
[ 08.09.2018 17:39:27 ] Executing... Добре
[ 08.09.2018 17:40:03 ] Читання даних з телефону... Добре
[ 08.09.2018 17:40:26 ] Калькулювання... Добре
[ 08.09.2018 17:40:30 ] Пошук сервера... Добре
[ 08.09.2018 17:40:34 ] Waiting for server answer... Добре
[ 08.09.2018 17:41:23 ] Код заморозки: 80939140
[ 08.09.2018 17:41:23 ] NET замок: 92607428
[ 08.09.2018 17:41:23 ] SUB замок: 00000000
[ 08.09.2018 17:41:23 ] SP замок: 00000000
[ 08.09.2018 17:41:23 ] CP замок: 00000000
[ 08.09.2018 17:41:23 ] SIM замок: 00000000
[ 08.09.2018 17:41:23 ] Щоб перевірити статус блокування: *#7465625#
Old 09-10-2018, 13:41   #21029 (permalink)
Freeboy08's Avatar
Member: 1272267
Sonork: 100.1667652
Thanks Meter: 194
SM-G950F S8 Read code Done by z3x
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
4. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Selected model: SM-G950F
Ballance: 35 crd.
You have 35 credit(s) left. This operation takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM8
Model: SM-G950F
AP version: G950FXXU1AQJ1
CSC version: G950FOVF1AQJ1
CP version: G950FXXU1AQJ1
Product code: VOD
Phone SN: RF8J42PTV6H
IMEI: 358793086056205
Unique number: CE031713E9F3DC820D
Searching Samsung diag port... detected COM9
Reading phone info... OK
CP build: Oct 11 2017 15:46:48
Calculating... OK
Freeze code: 04942472
NET lock: 79304131
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 09-10-2018, 16:37   #21030 (permalink)
anrmobile's Avatar
Member: 1680232
Sonork: 100.1611221
Thanks Meter: 183
Model: SM-G930T
PDA version: G930TUVU4BQG5
CSC version: G930TTMB4BQG5
Phone version: G930TUVU4BQG5
Product code: SM-G930TZKATMB
CSC sales code: TMB
Phone SN: R28HC07FYAT
IMEI: 359755075035929
HW version: REV0.6
RF cal date: 2016.12.03
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2017-07-01
Start... OK
Searching Ramdump interface... COM24 detected
Calculating... OK
Start... OK
Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1726 01-14-2019 06:14
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.63861 seconds with 9 queries
