Old 10-08-2018, 22:38   #21151 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 465
Operation: Unlock
Selected model: SM-J500M
Selected port: COM387 SAMSUNG Mobile USB Serial Port
Software version: 33.8
Reading phone info...
Reading IMEI... OK
IMEI: 3597710xxxxxxxx
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.33.8
Old 10-09-2018, 07:58   #21152 (permalink)
Member: 2590666
Thanks Meter: 53
And once again flashing engboot...
Operation: Unlock
Selected model: SM-J727T1
Checking Login and Password... OK
Ballance: 5 crd.
You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Model: SM-J727T1
Android version: 7.0
PDA version: J727T1UVS3ARC1
CSC version: J727T1TMK3ARC1
Phone version: J727TUVU3ARA1
Product code: SM2J727TZKETMK
CSC country code: USA
CSC sales code: TMK
Phone SN: R28K71EHRER
IMEI: 357847093*******
HW version: REV0.7
RF cal date: 20180718
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2018-03-01
Boot Warranty bit: 0
Searching Samsung diag port... detected COM99
Reading phone info... OK
CP version: J727TUVU3ARA1
CP build: Jan 24 2018 13:02:34
Reading data from phone... OK
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Rebooting phone... OK
Unlock done
Old 10-09-2018, 20:48   #21153 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,501
Samsung sgh-e250 read code done
UNLOCK INSTRUCTIONS:
Phone must be powered off!
1. Select correct COM port in 'Port' options.
2. Select connection mode in options ('Flash Mode' or 'TAT Mode') .
3. Press 'Unlock' for direct unlock.
4. Press 'Read Codes' to read security codes.
5. - Flash Mode:
Connect the phone to selected port with UART cable and press 'Power' button shortly,
or just insert cable to phone if you are using auto-ignition cable .
(If you have connection problem, try to push 'Power' button while loader will be sent.)
- TAT Mode:
Connect the phone to selected port with UART cable and press 'Power' button about 3 seconds,
Operation: Read Codes
Selected model: SGH-E250
Selected port: COM11 Z3X BOX Serial Port, 460800
Connect phone, press power button
Waiting phone... OK
Setting download address... OK
Sending PRELOADER... OK
Checking PRELOADER... OK
Checking baud... OK
Getting BB Chip version... OK
BB Chip version: 00003541
Sending LOADER... OK
Setting base address... OK
Checking Flash ID... OK
Flash ID: 00EC (Samsung) 2206 (KAP29SN00M)
Nand Flash ID: 0014 (ONE 256M NAND FLASH)
Checking LOADER... OK
Reading FLASH... OK
Phone version: E250DBVGG1_HA1
HW version: MP 0.803
Phone BT: 00:1F:CC:C5:43:02
IMEI: 352562029069500
Please wait, calculating codes... OK
Freeze code: 55169490
NET lock: 95732440
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Multi lock: 00000000
Phone lock: 00000000
Old 10-10-2018, 11:02   #21154 (permalink)
Member: 2778229
Thanks Meter: 5
samsung g610f downgrade oreo to noget
samsung g610f after oreo problem battery problem and charging problem solved downgrad youer device
Old 10-10-2018, 12:39   #21155 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 332
SM-G610F IMEI Repair Done
Operation: Repair
Selected model: SM-G610F
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Model: SM-G610F
Android version: 6.0.1
PDA version: G610FDXU1APK2
CSC version: G610FOLB1APK2
Phone version: G610FDDU1APK1
Product code: SM-G610FZKAXME
CSC country code: MALAYSIA
CSC sales code: XME
Phone SN: R58J73161HD
IMEI: 356576576667678
HW version: MP 0.400
RF cal date: 20170717
Security patch: 2016-11-01
Boot Warranty bit: 1
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Start... OK
HWID: E6 06 00 00 00 00 00 00 00 00 00 00 C0 55 CF E7
Calculating... OK
Repairing... OK
Writing NV data... OK
Repair done
Operation: Patch Certificate
Model: SM-G610F
CSC sales code: XME
IMEI: 356776677780004
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Patching CERT check... done
Old 10-10-2018, 15:17   #21156 (permalink)
Member: 2752048
Thanks Meter: 15
Gelaxy Note5 N920c Write cert Done
Old 10-10-2018, 23:34   #21157 (permalink)
Member: 216446
Thanks Meter: 157
SAMSUNG GALAXY N910F IMEI REPAIR
IMEI WAS BLOCKED -
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-N910F
Selected port: COM91 SAMSUNG Mobile USB Serial Port
Checking CERT file... OK
KEY ID: 0772
Model: SM-N910F
PDA version: N910FXXU1DPI1
CSC version: N910FVIA1DPI1
Phone version: N910FXXU1COJ3
Product code: SM-N910FZWEVIA
CSC country code: Germany
CSC sales code: VIA
Phone SN: 00000000000
IMEI:
HW version: MP 0.900
RF cal date: 2015.01.09
Chip name: APQ8084
Modem board: MDM9235
Security patch: 2016-09-01
Writing AT RIL... OK
Initialization AT RIL... root required
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0772
Writing CERT... OK
Checking CERT status... OK
Old 10-10-2018, 23:41   #21158 (permalink)
Member: 2300959
Thanks Meter: 40
SAMSUNG S9 ATT UNLOCK DONE!!
[ 10/10/2018 02:55:08 p.m. ] Reading phone info...
[ 10/10/2018 02:55:08 p.m. ] Model: SM-G960U
[ 10/10/2018 02:55:09 p.m. ] Android version: 8.0.0
[ 10/10/2018 02:55:09 p.m. ] PDA version: G960USQS2ARF4
[ 10/10/2018 02:55:09 p.m. ] CSC version: G960UOYN2ARF4
[ 10/10/2018 02:55:10 p.m. ] Phone version: G960USQS2ARF4
[ 10/10/2018 02:55:10 p.m. ] Product code: SM-G960UZKAATT
[ 10/10/2018 02:55:10 p.m. ] CSC country code: USA
[ 10/10/2018 02:55:11 p.m. ] CSC sales code: ATT
[ 10/10/2018 02:55:11 p.m. ] Phone SN: R38XXXXXXXX
[ 10/10/2018 02:55:11 p.m. ] IMEI: 35330XXXXXXXXXX
[ 10/10/2018 02:55:12 p.m. ] HW version: REV1.1
[ 10/10/2018 02:55:12 p.m. ] RF cal date: 2018.03.08
[ 10/10/2018 02:55:12 p.m. ] Chip name: SDM845
[ 10/10/2018 02:55:13 p.m. ] Modem board: SDM845
[ 10/10/2018 02:55:13 p.m. ] Security patch: 2018-06-01
[ 10/10/2018 02:55:13 p.m. ] Boot Warranty bit: 0
[ 10/10/2018 02:55:16 p.m. ] Searching Samsung diag port... detected COM55
[ 10/10/2018 02:55:17 p.m. ] Reading phone info... OK
[ 10/10/2018 02:55:17 p.m. ] Reading data from phone... OK
[ 10/10/2018 02:55:18 p.m. ] Searching server... OK
[ 10/10/2018 02:55:23 p.m. ] Waiting for server answer... OK
[ 10/10/2018 02:57:47 p.m. ] Freeze code: 17205869
[ 10/10/2018 02:57:47 p.m. ] NET lock: 15163538
[ 10/10/2018 02:57:48 p.m. ] SUB lock: 00000000
[ 10/10/2018 02:57:48 p.m. ] SP lock: 00000000
[ 10/10/2018 02:57:48 p.m. ] CP lock: 00000000
[ 10/10/2018 02:57:49 p.m. ] For check lock status: *#7465625#
but in PDA G960USQS3ARG8 dont read code check..
[ 10/10/2018 03:27:25 p.m. ] Reading phone info...
[ 10/10/2018 03:27:26 p.m. ] Model: SM-G960U
[ 10/10/2018 03:27:26 p.m. ] Android version: 8.0.0
[ 10/10/2018 03:27:27 p.m. ] PDA version: G960USQS3ARG8
[ 10/10/2018 03:27:27 p.m. ] CSC version: G960UOYN3ARG8
[ 10/10/2018 03:27:27 p.m. ] Phone version: G960USQS3ARG8
[ 10/10/2018 03:27:28 p.m. ] Product code: SM2G960UZPAATT
[ 10/10/2018 03:27:28 p.m. ] CSC country code: USA
[ 10/10/2018 03:27:28 p.m. ] CSC sales code: ATT
[ 10/10/2018 03:27:29 p.m. ] Phone SN: R38xxxxxxxx
[ 10/10/2018 03:27:29 p.m. ] IMEI: 354817XXXXXXXXX
[ 10/10/2018 03:27:29 p.m. ] HW version: REV1.1
[ 10/10/2018 03:27:30 p.m. ] RF cal date: 2018.06.14
[ 10/10/2018 03:27:30 p.m. ] Chip name: SDM845
[ 10/10/2018 03:27:30 p.m. ] Modem board: SDM845
[ 10/10/2018 03:27:31 p.m. ] Security patch: 2018-08-01
[ 10/10/2018 03:27:31 p.m. ] Boot Warranty bit: 0
[ 10/10/2018 03:27:34 p.m. ] Searching Samsung diag port... detected COM35
[ 10/10/2018 03:27:35 p.m. ] Reading phone info... OK
[ 10/10/2018 03:27:35 p.m. ] Reading data from phone... error (1), skip
[ 10/10/2018 03:27:35 p.m. ] Waiting for device to become ready... OK
[ 10/10/2018 03:27:38 p.m. ] Initialization zTool... OK
[ 10/10/2018 03:27:40 p.m. ] Running zTool, please wait...
[ 10/10/2018 03:27:40 p.m. ] Start... OK
[ 10/10/2018 03:27:43 p.m. ] Initialization... OK
[ 10/10/2018 03:27:44 p.m. ] Generate and check client proof... OK
[ 10/10/2018 03:27:45 p.m. ] Verify proof by client... OK
[ 10/10/2018 03:27:45 p.m. ] Reading data from phone... OK
[ 10/10/2018 03:27:54 p.m. ] Searching Ramdump interface... COM56 detected
[ 10/10/2018 03:29:17 p.m. ] Reading data from phone... OK
[ 10/10/2018 03:29:27 p.m. ] Calculating...
[ 10/10/2018 03:29:27 p.m. ] Exception: Invalid pointer operation
help please with bit 3
Old 10-11-2018, 11:21   #21159 (permalink)
theboy's Avatar
Member: 7557
Thanks Meter: 17
Samsung N960f Note 9 read codes
Done
You have 16 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-N960F
Android version: 8.1.0
PDA version: N960FXXU1ARH5
CSC version: N960FOVF1ARGD
Phone version: N960FXXU1ARGC
Product code: SM-N960FZKATCL
CSC country code: Portugal
CSC sales code: TCL
Phone SN: RF8K827APED
IMEI: 356630092193584
HW version: MP 0.700
RF cal date: 20180823
Chip name: EXYNOS9810
Modem board: SHANNON360
Checking server answer... OK
Start... OK
Executing... OK
Calculating... OK
Freeze code: 24707319
NET lock: 24941575
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 10-11-2018, 14:00   #21160 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 192
Wink Sm-j327t1
Operation: Unlock
Selected model: SM-J327T1
Ballance: 50 crd.
You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes
Model: SM-J327T1
PDA version: J327T1UVS2ARE1
CSC version: J327T1TMK2ARE1
Phone version: J327T1UVS2ARE1
Product code: SM-J327TZSATMK
CSC sales code: TMK
Phone SN: RV8K703TVFV
IMEI: 35921409*********
HW version: REV0.1
RF cal date: 20180704
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2018-05-01
Searching Samsung modem... detected COM104
Model: SM-J327T1
AP version: J327T1UVS2ARE1
CP version: J327T1UVS2ARE1
Product code: TMK
Unique number: CQE00B8CBD0AF45
Checking data... OK
Start... OK
Unlock done
Old 10-12-2018, 06:33   #21161 (permalink)
Member: 2549748
Thanks Meter: 78
Cool SM-J700h FRP RESET
[ 10/11/2018 11:04:20 PM ] Operation: Reset FRP/React/EE
[ 10/11/2018 11:04:20 PM ] Selected model: SM-J700H
[ 10/11/2018 11:04:20 PM ] Software version: 33.8
[ 10/11/2018 11:04:21 PM ] Searching Samsung USB Flash interface... COM27 detected
[ 10/11/2018 11:04:21 PM ] Setup connection... OK
[ 10/11/2018 11:04:22 PM ] Reading PIT from phone... OK
[ 10/11/2018 11:04:23 PM ] Searching FRP lock... OK
[ 10/11/2018 11:04:24 PM ] Erasing FRP lock... OK
[ 10/11/2018 11:04:26 PM ] Reset done
[ 10/11/2018 11:04:27 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 10-12-2018, 06:34   #21162 (permalink)
Member: 2549748
Thanks Meter: 78
Wink sm-j700h read codes
[ 10/11/2018 11:09:18 PM ] Operation: Read Codes
[ 10/11/2018 11:09:19 PM ] Selected model: SM-J700H
[ 10/11/2018 11:09:20 PM ] Software version: 33.8
[ 10/11/2018 11:09:21 PM ]
[ 10/11/2018 11:09:23 PM ] Please wait, generating hash codes file, this can take few minutes... OK
[ 10/11/2018 11:16:59 PM ] Searching Samsung modem... detected COM95
[ 10/11/2018 11:17:01 PM ] Reading phone info...
[ 10/11/2018 11:17:03 PM ] Model: SM-J700H
[ 10/11/2018 11:17:04 PM ] AP version: J700HXXU1APA3
[ 10/11/2018 11:17:05 PM ] CSC version: J700HOJV1AOK6
[ 10/11/2018 11:17:05 PM ] CP version: J700HXXU1APA2
[ 10/11/2018 11:17:06 PM ] Product code: SM-J700HZKDXFE
[ 10/11/2018 11:17:07 PM ] Phone SN: R51H30EJYGW
[ 10/11/2018 11:17:07 PM ] IMEI: 358301072885395
[ 10/11/2018 11:17:07 PM ] IMEI2: 358302072885393
[ 10/11/2018 11:17:08 PM ] Unique number: C0000A6E24473C2
[ 10/11/2018 11:17:23 PM ] Searching Samsung diag port... detected COM96
[ 10/11/2018 11:17:25 PM ] Reading phone info... OK
[ 10/11/2018 11:17:27 PM ] CP version: J700HXXU1APA2
[ 10/11/2018 11:17:27 PM ] CP build: Jan 7 2016 14:13:31
[ 10/11/2018 11:17:28 PM ] Reading data from phone... OK
[ 10/11/2018 11:17:33 PM ] Reading NV data... OK
[ 10/11/2018 11:19:37 PM ] Modem board: SHANNON310
[ 10/11/2018 11:19:37 PM ] Checking NV data... OK
[ 10/11/2018 11:19:38 PM ] Please wait, calculating codes... OK (time - 00:00:11)
[ 10/11/2018 11:19:56 PM ] Freeze code: 35940853
[ 10/11/2018 11:20:01 PM ] NET lock: 00000000
[ 10/11/2018 11:20:02 PM ] SUB lock: 00000000
[ 10/11/2018 11:20:04 PM ] SP lock: 00000000
[ 10/11/2018 11:20:04 PM ] CP lock: 00000000
[ 10/11/2018 11:20:06 PM ] SIM lock: 00000000
[ 10/11/2018 11:20:06 PM ] For check lock status: *#7465625#
Old 10-12-2018, 14:46   #21163 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,284
SM-G935FD REPAIR IMEI DONE WITH Z3X WITH OLD VERSION THE LATEST VERSION FUNCTION REMOVE BY TEAM STILL KEEP OLD VERSION ALL PEOPLE
[ 10/12/2018 7:34:00 AM ] Operation: Repair
[ 10/12/2018 7:34:00 AM ] Selected model: SM-G935FD
[ 10/12/2018 7:34:00 AM ] Software version: 27.6
[ 10/12/2018 7:34:00 AM ] Waiting ADB device... Ok
[ 10/12/2018 7:34:00 AM ] Reading phone info...
[ 10/12/2018 7:34:00 AM ] Model: SM-G935F
[ 10/12/2018 7:34:00 AM ] Android version: 6.0.1
[ 10/12/2018 7:34:00 AM ] Product code:
[ 10/12/2018 7:34:00 AM ] Phone version: G935FXXU1APB4
[ 10/12/2018 7:34:00 AM ] PDA version: G935FXXU1APB4
[ 10/12/2018 7:34:00 AM ] CSC version: G935FUUB1APB4
[ 10/12/2018 7:34:00 AM ] CSC country code: PANAMA
[ 10/12/2018 7:34:00 AM ] CSC sales code: TPA
[ 10/12/2018 7:34:00 AM ] HW version:
[ 10/12/2018 7:34:00 AM ] Phone SN: RF8H42P8KPJ
[ 10/12/2018 7:34:00 AM ] Chip name: EXYNOS8890
[ 10/12/2018 7:34:00 AM ] Modem board: SHANNON335
[ 10/12/2018 7:34:00 AM ] RF cal date:
[ 10/12/2018 7:34:00 AM ] IMEI:
[ 10/12/2018 7:34:00 AM ] Checking Super user right... true
[ 10/12/2018 7:34:00 AM ] Reading NV data... Ok
[ 10/12/2018 7:34:00 AM ] Checking NV data... Ok
[ 10/12/2018 7:34:00 AM ] Initialization zTool... Ok
[ 10/12/2018 7:34:00 AM ] Running zTool, please wait...
[ 10/12/2018 7:34:00 AM ] Start... Ok
[ 10/12/2018 7:34:00 AM ] Initialization... Ok
[ 10/12/2018 7:34:00 AM ] Generate and check client proof... Ok
[ 10/12/2018 7:34:00 AM ] Verify proof by client... Ok
[ 10/12/2018 7:34:00 AM ] Reading data from phone... Ok
[ 10/12/2018 7:34:00 AM ] HWID: B9 84 43 98 4D 53 A2 46 C8 0F E0 AE E0 8F AB 4D
[ 10/12/2018 7:34:00 AM ] Calculating... Ok
[ 10/12/2018 7:35:00 AM ] Repairing... Ok
[ 10/12/2018 7:35:00 AM ] Writing NV data... Ok
[ 10/12/2018 7:35:00 AM ] Rebooting phone... Ok
[ 10/12/2018 7:35:00 AM ] Repair done
REPAIR INSTRUCTIONS:
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Model: SM-G935F
Product code:
CSC sales code: TPA
HW version:
RF cal date:
IMEI:
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Done with Samsung Tool PRO v.27.6
Old 10-12-2018, 14:49   #21164 (permalink)
GsmServerEcuado's Avatar
Member: 2871022
Sonork: Server Unlock
Thanks Meter: 19
EXCELLENT BOX with EXCELLENT SUPPORT
Old 10-12-2018, 16:08   #21165 (permalink)
Member: 1444462
Thanks Meter: 332
SM-J530F IMEI Repair Done
Selected model: SM-J530F
Model: SM-J530F
PDA version: J530FXWU2ARC1
CSC version: J530FOJV2ARC2
Phone version: J530FXXU2ARA2
Product code: SM-J530FZDAXFA
CSC country code: SOUTH AFRICA
CSC sales code: XFA
Phone SN: RF8JB2KPKTB
IMEI: 355776867867802
HW version: MP 0.500
RF cal date: 20171120
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1726 01-14-2019 06:14
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.59740 seconds with 9 queries
