11-20-2010, 00:14 | #2162 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Colombia Unlock
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: S5230 Selected com port: COM8 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 17041004557123 /4 Phone S/N: RP7Z493413 Detecting UART port..... OK Repower phone - please wait Phone must be ON Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 47 second, sw ver: 3.4.0071 |
11-20-2010, 00:15 | #2163 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: B3310 Selected com port: COM14 Selected speed port: USB Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: B3310UAIJ1 IMEI: 35659203666153 MSL DEACTIVATED - TRUE Set default customer - fail NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 22 second, sw ver: 3.4.0071 |
11-20-2010, 00:17 | #2164 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: M310 Selected com port: COM8 Selected speed port: 921600 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 18333132 byte segment 3 2001E000 144 byte segment 4 20016000 4652 byte segment 5 20078000 1093276 byte segment 6 2000C000 20128 byte segment 7 20058000 56 byte segment 8 20058138 18060 byte segment 9 2003803C 36688 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 010000427E22 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 12 Format FFS - wait... OK Send content - wait... OK Elapsed time: 504 second, sw ver: 3.4.0071 |
11-20-2010, 00:17 | #2165 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: E2120 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Start NOR flash NOR flash - ok Download - ok Elapsed time: 575 second, sw ver: 3.4.0071 |
11-20-2010, 00:18 | #2166 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: E2120 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 53 second, sw ver: 3.4.0071 |
11-20-2010, 00:24 | #2167 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: E1080 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 62 second, sw ver: 3.4.0071 |
11-20-2010, 00:25 | #2168 (permalink) |
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Selected model: M130 Selected com port: COM8 Selected speed port: 460800 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK Flash ID: A00300C2017E Sending loader2... OK Unlock block If lock - not deactivate: try with code 00000000 Unlock - ok Elapsed time: 57 second, sw ver: 3.4.0071 |
11-20-2010, 09:58 | #2169 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | GT-S3370 Unlock done Code: Model: GT-S3370 CountryCode: 3IT Factory SW: S3370NEJD4_3ITJD4 UniqueNumber: 80090000057993 MemoryPhone: K522H1HACC(S3370)S IMEI: 3526730418xxxxx Phone S/N: RVTZ663284 Build: Q6270B-KPVZL-1.5.55011ST Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:01:10) Freeze code: 06079084 NET lock: #7465625*638*07385972# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
11-20-2010, 11:30 | #2170 (permalink) |
No Life Poster Join Date: May 2008 Location: gsm city
Member: 767786 Status: Offline Thanks Meter: 320 | Selected model: C3053 Selected com port: COM31 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3053JAIF1 IMEI: 35471803134*** MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 18 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-20-2010, 12:05 | #2171 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | S3650 Selected model: S3650 Selected com port: COM6 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 35857303927771 /4 Phone S/N: RQ3Z432585 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 85 second, sw ver: 3.4.0068 --------------------------------------------- |
11-20-2010, 14:04 | #2172 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Phone OLD IMEI: 35205804087381 /4 ------------------------------------------------------------------------------- Selected model: S5620 Selected com port: Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Phone OLD IMEI: 35205804087355 /8 Phone SW: S5620XXIL7/S5620OXAIL4 Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM12 Send loader... OK Wait for boot ... Phone must be ON Search modem ... OK Search modem on:COM12 MSL DEACTIVATED - TRUE Write imei - ok Phone NEW IMEI: 35205804087355 /8 Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM12 Send loader... OK Elapsed time: 167 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-20-2010, 15:28 | #2173 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Samsung a877 att unlock done!!!! SAMSUNG A877 (ATT )UNLOCK DONE!!!! Model: SGH-A877 CountryCode: ATT Factory SW: UCID3 UniqueNumber: 80200000303449 MemoryPhone: KAV00500FM(A877) IMEI: 35701103452344/5 Phone S/N: RUMSA86486 Build: M6290A-KPMZL-1.2.003503T Done with Samsung 3G tool ver 8.5 ----------------------------- Model: SGH-A877 CountryCode: ATT Factory SW: UCID3 UniqueNumber: 80200000303449 MemoryPhone: KAV00500FM(A877) IMEI: 35701103452344/5 Phone S/N: RUMSA86486 Build: M6290A-KPMZL-1.2.003503T Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:01:46) Freeze code: 35162914 NET lock: #7465625*638*59136050# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.5 |
11-20-2010, 19:17 | #2174 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | samsung s5230 unlocked successfully Selected model: S5230 Selected com port: COM5 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Phone IMEI: 35767603xxxxxxx /9 Phone S/N: RQPS805209 Detecting UART port..... OK Repower phone - please wait Phone must be ON Search modem ... OK Search modem on:COM12 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 49 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-20-2010, 19:41 | #2175 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | C3300K UNLOCKED SUCCESSFULLY [USED C3300K CABLE] Selected model: C3300K Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 178 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
