01-30-2010, 23:31 | #466 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 575576 Status: Offline Thanks Meter: 25 | 1.) direct unlock it gives an error 7 times 2) reset code *2767*3855# 3)then unlock again done Selected model: A177 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC220600010000E1D0 Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 123 second, sw ver: 3.4.0024 -------------------------------------------- |
02-01-2010, 01:21 | #467 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Count supported models - 146 Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM122) Model: M8800 IMEI: xxxxxxxxx SW: M8800LVMIA1 Searching Qualcomm USB interface... detected (COM122) Model: M8800 IMEI: xxxxxxxxxx SW: M8800LVMIA1 Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:33) Freeze code... 19479463 NET lock code... 46292049 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*46292049# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# For check lock status: *#7465625# M8800L movilnet Venezuela unlock OK thanks Z3x |
02-01-2010, 14:04 | #468 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | Selected model: B3310 Selected com port: COM26 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: B3310XXIH3 IMEI: 35659********** MSL DEACTIVATED - TRUE Set default customer - fail NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 20 second, sw ver: 3.4.0027 |
02-01-2010, 16:23 | #469 (permalink) |
No Life Poster Join Date: Jul 2005 Location: turkey, izmir
Member: 163458 Status: Offline Sonork: 100.1606694 Thanks Meter: 503 | f490 unlock slove Searching phone at COM interface... ok Model: F490 SW: F490AEHD1 Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: F490 SW: F490AEHD1 Unlock as MSL2 Direct... OK (time - 00:00:03) |
02-01-2010, 16:24 | #470 (permalink) |
Member: 163458 Status: Offline Sonork: 100.1606694 Thanks Meter: 503 | f490 imei ..... Searching phone at COM interface... ok Model: F490 SW: F490AEHD1 Reading NVM... ok (C:\Program Files\Z3X\Samsung\Qualcomm\NVM\f490__1.2.2010_16-58-13.qnvmbkp) Searching Qualcomm USB interface... not found Repairing as MSL2 Direct... ok (IMEI - 35002**********)! (time - 00:00:03) |
02-02-2010, 03:30 | #471 (permalink) |
Freak Poster Join Date: Nov 2009 Location: across in the archipelago
Member: 1170687 Status: Offline Thanks Meter: 30 | B3310 unlock Selected model: B3310 Selected com port: COM17 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: B3310DFII4 IMEI: 35659203348023 MSL DEACTIVATED - TRUE Set default customer - fail NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 16 second, sw ver: 3.4.0027 ------------------------------------------------------------------------------- |
The Following User Says Thank You to Mintsea For This Useful Post: |
02-02-2010, 10:18 | #472 (permalink) |
Freak Poster Join Date: Sep 2009 Location: TUNISIA
Member: 1114818 Status: Offline Thanks Meter: 247 | samsung S3100 Selected model: S3100 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Unlock - ok Elapsed time: 8 second, sw ver: 3.4.0027 |
The Following User Says Thank You to jbenianamohsen For This Useful Post: |
02-03-2010, 06:18 | #473 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Great Pakistan
Member: 101548 Status: Offline Sonork: 100.1611535 Thanks Meter: 210 | g600 restart.... I have G600 which keeps restarting when powering on. I have flashed BIN and TFS but same result. The firmware was G600XAGJ1 and i flashed with G600XAGH2.any one help me... REGARDS. TAIMOOR KHAN |
02-03-2010, 12:03 | #475 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | i7500 successfully IMEI repair Quote:
02-03-2010, 12:04 | #476 (permalink) | |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | i7500 successfully unlock Quote:
02-03-2010, 12:31 | #477 (permalink) |
Junior Member Join Date: Jul 2009 Location: Mehatpur(Punjab
Member: 1083731 Status: Offline Thanks Meter: 15 | samsung e1120 unlock my dasmesh mobile care.mehatpur. Last version on support: 2G tools v3.4.0027 Selected model: E1120 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 3560xxxxxxxxxx Phone SW: E1120BVID1 Phone BT ADDR: 0000-00-000000 Phone SN: RVBS918658 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 21 second, sw ver: 3.4.0027 http://img202.imageshack.us/i/samsunge1120unlock.jpg/ Last edited by dasmeshmehatpur; 02-03-2010 at 12:33. Reason: imei change |
02-04-2010, 16:44 | #478 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 173741 Status: Offline Thanks Meter: 986 | M610 Selected model: M610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 0001227E224222000000 Phone IMEI -> 35288702xxxxx Phone SW -> M610CWHI2 Langpack-> Not found langpack ! Phone HW -> MP 1.000 Phone BT ADDR -> 0025-66-CF8D17 Phone WI-FI ADDR -> [NET LOCK]:90734870, [SIM LOCK]:00000000, [PHONE LOCK]:00000000, [SP LOCK]:00000000, Read Info - ok Elapsed time: 70 second, sw ver: 3.4.0027 |
02-04-2010, 17:56 | #479 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | 821sc Preved! Count supported models - 146 Server news: [01.02.2010] LG Qualcomm 1.7.9 released! Direct unlock and Imei repair for GU280, GU280f, GU285, GU285f, GU285g first in the world! Added BL40e, BL40f, BL40g. [29.01.2010] Samsung Smart Phone Tool Update 2.3.05 B7300, B7610, B7620, i6410, i8000, i8510, i8320, 001B,X01B supported !!! [26.01.2010] Samsung Tool 3.4.0027 [17.01.2010] Samsung Qualcomm Tool Update 6.4.05 skip FFS flashing added [13.01.2010] LG 2g Tool 1.0.3beta release! [1.01.2010] Happy new year for z3x-team customers. ----------------------------------- READ NEWS FOR DETAILS! Checking ports... ok Searching Samsung USB interface... detected (COM89) Checking mobile state... normal Model: 821SC SW: 821SCID3 IMEI: 359198010794948 Searching Samsung USB Flash interface... detected (COM88) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:03:51) Searching phone at COM interface... ok Model: 821SC SW: 821SCID3 Unlock as Softbank... ok |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
