01-29-2013, 13:39 | #8281 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Gazipur,Mawna
Member: 1379712 Status: Offline Sonork: 100.1607970 Thanks Meter: 44 | Galaxy S II SHW-M250S Selected model: I9100 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SHW-M250S Android version: 4.0.3 Product code: Not Active Phone version: M250S.UD18.1125.ST PDA version: M250S.UE21.0039 CSC version: Unknown IMEI: Unknown Checking Super user right... false Rooting phone, please wait... Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.9 Done with Samsung Tool v.13.9 |
01-29-2013, 17:25 | #8282 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1875900 Status: Offline Thanks Meter: 0 | MICROMAX Superfone using Android 4.0.4 is locked MICROMAX Superfone (MODEL:A110,CANVAS2) using Android 4.0.4(ICS) is locked.How can I unlock it? It got locked due to wrong pattern entry multiple times.It is asking for google ID and password and after correct entry also it is not unlocking!!Pls help.Thanks. Note: This is a new smart phone,like Samsung note2. Last edited by bhadrasc; 01-29-2013 at 17:35. |
01-29-2013, 19:43 | #8283 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 68705 Status: Offline Thanks Meter: 38 | n7105 Selected model: N7105 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.13.8 Selected model: N7105 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179545 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.13.8 |
01-29-2013, 19:53 | #8284 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung galaxy s i9000 rooted and unlock done i have finaly rooted and unlock my galaxy s i9000 after 2 days by this step DOWNLOAD THIS FILE: CF-Root Download Extract the rooted kernel from the ZIP file you downloaded. You will get one file after extracting: CF-Root-XX_OXA_JVU_2.3.6-v4.3-CWM3RFS.tar. Launch Odin3 on your computer. Turn off your phone. Reboot your phone into download mode by holding down the Volume Down key and the OK button simultaneously, then pressing the Power button. Once the phone is in download mode, connect your phone to your computer via the USB Cable. Odin3 should be able to detect your phone. If so, the ID:COM field in Odin3 will turn yellow. If not, your phone was not properly detected and you should not proceed. In the Odin3 window, click the PDA button. Select CF-Root-XX_OXA_JVU_2.3.6-v4.3-CWM3RFS.tar. Under “Options” in Odin3, make sure “Repartition” is not checked. Click the Start button in Odin3. The program will start flashing the update file to your phone. Your phone will automatically reboot after Odin3 has finished flashing the update. Disconnect the phone from the computer only after it has completely rebooted. Your Samsung Galaxy S GT-I9000 should now be rooted. You’re now running Android 2.3.6 XXJVU firmware with root access on your Samsung Galaxy S GT-I9000. i have rooted my phone with odin 1.85 see logs <ID:0/076> Added!! <ID:0/076> Odin v.3 engine (ID:76).. <ID:0/076> File analysis.. <ID:0/076> SetupConnection.. <ID:0/076> Initialzation.. <ID:0/076> Get PIT for mapping.. <ID:0/076> Firmware update start.. <ID:0/076> zImage <ID:0/076> NAND Write Start!! <ID:0/076> RQT_CLOSE !! <ID:0/076> RES OK !! <ID:0/076> Removed!! <ID:0/076> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/073> Added!! <ID:0/073> Removed!! <ID:0/073> Added!! <ID:0/073> Removed!! after root successful i use z3xbox unlock 100% done. Selected model: I9000 Selected port: COM26 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9000 Android version: 2.3.6 Product code: GT-I9000HKDKOR Phone version: I9000XXJVU PDA version: I9000XXJVU CSC version: I9000OXAJVU IMEI: 354781043482733 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... false Done with Samsung Tool v.13.9 Selected model: I9000 Selected port: COM26 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9000 Android version: 2.3.6 Product code: GT-I9000HKDKOR Phone version: I9000XXJVU PDA version: I9000XXJVU CSC version: I9000OXAJVU IMEI: 354781043482733 Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.9 Done with Samsung Tool v.13.9 |
01-30-2013, 15:06 | #8285 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | Quote:
please download and install rockey200-after installation it should work, when installed run z3x shell and download samsung 13.8 and 2g and u r ready to go i had same issue with win vista, after installation box works ok, card is shown and working.. instDrv_stdRK200 - Download - 4shared | |
01-30-2013, 15:07 | #8286 (permalink) |
No Life Poster Join Date: Feb 2011 Location: United Kingdome
Member: 1507640 Status: Offline Thanks Meter: 131 | Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8160 Android version: 2.3.6 Product code: GT-I8160OKAO2U Phone version: I8160XXLK6 PDA version: I8160XXLK6 CSC version: I8160O2ULK1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM6 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.13.8 Done with Samsung Tool v.13.8 Report Post Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post! |
01-30-2013, 15:14 | #8287 (permalink) |
Member: 1507640 Status: Offline Thanks Meter: 131 | Selected model: S5830I Selected port: Selected port speed: 115200 Reading phone info... Model: GT-S5830i Android version: 2.3.6 Product code: Unknown Phone version: S5830iXXLD2 PDA version: S5830iXXLD3 CSC version: S5830iBTULC1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.8 Done with Samsung Tool v.13.8 |
01-30-2013, 16:29 | #8288 (permalink) |
Member: 1507640 Status: Offline Thanks Meter: 131 | Selected model: I9100 Selected port: COM38 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.0.3 Product code: GT-I9100LKAO2U Phone version: I9100XXLPR PDA version: I9100XWLP3 CSC version: I9100O2ULP4 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.8 Done with Samsung Tool v.13.8 |
01-30-2013, 17:00 | #8289 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | Selected model: I9300 Selected port: Selected port speed: 115200 Reading phone info... Model: GT-I9300 Android version: 4.0.4 Product code: GT-I9300MBDMOB Phone version: I9300BULF1 PDA version: I9300BUALF1 CSC version: I9300VFGALF1 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.7 Done with Samsung Tool v.13.7 |
01-30-2013, 20:22 | #8290 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Selected model: I9305 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179535 Repairing IMEI... OK Repair done Reseting... OK Done with Samsung Tool v.13.9 |
01-31-2013, 01:49 | #8291 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Selected model: I9300 Selected port: COM11 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9300 Android version: 4.0.4 Product code: GT-I9300MBASFR Phone version: I9300BULF1 PDA version: I9300BUALF1 CSC version: I9300VFGALF1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.9 Selected model: S3350 Selected com port: COM11 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Already patched SW Erasing ... OK Writing ... OK After power on phone - connect to UART cable Phone SN: RGDBA18784 Deactivate MSL - OK Read - fail Unlock - ok Elapsed time: 54 second, sw ver: 3.5.0040 |
01-31-2013, 01:51 | #8292 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Selected model: S5830 Selected port: COM11 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: S5830BUKS2/S5830SFRKS2 Phone version: S5830XWKS2 Phone HW: MP 0.600 Cal date: 2011.02.16 Reading IMEI... OK IMEI: 354890045981830 Phone S/N: RPJB216879 Build: M76XX-TSNCJOLYM-6140 Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.13.8 Selected model: B3410 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: B3410AEIL1_ Phone CSC: B3410SFRIL1_ Phone BT ADDR: D4E8-B2-ADCBB4 Phone IMEI: 35395504126741 Deactivated MSL - TRUE Unlock - ok Elapsed time: 30 second, sw ver: 3.5.0040ry again Elapsed time: 2 second, sw ver: 3.5.0040 |
01-31-2013, 01:52 | #8293 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Selected model: S5750E Selected com port: COM11 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM5 Model: GT-S5750E CountryCode: BOG Factory SW: S5750EAGKH1_BOGKC1 UniqueNumber: 79350000725928 MemoryPhone: KAT00M020A(S5750E) Phone IMEI: 35579404481209 /6 Phone S/N: RDOBB28499 Phone Bluetooth ID: BC B1 F3 C6 20 EC Phone SW: S5750EXXKG2/S5750EBSEKG2 Phone HW: MP 0.300 Phone CalData ver: 20111107 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:81829485 [NET LOCK]:97314072 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 56 sec Elapsed time: 68 second, sw ver: 3.5.0040 ------------------------------------------ |
01-31-2013, 01:53 | #8294 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Selected model: I5800 Selected port: COM49 SAMSUNG Mobile Modem Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... Model: GT-I5800 Country code: ÇÁ¶û½º Cal date: 2010-08-03 Factory SW: I5800POJG5 Unique number: 86070000398671 Memory phone: KAC007021B(I5801) PDA/CSC version: I5800POJG5/none Phone version: I5800XXJG3 Phone HW: MP 1.000 Cal date: 2010.08.09 Reading IMEI... OK IMEI: 352286040374372 Phone S/N: RVDZ874447 Build: Q6270B-KPRBL-1.5.55062ST Reading security... OK Calculating... OK Bypass MSL... OK Unlocking... OK Reseting... Unlock done Done with Samsung Tool v.13.9 |
01-31-2013, 01:53 | #8295 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Selected model: S3350 Selected com port: COM11 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Damping ... OK Patch block Patch block Already patched SW Erasing ... OK Writing ... OK After power on phone - connect to UART cable Phone SN: RDRBA83649 Deactivate MSL - OK Calculated code please wait... Decrypted time: 60 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*98732435# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*13479571# this is Master(freeze) code Read info - ok Elapsed time: 111 second, sw ver: 3.5.0040 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
