03-24-2014, 20:38 | #10441 (permalink) |
Major Poster Join Date: Mar 2013
Member: 1894807 Status: Offline Thanks Meter: 4 | Galaxy S4 [I9505] 4.3 - Repair imei or modify Reboot your device on download mode, now flash For_Unlock_and_IMEI_Repair_GT-I9505.oct reboot your device and do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. This is my log Welcome to Octoplus/Octopus Box Samsung software version 1.5.1 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9505_new.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Selected firmware file: For_Unlock_and_IMEI_Repair_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM4 Phone connection failed ---------------------------------- Platform: Samsung Android Selected port: COM29 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 351979-04-294663-2 Creating NVM backup Reading NVM done! Firmware compiled date: Tue Oct 15 16:21:56 KST 2013 PDA version: I9505XXUEMJ7 CSC version: I9505OMNEMJ1 SW version: I9505XXUAMDC Phone IMEI: 357634050*****8 Phone SN: RF1D64997DK Android version: 4.3 (JSS15J) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-357634050910558-24-03-2014_18-52- 33-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM28 Repairing NVM for GT-I9505 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
03-24-2014, 20:41 | #10442 (permalink) |
Member: 1894807 Status: Offline Thanks Meter: 4 | Galaxy S4 [I9505] 4.4.2 - Repair imei or modify Welcome to Octoplus/Octopus Box Samsung software version 1.5.1 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9505_new.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Selected firmware file: For_Unlock_and_IMEI_Repair_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505VFGFNB3 SW version: I9505XXUEML6 Phone IMEI: Unknown Phone SN: RF1D62LC43T Android version: 4.4.2 (KOT49H) Selected firmware file: For_Unlock_and_IMEI_Repair_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM20 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 004400-15-202000-0 New IMEI: 354244-05-644790-3 Creating NVM backup Reading NVM done! Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505VFGFNB3 SW version: I9505XXUAMDC Phone IMEI: Unknown Phone SN: RF1D62LC43T Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-24-03-2014_19-10-11-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM20 Repairing NVM for GT-I9505 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
03-24-2014, 20:45 | #10443 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: S5301 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-S5301 Android version: 4.0.4 Product code: Unknown Phone version: S5301XXMJ1 PDA version: S5301XXAMJ1 CSC version: S5301COVAMJ1 IMEI: 359078053385343 Phone S/N: R21DB2ZTSAB Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.17.2 |
03-25-2014, 10:01 | #10446 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2111259 Status: Offline Sonork: 100:1625853 Thanks Meter: 1 | i747m 4.3 unlock done by:Z3X box Selected model: I747M Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SGH-I747M Android version: 4.3 Product code: Not Active Phone version: I747MVLUEMK5 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 IMEI: 353321050166951 Phone S/N: R21CA468WTP Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... OK Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done |
03-25-2014, 11:59 | #10447 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Austria Age: 43
Member: 7688 Status: Offline Sonork: klaus4 Thanks Meter: 2 | Selected model: I9505 Selected port: COM17 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.3 Product code: Not Active Phone version: I9505XXUAMDC PDA version: I9505XXUEMKF CSC version: I9505DREEMK2 IMEI: 356843054334183 Phone S/N: RF1D871LEFD Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.17.2 Selected model: I9505 Selected port: COM17 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.3 Product code: Not Active Phone version: I9505XXUAMDC PDA version: I9505XXUEMKF CSC version: I9505DREEMK2 IMEI: 356843054334183 Phone S/N: RF1D871LEFD Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM17 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Bypass MSL... OK Repairing... OK Checking phone at COM17 Restoring NVM... OK Reseting... OK Repair done Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 DONE |
03-25-2014, 13:31 | #10448 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: E1200I Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Waiting phone... detected COM117 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 352317063734141 Phone HW: MP 0.300 Product code: GT-E1200ZKITSC Please wait, calculating codes... OK (time - 00:00:28) Freeze code: 14086053 NET lock: 05168648 Sub lock: 00000000 SP lock: 38037319 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.17.2 |
03-26-2014, 12:46 | #10451 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | i8552 imei repair done Selected model: I8552 Selected port: COM124 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I8552XXAMG1/I8552OJVAMG1 Phone version: SW VERSION :None Phone HW: None Cal date: none Searching ADB device... OK Reading phone info... Model: GT-I8552 Android version: 4.1.2 Product code: Not Active Phone version: I8552XXAMDB PDA version: I8552XXAMG1 CSC version: I8552OJVAMG1 IMEI: 357091005342348 Phone S/N: RV1D559TE2Y Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM124 Reading phone info... PDA/CSC version: I8552XXAMG1/I8552OJVAMG1 Phone version: SW VERSION :None Phone HW: None Cal date: none Bypass MSL... OK Repairing Master IMEI... OK Repairing Slave IMEI... OK Repairing network settings... OK Reseting... OK Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 |
03-26-2014, 17:50 | #10452 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: I9100 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: GT-I9100LKAXEU Phone version: I9100XXMS2 PDA version: I9100XWLSW CSC version: I9100XEULS5 IMEI: 359585044506712 Phone S/N: 00000000000 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading nv data... OK Checking magic... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.17.2 |
03-26-2014, 22:14 | #10453 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | Selected model: I727 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I727UCKJ2/I727ATTKJ2 Phone version: SW VERSION :None Phone HW: REV0.2 Cal date: 2011.12.16 IMEI: 35728804416050 Phone S/N: R28BC30890 Build: M9200B-SCAQCSZD-3.0.552050 Reading security... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 |
03-27-2014, 13:38 | #10455 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | s7582 imei repair done Selected model: S7582 Selected port: COM127 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-S7582 Android version: 4.2.2 Product code: Unknown Phone version: S7582XXUAMK3 PDA version: S7582XXUAMK3 CSC version: S7582OJVAMJ2 IMEI: 352218064773544 Phone S/N: R21F22TY17H Checking Super user right... true Reading EFS from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\EFS\EFS_S7582_27-3-2014_14-36-6.bak Done with Samsung Tool v.17.2 Selected model: S7582 Selected port: COM127 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-S7582 Android version: 4.2.2 Product code: Unknown Phone version: S7582XXUAMK3 PDA version: S7582XXUAMK3 CSC version: S7582OJVAMJ2 IMEI: 352218064773544 Phone S/N: R21F22TY17H Checking Super user right... true Repairing network... OK Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool v.17.2 Done with Samsung Tool v.17.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
