05-06-2015, 10:24 | #13531 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Selected model: E1202 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F816 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 356203055 Phone slave IMEI: 3562040557 Phone SW: E1202XXLK2 Phone CSC: E1202OXFLK1 Phone BT ADDR: 0000-00-000000 Phone SN: RV1D7433AX Deactivated MSL - TRUE [FREZEE]: 58451700 [NET Lock]: 77351720 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00000000 Read info - ok Elapsed time: 57 second, sw ver: 3.5.0040 |
05-06-2015, 11:09 | #13532 (permalink) |
Insane Poster Join Date: Mar 2009 Location: Romania , Bucuresti Age: 44
Member: 988173 Status: Offline Thanks Meter: 23 | Unlock SGH-T999 Nice Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-T999 Selected port: COM19 SAMSUNG Mobile USB Serial Port , Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 355164054486779 Reading security... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
The Following User Says Thank You to morfeus_noe For This Useful Post: |
05-06-2015, 11:52 | #13533 (permalink) |
Freak Poster Join Date: Apr 2014 Location: Pakistan
Member: 2170171 Status: Offline Sonork: 100.1652359 Thanks Meter: 30 | I9505 4.4.2 unlock Done UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9505 Selected port: COM184 SAMSUNG Mobile USB Serial Port , Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 357377xxxxxxx Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
The Following User Says Thank You to Federalgsm For This Useful Post: |
05-06-2015, 12:02 | #13534 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung Galaxy S3 GT-I9300 Orange unlock done... other two box failed this phone.... UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9300 Software version: 20.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: GT-I9300XXXORA Phone version: I9300BVUGNB2 PDA version: I9300XXUGNB5 CSC version: I9300ORAGML2 CSC country code: UK CSC sales code: ORA HW version: REV0.1 Phone S/N: RF1C70ACTSB Modem board: RF cal date: 2014.1.23 IMEI: 353720059111969 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.20.5 |
The Following User Says Thank You to razib143 For This Useful Post: |
05-06-2015, 12:54 | #13536 (permalink) |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | Operation: Unlock Selected model: SM-G530H Selected port: COM398 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: 357xxxxxxxxxx034 Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.20.5 |
05-06-2015, 13:49 | #13537 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsugn E1200I Phone Lock code read done.... Selected model: E1200I Selected port: COM55 SciCmpst Diag Selected port speed: 921600 Reading phone info... OK IMEI Master: 356003064490794 Product code: GT-E1200ZKISUW Phone HW: MP 0.300 Phone S/N: R21F84BJLM Reading codes... OK Please wait, calculating codes... OK (time - 00:00:49) Freeze code: 37026173 NET lock: 29308404 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.18.9 |
05-06-2015, 14:19 | #13538 (permalink) |
Freak Poster Join Date: Dec 2011 Location: portgual
Member: 1701048 Status: Offline Sonork: 100.1655662 Thanks Meter: 17 | s7275r unlock done http://imageshack.com/a/img673/4346/Ke7uQb.jpg |
The Following User Says Thank You to diljit07 For This Useful Post: |
05-06-2015, 15:05 | #13539 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Operation: Unlock Selected model: GT-S3800W Selected port: COM1 Communications Port, 921600 Software version: 20.2 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Patching firmware block... OK Erase Flash... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM116 Reading phone info... Model: Country code: Factory SW: Unique number: Memory phone: Software version: S3800WXXMD8/S3800WOXFMD2 IMEI: 35517105144635 Reading Phone S/N... OK Phone S/N: RV1D56ZQDR Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.20.2 |
The Following User Says Thank You to zvrrr For This Useful Post: |
05-06-2015, 19:08 | #13540 (permalink) |
Insane Poster Join Date: Aug 2011 Location: Houston
Member: 1632138 Status: Offline Thanks Meter: 10 | Hey guys is there anyway to repair imei without root such as g900a g900t n910a n910t and so on. Thanks |
The Following User Says Thank You to njdevil90 For This Useful Post: |
05-07-2015, 07:04 | #13543 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Samsung B5330 flash done. Operation: Flash Selected model: GT-B5330 Software version: 20.5 File analysis... OK Total file size: 0x323A210D (803 Mb) Searching USB Flash Interface... detected COM11 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.md5... OK Sending boot.img.md5... OK Sending recovery.img.md5... OK Sending BcmCP.img.md5... OK Sending system.img.md5... OK Sending dt-blob.md5... OK Sending param.lfs.md5... OK Sending cache.img.md5... OK Sending hidden.img.md5... OK Flashing done (time - 00:04:11) Done with Samsung Tool v.20.5 |
05-07-2015, 10:17 | #13544 (permalink) |
Freak Poster Join Date: Jun 2012 Location: valencia spain
Member: 1770619 Status: Offline Sonork: 100.1619675 Thanks Meter: 44 | i9305 4.4.4 unlock done Operation: Unlock Selected model: GT-I9305 Selected port: COM42 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: 35629xxxxxxxxxx Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.20.5 |
05-07-2015, 11:09 | #13545 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung E1270 Firmware write done... :d Selected model: E1270 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM24 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1270_ 7-5-2015_10-3-27.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:01:07) Done with Samsung Tool v.18.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
