08-31-2010, 12:55 | #1441 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Selected com port: COM64 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3050VIID2 IMEI: 35337203084269 MSL DEACTIVATED - TRUE Set default customer - fail Set default customer - fail Unlock - fail Unlock - false Elapsed time: 30 second, sw ver: 3.4.0065 ------------------------------------------------------------------------------- Selected model: C3050 Selected com port: COM64 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: 050VIID2 Langpack: Not found langpack ! IMEI: 35337203084269 S/N: RS5S767632 HW-> MP 0.300 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 887e0000 Flash size: 67108864 Bytes Flash sectors: 256 sectors Bluetooth ID: 002567-3a7bbb Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Calculated code please wait Decrypted time: 66 sec [PCK]:#0141*00000000# [NCK]:#0111*80082437# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*25574250# Read info - ok Elapsed time: 84 second, sw ver: 3.4.0065 ------------------------------------------------------------------------------- |
08-31-2010, 14:45 | #1442 (permalink) | |
Product Manager Join Date: Nov 2005 Location: WWW
Member: 199768 Status: Offline Thanks Meter: 16,170 | Quote:
use latest SW | |
08-31-2010, 16:30 | #1443 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Be or no to be
Member: 1233100 Status: Offline Thanks Meter: 17 | samsung s5230w Selected model: S5230W Selected com port: COM18 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Model: GT-S5230W CountryCode: AMN Factory SW: S523WBNJE1 UniqueNumber: 55770000540315 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35868103459xxxxx /x Phone S/N: RPMZ871730 Phone Bluetooth ID: F4 9F 54 2A AE 92 Phone SW: S523WBNJE1 Phone HW: MP 0.220 Phone CalData ver: 20100814 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:84973827 [NET LOCK]:46202850 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 41 sec Elapsed time: 55 second, sw ver: 3.4.0065 |
08-31-2010, 17:07 | #1444 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Code: Selected model: C6620 Selected com port: COM96 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6620XXIC2 [Unique number]:60380000015452 [IMEI]:357167xxxxxxxxxxx [Serial number]:R1VS320702 Start Bruteforce Msl code detected: 500025 Unlock - ok Elapsed time: 9622 second, sw ver: 3.4.0064 |
08-31-2010, 21:42 | #1445 (permalink) |
Freak Poster Join Date: Feb 2009 Location: spain
Member: 980172 Status: Offline Thanks Meter: 85 | hard to unlock .but finaly unlocked Model: GT-S3370 CountryCode: YOG Factory SW: S3370REJE2_YOGJE3 UniqueNumber: 74050001886801 MemoryPhone: K522H1HACC(S3370)S IMEI: 3586630xxxxxxx Phone S/N: R2XZ540290 Build: Q6270B-KPVZL-1.5.55011ST Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:01:03) Freeze code: 51648640 NET lock: #7465625*638*53814603# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# |
09-01-2010, 06:35 | #1446 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | A877 from USA AT&T unlock done. Model: SGH-A877 CountryCode: ATT Factory SW: UCID3 UniqueNumber: 80650000678852 MemoryPhone: KAV00500FM(A877) IMEI: 35701103683027/7 Phone S/N: RUDSB38630 Build: M6290A-KPMZL-1.2.003503T Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:01:11) Freeze code: 04642517 NET lock: #7465625*638*68468147# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# |
09-01-2010, 09:48 | #1447 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2010 Location: gsm hospital
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | samsung E2121B unlock done wth 52 seconds Selected model: E2121B Selected com port: COM55 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 52 second, sw ver: 3.4.0066 |
09-01-2010, 09:56 | #1448 (permalink) |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | samsung C3050 unlock done wth 23 seconds Selected model: C3050 Selected com port: COM55 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3050XXIH4 IMEI: 35247704319864 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 23 second, sw ver: 3.4.0066 |
09-01-2010, 10:00 | #1449 (permalink) |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | samsung E1360 unlock done wth 32 seconds Selected model: E1360B Selected com port: COM55 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35191303530463 Phone SW: E1360BBVID1 Phone BT ADDR: A007-98-3E4EF3 Phone SN: RPBSA78843 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 32 second, sw ver: 3.4.0066 |
09-01-2010, 10:07 | #1450 (permalink) |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | samsung E1120 unlock done wth 17 seconds Selected model: E1120 Selected com port: COM55 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35805403468295 Phone SW: E1120BVID1 Phone BT ADDR: 0000-00-000000 Phone SN: RU4SC30341 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 17 second, sw ver: 3.4.0066 |
09-01-2010, 10:46 | #1451 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | Samsung A177 unlocking done Selected model: A177 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35261704022506 Phone SW: A177UCIC3 Phone BT ADDR: E8E5-D6-73F1D4 Phone SN: RPIZ691792 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 26 second, sw ver: 3.4.0065 |
09-01-2010, 13:13 | #1452 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Selected model: J700I Selected com port: COM64 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35983702347939 Phone SW: J700iVJIE2 Phone BT ADDR: A8F2-74-B6298E Phone SN: RS6Z392622 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 19 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-01-2010, 13:14 | #1453 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | ------------------------------------------------------------------------------- Selected model: E1075 Selected com port: COM64 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35258203284763 Phone SW: E1075UTIA1_ Phone BT ADDR: 0000-00-000000 Phone SN: RSBS611711 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 19 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-01-2010, 14:08 | #1454 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Selected model: J700I Selected com port: COM64 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35983702347939 Phone SW: J700iVJIE2 Phone BT ADDR: A8F2-74-B6298E Phone SN: RS6Z392622 Deactivated MSL - TRUE Write imei - ok Repair - ok Elapsed time: 25 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-01-2010, 15:22 | #1455 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Selected model: M2520 Selected com port: COM12 Selected speed port: USB Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: M2520VIIH3 IMEI: 35820403271593 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 19 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
