Old 11-19-2015, 02:44   #14881 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Write CERT
Selected model: SM-G900P
Selected port: COM43 SAMSUNG Mobile USB Serial Port
Software version: 23.2
Checking certificate file... OK
KEY ID: 0478
Waiting ADB device... OK
Reading phone info...
Model: SM-G900P
Android version: 5.0
Product code: Not Active
Phone version: G900PVPU3BOF6
PDA version: G900PVPU3BOF6
CSC version: G900PSPT3BOF6
CSC country code: USA
CSC sales code: SPR
HW version: G900P.04
Phone S/N: 00000000000
Modem board: MSM8974PRO
RF cal date: 2014.10.26
IMEI:
Initialization AT RIL... OK
Bypass SPC... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0478
Writing CERT... OK
Checking CERT status... OK
Rebooting phone... OK
Done with Samsung Tool PRO v.23.2
Operation: Unlock
Reading IMEI... OK
IMEI: 990004476159656
Reading security... new type
Bypassing... OK
Unlocking... OK
Reseting... OK
Unlock done
Operation: Unlock SPRNT
Model: SM-G900P
CSC sales code: SPR
IMEI:
Unlocking... OK
Unlock done
Old 11-19-2015, 08:20   #14882 (permalink)
Member: 1785765
Sonork: 100.1654028
Thanks Meter: 22
Welcome to Octoplus/Octopus Box Samsung software version 2.1.1
To connect SM-G530H phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Restart phone.
11. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: SM-G530H
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM22
Phone connection failed
Connecting to phone on COM23
Mode: Normal
Phone model: SM-G530H
Firmware compiled date: May 07 2015
Firmware compiled time: 21:00:00
Firmware released date: May 14 2015
Firmware released time: 09:56:34
Phone IMEI: 352832-07-703473-4
SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM-1.19727.1
Selected port: COM23
Reading info...
Mode: Normal
SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM-
1.19727.1
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: SM-G530H
Firmware compiled date: Fri May 15 09:25:04 KST 2015
PDA version: G530HXCU1AOE2
CSC version: G530HOJV1AOF1
SW version: G530HXCU1AOE2
Phone IMEI: 3528320********
Phone SN: R51G90WVKLW
Android version: 4.4.4 (KTU84P)
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as Security-SM-G530H-19-11-2015_13-14-45 file
Unlocking phone...
Phone will restart now. Please don't disconnect cable!
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu.
Old 11-19-2015, 11:53   #14883 (permalink)
shaikh_shoeb50's Avatar
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 154
S6 Edge G925i Unlock Done...Via Read Code
S6 Edge G925i Unlock Done...With Samsung Pro...
Operation: Read Codes
Selected model: SM-G925I
Software version: 23.3
Checking hash file... OK
Model: SM-G925I
Android version: 5.0.2
Product code: SM-G925IZDAKSA
Phone version: G925IDVU1AOD2
PDA version: G925IDVU1AOD1
CSC version: G925IKSA1AOD1
CSC country code: KSA
CSC sales code: KSA
HW version: MP 0.700
Phone S/N: R58G61X52MM
Modem board: SHANNON333
RF cal date: 20150624
IMEI:
Checking Super user right... true
Initializating zTool... OK
Running zTool, please wait... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:05)
Freeze code: 61490485
NET lock: 85818528
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.23.3
Thanks Z3X Team...!!!
Old 11-19-2015, 15:32   #14884 (permalink)
Member: 1092417
Sonork: 100.1645946
Thanks Meter: 45
GT-S6810 "Unfortunately Stopped..." Solved By Flash With Z3X PRO v23.4
FLASH INSTRUCTIONS:
  1. Choose correct flash file(s).
  2. If you have PIT file chosen, then you must check 'Repartition' option.
  3. If you have one file firmware, then you must check 'Use one package file' option.
  4. Check flashing options if needed (Repartition, EFS clear, Boot update).
  5. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power).
  6. Connect phone to PC with USB cable, install drivers if needed.
  7. Press 'Flash' button.
Operation: Flash
Selected model: GT-S6810
Software version: 23.4
File analysis... OK
Total file size: 0x3598D9D5 (857 Mb)
Searching USB Flash Interface... detected COM45
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending BcmCP.img... OK
Sending cache.img... OK
Sending system.img... OK
Sending hidden.img... OK
Sending dt-blob... OK
Sending param.lfs... OK
Flashing done (time - 00:05:00)
Done with Samsung Tool PRO v.23.4
Old 11-20-2015, 13:03   #14885 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Samsung e2210 unlocked done
Selected model: E2210
Selected com port: COM10
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone IMEI: 352502037xxxxx
Phone SW: E2210BBGIG1
Phone BT ADDR: A007-98-A3BDCB
Phone SN: RQ6SA15528
Deactivated MSL - TRUE
[FREZEE]: 34892310
[NET Lock]: 34068980
[Subset Lock]: 00000000
[SP Lock]: 00000000
[CP Lock]: 00000000
[Sim Lock]: 00000000
[Phone Lock]: 00011234
Read info - ok
Old 11-20-2015, 14:44   #14886 (permalink)
Member: 1092417
Sonork: 100.1645946
Thanks Meter: 45
SM-G531H NETWORK LOCK CODE READ DONE!
Old 11-20-2015, 17:31   #14887 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 95
Unlock and imei succesful on oj5
I dont know why people do this but here goes...lol
Selected model: SM-G928T
Model: SM-G928T
Android version: 5.1.1
Product code: SM-G928TZDETMB
Phone version: G928TUVU2COJ5
PDA version: G928TUVU2COJ5
CSC version: G928TTMB2COJ5
CSC sales code: TMB
HW version: REV1.0
Phone S/N: R58GA0RZGQF
RF cal date: 20151008
IMEI:
KEY ID: 0784
Calculating... OK
Writing nv data... OK
Write CERT done
Old 11-21-2015, 05:40   #14888 (permalink)
mr.luckytarun's Avatar
Member: 1195083
Sonork: QQ:3208821449
Thanks Meter: 1,348
GT-S7562 flash done
[IMG][/IMG]
Old 11-21-2015, 09:52   #14889 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
G361H 5.1.1 RESET FRP LOACK DON
Old 11-21-2015, 11:49   #14890 (permalink)
Member: 284336
Thanks Meter: 52
Selected model: SM-G928C
Model: SM-G928C
Product code: SM-G928CZDAKSA
Phone version: G928FXXU2AOJ3
PDA version: G928CXXU2AOJ5
CSC version: G928COJP2AOJ5
CSC sales code: KSA
HW version: MP 0.500
Phone S/N: R58G71XYYEV
RF cal date: 20150731
IMEI:
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:06)
Freeze code: 83080841
NET lock: 31481427
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 11-21-2015, 20:24   #14891 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Model: SM-G928T
Product code: SM-G928TZDATMB
CSC sales code: TMB
HW version: REV1.0
Phone S/N: R58G81KCPFE
RF cal date: 20150820
IMEI:
KEY ID: 0784
Calculating... OK
Write CERT done
Operation: Unlock
Model: SM-G928T
CSC sales code: TMB
HW version: REV1.0
IMEI:
Calculating... OK
Unlock done
Old 11-22-2015, 10:36   #14892 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 279
Arrow C3303 Read codes done 2G TOOL
C3303 read codes done Z3X 2g tool , used cable C3300K .
The Following User Says Thank You to Safyan sufi For This Useful Post:
Old 11-22-2015, 10:38   #14893 (permalink)
.:Zulfiqar:.'s Avatar
Member: 1224733
Thanks Meter: 158
l600 unlocked
Operation: Unlock
Selected model: SPH-L600
Selected port: COM33 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 990004356040679
Bypassing... OK
Unlocking... OK
Reseting... OK
Unlock done
The Following User Says Thank You to .:Zulfiqar:. For This Useful Post:
Old 11-22-2015, 10:40   #14894 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
i747m unlock
  UNLOCK INSTRUCTIONS:
     Micro-USB cable:
  1. Phone must be powered on.
  2. Type *#0808# and select 'DM+MODEM+ADB'.
  3. Type *#9090# and choose USB (or 'DM/DUN over HSIC').
  4. Reboot phone.
  5. Connect USB cable, install drivers if needed.
  6. Select Samsung diagnostic port in port settings.
  7. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: SGH-I747M
Selected port: COM511 SAMSUNG Mobile USB Serial Port ,
Software version: 20.0
Reading IMEI... OK
IMEI: 354524053096880
Reading security... error
Detected new type of security
Bypassing... OK
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool v.20.0
Old 11-22-2015, 10:41   #14895 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
T399n network repair
  REPAIR INSTRUCTIONS:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
     tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Fill values what you need to repair.
  5. Press 'Repair' button.
  6. Press 'Reset EFS' if you need to reset it.
     Be carefully, do not perform this without necessity and make backup before.
  7. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed.
Operation: Patch Certificate
Selected model: SGH-T399N
Model: SGH-T399N
Android version: 4.4.2
Product code:
Phone version: T399NUVUANK3
PDA version: T399NUVUANK3
CSC version: T399NTMBANK3
CSC sales code: TMB
HW version:
Phone S/N: RV8G11FF92T
Modem board: SS222
RF cal date:
IMEI: 350695200123951
Reading modem... OK
Patching modem... OK
Writing modem... OK
Patching CERT check... done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.40109 seconds with 11 queries
