02-26-2019, 14:57 | #468 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SM-J327P Software version: 34.11 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 PDA version: J327PVPU3AQJ3 CSC version: J327PSPT3AQJ3 Phone version: J327PVPU3AQJ3 Product code: Not Active CSC country code: USA CSC sales code: XAS Phone SN: 00000000000 IMEI: 3525100xxxxxx HW version: J327P.03 RF cal date: 2017.11.28 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2017-08-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Searching Samsung diag port... detected COM1046 Writing data to phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.11 |
02-26-2019, 17:14 | #469 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Zimbabwe
Member: 2524486 Status: Offline Thanks Meter: 112 | SAMSUNG SM-A510F SUCCESFULLY REPAIRED NETWORK REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-A510F Software version: 34.11 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 7.0 Product code: SM-A510FEDFXSG Phone version: A510FDXXU7CRJA PDA version: A510FXXS7CSA4 CSC version: A510FDOJP7CRK1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.000 Phone SN: R58H62QYGLN Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2019-01-01 RF cal date: 20160618 IMEI: 357766076384374 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.34.11 |
02-27-2019, 11:36 | #474 (permalink) |
Freak Poster Join Date: Mar 2017 Location: south africa
Member: 2696842 Status: Offline Sonork: 100.1683002 Thanks Meter: 296 | Waiting ADB device... OK Reading phone info... Model: SM-A320FL Android version: 8.0.0 PDA version: A320FLXXU3CRH2 CSC version: A320FLHUI3CRH1 Phone version: A320FLXXU3ARI1 Product code: SM-A320FZKNHUI CSC country code: ITALY CSC sales code: HUI Phone SN: RF8J91DPDTK IMEI: 359751089950625 HW version: MP 0.300 RF cal date: 20170913 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-08-01 Boot Warranty bit: 0 SIM State: ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 57 05 00 00 00 00 00 00 00 00 00 00 7C 5F B5 29 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done |
02-27-2019, 14:31 | #475 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung SM-G935T (U4) Remove FRP Lock Done :) Code: UNLOCK INSTRUCTIONS: To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G935T Software version: 34.11 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash interface... COM233 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935T Android version: 6.0.1 PDA version: G935TXXU4API3 CSC version: G935FVZW4API3 Phone version: Product code: CSC country code: USA CSC sales code: XSG Phone SN: R38H7014MBB IMEI: HW version: RF cal date: Chip name: MSM8996 Modem board: Security patch: 2016-10-01 Boot Warranty bit: 0 Checking Super user right... true Erasing FRP... OK Restore original kernel? Yes Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.34.11 |
02-27-2019, 14:36 | #476 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung SM-G532F Write Firmware Done :) Code: Operation: Flash Selected model: SM-G532F Software version: 34.11 File analysis... OK Total file size: 0xC46B3B9F (3142 Mb) Searching USB Flash interface... COM233 detected Setup connection... OK Reading PIT from phone... OK Sending preloader.img... OK Sending lk.bin... OK Sending param.bin... OK Sending trustzone.bin... OK Sending efuse.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending secro.img... OK Sending userdata.img... OK Sending md1rom.img... OK Sending md1dsp.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:14) |
02-27-2019, 14:59 | #477 (permalink) |
Freak Poster Join Date: Jul 2012 Location: IRAN
Member: 1780733 Status: Offline Sonork: 100.1624035 Thanks Meter: 15 | Operation: Reset FRP/React/EE Selected model: SM-J500H Selected port: COM8 Z3X BOX Serial Port Software version: 34.6 Searching Samsung USB Flash interface... COM67 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done Done with Samsung Tool PRO v.34.6 |
02-27-2019, 17:16 | #478 (permalink) |
Registered User Join Date: Jul 2006 Location: <<SearcH EnginE>>
Member: 307373 Status: Offline Sonork: paypal.me/div859 Thanks Meter: 590 | SM-J610FN unlock done Reading phone info... Model: SM-J610FN Android version: 8.1.0 PDA version: J610FNXXU1ARIO CSC version: J610FNOXM1ARIO Phone version: J610FNXXU1ARIO Product code: SM-J610FZKNXEO CSC country code: Poland CSC sales code: XEO Phone SN: R58KB2JD50B IMEI: 352985104140252 HW version: REV0.5A RF cal date: 2018.11.10 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM47 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 64268295 NET lock: 05061393 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.11 |
02-27-2019, 23:13 | #479 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Pakistan/Canada/UK
Member: 2769072 Status: Offline Thanks Meter: 126 | S8 Sprint Bit 5 Unlock Done UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G935P Software version: 34.11 Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 7.0 PDA version: FA70_G950USQU5ARG4 CSC version: Phone version: G950USQU5CRF1 Product code: SM-G950UZKASPR CSC country code: CSC sales code: Phone SN: R28J82KA7CA IMEI: 35598208xxxxxxx HW version: REV1.0 RF cal date: 2017.08.17 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-02-01 Boot Warranty bit: 0 Incorrect model selected. This may damage your phone. Continue? Yes Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.11 |
The Following User Says Thank You to Rem0teunl0ck For This Useful Post: |
02-28-2019, 12:00 | #480 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | SM-G532F Remove FRP Lock Done :) Code: Operation: Reset FRP Selected model: SM-G532F Software version: 34.11 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 Phone version: G532FXXU1AQB3 Product code: SM-G532FZKDPAK CSC country code: PAKISTAN CSC sales code: PAK Phone SN: R58J56VP7FT IMEI: 357953089064868 HW version: MP 0.300 RF cal date: 20170530 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.34.11 |
