-   Z3X-Team Products (http://forum.gsmhosting.com/vbb/f453/)
-   -   Post here successfully job with Z3X-BOX Samsung (2018-2019) (http://forum.gsmhosting.com/vbb/f453/post-here-successfully-job-z3x-box-samsung-2018-2019-a-2514647/)
gsmshafait 08-18-2015 16:07
Samsung sgh-x460 unlock done by z3x
SGH-X460 UNLOCK DONE BY Z3X
http://www.4shared.com/download/8ez4....jpg?lgfp=1000
Connect PHONE BY E700 CABLE
CLICK READ INFO
BR,
GSM-SHAFAIT
josuan 10-07-2015 14:59
N920T repair succeed done
Operation: Write CERT
Selected model: SM-N920T
Software version: 22.8
Waiting ADB device... OK
Reading phone info...
Model: SM-N920T
Android version: 5.1.1
Product code: SM-N920TZKATMB
Phone version: N920TUVU1BOH4
PDA version: N920TUVU1BOH4
CSC version: N920TTMB1BOH4
CSC country code: USA
CSC sales code: TMB
HW version: REV0.2
Phone S/N: RF8G724HKCL
Modem board: SHANNON333
RF cal date: 20150727
IMEI:
Checking Super user right... true
Checking certificate file... OK
KEY ID: 0448
Initializating zTool... OK
Running zTool, please wait... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Writing nv data... OK
Rebooting phone... OK
Write CERT done
Done with Samsung Tool PRO v.22.8
virtue 10-07-2015 16:58
Where is the cert file ?
Deni's 01-15-2016 02:10
SM-J100Y unlock DONE
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 00000000
Operation: Unlock
Selected model: SM-J100Y
Software version: 24.1
Model: SM-J100Y
Android version: 4.4.4
Product code: SM-J100YZWAOPP
Phone version: J100YDXU0AOC1
PDA version: J100YDXU0AOC1
CSC version: J100YOPP0AOC1
CSC country code: Australia
CSC sales code: OPP
HW version: MP 0.100
Phone S/N: R28GA3EKQAL
Modem board:
RF cal date: 20151029
IMEI: 358926061661041
Analysing SEC file... OK
Initialization AT RIL... OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.24.1
thankz Z3X Team
earth2345 02-09-2016 00:42
SM-N910T 5.1.1 write cert done..
KEY ID:****
Please, allow USB debugging on phone... OK
Model: SM-N910T
Product code: SM-N910TZWATMB
Phone version: N910TUVU2DOK2
PDA version: N910TUVU2DOK2
CSC version: N910TTMB2DOK2
CSC sales code: TMB
HW version: REV1.1
Phone S/N:********
Modem board: *******
RF cal date: 2015.10.05
IMEI:
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: *****
Writing CERT... OK
Checking CERT status... OK
Done with Samsung Tool PRO v.24.2 :D:D:D
PlayGsm 03-17-2016 14:04
G928F Unlock done Z3X
G928F S6 edge plus 5.1.1 UNLOCK DONE With Z3x
PROCEDURE
1. ENABLE OEM
2. DOWNLOAD Root File
https://www.4shared.com/file/NY3tPIy...KLSI-ODIN.html
3. Put Phone to DOWNLOAD MODE
4. Open Odin3_v3.10.6 and select root file
After root unlock via Z3x
https://dc780.4shared.com/img/WT-cPr...8/IMG_2949__1_
https://www.4shared.com/account/home.jsp#dir=UzWtJeah
khassene01 03-21-2016 13:29
unlock is ok after root 5.0.1 thank you men
GSM SNIPER 04-22-2016 17:10
does any one tested it?
GSM SNIPER 04-22-2016 17:12
try to read IMEI ? is-it good?
sr8787 07-01-2016 04:15
Samsung Galaxy S SC-02B IMEI Repair Done
Samsung Galaxy S SC-02B IMEI Repair Done With z3x
In my Set No IMEI After update
but with the help of z3x Box All Done
1. Flash with z3x this firmwre SC02BOMKL4_SC02BDCMKL4 (Download From support Area)
2. After Flash IMEI ok automatic. But not Registered on Network
3 Now write Modem file "Modem_SC02BOMJJ1_patched.zip" file (download From Support Area)
And All Done :)
Thanks z3x Team
zangoako 08-06-2016 10:55
Samsung G928F unlock done 100%
Searching Samsung modem... detected COM508
Reading phone info... OK
Model: SM-G928F
AP Version: G928FXXS2BPG1
CSC Version: G928FOXX2BPF1
CP Version: G928FXXU2BPE6
Product code: SM-G928FZDATPH
Phone S/N: RF8GB2JXWXH
Imei: 354750074186851
Unique number: 0915F9D9E2D72704
Reading data from phone... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.3.1
A phone must be root! You can root with cf auto root
souma_k 08-06-2016 18:12
Model: SM-G928F
Unlocking... OK
Unlock done
No need for root if you direct unlock
jordachi 08-16-2016 09:39
samsung g828f unlock
Yes but unlock without root :
Directly unlock with read codes not work
Searching Samsung modem... detected COM89
Model: SM-G928F
AP Version: G928FXXS2BPG2
CSC Version: G928FVFG2BPB6
CP Version: G928FXXU2BPF1
Product code: SM-G928FZDACNX
Phone S/N: R58G80F4X1R
Imei: xxxxxxxxxxxxxx
Unique number: xxxxxxxxxxxxx
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.4
Salman725626 06-15-2017 12:15
Samsung G925f DRk Repair Done With great Z3x Box
REPAIR INSTRUCTIONS:
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Repair DRK
Selected model: SM-G925F
Software version: 28.2
Checking local file... Ok
Searching server... Ok
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM4 detected
Setup connection... Ok
Reading data from phone... Ok
Sending data to phone... Ok
Waiting ADB device... Ok
Recovery build version: 6.0.1
Boot version: G925FXXU5DQD3
Platform: exynos7420
Boot serial: 01157df18a9b6119
Product board: zerolte
Initialization zTool... Ok
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Checking DRK status... NG!
Writing DRK... Ok
Repairing DMVT key... Ok
Rebooting phone... Ok
Repair DRK done
Done with Samsung Tool PRO v.28.2
nayan sarder 06-28-2017 14:27
samsung sm-g570y unlock done
Operation: Unlock
Selected model: SM-G570Y
Software version: 28.1
Model: SM-G570Y
Android version: 6.0.1
Product code: SM-G570YWDDXME
Phone version: G570YDXU1APK2
PDA version: G570YDXU1APL4
CSC version: G570YOLB1APL2
CSC country code: MALAYSIA
CSC sales code: XME
HW version: MP 0.500
Phone SN: R58J56MDXBA
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2016-12-01
RF cal date: 20170529
IMEI:
Reading NV data... Ok
Checking NV data... Ok
Reading data... error
Security damaged (4 23)
Start... Ok
HWID: 59 CA 97 6F 95 15 C6 84 E8 8D F8 6B 0A 00 00 00
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Unlock done
Done with Samsung Tool PRO v.28.1
Page generated in 0.37381 seconds with 5 queries
