12-31-2018, 09:13 | #226 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung e120s flash done SAMSUNG E120S FLASH DONE FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SHV-E120S Software version: 34.6 File analysis... OK Total file size: 0x32D99B30 (813 Mb) Searching USB Flash interface... COM66 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending amss.bin... OK Sending mdm.bin... OK Flashing done (time - 00:03:39) Done with Samsung Tool PRO v.34.6 |
12-31-2018, 09:15 | #227 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung j200f frp reset done SAMSUNG J200F FRP RESET DONE Operation: Reset FRP/React/EE Selected model: SM-J200F Software version: 33.5 Searching Samsung USB Flash interface... COM34 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.5 |
12-31-2018, 09:20 | #228 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Sasmsung s8 flash g955f frp reset done SASMSUNG S8 FLASH G955F FRP RESET DONE FIRST FLASH COMBINATION FILE THEN FLASH 4 FRIMWARE SLECT ONLY ....BOOT ,,PDA,,,CSC FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G955F Software version: 34.6 File analysis... OK Total file size: 0xFF06345E (4080 Mb) Searching USB Flash interface... COM66 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending up_param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending cache.img.lz4... OK Flashing done (time - 00:03:56) Done with Samsung Tool PRO v.34.6 |
12-31-2018, 09:20 | #229 (permalink) |
12-31-2018, 09:26 | #232 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung note n900 flash done SAMSUNG NOTE N900 FLASH DONE FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-N900 Software version: 27.5 File analysis... Ok Total file size: 0x8CAF038C (2250 Mb) Searching USB Flash interface... COM66 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:03:40) Done with Samsung Tool PRO v.27.5 |
12-31-2018, 10:41 | #233 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Sm-j610fn unlock done Code: UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J610FN Software version: 34.6 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J610FN Android version: 8.1.0 PDA version: J610FNXXU1ARIO CSC version: J610FNOXM1ARIO Phone version: J610FNXXU1ARIO Product code: SM-J610FZKNXEF CSC country code: France CSC sales code: XEF Phone SN: R58KA1JRVWX IMEI: 351765104001717 HW version: REV0.5A RF cal date: 2018.10.06 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM20 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 14857593 NET lock: 27408686 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.6 |
12-31-2018, 13:55 | #234 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | SAMSUNG XCOVER 3 NETWORKUNLOCK Waiting ADB device... OK Reading phone info... Model: SM-G389F Android version: 6.0.1 PDA version: G389FXXU1ARF2 CSC version: G389FVFG1ARF2 Phone version: G389FXXU1ARF2 Product code: SM-G389FDSAVOD CSC country code: UK CSC sales code: VOD Phone SN: R58H713APTE IMEI: 358XXXXXXXXXXX HW version: MP 0.100 RF cal date: 20160708 Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2018-06-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... OK HWID: C5 ED 1E 2F F1 C2 4D E5 66 93 8A 39 CC AD 43 7C Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.6 |
01-01-2019, 14:28 | #236 (permalink) |
No Life Poster Join Date: Aug 2005 Location: EL-BALOUTE Age: 48
Member: 168513 Status: Offline Thanks Meter: 838 | SM-J730f successfully unlocked hello !!! i tried to root phone,unfortunately i have damaged warrany . WARRANTY VOID: 1 (0x030c)) finally Z3X took care of it all !! LOG: Code: Operation: Read Codes via Server Selected model: SM-J730F Software version: 34.6 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J730F Android version: 8.1.0 PDA version: J730FXXU3BRI3 CSC version: J730FITV3BRI4 Phone version: J730FXXU3BRI3 Product code: SM2J730FZKDITV CSC country code: ITALY CSC sales code: ITV Phone SN: R58K54VVQSZ IMEI: 35620409841**** HW version: MP 0.500 RF cal date: 20180525 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-08-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... OK KNOX WARRANTY VOID is 0x1. Available CP file for downgrade, try download and flash? Continue? Yes Downloading file... OK Checking local file... OK Switching to flash mode... OK Searching USB Flash interface... COM3 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 15713084 NET lock: 85282759 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.6 |
01-02-2019, 08:51 | #237 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | J730F touch not working after update to 8.1 U3 FIX DONE Samsung SM-J730F after update 8.1.0 touch not work U3 touch Fix Firmware Just flash it BL AP CSC FLASH FILE https://androidfilehost.com/?fid=132...s9VDdMunlsYQHs FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J730F Software version: 34.6 File analysis... OK Total file size: 0xEC634052 (3782 Mb) Searching USB Flash interface... COM150 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:02:57) Done with Samsung Tool PRO v.34.6 |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
01-02-2019, 08:52 | #238 (permalink) |
01-03-2019, 08:14 | #239 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | J330FN Read code done Using server need 5 credits in Z3X Code: Operation: Read Codes via Server Selected model: SM-J330FN Software version: 34.6 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 8.0.0 PDA version: J330FNXXU3BRG2 CSC version: J330FNBTU3BRG2 Phone version: J330FNXXU3BRG2 Product code: SM-J330FZDNBTU CSC country code: UK & IRE CSC sales code: BTU Phone SN: R58KA4WQN1H IMEI: 351823107259608 HW version: MP 0.500 RF cal date: 20181019 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 53717170 NET lock: 31536196 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Sabah Mangattupulam |
The Following User Says Thank You to Abussabah For This Useful Post: |
01-03-2019, 10:32 | #240 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Kharian Age: 43
Member: 2826140 Status: Offline Sonork: 1644958 Thanks Meter: 103 | G920F Unlock Done Searching Samsung modem... detected COM25 Reading phone info... Model: SM-G920F AP version: G920FXXU3DPDP CSC version: G920FEVR3DPD1 CP version: G920FXXU3DPDP Product code: SM-G920FZKAEVR Phone SN: R58 IMEI: 3556 Unique number: 05157DF52BE70104 Reading IMEI... OK IMEI: 3556 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.6 |
The Following 2 Users Say Thank You to gsmkharian For This Useful Post: |
