Old 07-02-2017, 17:18   #16 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 713
G9005 unlocking done
SAMSUNG S5 G900F
COUNTRY CODE UNLOCKING DONE THANKS SOMUCH Z3X TEAM
The Following User Says Thank You to farooquepm For This Useful Post:
Old 07-10-2017, 06:30   #17 (permalink)
Member: 1860703
Sonork: 100.1641707:shahid
Thanks Meter: 35
g920t version naugat 7.0 unlock done
Operation: Unlock
Selected model: SM-G920T
Software version: 28.6
Waiting ADB device... OK
Reading phone info...
Model: SM-G920T
Android version: 7.0
Product code: SM2G920TZWATMB
Phone version: G920TUVU5FQE1
PDA version: G920TUVU5FQE1
CSC version: G920TTMB5FQE1
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R58G51D2YWF
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-05-01
RF cal date: 20150520
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Initialization zTool... OK
Running zTool, please wait... OK
HWID: 88 11 D1 77 35 04 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.28.6
The Following User Says Thank You to shahid. For This Useful Post:
Old 07-18-2017, 11:47   #18 (permalink)
Member: 2730724
Thanks Meter: 2
Originally Posted by shahid. View Post
Operation: Unlock
Model: SM-G920T
CSC sales code: TMB
HW version: REV1.0
IMEI:
Calculating... OK
Unlocking... OK
Unlock done
can yu plz explain how yu rooted it
Old 07-23-2017, 09:45   #19 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 361
  UNLOCK INSTRUCTIONS:
    New Securiry Type:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
  6. Press 'Read codes' button and select 'Read codes New' to read security codes.
    Old Securiry Type:
  2. Connect the phone to PC with USB cable.
  3. Check Samsung modem in device manager, install drivers if needed.
  4. Press 'Unlock' button and select 'Unlock' for direct unlock.
  5. Press 'Read codes' button and select 'Read codes' to read security codes.
   To reset Google account activation or Samsung reactivation lock:
  1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
  2. Connect the phone to PC with USB cable, install drivers if needed.
  3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
  4. After phone reboot, go to settings and perform factory reset.
Operation: Unlock
Selected model: SM-G925T
Model: SM-G925T
Product code: SM-G925TZKFTMB
Phone version: G925TUVS5FQG1
PDA version: G925TUVS5FQG1
CSC version: G925TTMB5FQG1
CSC sales code: TMB
HW version: REV0.2
Phone SN: R58G31D340V
Security patch: 2017-07-01
RF cal date: 20150318
IMEI:
HWID:  08 E7 D4 CF D6 06 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Unlocking... OK
Unlock done
Root method here:
https://forum.xda-developers.com/app...mless-t3473445
The Following User Says Thank You to galijus For This Useful Post:
Old 09-15-2017, 16:40   #20 (permalink)
Member: 1488173
Thanks Meter: 184
good solution but not so much, because is temporary solution, if you reflash the device with new os, problem appear again...
Old 10-19-2017, 21:25   #21 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,408
Arrow Sm-g930a unlock done
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
Operation: Read Codes via Server
Selected model: SM-G930A
Selected port: COM669 SAMSUNG Mobile USB Serial Port
Software version: 29.5
Checking Login and Password... OK
Ballance: 15 crd.
Please, allow USB debugging on phone... OK
Model: SAMSUNG-SM-G930A
Product code: SM-G930AZKAATT
Phone version: G930AUCS4BQE1
PDA version: G930AUCS4BQE1
CSC version: G930AATT4BQE1
CSC sales code: ATT
HW version: REV0.6
Phone SN: R58J42HZE1L
Chip name: MSM8996
Modem board: MSM8996
RF cal date: 2017.04.12
IMEI: 35XXXXXXXXXXXXXX
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM5 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 95730636
NET lock: 85020704
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.29.5
The Following User Says Thank You to ghacks For This Useful Post:
Old 10-31-2017, 15:20   #22 (permalink)
Member: 2682425
Thanks Meter: 60
successfully Remove Frp From G531H
Thanks
Searching Samsung USB Flash interface... COM85 detected
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 11-05-2017, 19:58   #23 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,408
SM-N950U read codes done
Selected model: SM-N950U
Software version: 29.6
Ballance: 5 crd.
Model: SM-N950U
Android version: 7.1.1
Product code: SM-N950UZKAATT
Phone version: N950USQU1AQIA
PDA version: N950USQU1AQIA
CSC version: N950UOYN1AQIA
CSC sales code: ATT
HW version: REV1.0
Phone SN: R38J906S88B
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-08-01
RF cal date: 2017.09.09
IMEI: 350000000xxxxxxxxxxxx8
Start... OK
Searching Ramdump interface... COM49 detected
Calculating... OK
Freeze code: 83839748
NET lock: 84619693
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Done with Samsung Tool PRO v.29.6
The Following 2 Users Say Thank You to ghacks For This Useful Post:
Old 11-06-2017, 08:29   #24 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 139
plz tell me how did u root or tel me procedure plz
Old 11-06-2017, 08:38   #25 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 139
also want to unlock sprint SM-N950U plz tel me procedure
Old 11-06-2017, 11:48   #26 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 522
read codes with server doesn't need root
The Following User Says Thank You to THE GREAT ONE For This Useful Post:
Old 11-06-2017, 14:30   #27 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,408
Thumbs up for the info
root the phone selected model sprint unlock the phone
Model: SM-N950U
Product code: SM-N950UZVASPR
Phone version: N950USQU1AQH8
PDA version: FA71_N950USQU1AQH8
CSC version:
CSC country code:
CSC sales code:
HW version: REV1.0
Phone SN: R28J90R2K4T
RF cal date: 2017.09.07
IMEI:
Writing AT RIL... OK
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.29.2
https://mega.nz/#!8TBVQJqJ!VVK8EMogy...bCghyx-0ijrmvU
https://mega.nz/#!cXJGEC4Q!DAHl-s9li...W9UlfvW9Cp8nEo
Old 11-06-2017, 14:37   #28 (permalink)
sadamsoft's Avatar
Member: 2637339
Thanks Meter: 42
https://mega.nz/#!kM1ySRYT!TFO7QKtvC...QdEBp9aWmrhCE4
https://mega.nz/#!sYEnUCwB!dpd96ENI6...lY1FqbtMvBud08
Model: SM-N950U
CSC version:
CSC country code:
CSC sales code:
HW version: REV1.0
IMEI:
Unlocking... OK
Unlock done
Report Post
thank u bro good post
Old 11-06-2017, 14:51   #29 (permalink)
Member: 563008
Thanks Meter: 70
ghacks bro pls provide N950f eng root file if you have.thanks in advance
The Following User Says Thank You to pashamangl For This Useful Post:
Old 11-06-2017, 21:05   #30 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,408
Arrow bro
this file its a gold sorry i cannot find it..
Page generated in 0.21786 seconds with 8 queries
