01-23-2019, 03:20 | #331 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Software version: 34.8 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 PDA version: G955USQU5CRL2 CSC version: G955UOYN5CRL2 Phone version: G955USQU5CRF1 Product code: SM-G955UZVAATT CSC country code: USA CSC sales code: ATT Phone SN: R38J40F6P2J IMEI: 355979081360741 HW version: REV1.0 RF cal date: 2017.11.28 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-12-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 03068249 NET lock: 47386909 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-23-2019, 15:36 | #332 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | C5212i Reset User Lock Done :) Code: Selected model: C5212I_m Selected com port: COM38 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Phone IMEI -> 35715004355307 Phone SW -> C5212iJPKD Langpack-> Not found langpack ! Phone HW -> MP 0.300 Phone BT ADDR -> 8C77-12-E82E79 Phone WI-FI ADDR -> [NET LOCK]: [SIM LOCK]: [PHONE LOCK]: [SP LOCK]: Read Info - ok Elapsed time: 82 second, sw ver: 3.5.0040 Code: Selected model: C5212I_m Selected com port: COM38 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 143 second, sw ver: 3.5.0040 |
01-23-2019, 17:19 | #333 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Samsung G570 Hang and Restart Done By Flashing With Z3X Samsung G570 Hang and Restart Done By Flashing With Z3X Here are logs Youtube Link https://www.youtube.com/watch?v=f-jowceLXj8 |
01-23-2019, 17:29 | #334 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Armenia Yerevan
Member: 1559514 Status: Offline Thanks Meter: 49 | samsung g935f to fd u3 8.0.0 read write cert ok) Searching Samsung modem... detected COM106 Reading phone info... Model: SM-G935F AP version: FA60_G935FXXU3ARI2 CSC version: NONE CP version: G935FXXU3ARI1 Phone SN: 00000000000 IMEI: 358809077275404 Unique number: 9886733035585xxxx Reading IMEI... OK IMEI: 358809077275404 (SIGN: OK) Reading data from phone... OK Modem board: SHANNON335 HWID: 2A 6F A1 10 2B 02 5F 9A 03 DB 62 E2 C5 0B 3A CF Reading NV data... OK Checking NV data... OK Calculating... OK Certificate file saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-G935F_00000000000_35880907727xxx_23-1-2019_13-49-17.cert Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 PDA version: FA60_G935FXXU3ARI2 CSC version: Phone version: G935FXXU3ARI1 Product code: CSC country code: CSC sales code: Phone SN: RF8H337Mxxx IMEI: 000000000000000 HW version: RF cal date: Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-01-01 Boot Warranty bit: 1 SIM State: ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Modem board: SHANNON335 HWID: 2A 6F A1 10 2B 02 5F 9A 03 DB 62 E2 C5 0B 3A CF Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0445 Checking certificate file... OK KEY ID: 0445 Crypting CERT 1... OK Crypting CERT 2... OK Writing NV data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.34.8 |
01-23-2019, 22:35 | #335 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Samsung n9005 note 3 unlock DONT SKIP ANY STEP ENABLE USB DEBBUGGING TYPE *#*#0808*# EBABLE MTP +ADB OPEN Z3X REPAIRTAB>>>ENABLE DIAG PORT THIS WILL ENABLE DIAG PORT OPEN *#*#0808*# EBABLE MTP +ADB+DM INSTALL DIAGNOSTIC PORT Z3X >>UNLOCK TAB UNLOCK DONE Reading phone info... Reading IMEI... OK IMEI: 359093050259870 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.34.8 |
The Following User Says Thank You to jseyedanas For This Useful Post: |
01-24-2019, 09:56 | #336 (permalink) |
Freak Poster Join Date: Aug 2011 Location: india,punjab Age: 32
Member: 1644779 Status: Offline Thanks Meter: 454 | samsung galaxy note 5 SM-N920W8 network unlock done by z3x Operation: Read Codes Selected model: SM-N920W8 Selected port: COM4 Z3X BOX Serial Port Software version: 34.8 Waiting ADB device... OK Reading phone info... Model: SM-N920W8 Android version: 7.0 PDA version: N920W8VLS4CQG1 CSC version: N920W8OYA4CQG1 Phone version: N920W8VLS4CQG1 Product code: SM-N920WZKABMC CSC country code: Canada CSC sales code: BMC Phone SN: RF8GA0T1WLM IMEI: 353120xxxxxxxxx HW version: REV1.0 RF cal date: 20151008 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 48 72 BA 4F B7 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Please wait, generating hash codes file, this can take few minutes... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 60718072 NET lock: 95824047 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-24-2019, 10:08 | #337 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung g925a hong on logo done by z3x samsung g925a hong on logo done by z3x FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925A Software version: 34.8 File analysis... OK Total file size: 0x12FADD9D0 (4858 Mb) Searching USB Flash interface... COM54 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Flashing done (time - 00:05:43) Done with Samsung Tool PRO v.34.8 |
01-24-2019, 10:13 | #338 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung g925t convert to g925f done samsung g925t convert to g925f done FLASH INSTRUCTIONS: [/CENTER] 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925T Software version: 34.8 File analysis... OK Total file size: 0x8D7BC020 (2263 Mb) Searching USB Flash interface... COM54 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending cm.bin... OK Sending modem.bin... OK Sending recovery.img... OK Sending sboot.bin... OK Sending system.img... OK Flashing done (time - 00:02:47) Done with Samsung Tool PRO v.34.8 |
01-24-2019, 10:17 | #339 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung g28t flash done samsung g28t flash done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G928T Software version: 34.8 File analysis... OK Total file size: 0xF4E446B0 (3918 Mb) Searching USB Flash interface... COM54 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending modem.bin... OK Flashing done (time - 00:03:10) Done with Samsung Tool PRO v.34.8 |
01-24-2019, 12:07 | #340 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 551619 Status: Offline Thanks Meter: 136 | A750F Unlock Done : Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A750F Android version: 8.0.0 PDA version: A750FXXU1ARII CSC version: A750FOJM1ARII Phone version: A750FNXXU1ARIC Product code: SM-A750FZBGMID CSC country code: Iraq CSC sales code: MID Phone SN: RF8KXXXXXXX IMEI: 3534XXXXXXXXXXX HW version: MP0.3 RF cal date: 20181123 Chip name: EXYNOS7885 Modem board: SHANNON327 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 79514685 NET lock: 59719692 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-24-2019, 15:21 | #341 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 226190 Status: Offline Thanks Meter: 22 | Samsung Galaxy On7 SM-G600FY FRP GOOGLE ACCOUNT REMOVE BY Z3X BOX 100% SUCCESS Samsung Galaxy On7 SM-G600FY FRP GOOGLE ACCOUNT REMOVE BY Z3X BOX 100% SUCCESS https://www.youtube.com/watch?v=gsaHUJSth-M |
01-25-2019, 09:40 | #342 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung G900P write Root file Done :) Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G900P Software version: 34.8 File analysis... OK Total file size: 0x026618C4 (38 Mb) Searching USB Flash interface... COM13 detected Setup connection... OK Reading PIT from phone... OK Sending recovery.img... OK Sending cache.img.ext4... OK Flashing done (time - 00:00:14) Done with Samsung Tool PRO v.34.8 |
