Old 11-09-2017, 16:42   #31 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 139
after flash on eng root phone stuck on serial number any solution
Old 11-13-2017, 14:55   #32 (permalink)
Member: 1326581
Sonork: (((NAEEM)))
Thanks Meter: 45
Thumbs up G950W S8 UNLOCK Done With Z3X
Checking Login and Password... OK
Ballance: 21 crd.
Waiting ADB device...
Please, allow USB debugging on phone... OK
Reading phone info...
Model: SM-G950W
Android version: 7.0
Product code: SM-G950WZVARWC
Phone version: G950WVLU1AQD9
PDA version: G950WVLU1AQD9
CSC version: G950WOYA1AQD9
CSC country code: Canada
CSC sales code: RWC
HW version: REV1.0
Phone SN: R28J4462MLR
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-04-01
RF cal date: 2017.05.02
IMEI: 355757081962488
Rebooting phone... OK
Waiting ADB device... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM112 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 19604684
NET lock: 19618695
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.29.6
The Following User Says Thank You to (((NAEEM))) For This Useful Post:
Old 11-16-2017, 11:09   #33 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 953
Arrow samsung galaxy j5 prime g570f unlock done
Operation: Unlock
Selected model: SM-G570F
Software version: 28.2
Please, allow USB debugging on phone... Ok
Model: SM-G570F
Android version: 6.0.1
Product code: SM-G570FZKDINS
Phone version: G570FXXU1API6
PDA version: G570FXXU1API6
CSC version: G570FODD1API7
CSC country code: India
CSC sales code: INS
HW version: MP 0.500
Phone SN: R28J13Z4NDL
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2016-09-01
RF cal date: 20170201
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... Ok
Reading data... error
Security damaged (4 23)
Initialization zTool... Ok
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data from phone... Ok
HWID: 91 D1 89 7E 42 40 1B 51 35 94 2C C7 0A 00 00 00
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Rebooting phone... Ok
Unlock done
Done with Samsung Tool PRO v.28.2
The Following User Says Thank You to Rizwan ch08 For This Useful Post:
Old 11-16-2017, 11:13   #34 (permalink)
Member: 2478653
Sonork: 100.1678019
Thanks Meter: 138
Good Work CH Rizwan
Old 12-04-2017, 18:18   #35 (permalink)
Member: 1948608
Thanks Meter: 1,572
Thumbs up J7 Neo SM-J701F frp Done.
Galaxy J7 Nio frp Done By ADB Mode.
Operation: Reset FRP
Selected model: SM-J710FN
Software version: 30.0
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Model: SM-J701F
Product code: SM-J701FZDDXFA
Phone version: J701FXXU1AQF8
PDA version: J701FXVU1AQF8
CSC version: J701FOJV1AQG1
CSC country code: SOUTH AFRICA
CSC sales code: XFA
HW version: MP 0.400
Phone SN: RF8JA1G36SN
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2017-07-01
RF cal date: 20171012
IMEI: 3528xxxxxxxxxxx
Incorrect model selected. This may damage your phone. Continue? Yes
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.30.0
The Following User Says Thank You to -Mosin- For This Useful Post:
Old 01-17-2018, 14:24   #36 (permalink)
Member: 2361634
Thanks Meter: 31
ATT SM-N950U Read Codes via Server Done
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-N950U
Software version: 30.5
Model: SM-N950U
Android version: 7.1.1
Product code: SM-N950UZKAATT
Phone version: N950USQU1AQH7
PDA version: N950USQU1AQH7
CSC version: N950UOYN1AQH7
CSC country code: USA
CSC sales code: ATT
HW version: REV1.0
Phone SN:
Chip name: MSM8998
Security patch: 2017-08-01
RF cal date: 2017.09.26
IMEI: 35xxxxxxxxxxxxx
Waiting for device to become ready... OK
Start... OK
Searching Ramdump interface... COM9 detected
Calculating... OK
Freeze code: 58506405
NET lock: 13693642
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Done with Samsung Tool PRO v.30.5
Old 02-15-2018, 07:34   #37 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,222
SM-G925F Repair DRK done
hi
phone was slow
when i did factory reset i noticed dm failed in recovery
i downgrade from 7 to 6.0.1
phone stuck at recovery
dm failed
i tried octopus and chimera but both required phone on normal mode
but z3x did it in download mode
so i did drk repair by z3x
first flash pit file + 4 file stock firmware
then do drk by z3x
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Repair DRK
Selected model: SM-G925F
Software version: 30.7
Checking local file... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM7 detected
Setup connection... OK
Sending data to phone... OK
Recovery build version: 6.0.1
Boot version: G925FXXU5DQAG
Platform: exynos7420
Boot serial: 03157df3f809b924
Product board: zerolte
Start... OK
Checking DRK status... NG!
Writing DRK... OK
Repairing DMVT key... OK
Repair DRK done
Done with Samsung Tool PRO v.30.7
The Following 2 Users Say Thank You to profkefah For This Useful Post:
Old 04-04-2018, 12:35   #38 (permalink)
muzammilrashdi's Avatar
Member: 2116947
Sonork: 100.1652193
Thanks Meter: 1,178
Talking Galaxy a520f 7.0 frp done
GALAXY A520F 7.0 FRP DONE VERY EASY WITHOUT ADB ENABLE
JUST SELECT G925F AND RESET FRF......
LOG:
Operation: Reset FRP/React/EE
Software version: 31.0
Searching Samsung USB Flash interface... COM34 detected
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
Done with Samsung Tool PRO v.31.0
BIG THANX Z3X TEAM U SAVE MY TIME.....
BR MUZAMMILRASHDI
The Following 4 Users Say Thank You to muzammilrashdi For This Useful Post:
Old 04-04-2018, 12:52   #39 (permalink)
Member: 1351039
Sonork: 2769
Thanks Meter: 3
without adb activate possible?
Old 04-04-2018, 14:59   #40 (permalink)
Member: 2116947
Sonork: 100.1652193
Thanks Meter: 1,178
yes bro check log....
finally after 2 days i found this solution...
The Following 3 Users Say Thank You to muzammilrashdi For This Useful Post:
Old 04-09-2018, 11:55   #41 (permalink)
mebugti's Avatar
Member: 2545664
Sonork: nill
Thanks Meter: 84
samsung sm-j510f wifi not working 1000 % done
j5 2016 model wifi not open i done ....
http://www.youtube.com/watch?v=SXaSGG7-ClY
The Following 4 Users Say Thank You to mebugti For This Useful Post:
Old 04-17-2018, 18:22   #42 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 183
g570m unlock done
Operation: Unlock
Selected model: SM-G570M
Software version: 31.3
Model: SM-G570M
PDA version: G570MUBU1AQH2
CSC version: G570MUWM1AQJ1
Phone version: G570MUBU1API9
Product code: SM-G570MZKACOL
CSC country code: COLOMBIA
CSC sales code: COL
Phone SN: R28J225VZSA
IMEI: 353420085929993
HW version: Rev0.0
RF cal date: 20170214
Boot Warranty bit: 1
Reading NV data... OK
Checking NV data... OK
Security damaged (4 13)
Start... OK
HWID: 36 A0 D5 01 67 02 15 75 BE 3E E4 14 0A 00 00 00
Calculating... OK
Unlocking... OK
Writing NV data... OK
Unlock done
Done with Samsung Tool PRO v.31.3
The Following 2 Users Say Thank You to headszone1 For This Useful Post:
Old 05-16-2018, 19:07   #43 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,408
Thumbs up Sm-g903w unlock done by z3x +modem unlock
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Read Codes DIAG
Selected model: SM-G903W
Software version: 31.5
Checking hash file... OK
Searching Samsung modem... detected COM109
Model: SM-G903W
AP version: G903WVLU1CQI1
CSC version: G903WOYA1CQI1
CP version: G903WVLU1APJ1
Product code: VTR
Phone SN: RF8H629M7TA
IMEI: 3547XXXXXXXXXXXXXXX
Unique number: C00007AE937D323
Searching Samsung diag port... detected COM110
Reading phone info... OK
CP build: Oct 20 2016 15:31:45
Modem board: SHANNON310
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:09)
Freeze code: 60919240
NET lock: 86462706
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.31.5
https://mega.nz/#!QHIlnJQC!pwW-sadYR...CZtzqg0xjy9nzw PJ1
https://mega.nz/#!pXojmRgJ!4OUgFReLS...niMDFcG-I10tUQ PF1
Old 05-27-2018, 10:42   #44 (permalink)
Member: 2487583
Wink SM-J700F Patch Certificate ok
Operation: Patch Certificate
Selected model: SM-J700F
Software version: 32.4
Model: SM-J700F
PDA version: J700FXXU2BPG3
CSC version: J700FOJV2BPG1
Phone version: J700FXXU2BPG1
Product code: SM-J700FZWDKSA
CSC country code: KSA
CSC sales code: KSA
Phone SN: R28H5xxxxxx
IMEI: 352842xxxxxxxxx
HW version: MP 0.700
RF cal date: 20150722
Chip name: EXYNOS7580
Security patch: 2016-07-01
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Patching CERT check... done
Done with Samsung Tool PRO v.32.4
Old 06-01-2018, 18:36   #45 (permalink)
ky_bAttaUsAi's Avatar
Member: 919402
Sonork: ky
Thanks Meter: 86
would you be able to share the root file please.
Page generated in 0.28156 seconds with 8 queries
