Old 02-24-2019, 14:50   #466 (permalink)
mouhane's Avatar
Member: 2178934
Thanks Meter: 1,288
Better to bypass NEW FRP by tricks if you have time to do
Old 02-26-2019, 09:02   #467 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung s5660m network unlock done
Thanks z3x team
Old 02-26-2019, 14:57   #468 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 573
Operation: Unlock
Selected model: SM-J327P
Software version: 34.11
Waiting ADB device... OK
Reading phone info...
Model: SM-J327P
Android version: 6.0.1
PDA version: J327PVPU3AQJ3
CSC version: J327PSPT3AQJ3
Phone version: J327PVPU3AQJ3
Product code: Not Active
CSC country code: USA
CSC sales code: XAS
Phone SN: 00000000000
IMEI: 3525100xxxxxx
HW version: J327P.03
RF cal date: 2017.11.28
Chip name: MSM8937
Modem board: MSM8917
Security patch: 2017-08-01
Boot Warranty bit: 0
SIM State: CARD_IO_ERROR
Searching Samsung diag port... detected COM1046
Writing data to phone... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.34.11
Old 02-26-2019, 17:14   #469 (permalink)
julius84's Avatar
Member: 2524486
Thanks Meter: 112
SAMSUNG SM-A510F SUCCESFULLY REPAIRED NETWORK
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
8. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Operation: Patch Certificate
Selected model: SM-A510F
Model: SM-A510F
Android version: 7.0
Product code: SM-A510FEDFXSG
Phone version: A510FDXXU7CRJA
PDA version: A510FXXS7CSA4
CSC version: A510FDOJP7CRK1
CSC country code: UAE
CSC sales code: XSG
HW version: MP 0.000
Phone SN: R58H62QYGLN
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2019-01-01
RF cal date: 20160618
IMEI: 357766076384374
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Initialization data... OK
Writing zTool... OK
Initialization zTool... OK
Patching CERT check... done
Old 02-26-2019, 19:15   #470 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
G925T FRP RESET DONE
Old 02-27-2019, 08:48   #471 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
SAMSUNG S7 EDGE G935P FLASHING DONE
Old 02-27-2019, 09:16   #472 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
SAMSUNG G925T FLASGING DONE
Old 02-27-2019, 10:24   #473 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
SAMSUNG GALAXY S2 I9100 UNLOCK DONE
Old 02-27-2019, 11:36   #474 (permalink)
umerkhalid1992's Avatar
Member: 2696842
Sonork: 100.1683002
Thanks Meter: 296
Model: SM-A320FL
Android version: 8.0.0
PDA version: A320FLXXU3CRH2
CSC version: A320FLHUI3CRH1
Phone version: A320FLXXU3ARI1
Product code: SM-A320FZKNHUI
CSC country code: ITALY
CSC sales code: HUI
Phone SN: RF8J91DPDTK
IMEI: 359751089950625
HW version: MP 0.300
RF cal date: 20170913
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2018-08-01
SIM State: ABSENT
Reading data... OK
Reading MODEM... OK
Calculating... OK
Waiting for device to become ready... OK
Writing zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID: 57 05 00 00 00 00 00 00 00 00 00 00 7C 5F B5 29
Calculating... OK
Unlocking... OK
Writing NV data... OK
Unlock done
Old 02-27-2019, 14:31   #475 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Samsung SM-G935T (U4) Remove FRP Lock Done :)
 UNLOCK INSTRUCTIONS:
    To unlock:
  5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear.
    (Login and password will be saved as default after first input and can be changed in settings)
    To reset Pattern lock:
  1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
  3. Press 'Reset Pattern Lock' button.
    To reset Google account activation lock:
  1. ADB must be activated in any way (you can flash sBoot from combination firmware,
     make sure, that you are not upgrade sBoot).
  3. Select device in ADB settings.
  4. Press 'Reset FRP' to deactivate Google account activation lock.
   To reset Google account activation or Samsung reactivation lock:
  3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
    (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Reset FRP/React/EE
Selected model: SM-G935T
Checking local file... not found
Searching server... OK
Downloading file... OK
Checking local file... OK
Searching USB Flash interface... COM233 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Model: SM-G935T
PDA version: G935TXXU4API3
CSC version: G935FVZW4API3
Phone version:
Product code:
CSC sales code: XSG
Phone SN: R38H7014MBB
IMEI:
HW version:
RF cal date:
Chip name: MSM8996
Modem board:
Security patch: 2016-10-01
Erasing FRP... OK
Restore original kernel?  Yes
Restoring kernel... OK
Reset FRP done
Old 02-27-2019, 14:36   #476 (permalink)
Member: 654997
Thanks Meter: 4,073
Samsung SM-G532F Write Firmware Done :)
 Operation: Flash
 Selected model: SM-G532F
 File analysis... OK
 Total file size: 0xC46B3B9F (3142 Mb)
 Reading PIT from phone... OK
 Sending preloader.img... OK
 Sending lk.bin... OK
 Sending param.bin... OK
 Sending trustzone.bin... OK
 Sending efuse.img... OK
 Sending boot.img... OK
 Sending recovery.img... OK
 Sending system.img... OK
 Sending secro.img... OK
 Sending userdata.img... OK
 Sending md1rom.img... OK
 Sending md1dsp.img... OK
 Sending cache.img... OK
 Sending hidden.img... OK
 Flashing done (time - 00:03:14)
Old 02-27-2019, 14:59   #477 (permalink)
Member: 1780733
Sonork: 100.1624035
Thanks Meter: 15
Selected model: SM-J500H
Selected port: COM8 Z3X BOX Serial Port
Software version: 34.6
Searching Samsung USB Flash interface... COM67 detected
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
Done with Samsung Tool PRO v.34.6
Old 02-27-2019, 17:16   #478 (permalink)
Registered User
Member: 307373
Sonork: paypal.me/div859
Thanks Meter: 590
SM-J610FN unlock done
Model: SM-J610FN
Android version: 8.1.0
PDA version: J610FNXXU1ARIO
CSC version: J610FNOXM1ARIO
Phone version: J610FNXXU1ARIO
Product code: SM-J610FZKNXEO
CSC country code: Poland
CSC sales code: XEO
Phone SN: R58KB2JD50B
IMEI: 352985104140252
HW version: REV0.5A
RF cal date: 2018.11.10
Chip name: MSM8917
Security patch: 2018-09-01
SIM State: ABSENT,NETWORK_LOCKED
Running zTool, please wait... OK
Searching Ramdump interface... COM47 detected
Calculating... OK
Waiting for server answer... OK
Freeze code: 64268295
NET lock: 05061393
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Old 02-27-2019, 23:13   #479 (permalink)
Member: 2769072
Thanks Meter: 126
S8 Sprint Bit 5 Unlock Done
Domestic Unlock:
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
5. Press 'Unlock Domestic' button.
Operation: Unlock
Selected model: SM-G935P
Model: SM-G950U
PDA version: FA70_G950USQU5ARG4
CSC version:
Phone version: G950USQU5CRF1
Product code: SM-G950UZKASPR
CSC country code:
CSC sales code:
Phone SN: R28J82KA7CA
IMEI: 35598208xxxxxxx
HW version: REV1.0
RF cal date: 2017.08.17
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-02-01
Incorrect model selected. This may damage your phone. Continue? Yes
Writing AT RIL... OK
Initialization AT RIL... OK
Unlocking... OK
Unlock done
The Following User Says Thank You to Rem0teunl0ck For This Useful Post:
Old 02-28-2019, 12:00   #480 (permalink)
Member: 654997
Thanks Meter: 4,073
SM-G532F Remove FRP Lock Done :)
You must activate ADB before reset FRP  Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA  Yes
Model: SM-G532F
PDA version: G532FXWU1AQB5
CSC version: G532FOJV1AQB5
Phone version: G532FXXU1AQB3
Product code: SM-G532FZKDPAK
CSC country code: PAKISTAN
CSC sales code: PAK
Phone SN: R58J56VP7FT
IMEI: 357953089064868
RF cal date: 20170530
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2017-03-01
SIM State: ABSENT,ABSENT
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Page generated in 0.27691 seconds with 9 queries
