Old 04-17-2018, 18:22   #46 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 208
g570m unlock done
Operation: Unlock
Selected model: SM-G570M
Software version: 31.3
Waiting ADB device... OK
Reading phone info...
Model: SM-G570M
Android version: 6.0.1
PDA version: G570MUBU1AQH2
CSC version: G570MUWM1AQJ1
Phone version: G570MUBU1API9
Product code: SM-G570MZKACOL
CSC country code: COLOMBIA
CSC sales code: COL
Phone SN: R28J225VZSA
IMEI: 353420085929993
HW version: Rev0.0
RF cal date: 20170214
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-08-01
Boot Warranty bit: 1
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... error
Security damaged (4 13)
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
HWID: 36 A0 D5 01 67 02 15 75 BE 3E E4 14 0A 00 00 00
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.31.3
The Following 2 Users Say Thank You to headszone1 For This Useful Post:
Old 05-16-2018, 19:07   #47 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Thumbs up Sm-g903w unlock done by z3x +modem unlock
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Read Codes DIAG
Selected model: SM-G903W
Software version: 31.5
Checking hash file... OK
Searching Samsung modem... detected COM109
Model: SM-G903W
AP version: G903WVLU1CQI1
CSC version: G903WOYA1CQI1
CP version: G903WVLU1APJ1
Product code: VTR
Phone SN: RF8H629M7TA
IMEI: 3547XXXXXXXXXXXXXXX
Unique number: C00007AE937D323
Searching Samsung diag port... detected COM110
Reading phone info... OK
CP build: Oct 20 2016 15:31:45
Modem board: SHANNON310
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:09)
Freeze code: 60919240
NET lock: 86462706
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.31.5
https://mega.nz/#!QHIlnJQC!pwW-sadYR...CZtzqg0xjy9nzw PJ1
https://mega.nz/#!pXojmRgJ!4OUgFReLS...niMDFcG-I10tUQ PF1
Old 05-27-2018, 10:42   #48 (permalink)
Member: 2487583
Thanks Meter: 6
Wink SM-J700F Patch Certificate ok
Operation: Patch Certificate
Selected model: SM-J700F
Software version: 32.4
Model: SM-J700F
PDA version: J700FXXU2BPG3
CSC version: J700FOJV2BPG1
Phone version: J700FXXU2BPG1
Product code: SM-J700FZWDKSA
CSC country code: KSA
CSC sales code: KSA
Phone SN: R28H5xxxxxx
IMEI: 352842xxxxxxxxx
HW version: MP 0.700
RF cal date: 20150722
Chip name: EXYNOS7580
Security patch: 2016-07-01
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Patching CERT check... done
Done with Samsung Tool PRO v.32.4
Old 06-01-2018, 18:36   #49 (permalink)
ky_bAttaUsAi's Avatar
Member: 919402
Sonork: ky
Thanks Meter: 93
would you be able to share the root file please.
Old 06-05-2018, 07:46   #50 (permalink)
fahadboss's Avatar
Member: 2441366
Sonork: Telegram: @FahadBoss10
Thanks Meter: 245
Cool SM-J120AZ 6.0.1 Binary 5 Unlock [Done]
J120AZ 6.0.1 Binary 5 Successfully Unlocked by Z3X
1. Read Info:
2. Flash ENG_Modem file by Odin in CP section.
3. Read Codes DIAG:
4. Enter NET lock code. That's it
Br,
Fahad Ahmad
The Following 8 Users Say Thank You to fahadboss For This Useful Post:
Old 06-21-2018, 01:53   #51 (permalink)
Member: 2730595
Thanks Meter: 13
j727 t1 unlocking done
Warning! Knox warranty must be active (0x00)!
3. Type *#0808# and select 'DM + MODEM + ADB' (or 'DM + ACM + ADB').
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select device in ADB settings.
6. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Operation: Unlock
Selected model: SM-J727T1
Software version: 32.7
Checking Login and Password... OK
Ballance: 130 crd.
You have 130 credit(s) left. This operation takes 5 credits.Continue? Yes
Model: SM-J727T1
Android version: 7.0
PDA version: J727T1UVS3ARE1
CSC version: J727T1TMK3ARE1
Phone version: J727TUVU3ARA1
Product code: SM2J727TZKETMK
CSC country code: USA
CSC sales code: TMK
Phone SN: R28K30QABPN
IMEI: 354254093027501
HW version: REV0.7
RF cal date: 20180306
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2018-05-01
Boot Warranty bit: 0
Searching Samsung diag port... detected COM184
CP version: J727TUVU3ARA1
CP build: Jan 24 2018 13:02:34
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Start... OK
Unlock done
Done with Samsung Tool PRO v.32.7
The Following User Says Thank You to dineshkannur123 For This Useful Post:
Old 06-21-2018, 03:22   #52 (permalink)
Member: 2457418
Nice one!
Is this applicable to SM-J710GN?
The Following User Says Thank You to redpiles31 For This Useful Post:
Old 06-21-2018, 21:55   #53 (permalink)
Member: 2730595
Thanks Meter: 13
brother ,first whn i try for unlocking z3x box saying reading phone data is failed
afer that i have done modem downgrade
after downgrade modem
then ucan unlock via z3x server
if u getting reading pone data error,,,
same way u can do ( downgrading the modem)
Thanks bro..
Old 06-21-2018, 21:59   #54 (permalink)
Member: 2730595
Thanks Meter: 13
Smile
Originally Posted by redpiles31 View Post
Nice one!
Thanks bro..
Report Post
Old 06-23-2018, 11:53   #55 (permalink)
Member: 2826140
Sonork: 1644958
Thanks Meter: 103
Thumbs up G920P Unlock done
Operation: Unlock
Selected model: SM-G920P
Model: SM-G920P
PDA version: G920PVPS4DRA2
CSC version: G920PSPT4DRA2
Phone version: G920PVPS4DRA2
CSC sales code: SPR
IMEI: 99
HW version: G920P.02
RF cal date: 2016.01.22
Chip name: EXYNOS7420
Modem board: MDM9635M
Security patch: 2018-01-01
Writing AT RIL... OK
Initialization AT RIL... root required
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Old 08-13-2018, 13:32   #56 (permalink)
Cheater -Don't Deal with him-
Member: 2780773
Sonork: Not useing
Thanks Meter: 152
Cool SAMSUNG SM-J320F Unlock [Done]
Selected model: SM-J320F
Software version: 33.2
Searching Samsung modem... detected COM57
Model: SM-J320F
AP version: J320FXXU0AQG2
CSC version: J320FDBT0AQG1
CP version: J320FXXU0AQE2
Product code: SM-J320FZKDDBT
Phone SN: RV8JA1CFXXX
IMEI: 353751090547XXX
IMEI2: 353752090547XXX
Unique number: CQN00CA71D46884
Reading codes... OK
Please wait, calculating codes... OK (time - 00:01:15)
Freeze code: 31727926
NET lock: 35081684
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.33.2
Old 08-13-2018, 13:57   #57 (permalink)
Member: 9569
Thanks Meter: 14
sorry what is @insideunlocker
The Following User Says Thank You to aprivate For This Useful Post:
Old 10-02-2018, 08:40   #58 (permalink)
Member: 1689739
Sonork: 100.1608775
Thanks Meter: 164
SAMSUNG N920P unlock done
Operation: Unlock
Selected model: SM-N920P
Software version: 33.8
Model: SM-N920P
PDA version: N920PVPS3DRC1
CSC version: N920PSPT3DRC1
Phone version:
Product code:
CSC sales code: SPR
Phone SN: 00000000000
IMEI:
HW version:
RF cal date:
Modem board:
Security patch: 2018-03-01
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.33.8
Old 11-05-2018, 04:32   #59 (permalink)
Member: 2595994
Thanks Meter: 2
This worked for me thanks
The Following User Says Thank You to controlsub For This Useful Post:
Old 11-13-2018, 07:29   #60 (permalink)
Member: 430612
Thanks Meter: 301
j260f frp unlock
please me j260f frp fail
Page generated in 0.17086 seconds with 10 queries
