09-11-2010, 16:22 | #1516 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung e2130 blinking repair successfully Selected model: E2130 Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 707 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-11-2010, 17:44 | #1517 (permalink) |
Freak Poster Join Date: Nov 2009 Location: U.K (leeds)
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | s3370 successfully unlocked Count supported models - 203 ----------------------------- Model: GT-S3370 CountryCode: H3G Factory SW: S3370NEJD1_3UKJD1 UniqueNumber: 74050001854575 MemoryPhone: K522H1HACC(S3370)S IMEI: 358663030xxx68/9 Phone S/N: R2YZ537269 Build: Q6270B-KPVZL-1.5.55011ST Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:01:06) Freeze code: 63974084 NET lock: #7465625*638*68647157# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# |
09-11-2010, 19:31 | #1519 (permalink) |
No Life Poster Join Date: Jul 2006 Age: 17
Member: 306410 Status: Offline Thanks Meter: 58 | Selected model: J600E Selected com port: COM12 Selected speed port: 460800 Start generation to file... 00666666 Encode *.s3 - wait... OK EEP saved to file-> D:\Program Files\Z3X\Samsung\All\J600E_RPQS114969H_.sre Phone must be ON! Please, connect phone Entering TestMode... OK Start calibrate NVM Calibrate NVM field - fail Calibrate NVM - Ok Repair OTP - ok Elapsed time: 78 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- Selected model: J600E Selected com port: COM12 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: 600EXXHB1 IMEI: 35367502088087 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 19 second, sw ver: 3.4.0066 cant rep+unlock with ust no work |
09-11-2010, 19:32 | #1520 (permalink) |
Member: 306410 Status: Offline Thanks Meter: 58 | Selected model: M620 Selected com port: COM12 Selected speed port: 921600 Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 0100003D7E22 Syncing phone... OK Format FFS - wait... Format FFS - ok Elapsed time: 257 second, sw ver: 3.4.0066 3 day rep with ust no work |
09-11-2010, 19:33 | #1521 (permalink) |
Member: 306410 Status: Offline Thanks Meter: 58 | Count supported models - 203 Reading file... OK Model: S8500 Version: S8500XEJH2 Info: Patched for Unlock and IMEI repair v2 Searching Samsung USB Flash interface... detected (COM6) Sending amss... sended Sending apss... sended Sending rsrc1... sended Sending rsrc2... sended Sending ffs... sended Sending csc... sended Sending app... sended Sending pfs... sended Flashing done (time - 00:16:04) ----------------------------- Searching Samsung USB interface... not found ----------------------------- Searching Samsung USB interface... detected (COM7) Model: GT-S8500 SW: S8500XEJH2 IMEI: 35922303369344/6 MSL Adr: R2YZ642005 CountryCode: FTM Factory SW: S8500BVJE7_FTMJE7_1 UniqueNumber: 74320001435999 MemoryPhone: KAC007021M(S8500) Bypass MSL... OK Reading codes... OK Calculating codes... OK (time - 00:00:10) Freeze code: 03969503 NET lock: #7465625*638*16308068# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# not supported with ust-dead |
09-12-2010, 23:05 | #1522 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | s3650 unlock done by z3x Selected model: S3650 Selected com port: COM7 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM8 Phone IMEI: 35xxxxxxxxx Phone S/N: RDOZ704680 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 49 second, sw ver: 3.4.0066 |
09-13-2010, 10:28 | #1523 (permalink) |
Crazy Poster Join Date: Dec 2006
Member: 420744 Status: Offline Thanks Meter: 5 | Hello there can you please help me with this problem. Am working on the sumsung but it has the following serial number what is the solution to repair it the orignal is 3576763036093645, but just check out what it is showing me below Selected model: S5230 Selected com port: COM8 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM9 Model: GT-S5230 CountryCode: ORA Factory SW: S5230BUIF1 UniqueNumber: 55030000402055 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 12345678912345 /8 Phone S/N: RPGS950760 Phone Bluetooth ID: 60 D0 A9 45 A6 3C Phone SW: S5230BVIJ1_IJ2 Phone HW: MP 0.610 Phone CalData ver: 20090909 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:12345678 [NET LOCK]:25819474 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 58 sec Elapsed time: 175 second, sw ver: 3.4.0033 ------------------------------------------------------------------------------- Phone must be ON Search modem ... OK Search modem on:COM9 Phone OLD S/N: RPGS950760 Phone OLD IMEI: 12345678912345 /8 Phone SW: S5230BVIJ1_IJ2 Set SWAP as OLD msl... False Set SWAP as NEW msl... False Detecting UART port..... OK Wait for boot ... Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM9 Phone NEW IMEI: 12345678912345 /8 Phone NEW S/N: RPGS950760 Detecting UART port..... OK Repair - sec zone ok |
09-13-2010, 16:48 | #1524 (permalink) |
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | Samsung Galaxy 19000 successfully unlocked. Count supported models - 203 Searching Android modem... detected (COM114) Model: GT-I9000 SW: I9000BOJF1 IMEI: 351751049xxx82/6 CountryCode: ¿µ±¹ Factory SW: I9000BOJG3 UniqueNumber: 75910000166209 MemoryPhone: KB100D00WM(I9000) Reading Data from phone... OK MCK: 19308304 NET lock: 39471424 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# after this procedure put wrong sim and put net lock code.Tested work 100%,no need flashing firmware.BR |
09-13-2010, 17:31 | #1525 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Ghana
Member: 1230787 Status: Offline Thanks Meter: 96 | successfully flashed C5212 with z3x Selected model: C5212_m Selected com port: COM64 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok Download - ok Elapsed time: 1206 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-13-2010, 18:05 | #1526 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung E1080 UNLOCK DONE!!! Selected model: E1080 Selected com port: COM146 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock block Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 60 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM146 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 56 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM146 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock block Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 56 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
09-13-2010, 18:15 | #1527 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | C3510 C3510 succesfully unlocked. Thank you Z3X Team. BR. ------------------------------------------------------------------------------- Selected model: C3510 Selected com port: COM88 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 160 second, sw ver: 3.4.0066 |
09-13-2010, 18:16 | #1528 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | C270 C270 succesfully unlocked. Thank you Z3X Team. BR. Selected model: C270 Selected com port: COM88 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 351666049xxxxxx Phone SW: C270CWID1 Phone BT ADDR: 0000-00-000000 Phone SN: RU9Z627220 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 20 second, sw ver: 3.4.0066 ----------------------------------------------------- |
09-14-2010, 01:26 | #1529 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | i900 unlocked: Model: SGH-I900 CountryCode: XEU Factory SW: I900XXHG5 UniqueNumber: 74060000691272 MemoryPhone: K5D1258DCA(I900) PDA/CSC version: i900XXHG5/MSHG1 Phone version: i900XXHG5 Phone HW: MP 0.601 IMEI: c3528190218964/ Phone S/N: R4YQ964057 Build: M6281A-KLRZ-4.0.95601S Reading Security... OK Bypass MSL... OK Unlocking ... OK |
09-14-2010, 04:58 | #1530 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2007
Member: 488833 Status: Offline Thanks Meter: 52 | S5620 tricky but done well just need to read the procedure and get multiloader 5.62 Selected model: S5620 Selected com port: COM9 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM36 Phone OLD IMEI: 35858003313790 /1 Phone SW: S5620BVJJD1/S5620ZTOJD1 Search modem ... OK Phone detected... OK Send loader... OK Wait for boot ... Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM36 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Search modem ... OK Phone detected... OK Send loader... OK Elapsed time: 94 second, sw ver: 3.4.0066 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
