Old 08-25-2017, 11:24   #18976 (permalink)
Member: 2185549
Sonork: +256703988005
Thanks Meter: 379
Checking phone at COM577 OK
Model: SHV-E160S
Country code: ŠU
Cal date: ŠU
Factory SW: E160SKSJMH2
Unique number: CKT09DEEB22F27F
Memory phone: ŠU
Phone SN: R33C71FF9F
PDA/CSC version: E160SKSJMH2/none
Phone version: SW VERSION :None
Phone HW: E16.10
Cal date: none
Bypass MSL OK
Reading IMEI... OK
IMEI: 35231805070434
Repairing IMEI... OK
Reseting... OK
Repair done
Done with Samsung Tool PRO v.29.0
Old 08-25-2017, 12:15   #18977 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-A500F
Selected port: COM55 SAMSUNG Mobile USB Serial Port
Software version: 29.1
Checking CERT file... OK
KEY ID: 0756
Waiting ADB device... OK
Reading phone info...
Model: SM-A500F
Android version: 4.4.4
Product code: SM-A500FZKDSKZ
Phone version: A500FXXU1ANL1
PDA version: FA44_A500FXXU1AOG1
CSC version:
CSC country code:
CSC sales code:
HW version: MP 1.100
Phone SN: RF8H11TP9VL
Modem board: MSM8916
RF cal date: 2016.01.22
IMEI: 356321062970272
Writing AT RIL... OK
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0756
Writing CERT... OK
Checking CERT status... OK
Writing Slave CERT... OK
Checking Slave CERT status... OK
Rebooting phone... OK
Done with Samsung Tool PRO v.29.1
Old 08-25-2017, 12:42   #18978 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Write QCN
Reading QCN file... OK
Reading ID... OK
Detected ID: 00000FFE (MSM8916)
SW version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1
Checking paths... OK
Restoring EFS backup... OK
Restoring NV items... OK
Restoring NV item SIM1... OK
Restoring NV item SIM2... OK
Restoring Provisioning Item Files... OK
Restore QCN done
Old 08-26-2017, 08:00   #18979 (permalink)
Member: 572216
Thanks Meter: 3,626
SM-G891A unlock done
  UNLOCK INSTRUCTIONS:
    Unlocking with original MSL code:
    Warning! Knox warranty must be active (0x00)!
    If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
  1. Phone must be powered on.
  2. Run dialer and type *#0*# (service mode will apear).
  3. Connect the phone to UART cable, choose correct COM port in port settings.
  4. Press 'Unlock' button.
  5. Paste MSL code in new opened window and press 'OK'.
    Reading codes using sever:
  5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
    (Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-G891A
Selected port: COM578 SAMSUNG Mobile USB Serial Port
Checking Login and Password... OK
Ballance: 40 crd.
Model: SAMSUNG-SM-G891A
Android version: 6.0.1
Product code: SM-G891AZAAATT
Phone version: G891AUCS2API2
PDA version: G891AUCS2API2
CSC version: G891AATT2API2
CSC country code: USA
CSC sales code: ATT
HW version: REV0.5
Phone SN: R38H60HQ52M
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2016-09-01
RF cal date: 2016.06.17
IMEI:
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM8 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 06946840
NET lock: 75158038
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Old 08-26-2017, 10:05   #18980 (permalink)
Member: 1732025
Sonork: 100.1615024
Thanks Meter: 364
g531f unlock
Operation: Reset FRP/React/EE
Selected model: SM-G531F
Searching Samsung USB Flash interface... COM4 detected
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 08-26-2017, 10:13   #18981 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
To unlock NEW security type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' to deactivate Google account activation lock.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset FRP UFS
Selected model: SM-G935F
Selected port: COM26 USB Serial Port
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM26 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (G935F)
Reseting FRP... OK
Reset FRP done
Old 08-26-2017, 14:01   #18982 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 434
Selected model: SM-G532F
Model: SM-G532F
Product code: SM-G532FZDDMID
Phone version: G532FXXU1APJ7
PDA version: G532FXWU1APJ3
CSC version: G532FOJV1APJ6
CSC country code: Iraq
CSC sales code: MID
HW version: MP 0.300
Phone SN: R58HC51X68B
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2016-10-01
RF cal date: 20161224
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 08-26-2017, 16:53   #18983 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
REPAIR INSTRUCTIONS:
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Patch Certificate
Selected model: SM-G925F
Model: SM-G925F
Product code: SM-G925FZDAMID
Phone version: G925FXXU5DQA3
PDA version: G925FXXS5DQA3
CSC version: G925FOJV5DQA3
CSC sales code: MID
HW version: MP 0.710
Phone SN: RF8H93508NA
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-01-01
RF cal date: 20160928
IMEI:
Checking Super user right... true
Running zTool, please wait... OK
Reading modem... OK
Patching modem... OK
Writing modem... OK
Patching CERT check... done
Old 08-26-2017, 17:47   #18984 (permalink)
Afghanboy's Avatar
Member: 1087322
Thanks Meter: 172
FRP SM-G570F J5 Prime done
Download File in z3x Server
COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL9218 515_QB10877448_REV00_user_mid_noship.tar
Option sboot Flash
Selected model: SM-G570F
Lese Telefoninfo...
Model: SM-G570F
Produkt Code: SM-G570FZKDXNZ
Phone version: G570FXXU1AQE1
PDA version: G570FXXU1AQE1
CSC version: G570FXNZ1AQE1
CSC country code: New Zealand
CSC sales code: XNZ
HW version: MP 0.500
Phone SN: R58J53ECK7Z
Chip Name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-05-01
RF cal date: 20170516
IMEI:
Bypass FRP... OK
B.r
Afghanboy
Old 08-27-2017, 15:26   #18985 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1659400
Thanks Meter: 1,008
Wink
Operation: Unlock
Selected model: SM-G900F
Selected port: COM370 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 353421064805766
Unlocking... OK
Reseting... OK
Unlock done
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 08-27-2017, 20:18   #18986 (permalink)
Member: 2549748
Thanks Meter: 42
FIRST UNLOCK WITH Z3X...
FIRST DOWNGRADE MODEM TO OG2 AND THEN MAGIC WITH Z3X
Operation: Unlock
Selected model: SM-N910T
Selected port: COM7 SAMSUNG Mobile USB Serial Port
Reading phone info
Reading IMEI OK
IMEI: 3560950644XXXX
Unlocking OK
Reseting OK
Unlock done
THANKS
Old 08-28-2017, 14:35   #18987 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
Operation: Repair
Selected model: SM-J700F
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Model: SM-J700F
Product code: SM-J700FZKATUR
Phone version: J700FXXU4BQC3
PDA version: J700FXXU4BQC6
CSC version: J700FOJV4BQC6
CSC country code: TURKEY
CSC sales code: TUR
HW version: MP 0.701
Phone SN: R28GC0JRQ7L
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2017-03-01
RF cal date: 20151203
IMEI:
Reading NV data... OK
Checking NV data... OK
Repairing... OK
Writing NV data... OK
Repair done
Old 08-28-2017, 14:37   #18988 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 298
Model: SM-J700F
CSC sales code: TUR
IMEI:
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Old 08-28-2017, 18:33   #18989 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,519
Operation: Unlock
Selected model: SM-G550T
Software version: 29.2
Please, allow USB debugging on phone... OK
Model: SM-G550T
Product code: SM2G550TZKATMB
Phone version: G550TUVU1APF1
PDA version: G550TUVU1APF1
CSC version: G550TTMB1APF1
CSC sales code: TMB
HW version: REV0.4
Phone SN: RV8H80AAAAAD
Chip name: EXYNOS3475
Modem board: SHANNON308
Security patch: 2016-06-01
RF cal date: 20160818
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: 66 9E B6 76 F2 BC 6A D6 58 A7 54 8A A5 13 00 47
Calculating... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.29.2
Old 08-29-2017, 09:07   #18990 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 322
Ballance: 20 crd.
Android version: 7.0
Phone version: G891AUCU2BQF2
PDA version: G891AUCU2BQF2
CSC version: G891AATT2BQF2
CSC sales code: ATT
HW version: REV0.5
Phone SN: R38H90K4KJV
Chip name: MSM8996
Security patch: 2017-06-01
RF cal date: 2016.10.24
IMEI:
Start... OK
Searching Ramdump interface... COM67 detected
Calculating... OK
Freeze code: 39725169
NET lock: 35914290
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1656 10-15-2018 13:15
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.41533 seconds with 9 queries
