10-13-2017, 13:32 | #19231 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-N920C Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920C Android version: 7.0 Product code: SM-N920CZWAXSG Phone version: N920CXXU3CQG1 PDA version: N920CXXS3CQH1 CSC version: N920COJV3CQG1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.900 Phone SN: RF8J2114KRB Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-08-01 RF cal date: 20170210 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: B8 22 2D 1E 35 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-13-2017, 13:34 | #19232 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-N920C Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-N920C Android version: 7.0 Product code: SM-N920CZWAXSG Phone version: N920CXXU3CQG1 PDA version: N920CXXS3CQH1 CSC version: N920COJV3CQG1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.900 Phone SN: RF8J2114KRB Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-08-01 RF cal date: 20170210 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-13-2017, 16:12 | #19233 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: GT-N7100 Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-N7100 Android version: 4.4.2 Product code: GT-N7100RWDXSG Phone version: N7100XXUFOA1 PDA version: N7100XXSFQA5 CSC version: N7100OJVFOD1 CSC country code: UAE CSC sales code: XSG HW version: MP 1.301 Phone SN: RF1CC9QJLXT Modem board: XMM6262 RF cal date: 2012.12.30 IMEI: 3XXXXXXXXXXXXXXX Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-13-2017, 16:12 | #19234 (permalink) |
10-13-2017, 17:11 | #19235 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Operation: Read Codes Selected model: SM-G925F Selected port: COM458 SAMSUNG Mobile USB Serial Port Software version: 29.5 Searching Samsung modem... detected COM459 Reading phone info... OK Model: SM-G925F AP version: G925FXXU5EQG7 CSC version: G925FEVR5EQG1 CP version: G925FXXU5BPK2 Product code: EVR Phone SN: R58GB0NGVJY Unique number: 0815F8B24A9D2605 Reading IMEI... OK IMEI: 353621077473409 (SIGN: OK) Checking hash file... OK Reading data from phone... OK HWID: C8 BE 21 F4 B4 04 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 38186391 NET lock: 16363816 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.5 |
10-14-2017, 09:02 | #19236 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: GT-I9082 Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: GT-I9082 Android version: 4.2.2 Product code: Phone version: I9082XXUBNA3 PDA version: I9082XXUBNC2 CSC version: I9082OJVBNC2 CSC country code: Kenya CSC sales code: AFR HW version: MP 0.600 Phone SN: RF1DC1STR4B Modem board: RF cal date: 20131212 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 10:24 | #19237 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-J110H/DS Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZKDSLK Phone version: J110HDDU0APE1 PDA version: J110HXXS0AQF1 CSC version: G355HOJV0ANH9 CSC country code: UAE CSC sales code: XSG HW version: MP 0.500 Phone SN: R51J800EY0K Modem board: SC7727S Security patch: 2017-05-01 RF cal date: 20170802 IMEI: 3XXXXXXXXXXXXXXX Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Repairing Slave IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 10:24 | #19238 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Patch Certificate Selected model: SM-J110H/DS Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZKDSLK Phone version: J110HDDU0APE1 PDA version: J110HXXS0AQF1 CSC version: G355HOJV0ANH9 CSC country code: UAE CSC sales code: XSG HW version: MP 0.500 Phone SN: R51J800EY0K Modem board: SC7727S Security patch: 2017-05-01 RF cal date: 20170802 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 12:31 | #19239 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G925F Android version: 7.0 Product code: SM-G925FZDAXSG Phone version: G925FXXU5EQEG PDA version: G925FXXU5EQHD CSC version: G925FXSG5EQH2 CSC country code: UAE CSC sales code: XSG HW version: MP 0.700 Phone SN: R58G61Q85SA Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-08-01 RF cal date: 20150625 IMEI: 3xxxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 48 A0 7F 74 14 05 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 12:42 | #19240 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: GT-I9300 Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: Not Active Phone version: I9300XXUGNA8 PDA version: I9300XXUGNJ2 CSC version: I9300OXXGNJ1 CSC country code: France CSC sales code: XEF HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 004999010640000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 12:44 | #19241 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Patch Certificate Selected model: GT-I9300 Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: Not Active Phone version: I9300XXUGNA8 PDA version: I9300XXUGNJ2 CSC version: CSC country code: France CSC sales code: XEF HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Patching kernel... OK Writing kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 12:47 | #19242 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Disable Factory Mode Selected model: GT-I9300 Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: Not Active Phone version: I9300XXUGNA8 PDA version: I9300XXUGNJ2 CSC version: CSC country code: France CSC sales code: XEF HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 3XXXXXXXXXXXXX Checking Super user right... true Disabling Factory mode... OK Done with Samsung Tool PRO v.29.5 |
10-14-2017, 15:35 | #19243 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G930FD Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDAVD2 Phone version: G930FXXU1APD1 PDA version: G930FXXU1APD1 CSC version: G930FVFG1APD2 CSC country code: Germany CSC sales code: VD2 HW version: MP 0.700 Phone SN: R58H559A3GP Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-04-02 RF cal date: 20160528 IMEI: 3XXXXXXXXXXXXXX Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: CF DD E8 3D D7 70 4C 4A 4E BA 7E C3 F2 6C 7F 1F Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 15:37 | #19244 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G930FD Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDAVD2 Phone version: G930FXXU1APD1 PDA version: G930FXXU1APD1 CSC version: G930FVFG1APD2 CSC country code: Germany CSC sales code: VD2 HW version: MP 0.700 Phone SN: R58H559A3GP Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-04-02 RF cal date: 20160528 IMEI: 3XXXXXXXXXXXXXX Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-14-2017, 16:05 | #19245 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Gt-n7100 Operation: Patch Certificate Selected model: GT-N7100 Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: Android version: 4.4.2 Product code: Not Active Phone version: N7100DDUFND1 PDA version: N7100XXUFND3 CSC version: CSC country code: India CSC sales code: INU HW version: Unknown Phone SN: 00000000000 Modem board: XMM6262 RF cal date: Unknown IMEI: 354792051264251 Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
