10-16-2017, 15:37 | #19261 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | I9500 Certificate Patch Success Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: Not Active Phone version: I9500XXUHPC1 PDA version: I9500XXUHPK1 CSC version: I9500SERHPH1 CSC country code: Russia CSC sales code: SER HW version: REV__ Phone SN: RV1F11D4X27 Modem board: XMM6360 Security patch: 2016-11-01 RF cal date: Unknown IMEI: Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-17-2017, 12:20 | #19262 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G610F Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKDEGY Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: Egypt CSC sales code: EGY HW version: MP 0.400 Phone SN: R28J845DFPR Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170830 IMEI: 352xxxxxxxxxx98 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: D7 04 00 00 00 00 00 00 00 00 00 00 84 A8 5B ED Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
10-17-2017, 12:21 | #19263 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G610F Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKDEGY Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: Egypt CSC sales code: EGY HW version: MP 0.400 Phone SN: R28J845DFPR Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170830 IMEI: 35xxxxxxxxxxx03 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.5 |
10-17-2017, 13:04 | #19264 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: I8190 Selected port: COM74 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I8190 Android version: 4.1.2 Product code: GT-I8190MBADBT Phone version: I8190XXAMG4 PDA version: I8190XXAMG4 CSC version: I8190OXAAMG4 IMEI: 3560980553AAAAA8 Phone S/N: RF1DA0AAAAAK Checking Super user right... true Reading data from phone... OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Rebooting phone... OK Done with Samsung Tool v.19.1 |
10-17-2017, 13:37 | #19265 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Operation: Unlock Selected model: SM-G928T Selected port: COM6 Z3X BOX Serial Port Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 7.0 Product code: SM2G928T------ Phone version: G928TUVU4EQG3 PDA version: G928TUVU4EQG3 CSC version: G928TTMB4EQG3 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58H----- Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20160118 IMEI: 3525---------------- Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: A8 41 D5 8F 17 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.5 |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
10-17-2017, 14:00 | #19266 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G920A Network Unlock Code: Operation: Unlock Selected model: SM-G920A Software version: 29.4 Searching Samsung modem... detected COM104 Reading phone info... OK Model: SM-G920A AP version: G920AUCS4CPG1 CSC version: G920AATT4CPG1 CP version: G920AUCS4CPG1 Product code: SM2G920AZWAATT Phone SN: R38GA0N0HKW Unique number: 0715F765A15E153A Reading IMEI... OK IMEI: 358843063572920 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 |
10-17-2017, 14:01 | #19267 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J200H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J200H Software version: 29.2 Searching Samsung USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
10-17-2017, 14:02 | #19268 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J120A Frp Reset Code: Operation: Reset FRP Selected model: SM-J120A Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWCATT Phone version: J120AUCU2APJ1 PDA version: J120AUCU2APJ2 CSC version: J120AATT2APJ2 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58J23CF9PT Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-10-01 RF cal date: 20170215 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
10-17-2017, 14:03 | #19269 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J500H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 29.2 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
10-17-2017, 19:59 | #19271 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | G361F imei repair+patch cert done Code: [ 10/17/2017 9:53:00 PM ] Operation: Repair [ 10/17/2017 9:53:00 PM ] Selected model: SM-G361F [ 10/17/2017 9:53:00 PM ] Software version: 29.5 [ 10/17/2017 9:53:00 PM ] [ 10/17/2017 9:53:00 PM ] [ 10/17/2017 9:53:00 PM ] Waiting ADB device... OK [ 10/17/2017 9:53:00 PM ] Reading phone info... [ 10/17/2017 9:53:00 PM ] Model: SM-G361F [ 10/17/2017 9:53:00 PM ] Android version: 5.1.1 [ 10/17/2017 9:53:00 PM ] Product code: SM-G361FZSAOMN [ 10/17/2017 9:53:00 PM ] Phone version: G361FXXU1AOL1 [ 10/17/2017 9:53:00 PM ] PDA version: G361FXXU1AQD1 [ 10/17/2017 9:53:00 PM ] CSC version: G361FVFG1AQC2 [ 10/17/2017 9:53:00 PM ] CSC country code: ITALY [ 10/17/2017 9:53:00 PM ] CSC sales code: OMN [ 10/17/2017 9:53:00 PM ] HW version: MP 0.100 [ 10/17/2017 9:53:00 PM ] Phone SN: ____________ [ 10/17/2017 9:53:00 PM ] Modem board: [ 10/17/2017 9:53:00 PM ] Security patch: 2017-04-01 [ 10/17/2017 9:53:00 PM ] RF cal date: 20160412 [ 10/17/2017 9:53:00 PM ] IMEI: 2515925302514f0 [ 10/17/2017 9:53:00 PM ] Checking Super user right... true [ 10/17/2017 9:53:00 PM ] Reading NV data... OK [ 10/17/2017 9:53:00 PM ] Analyzing SEC file... OK [ 10/17/2017 9:53:00 PM ] Writing AT RIL... OK [ 10/17/2017 9:53:00 PM ] Initialization AT RIL... root required [ 10/17/2017 9:53:00 PM ] Checking Super user right... true [ 10/17/2017 9:53:00 PM ] Initialization AT RIL... OK [ 10/17/2017 9:53:00 PM ] Bypass MSL... OK [ 10/17/2017 9:53:00 PM ] Repairing IMEI... OK [ 10/17/2017 9:53:00 PM ] Rebooting phone... OK [ 10/17/2017 9:53:00 PM ] Repair done [ 10/17/2017 9:53:00 PM ] [ 10/17/2017 9:54:00 PM ] Operation: Patch Certificate [ 10/17/2017 9:54:00 PM ] Selected model: SM-G361F [ 10/17/2017 9:54:00 PM ] Software version: 29.5 [ 10/17/2017 9:54:00 PM ] [ 10/17/2017 9:54:00 PM ] Waiting ADB device... OK [ 10/17/2017 9:55:00 PM ] Reading phone info... [ 10/17/2017 9:55:00 PM ] Model: SM-G361F [ 10/17/2017 9:55:00 PM ] Android version: 5.1.1 [ 10/17/2017 9:55:00 PM ] Product code: SM-G361FZSAOMN [ 10/17/2017 9:55:00 PM ] Phone version: G361FXXU1AOL1 [ 10/17/2017 9:55:00 PM ] PDA version: G361FXXU1AQD1 [ 10/17/2017 9:55:00 PM ] CSC version: G361FVFG1AQC2 [ 10/17/2017 9:55:00 PM ] CSC country code: ITALY [ 10/17/2017 9:55:00 PM ] CSC sales code: OMN [ 10/17/2017 9:55:00 PM ] HW version: MP 0.100 [ 10/17/2017 9:55:00 PM ] Phone SN: ___________ [ 10/17/2017 9:55:00 PM ] Modem board: [ 10/17/2017 9:55:00 PM ] Security patch: 2017-04-01 [ 10/17/2017 9:55:00 PM ] RF cal date: 20160412 [ 10/17/2017 9:55:00 PM ] IMEI: 2515925302514f0 [ 10/17/2017 9:55:00 PM ] Checking Super user right... true [ 10/17/2017 9:55:00 PM ] Patching CERT check... OK [ 10/17/2017 9:55:00 PM ] Detecting MODEM... OK [ 10/17/2017 9:55:00 PM ] Reading modem... OK [ 10/17/2017 9:55:00 PM ] Patching modem... OK [ 10/17/2017 9:55:00 PM ] Writing modem... OK [ 10/17/2017 9:55:00 PM ] Rebooting phone... OK [ 10/17/2017 9:55:00 PM ] Patching CERT check... done |
10-18-2017, 13:21 | #19273 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | G925t unlock done Operation: Unlock Selected model: SM-G925T Selected port: COM1 Communications Port Software version: 29.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM2G925TZDATMB Phone version: G925TUVU5FQG3 PDA version: G925TUVU5FQG3 CSC version: G925TTMB5FQG3 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G909ET0B Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20150903 IMEI: 359715062341029 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 8A 2B 8E E5 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.5 |
10-19-2017, 07:12 | #19274 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-J730F Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-J730F Android version: 7.0 Product code: SM-J730FZKDAUT Phone version: J730FXXU1AQF4 PDA version: J730FXXU1AQF4 CSC version: J730FAUT1AQE4 CSC country code: Switzerland CSC sales code: AUT HW version: MP 0.400 Phone SN: RF8J80ELFVZ Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20170804 IMEI: 357074085230765 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: AA 6E C7 58 E5 59 02 4B F7 38 2F A0 CB 9A 76 68 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.5 |
10-19-2017, 08:16 | #19275 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-A320F Software version: 29.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-A320F Android version: 6.0.1 Product code: SM-A320FZKDXSG Phone version: A320FXXU1APLC PDA version: A320FXXU1APLD CSC version: A320FOJV1APLC CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RF8J30FMN1T Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-12-01 RF cal date: 20170304 IMEI: 3XXXXXXXXXXXXX0 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: D6 05 00 00 00 00 00 00 00 00 00 00 4B CE DD 72 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.5 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
