11-23-2017, 19:08 | #19426 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Egypt Age: 40
Member: 1382969 Status: Offline Sonork: 100.1679189 Thanks Meter: 30 | Operation: Read Codes Selected model: SM-J320F Software version: 29.9 Searching Samsung modem... detected COM19 Reading phone info... OK Model: SM-J320F Version: J320FXXU0API2/J320FITV0APH1/J320FXXU0APG2/J320FXXU0API2 Product code: SM-J320FZKDITV Phone SN: IMEI: Unique number: CQN001CC7D33F24 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:37) Freeze code: 70758571 NET lock: 90953149 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
11-24-2017, 08:45 | #19427 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-G950F Software version: 29.9 Checking Login and Password... OK Ballance: 46 crd. You have 46 credit(s) left. This opreratin takes 4 credits.Continue? Yes Searching Samsung modem... detected COM387 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQJ5 CSC version: G950FOXM1AQJ5 CP version: G950FXXU1AQJ5 Product code: DBT Phone SN: RF8J52A7M3T Unique number: CE041714C9A3803D02 Searching Samsung diag port... detected COM386 Reading phone info... OK CP version: G950FXXU1AQJ5 CP build: Oct 25 2017 16:31:24 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04159591 NET lock: 93169183 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
11-24-2017, 10:16 | #19428 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM388 SAMSUNG Mobile USB Serial Port Software version: 29.9 Checking Login and Password... OK Ballance: 42 crd. You have 42 credit(s) left. This opreratin takes 4 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G935A Android version: 7.0 Product code: SM-G935AZKAATT Phone version: G935AUCU4BQA6 PDA version: G935AUCU4BQA6 CSC version: G935AATT4BQA6 CSC country code: USA CSC sales code: ATT HW version: REV0.7 Phone SN: R38H30SQENT Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-02-01 RF cal date: 2016.03.22 IMEI: 357216071350921 Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 63617379 NET lock: 19205059 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
11-24-2017, 13:25 | #19429 (permalink) |
Junior Member Join Date: Jun 2017 Location: I LOVE MY INDIA
Member: 2723060 Status: Offline Sonork: I Dont Used Thanks Meter: 17 | Samsung Galaxy S8 SM-G950F Factory Unlock Done By Z3X Samsung Galaxy S8 SM-G950F Factory Unlock Done By Z3X Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-G950F Software version: 29.9 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 4 credits.Continue? Yes Searching Samsung modem... detected COM18 Reading phone info... OK Model: SM-G950F AP version: G950FXXU1AQH3 CSC version: G950FEVR1AQG6 CP version: G950FXXU1AQH3 Product code: EVR Phone SN: RF8J33EHYPL Unique number: CE021712D29F28730C Searching Samsung diag port... detected COM17 Reading phone info... OK CP version: G950FXXU1AQH3 CP build: Aug 8 2017 23:17:44 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 02619469 NET lock: 79420864 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
11-26-2017, 05:59 | #19431 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J106H Software version: 29.6 Searching Samsung USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.6 |
11-26-2017, 17:57 | #19432 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2293383 Status: Offline Thanks Meter: 11 | V30.1 Read CERT DIAG Fail SM-G950N KNOXx0000 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Read CERT DIAG Selected model: SM-G950N Software version: 30.1 Searching Samsung modem... detected COM76 Reading phone info... OK Model: SM-G950N AP version: G950NKSU1AQDC CSC version: G950NOKR1AQDC CP version: G950NKOU1AQDB Product code: SKC Phone SN: ce031713744264110c Unique number: CE031713744264110C Searching Samsung diag port... detected COM159 Reading phone info... OK CP version: G950NKOU1AQDB CP build: Apr 10 2017 17:20:15 Reading data from phone... error (4) Done with Samsung Tool PRO v.30.1 |
11-27-2017, 06:36 | #19433 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Duabi
Member: 2745836 Status: Offline Sonork: @djbeka Thanks Meter: 17 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G570F Software version: 30.1 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZDDCAC Phone version: G570FXXU1AQE8 PDA version: G570FXXU1AQC5 CSC version: G570FOXE1AQC1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.500 Phone SN: R58J65T7RYT Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-04-01 RF cal date: 20170704 IMEI: XXXXXXXXXXXXXXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 23) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.1 |
11-27-2017, 07:37 | #19434 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | FLASH INSTRUCTIONS: Phone must be powered off! 1. Select correct COM port in 'Port' options. 2. Choose correct flashfiles . 3. Press 'Flash' button. 4. Connect the phone to selected port with UART cable and press 'Power' button shortly or just insert cable to phone if you are using auto-ignition cable. (If you have connection problem, try to push 'Power' button while loader will be sent.) Operation: Flash Selected model: GT-E1200T Selected port: COM836 Z3X BOX Serial Port, 921600 Software version: 30.1 Connect phone, press power button Waiting phone... OK Sending PRELOADER... OK Flash ID: F8 (Fidelix_FM25M64A) Sending LOADER... OK Checking LOADER... OK Writing BIN... OK Writing LPD... OK Formatting TFS... OK Erasing TFS... OK Checking LOADER... OK Mounting TFS... OK Sending NAND checksum... OK Set time TFS... OK Creating TFS directories... OK Writing TFS VERSION... OK Writing TFS files... OK Unmounting TFS... OK Checking LOADER... OK Formatting CSC... OK Checking LOADER... OK Sending CSC checksum... OK Set time TFS... OK Creating CSC directories... OK Writing CSC files... OK Unmounting CSC... OK Flashing done (time - 00:07:09) Done with Samsung Tool PRO v.30.1 |
11-27-2017, 08:16 | #19435 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-A520F Software version: 30.1 Checking Login and Password... OK Ballance: 33 crd. You have 33 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM396 Reading phone info... OK Model: SM-A520F AP version: A520FXXS2BQIJ CSC version: A520FPHN2BQI3 CP version: A520FXXU2BQIE Product code: PHN Phone SN: R58J64EMJGD Unique number: CBJ10944A481E44 Searching Samsung diag port... detected COM397 Reading phone info... OK CP version: A520FXXU2BQIE CP build: Sep 19 2017 12:40:29 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 40635868 NET lock: 50793957 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
11-27-2017, 09:02 | #19436 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | J700f frp unlock by z3x Operation: Reset FRP Selected model: SM-J700F Software version: 30.1 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 Product code: SM-J700FZDDINS Phone version: J700FXXU4BQI2 PDA version: J700FXXU4BQI2 CSC version: J700FODD4BQI2 CSC country code: India CSC sales code: INS HW version: MP 0.800 Phone SN: RZ8J31439PP Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-08-01 RF cal date: 20170321 IMEI: 357151087101895 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.1 |
11-28-2017, 08:47 | #19437 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Samsung j701f 7.0 unlock success UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. Operation: Unlock Selected model: SM-J701F Software version: 29.6 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 Product code: SM-J701FZDDINS Phone version: J701FXXU2AQI4 PDA version: J701FDDU2AQI5 CSC version: J701FODD2AQI5 CSC country code: India CSC sales code: INS HW version: MP 0.400 Phone SN: RF8J81453MP Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170809 IMEI: 351569094653820 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: E1 A5 35 AC 1B EA 32 96 A4 99 70 03 46 EB 91 01 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.6 |
11-28-2017, 08:55 | #19438 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | Successfully Unlock Frp in just 5 sec thanks Z3X Operation: Reset FRP/React/EE Selected model: SM-J700H Software version: 29.6 Searching Samsung USB Flash interface... COM3 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.6 |
11-28-2017, 10:04 | #19439 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | sm-j710fn android 7.0 frp done Operation: Reset FRP Selected model: SM-J710FN Software version: 30.0 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 7.0 Product code: SM-J710FZDUCAC Phone version: J710FXXU3BQG9 PDA version: J710FXXU3BQHD CSC version: J710FOXY3BQHD CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.400 Phone SN: RF8HC1R6YXL Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20161215 IMEI: 352721087119850 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.0 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
