01-17-2018, 10:22 | #19801 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J327P Software version: 30.2.2 File analysis... OK Total file size: 0x51D9EA28 (1309 Mb) Searching USB Flash interface... COM30 detected Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending devcfg.mbn... OK Sending NON-HLOS.bin... OK Sending cmnlib.mbn... OK Sending keymaster.mbn... OK Sending lksecapp.mbn... OK Sending sec.dat... OK Sending apdp.mbn... OK Sending msadp.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending modem.bin... OK Sending adspso.bin... OK Sending cache.img.ext4... OK Sending carrier.img.ext4... OK Flashing done (time - 00:02:22) Done with Samsung Tool PRO v.30.2.2 ================================================== ================ UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP Selected model: SM-J327P Software version: 30.2.2 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU2AQI1 PDA version: FA60_J327PVPU2AQI1 CSC version: CSC country code: CSC sales code: HW version: J327P.03 Phone SN: 00000000000 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2016-11-01 RF cal date: 2017.03.15 IMEI: 356964086012130 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.2.2 ================================================== ================== FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J327P Software version: 30.2.2 Unpacking file... oK File analysis... OK Total file size: 0xDA34E780 (3491 Mb) Searching USB Flash interface... COM30 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending devcfg.mbn... OK Sending NON-HLOS.bin... OK Sending cmnlib.mbn... OK Sending keymaster.mbn... OK Sending lksecapp.mbn... OK Sending sec.dat... OK Sending apdp.mbn... OK Sending msadp.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending modem.bin... OK Sending adspso.bin... OK Sending cache.img.ext4... OK Flashing done (time - 00:05:45) Done with Samsung Tool PRO v.30.2.2 |
01-17-2018, 13:28 | #19802 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Samsung a720f unlocked Operation: Read Codes via Server Selected model: SM-A720F Software version: 30.5 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM85 Reading phone info... OK Model: SM-A720F AP version: A720FXXU2BQI9 CSC version: A720FOJV2BQI9 CP version: A720FXXU2BQI6 Product code: KSA Phone SN: R28JA2XZZ8R Unique number: CBJ10D587E2BF74 Searching Samsung diag port... detected COM86 Reading phone info... OK CP version: A720FXXU2BQI6 CP build: Sep 19 2017 11:30:25 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 41425847 NET lock: 97382639 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-17-2018, 16:06 | #19803 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | samsung g615 successfully read codes Operation: Read Codes Selected model: SM-G615F Software version: 30.5 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G615F Android version: 7.0 Product code: SM-G615FZKDINS Phone version: G615FXXU1AQL1 PDA version: G615FXXU1AQL1 CSC version: G615FODD1AQL1 CSC country code: India CSC sales code: INS HW version: MP 0.200 Phone SN: RZ8J90K22NB Chip name: MT6757 Modem board: MT6757 Security patch: 2017-12-01 RF cal date: 20170906 IMEI: 352093094043345 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM453 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:11) Freeze code: 46068396 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 47492949 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-17-2018, 18:40 | #19804 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Operation: Unlock Selected model: SM-G530T Software version: 30.5 Checking Login and Password... OK Ballance: 95 crd. You have 95 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G530T Android version: 5.1.1 Product code: SM-G530TZAATMB Phone version: G530TUVS2AQE3 PDA version: G530TUVS2AQE3 CSC version: G530TTMB2AQE3 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R28G70C9M5R Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-05-01 RF cal date: 2017.01.04 IMEI: Checking Super user right... true Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM16 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
01-17-2018, 18:41 | #19805 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Operation: Unlock Selected model: SM-J327T1 Software version: 30.4 Checking Login and Password... OK Ballance: 80 crd. You have 80 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J327T1 Android version: 7.0 Product code: SM2J327TZKATMK Phone version: J327T1UVU1AQCB PDA version: J327T1UVU1AQCB CSC version: J327T1TMK1AQCB CSC country code: USA CSC sales code: TMK HW version: REV0.1 Phone SN: R28J645ZP7L Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-03-01 RF cal date: 20170703 IMEI: 359617083862373 Searching Samsung diag port... detected COM27 Reading phone info... OK CP version: J327T1UVU1AQCB CP build: Mar 23 2017 16:54:01 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... Please, allow USB debugging on phone... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-17-2018, 18:41 | #19806 (permalink) |
01-17-2018, 19:57 | #19807 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | G355M unlock succes Operation: Unlock Selected model: SM-G355M Software version: 30.5 Searching Samsung modem... detected COM82 Reading phone info... OK Model: Version: Product code: Phone SN: IMEI: Unique number: Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
01-18-2018, 09:26 | #19808 (permalink) | |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
01-18-2018, 11:14 | #19809 (permalink) |
Freak Poster Join Date: Mar 2017 Location: In this world
Member: 2692991 Status: Offline Thanks Meter: 210 | n900t write cert done BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900T Selected port: COM5 Z3X BOX Serial Port, Software version: 20.5 Checking certificate file... OK KEY ID: 0813 Waiting ADB device... OK Reading phone info... Model: SM-N900T Android version: 5.0 Product code: SM-N900TZWETMB Phone version: N900TUVUFOL1 PDA version: N900TUVUFOL1 CSC version: N900TTMBFOL1 CSC country code: USA CSC sales code: TMB HW version: REV0.6 Phone S/N: RV1DB6SGGXV Modem board: MSM8974 RF cal date: 2013.11.23 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0813 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool v.20.5 |
01-18-2018, 12:19 | #19811 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2337014 Status: Offline Thanks Meter: 0 | Good afternoon, who will help to solve this problem? REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SGH-T959 Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SGH-T959 Android version: 2.2 Product code: Phone version: PDA version: T959UVKB5 CSC version: T959TMKKB5 CSC country code: USA CSC sales code: TMK HW version: Phone SN: Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... error (4.3) Done with Samsung Tool PRO v.30.5 |
01-18-2018, 15:24 | #19812 (permalink) |
Member: 2692991 Status: Offline Thanks Meter: 210 | Note 3 n900 read and write cert done Operation: Write CERT Selected model: SM-N900 Software version: 30.2.2 Checking CERT file... OK KEY ID: 0813 Waiting ADB device... OK Reading phone info... Model: SM-N900 Android version: 4.4.2 Product code: SM-N9000ZWESER Phone version: N900XXUEBNL6 PDA version: N900XXUDNA6 CSC version: N900SERDNA6 CSC country code: Russia CSC sales code: SER HW version: MP 0.600 Phone SN: RF1F425AN1M Modem board: XMM6360 RF cal date: 2014.4.22 IMEI: 35xxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 1 Calculating... OK Writing NV Data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.30.2.2 |
01-18-2018, 23:04 | #19814 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | J327T UNLOCK PERFECT VIA SERVER UNLOCK INSTRUCTIONS: Warning! Knox warranty must be active (0x00)! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Type *#0808# and select 'DM + MODEM + ADB' (or 'DM + ACM + ADB'). 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J327T Software version: 30.5 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J327T Android version: 7.0 Product code: SM2J327TZKATMB Phone version: J327TUVU1AQK6 PDA version: J327TUVU1AQK6 CSC version: J327TTMB1AQK6 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: RV8JB0NRQ9T Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-11-01 RF cal date: 20171110 IMEI: 35200209xxxxxxx Searching Samsung diag port... detected COM142 Reading phone info... OK CP version: J327TUVU1AQK6 CP build: Nov 20 2017 14:48:43 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
01-19-2018, 05:30 | #19815 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | SGH-Z500 unlock don Searching Samsung modem... detected COM138 Reading phone info... OK Model: 129 Phone version: Z500CGEF1 IMEI: 355909000312119 Reading codes... OK Freeze code: 12345678 NET lock: 61484158 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 9874 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
