Old 03-15-2018, 11:33   #20281 (permalink)
Member: 2643730
Thanks Meter: 260
J200g frp unlock by z3x in dm mode direct
Operation: Reset FRP/React/EE
Selected model: SM-J200G
Software version: 30.9
Searching Samsung USB Flash interface... COM186 detected
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.30.9
Old 03-15-2018, 13:34   #20282 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 106
Samsung n920a 7.0 unlock success
Old 03-15-2018, 14:52   #20283 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 745
Red face
SAMSUNG G870A FLASHING SUCCESFFUL DONE BY Z3XBOX
  FLASH INSTRUCTIONS:
  1. Choose correct flash file(s).
  2. If you have PIT file chosen, then you must check 'Repartition' option.
  3. Check flashing options if needed (Repartition, EFS clear, Boot update).
  4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
  5. Connect the phone to PC with USB cable, install drivers if needed.
  6. Press 'Flash' button.
Operation: Flash
Selected model: SM-G870A
File analysis... OK
Total file size: 0x98B44420 (2443 Mb)
Searching USB Flash interface... COM8 detected
Set PIT file... OK
Sending aboot.mbn... OK
Sending sbl1.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending sdi.mbn... OK
Sending NON-HLOS.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending persist.img.ext4... OK
Sending modem.bin... OK
Sending cache.img.ext4... OK
Flashing done (time - 00:04:21)
Old 03-15-2018, 20:51   #20284 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 450
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Enable 'USB debugging' in
'Settings'-'Applications'-'Development' for Android 2.x or
'Settings'-'Developer options' for Android 4.x.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Unlock
Selected model: GT-S6790L
Waiting ADB device... OK
Reading phone info...
Model: GT-S6790L
Android version: 4.1.2
Product code: GT-S6790PWLVMT
Phone version: S6790LUBAMK2
PDA version: S6790LUBAML1
CSC version: S6790LTFGANB1
CSC country code: OPEN
CSC sales code: TFG
HW version: MP 0.101
Phone SN: RV1F72WY13J
Modem board:
RF cal date: 20140724
IMEI: 35937xxxxxxxxxx
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Old 03-16-2018, 05:07   #20285 (permalink)
abikarki's Avatar
Member: 2670396
Thanks Meter: 120
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 11111111
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Selected model: SM-J210F
Software version: 31.0
Searching Samsung USB Flash interface... COM12 detected
Reset done
Done with Samsung Tool PRO v.31.0
Old 03-16-2018, 07:10   #20286 (permalink)
kathir.'s Avatar
Member: 880497
Thanks Meter: 184
Samsung S7 Edge 7.0 Frp Done With Ufs Method
Old 03-16-2018, 07:30   #20287 (permalink)
Member: 2643730
Thanks Meter: 260
G610f frp reset by z3x ,adb on by combination
Selected model: SM-G610F
Model: SM-G610F
Android version: 6.0.1
Product code: SM-G610FZDDINS
Phone version: G610FDDU1AQC2
PDA version: FA60_G610FDDU1AQC2
CSC version:
CSC country code:
CSC sales code:
HW version: MP 0.300
Phone SN: RZ8HA0KAE5E
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2016-08-01
RF cal date: 20161008
IMEI:
Bypass FRP... OK
Old 03-16-2018, 14:06   #20288 (permalink)
Member: 621121
Thanks Meter: 337
G610F unlock done
Operation: Read Codes DIAG
Software version: 30.8
Checking hash file... OK
Searching Samsung modem... detected COM85
Reading phone info... OK
Model: SM-G610F
AP version: G610FXWU1BQK3
CSC version: G610FOJW1BQK3
CP version: G610FXXU1BQJ4
Product code: KSA
Phone SN: R58J83YSPTH
Unique number: C000044356F0A64
Searching Samsung diag port... detected COM86
CP build: Oct 13 2017 19:19:38
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 81791614
NET lock: 62813728
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.30.8
The Following User Says Thank You to alamgir80 For This Useful Post:
Old 03-16-2018, 14:39   #20289 (permalink)
Member: 1537078
Thanks Meter: 450
Selected model: SM-J700P
Model: SM-J700P
Product code: Not Active
Phone version: J700PVPU1APH4
PDA version: J700PVPU1APH4
CSC version: J700PSPT1APH4
CSC country code: USA
CSC sales code: XAS
HW version: J700P.03
Phone SN: 00000000000
Chip name: MSM8929
Modem board: MSM8929
RF cal date: 2016.09.17
IMEI: 35562xxxxxxxxxx
Bypass FRP... OK
Old 03-16-2018, 17:06   #20290 (permalink)
Member: 901335
Sonork: 100.1652281
Thanks Meter: 148
SM-A310F UNLOCK done
SM-A310F UNLOCK DONE with new update
Selected model: SM-A310F
THANKS Z3x Operation: Unlock
Model: SM-A310F
Android version: 7.0
Product code: SM2A310FZDAXEH
Phone version: A310FXXU3CQL2
PDA version: A310FXXU3CQL2
CSC version: A310FOXX3CQL2
CSC country code: Hungary
CSC sales code: XEH
HW version: MP 0.200
Phone SN: R28H91WZ73E
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2017-12-01
RF cal date: 20160919
IMEI: 35416208xxxxxx
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID: 80 B0 82 C2 6D F6 C8 BF 52 94 64 45 35 D1 B9 C4
Calculating... OK
Unlocking... OK
Writing NV data... OK
Unlock done
Old 03-17-2018, 04:50   #20291 (permalink)
sr8787's Avatar
Member: 788946
Thanks Meter: 397
Samsung s8+ unlock done
Operation: Read Codes via Server
Selected model: SM-G955W
Selected port: COM79 SAMSUNG Mobile USB Serial Port
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes
Model: SM-G955W
Product code: SM-G955WZKAGLW
Phone version: G955WVLS2ARA1
PDA version: G955WVLS2ARA1
CSC version: G955WOYA2ARA1
CSC country code: Canada
CSC sales code: GLW
HW version: REV1.0
Phone SN: R28J93ND4ZH
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-01-01
RF cal date: 2017.09.27
IMEI: 3564xxxxxxxxxxx
Waiting for device to become ready... OK
Start... OK
Searching Ramdump interface... COM40 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 96025039
NET lock: 42419385
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Thanks z3x Team
Old 03-17-2018, 05:55   #20292 (permalink)
Member: 2216186
Sonork: 100.1668130
Thanks Meter: 115
Thumbs up LG-K33o TMO App Unlock
Mode: Normal
Model: LGK330AT
Build version: Nov 21 201614:40:17Nov 17 201500:00:00LGK330AT
SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1
IMEI: 35943607322499-3
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
Elapsed: 1 secs. --> (v9.48)
Ballance: 10 crd.
You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes
Searching modem interface... found COM165
IMEI: 359436073224993
Checking root rights... OK
Writing zTool... OK
SW Version: K33011e
Initialization zTool... (this can take 1-2 minutes) OK
Calculating... OK
Unlocking done
Elapsed: 210 secs. --> (v9.48)
Old 03-17-2018, 06:53   #20293 (permalink)
abikarki's Avatar
Member: 2670396
Thanks Meter: 120
Samsung N7100 emergency calls only Solved 31.0 downgrade 27.0 tool Network Patch
REPAIR INSTRUCTIONS:
2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity and make backup before.
8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed.
Operation: Patch Certificate
Selected model: GT-N7100
Software version: 27.0
Waiting ADB device... ok
Model: GT-N7100
Android version: 4.3
Phone version: N7100XXUENA3
PDA version: N7100XXUENA1
CSC version: N7100OJVENA1
CSC country code: UAE
CSC sales code: XSG
HW version: Unknown
Phone SN: RF1F22Z4ZFE
Modem board: XMM6262
RF cal date: Unknown
IMEI: 35261306
Reading modem ok
Patching modem... ok
Writing modem... ok
Reading kernel... ok
Patching kernel... ok
Writing kernel... ok
Rebooting phone... ok
Patching CERT check... done
Done with Samsung Tool PRO v.27.0
Old 03-17-2018, 09:25   #20294 (permalink)
abikarki's Avatar
Member: 2670396
Thanks Meter: 120
PUK - 12345678
PIN - 11111111
Operation: Unlock
Selected model: SM-J111F
Searching Samsung modem... detected COM23
Model: SM-J111F
Version: J111FXXU0AQI2/J111FOLB0AQI2/J111FXXU0AQE1/J111FXXU0AQI2
Product code: SM-J111FZBDXME
Phone SN: RV8J51EE89E
IMEI: 3576590********
Unique number: C8G01286AADD544
Unlocking... OK
Unlock done
Old 03-17-2018, 12:23   #20295 (permalink)
irfanakareem's Avatar
Member: 2630333
Thanks Meter: 67
SM-G930F (Reset FRP UFS)
Operation: Reset FRP UFS
Selected model: SM-G930F
Selected port: COM7 Z3X BOX Serial Port
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM7 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (G930F)
Reseting FRP... OK
Reset FRP done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1649 09-20-2018 20:36
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.29334 seconds with 9 queries
