07-06-2011, 20:25 | #4501 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Marocunlocking™
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | andrew_tm 2010(c) supported models: 201 Selected model: GS101 Selected port: COM133 Selected speed: 921600 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader Ok! Change BaudRate done! FlashId: 260600EC, flash size: 4Mb IMEI: 352231-04-266123-6 NCK Code: 2267 3528 0311 7979 Read eeprom... Eeprom saved to: C:\Program Files\Z3X\LG\LG2G\backup\EEPROM_GS101__05072011_20 3609.bin Patch eeprom data Recalc eeprom check sum... New check sum 0xEDB0 Write eeprom data... Start erase: 0x00BF0000-0x00C00000 OK! Start write 0x00BF0000-0x00C00000 OK! Unlock succesfully! Elapsed: 17 secs. --> (v.1.1.5beta) |
07-07-2011, 06:53 | #4502 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | C3200 Successfully Read Codes With Best Samsung Tool Network Lock. Code: Selected model: C3200 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK [Phone IMEI]:35298004243986 [Phone SN]:RQ1Z881505 [Phone HW]:MP 0.401 Wait for decrypted code... OK Decrypted time: 159 sec [PCK]:#0141*4747915# [NCK]:#0111*00000000# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*97227032# Read info - ok Elapsed time: 190 second, sw ver: 3.5.0020 Code: Selected model: C3200 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Use UART cable E210 or J750 Phone IMEI: 35298004243986/00 Phone SN: RQ1Z881505 Phone SN: C3200JPJG4 Phone user code: 112233 Read user code - ok Elapsed time: 5 second, sw ver: 3.5.0020 |
07-07-2011, 07:18 | #4503 (permalink) |
Freak Poster Join Date: Mar 2011 Location: m + koti hyd 95
Member: 1532828 Status: Offline Thanks Meter: 77 | samsung c3303 unlocking done Selected model: C3303 Selected com port: COM43 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Unlock block Unlock block Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 117 second, sw ver: 3.5.0020 ------------------------------------------------------------------------------- |
07-07-2011, 08:57 | #4504 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | E1310s unlock done Selected model: E1310S Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35427403014351 Phone SW: E1310SDDIE2 Phone BT ADDR: 0000-00-000000 Phone SN: RW3S561052 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 18 second, sw ver: 3.5.0025 Last edited by joni_rajpura; 07-07-2011 at 08:58. Reason: title |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
07-07-2011, 09:42 | #4505 (permalink) |
No Life Poster Join Date: May 2008 Location: gsm city
Member: 767786 Status: Offline Thanks Meter: 320 | Selected model: J750 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending NAND pre loader... OK Sending NAND loader... OK Unlock - ok Elapsed time: 58 second, sw ver: 3.5.0025 ------------------------------------------------------------------------------- |
07-07-2011, 10:43 | #4506 (permalink) |
Freak Poster Join Date: Jun 2003 Location: zimbab Age: 46
Member: 32705 Status: Offline Thanks Meter: 66 | Reading Phone Info... OK Model: GT-I5500 Country Code: H3G Cal Date: 2010-10-19 Factory SW: I5500XWJJ4_H3GJJ1 Unique Number: 86230000155161 Memory Phone: K5W4G2GACB(I5500) Phone S/N: RV1ZB86171 Build: M76XX-TSNCJOLYM-53303005 IMEI: 359763037220829 PDA/CSC Version: I5500XWJJ4/I5500H3GJJ1 Phone version: I5500NEJJ1 Phone HW: MP 0.700 Cal Date: 2010.11.02 Read Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 10.3 |
07-07-2011, 10:43 | #4507 (permalink) |
Member: 32705 Status: Offline Thanks Meter: 66 | Selected model: G600 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 35568302391368 Phone SW: G600ACHF1 Phone BT ADDR: 0023-3A-784316 Phone SN: RVMQA43161 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.5.0021 |
07-07-2011, 14:44 | #4508 (permalink) |
Member: 767786 Status: Offline Thanks Meter: 320 | m310 flash Selected model: M310 Selected com port: COM3 Selected speed port: 921600 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 19048352 byte segment 3 2001E000 144 byte segment 4 20016000 4652 byte segment 5 20078000 1093592 byte segment 6 2000C000 20128 byte segment 7 20058000 56 byte segment 8 20058138 18060 byte segment 9 2003803C 36688 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 010000427E22 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 8 Format FFS - wait... OK Send content - wait... OK Elapsed time: 522 second, sw ver: 3.5.0025 ------------------------------------------------------------------------------- |
07-07-2011, 18:35 | #4509 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | S7230e Selected model: S7230 Selected com port: COM19 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM19 Model: GT-S7230E CountryCode: SFR Factory SW: S7230EBUJK1_SFRJK1 UniqueNumber: 79500000244283 MemoryPhone: KAT00M020A(S7230) Phone IMEI: 35531204039184 /9 Phone S/N: RDKZC98869 Phone Bluetooth ID: 3C 5A 37 B4 E9 0C Phone SW: S723EBUJK1/S723ESFRJK1 Phone HW: MP 0.500 Phone CalData ver: 20101211 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:42490692 [NET LOCK]:42626486 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 32 sec Elapsed time: 42 second, sw ver: 3.5.0025 ------------------------------------------------------------------------------- |
07-07-2011, 18:58 | #4510 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Count supported models - 241 Searching Samsung USB Modem... Detected (COM47) Model: GT-I9000 SW: T959UVKA6 IMEI: 351801040065548 Done with Samsung Tool ver 10.5 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.2 Model: SGH-T959 Product Code: SGH-T959ZKMTMB Phone Version: T959UVKA6 PDA Version: T959UVKA6 CSC Version: T959TMKKA6 IMEI: 35180104xxxxxxx8 Rooting Phones... OK Restarting... OK Checking ROOT... TRUE Reading Codes... OK Detected SHA1 Codes Please Wait, Calculating Codes... OK (time - 00:00:58) MCK: 09648603 NCK: 64942485 UNLOCKED NSCK: 00000000 UNLOCKED SPCK: 00000000 UNLOCKED CPCK: 00000000 UNLOCKED Done with Samsung Tool ver 10.5 me try to unlock t 959 it will unlock o cool good result also me try to read user code its also done |
07-08-2011, 09:37 | #4511 (permalink) |
Member: 1532828 Status: Offline Thanks Meter: 77 | samsung e2120 & s5620 unlocking done Selected model: E2120 Selected com port: COM188 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 48 second, sw ver: 3.5.0020 ------------------------------------------------------------------------------- Selected model: S5620 Selected com port: COM188 Selected speed port: 921600 Phone must be ON and use z3x autoignition micro-uart cable Phone IMEI: 35205304359036 /6 Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 6 second, sw ver: 3.5.0020 ------------------------------------------------------------------------------- |
07-08-2011, 09:52 | #4512 (permalink) |
Member: 1532828 Status: Offline Thanks Meter: 77 | samsung s8300 user code unlocked Searching Samsung USB interface... detected (COM339) Model: S8300 SW: S8300ADID1 IMEI: 35904302649038/0 Reading codes... OK SIM lock: 00000000 Phone lock: 00000000 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM339) Model: S8300 SW: S8300ADID1 IMEI: 35904302649038/0 Reseting... OK (code - 00000000)! Done with Samsung 3G tool ver 9.4 |
07-08-2011, 12:10 | #4513 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Unlock e900 Selected model: E900 Selected com port: COM6 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: E900JVGA2 Langpack: Algeria, Egypt, Iran, Iraq, Kuwait, Morocco, Nigeria, Oman, Pakistan, Saudi Arabia, South Africa, Syria, Tunisia, Turkey IMEI: 35603001374258 S/N: R5XP566418 HW-> MP 1.110 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 001b98-cf4749 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is inactive [NETLOCK]: Use #0111*00000000# for deactivate this lock [SIMLOCK]: Use #0141*11234# for deactivate this lock Read info - ok Elapsed time: 14 second, sw ver: 3.5.0025 ------------------------------------------------------------------------------- Selected model: E900 Selected com port: COM6 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: E900JVGA2 IMEI: 35603001374258 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 12 second, sw ver: 3.5.0025 ------------------------------------------------------------------------------- |
07-08-2011, 14:02 | #4514 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | A817 unlocked Selected model: A817 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 354493********* Phone SW: A817UCJI6 Phone BT ADDR: 2013-E0-8EEE95 Phone SN: RPOB459723 [FREZEE]:14789632 [NET LOCK]:71133980 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:12369874 [Activa LOCK]:12369874 Read info - ok Elapsed time: 8 second, sw ver: 3.5.0025 Thanks to z3x team good work ... |
07-08-2011, 15:05 | #4515 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Successful Repair LG KP110 Code: Selected model: KP110 Selected port: COM6 Selected speed: 460800 Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 012100 Flash type: S71PL129NB0 Flash size: 16Mb IMEI: 352008-02-1363XX-X Read backup Start read data... Call.data saved to: C:\Program Files\Z3X\LG\LGTool\backup\CAL_KP110_352008021363XXX_05072011_140108.bin Read data done. Start erase CodeData... CodeData erase done... Start erase AlchemyData... AlchemyData erase done... Start write CodeData... Reading MOT file... Reading MOT file succesfully completed ! Start write AlchemyData... Reading MOT file... Reading MOT file succesfully completed ! Firmware write done. For operation finishing do next: - press "Disconnect" and power phone ON without SIM - press 2945#*# for entering eng. mode - select "Factory Reset" Elapsed: 578 secs. --> (v2.3 build 0053) Last edited by ...:::::NP™:::::...; 07-08-2011 at 15:12. |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
