Post here successfully unlock or IMEI repair LG Please, post result here. If not successfully unlock (or IMEI) - report model and SW :) -- andrew_tm 2009 :) |
U880 Unlock OK v.1.4.0 supported models: 53 andrew_tm 2008(c) ;) Mode: Normal Model: U880 Build version: Oct 28 200502:16:34JUL 3 2005 SW Version: U880-MSM6250-V10a-OCT-27-2005-H3G-SW IMEI: 35705000xxxx-5 BlueTooth Address: 00:12:56:C7:1A:97 Elapsed: 0 secs. Reading file as U880... Ok Patch Flash File: U880-MUSEDR-V10b-Feb-08-2006-H3G-IT Patch by andrew_tm(downgrade and fix UK phone unlock) and kller Mode: Normal Model: U880 Build version: Oct 28 200502:16:34JUL 3 2005 SW Version: U880-MSM6250-V10a-OCT-27-2005-H3G-SW IMEI: 35705000xxxx-5 BlueTooth Address: 00:12:56:C7:1A:97 Elapsed: 0 secs. NV read... NV save:..\backup\U880_35705000xxxx5_24042009_104040. cnv Elapsed: 11 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 1168 secs. Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-SW IMEI: 35705000xxxx-5 BlueTooth Address: 00:12:56:C7:1A:97 Elapsed: 0 secs. Start repair media... Change country to: Sweden Phone reboot! Elapsed: 7 secs. Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-SW IMEI: 35705000xxxx-5 BlueTooth Address: 00:12:56:C7:1A:97 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM19 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 117 secs. |
lg u890 3g unlock ok 1 Attachment(s) thank you z3x team, good work1 u890 unlock ok with all sim cards 32k,64k,128k v.1.4.0 supported models: 53 andrew_tm 2008(c) ;) Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 359xxxxxxxxxxx-x BlueTooth Address: 00:12:56:2A:08:88 Elapsed: 0 secs. Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-IT IMEI: 3592xxxxxxxx-x BlueTooth Address: 00:12:56:2A:08:88 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM40 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 98 secs. |
KF310 unlock ok v.1.4.0 supported models: 53 andrew_tm 2008(c) ;) Not detect phone! Please manual select port or reboot PC! Mode: Normal Model: KF310 Build version: May 02 200813:44:40Feb 26 200808:00:00KF310 SW Version: KF310-MSM6245-V10b-APR-18-2008-XX IMEI: 35423902426032-1 BlueTooth Address: 00:1F:E3:43:CA:20 Elapsed: 0 secs. Mode: Normal Model: KF310 Build version: May 02 200813:44:40Feb 26 200808:00:00KF310 SW Version: KF310-MSM6245-V10b-APR-18-2008-XX IMEI: 35423902426032-1 BlueTooth Address: 00:1F:E3:43:CA:20 Elapsed: 0 secs. Mode: Normal Model: KF310 Build version: May 02 200813:44:40Feb 26 200808:00:00KF310 SW Version: KF310-MSM6245-V10b-APR-18-2008-XX IMEI: 35423902426032-1 BlueTooth Address: 00:1F:E3:43:CA:20 Elapsed: 0 secs. Firmware signature in base: 88 Ver: May 02 200813:44:40Feb 26 200808:00:00KF310 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_ty9000a80 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\KF310_354239024260321_2804 2009_094851.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 9 secs. |
U900 unlock ok v.1.4.1 supported models: 54 andrew_tm 2009(c) ;) Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400439360-2 BlueTooth Address: 00:12:56:43:40:F6 Elapsed: 0 secs. Reading file as U900... Ok Original Flash File: U900-HCLSDR-V11g-Jan-23-2007-H3G-IT Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400439360-2 BlueTooth Address: 00:12:56:43:40:F6 Elapsed: 0 secs. NV read... NV save:..\backup\U900_359304004393602_04052009_18452 6.cnv Elapsed: 8 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 1120 secs. Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400439360-2 BlueTooth Address: 00:12:56:43:40:F6 Elapsed: 5 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM118 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 174 secs. thank you z3x team |
unlock u310:) 04/05/2009 14:13:09: v.1.4.1 04/05/2009 14:13:09: supported models: 54 04/05/2009 14:13:09: andrew_tm 2009(c) ;) 04/05/2009 14:13:09: 04/05/2009 14:27:54: Reading file as U310... 04/05/2009 14:27:59: Original Flash File: 04/05/2009 14:27:59: U310-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC 04/05/2009 14:27:59: 04/05/2009 14:27:59: Mode: Normal 04/05/2009 14:27:59: Model: U310 04/05/2009 14:27:59: Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 04/05/2009 14:27:59: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:27:59: IMEI: 35281801216744-0 04/05/2009 14:27:59: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:27:59: Elapsed: 0 secs. 04/05/2009 14:27:59: 04/05/2009 14:28:28: Mode: Normal 04/05/2009 14:28:28: Model: U310 04/05/2009 14:28:28: Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 04/05/2009 14:28:28: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:28:28: IMEI: 35281801216744-0 04/05/2009 14:28:28: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:28:28: Elapsed: 0 secs. 04/05/2009 14:28:28: 04/05/2009 14:28:28: Start Flash... 04/05/2009 14:28:28: Modem Write Start... 04/05/2009 14:33:30: Flash Verify Done. 04/05/2009 14:33:33: EFS Erase Done. 04/05/2009 14:33:33: Modem Write Done. 04/05/2009 14:33:33: Phone Reboot. 04/05/2009 14:34:20: Phone Detected! 04/05/2009 14:34:21: EFS Write Start... 04/05/2009 14:34:21: Start Write Media... 04/05/2009 14:36:18: Start Write Module... 04/05/2009 14:38:22: EFS Write Done. 04/05/2009 14:38:22: Flash Done. 04/05/2009 14:38:22: Elapsed: 593 secs. 04/05/2009 14:38:22: 04/05/2009 14:39:45: Mode: Normal 04/05/2009 14:39:45: Model: U310 04/05/2009 14:39:45: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:39:45: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:39:45: IMEI: 35281801216744-0 04/05/2009 14:39:45: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:39:45: Elapsed: 0 secs. 04/05/2009 14:39:45: 04/05/2009 14:39:47: Mode: Normal 04/05/2009 14:39:47: Model: U310 04/05/2009 14:39:47: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:39:47: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:39:47: IMEI: 35281801216744-0 04/05/2009 14:39:47: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:39:47: Elapsed: 0 secs. 04/05/2009 14:39:47: 04/05/2009 14:39:53: Mode: Normal 04/05/2009 14:39:53: Model: U310 04/05/2009 14:39:53: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:39:53: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:39:53: IMEI: 35281801216744-0 04/05/2009 14:39:53: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:39:53: Elapsed: 0 secs. 04/05/2009 14:39:53: 04/05/2009 14:39:53: Start Unlock... 04/05/2009 14:39:53: - Unlock stage #1... 04/05/2009 14:39:53: - Write data... 04/05/2009 14:39:59: - Phone reboot! 04/05/2009 14:40:09: - Select Modem Port:COM103 04/05/2009 14:40:09: - Unlock stage #2... 04/05/2009 14:40:36: - Unlock stage #3... 04/05/2009 14:40:38: - Unlock stage #4... 04/05/2009 14:40:38: - Start read nand... 04/05/2009 14:40:38: Error read nand page 04/05/2009 14:40:38: Elapsed: 45 secs. 04/05/2009 14:40:38: 04/05/2009 14:40:48: Mode: Normal 04/05/2009 14:40:48: Model: U310 04/05/2009 14:40:48: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:40:48: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:40:48: IMEI: 35281801216744-0 04/05/2009 14:40:48: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:40:48: Elapsed: 1 secs. 04/05/2009 14:40:48: 04/05/2009 14:40:49: Start Unlock... 04/05/2009 14:40:49: - Unlock stage #1... 04/05/2009 14:40:49: - Write data... 04/05/2009 14:40:54: - Phone reboot! 04/05/2009 14:42:11: - Select Modem Port:COM103 04/05/2009 14:42:11: - Unlock stage #2... 04/05/2009 14:42:37: - Unlock stage #3... 04/05/2009 14:42:39: - Unlock stage #4... 04/05/2009 14:42:39: - Start read nand... 04/05/2009 14:42:40: - Read nand done... 04/05/2009 14:42:40: - Start erase nand... 04/05/2009 14:42:40: - Erase done... 04/05/2009 14:42:40: - Start write nand... 04/05/2009 14:42:41: - Write nand done... 04/05/2009 14:42:41: - Start read nand... 04/05/2009 14:42:41: - Read nand done... 04/05/2009 14:42:41: - Start erase nand... 04/05/2009 14:42:41: - Erase done... 04/05/2009 14:42:41: - Start write nand... 04/05/2009 14:42:42: - Write nand done... 04/05/2009 14:42:42: Unlock done! 04/05/2009 14:42:42: Phone reboot! 04/05/2009 14:42:42: Elapsed: 114 secs. 04/05/2009 14:42:42: 04/05/2009 14:48:43: Mode: Normal 04/05/2009 14:48:43: Model: U310 04/05/2009 14:48:43: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:48:43: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:48:43: IMEI: 35281801216744-0 04/05/2009 14:48:43: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:48:43: Elapsed: 0 secs. 04/05/2009 14:48:43: 04/05/2009 14:48:52: Start repair media... 04/05/2009 14:48:52: Change country to: Italy 04/05/2009 14:48:56: Phone reboot! 04/05/2009 14:48:56: Elapsed: 13 secs. 04/05/2009 14:48:56: 04/05/2009 14:54:43: Mode: Normal 04/05/2009 14:54:43: Model: U310 04/05/2009 14:54:43: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:54:43: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:54:43: IMEI: 35281801216744-0 04/05/2009 14:54:43: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:54:43: Elapsed: 1 secs. 04/05/2009 14:54:43: 04/05/2009 14:54:55: Cancel by user. 04/05/2009 14:54:55: Elapsed: 13 secs. 04/05/2009 14:54:55: 04/05/2009 14:55:03: Mode: Normal 04/05/2009 14:55:03: Model: U310 04/05/2009 14:55:03: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:55:03: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:55:03: IMEI: 35281801216744-0 04/05/2009 14:55:03: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:55:03: Elapsed: 1 secs. 04/05/2009 14:55:04: 04/05/2009 14:55:07: Start repair media... 04/05/2009 14:55:07: Change country to: Indonesia 04/05/2009 14:55:13: Phone reboot! 04/05/2009 14:55:13: Elapsed: 9 secs. 04/05/2009 14:55:13: 04/05/2009 14:55:33: Mode: Normal 04/05/2009 14:55:33: Model: U310 04/05/2009 14:55:33: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:55:33: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:55:33: IMEI: 35281801216744-0 04/05/2009 14:55:33: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:55:33: Elapsed: 1 secs. 04/05/2009 14:55:33: 04/05/2009 14:55:50: Start repair media... 04/05/2009 14:55:50: Change country to: Austria 04/05/2009 14:55:55: Phone reboot! 04/05/2009 14:55:55: Elapsed: 21 secs. 04/05/2009 14:55:55: 04/05/2009 14:56:13: Mode: Normal 04/05/2009 14:56:13: Model: U310 04/05/2009 14:56:13: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 14:56:13: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 14:56:13: IMEI: 35281801216744-0 04/05/2009 14:56:13: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 14:56:13: Elapsed: 0 secs. 04/05/2009 14:56:13: 04/05/2009 14:56:24: Start repair media... 04/05/2009 14:56:24: Change country to: Italy 04/05/2009 14:56:28: Phone reboot! 04/05/2009 14:56:28: Elapsed: 15 secs. 04/05/2009 14:56:28: 04/05/2009 15:07:18: Mode: Normal 04/05/2009 15:07:18: Model: U310 04/05/2009 15:07:18: Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 04/05/2009 15:07:18: SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT 04/05/2009 15:07:18: IMEI: 35281801216744-0 04/05/2009 15:07:18: BlueTooth Address: 00:19:A1:62:BB:8B 04/05/2009 15:07:18: Elapsed: 0 secs. 04/05/2009 15:07:18: 04/05/2009 15:07:19: NV file: U310_network_ok.cnv 04/05/2009 15:07:19: NV File Version: 1 04/05/2009 15:07:19: NV File Model: U310 04/05/2009 15:07:19: NV Records: 360 04/05/2009 15:07:19: Write NV... 04/05/2009 15:07:30: Phone reboot! 04/05/2009 15:07:30: Elapsed: 12 secs. 04/05/2009 15:07:30: thankiu 4 z3x team;) |
LG T5100 Unlock OK, Selected model: T5100 Please reconnect battery. Press and hold power button Disconnected by user Selected model: T5100 Please reconnect battery. Press and hold power button Phone found Sending loader... Please wait... Sending loader succesfully completed Release power button Reading phone info... Flash ID: 017E21 Flash type: AMD - 2x16 Mb IMEI:354395-00-xxxx-2 Phone locked. NCK code:11252825 Reading Cal.Data into file.. Reading Cal.Data into file succesfully completed! Unlocking... Phone unlocked! |
ThankS to z3x team, lg cu720 unlock ok in 9 seconds v.1.4.0 supported models: 53 andrew_tm 2008(c) ;) Mode: Normal Model: CU720 Build version: Mar 26 200812:40:01Oct 03 200723:00:00CU720 SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI: 01178300XXXXXX-XX BlueTooth Address: 00:21:FB:75:8B:43 Elapsed: 0 secs. Firmware signature in base: 75 Ver: Mar 26 200812:40:01Oct 03 200723:00:00CU720 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU720_01178300XXXXXX_05052 009_140235.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 9 secs. |
u900 unlock done . Quote:
LG KP235 Unlocked OK Selected model: KP235 Selected port: COM3 Press and hold power button Phone found Sending loader... Please wait... Sending loader succesfully completed Reading phone info... Flash ID:898816 Flash type:PF38F4455LLZBQ0 Flash size:32Mb IMEI: 352127-02-154792-7 Software version: UNKNOWN Release power button Backuping Cal. data... Backuping Cal. data succesfully completed! Unlocking... Phone unlocked! |
CU920 Unlock done v.1.5.0 supported models: 57 andrew_tm 2009(c) ;) Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300385132-8 BlueTooth Address: 00:1F:E3:FE:54:D3 Elapsed: 0 secs. Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300385132-8 BlueTooth Address: 00:1F:E3:FE:54:D3 Elapsed: 0 secs. NV read... NV save:..\backup\CU920_011333003851328_22052009_1348 52.cnv Elapsed: 7 secs. Select Modem Port:COM6 Detect phone Ok! Start Unlock Unlock ERROR! Elapsed: 7 secs. Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300385132-8 BlueTooth Address: 00:1F:E3:FE:54:D3 Elapsed: 0 secs. NV read... NV save:..\backup\CU920_011333003851328_22052009_1349 22.cnv Elapsed: 7 secs. Select Modem Port:COM6 Detect phone Ok! Start Unlock Unlock ERROR! Elapsed: 7 secs. Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300385132-8 BlueTooth Address: 00:1F:E3:FE:54:D3 Elapsed: 0 secs. Firmware signature in base: 101 Ver: Sep 26 200809:12:01Jul 31 200811:00:00CU920 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU920_011333003851328_2205 2009_134943.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. Port already opened! Elapsed: 0 secs. Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300385132-8 BlueTooth Address: 00:1F:E3:FE:54:D3 Elapsed: 0 secs. NV file: CU920_011333003851328_22052009_134922.cnv NV File Version: 1 NV File Model: CU920 NV Records: 731 Write NV... Phone reboot! Elapsed: 12 secs. |
i forgot to save the logs.... but i have unlocked 3 ku250... all very well... it's been here for a month mow... from different repair shops that i know.. but one more piece of ku250 version MAy 17,2007 was not unlocked.... |
cu720 unlock done share ko lng po mga master... v.1.5.0 supported models: 57 andrew_tm 2009(c) ;) Mode: Normal Model: CU720 Build version: Mar 26 200812:40:01Oct 03 200723:00:00CU720 SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI: 01167900940786-5 BlueTooth Address: 00:21:FB:CA:3F:26 Elapsed: 0 secs. Mode: Normal Model: CU720 Build version: Mar 26 200812:40:01Oct 03 200723:00:00CU720 SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI: 01167900940786-5 BlueTooth Address: 00:21:FB:CA:3F:26 Elapsed: 0 secs. Mode: Normal Model: CU720 Build version: Mar 26 200812:40:01Oct 03 200723:00:00CU720 SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US IMEI: 01167900940786-5 BlueTooth Address: 00:21:FB:CA:3F:26 Elapsed: 0 secs. Firmware signature in base: 100 Ver: Mar 26 200812:40:01Oct 03 200723:00:00CU720 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU720_011679009407865_0406 2009_144626.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
LG cu920 unlock v.1.5.0 supported models: 57 andrew_tm 2009(c) ;) Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300807881-0 BlueTooth Address: 00:21:FB:6A:9A:ED Elapsed: 0 secs. Mode: Normal Model: CU920 Build version: Sep 26 200809:12:01Jul 31 200811:00:00CU920 SW Version: CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI: 01133300807881-0 BlueTooth Address: 00:21:FB:6A:9A:ED Elapsed: 0 secs. Firmware signature in base: 100 Ver: Sep 26 200809:12:01Jul 31 200811:00:00CU920 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU920_011333008078810_0306 2009_193506.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
lg u250 v.1.5.2 supported models: 60 andrew_tm 2009(c) ;) Mode: Normal Model: U250 Build version: May 19 200702:54:59May 19 200714:00:00U250 SW Version: U250-MSM6245-V10a-MAY-19-2007-XX IMEI: 356xxxxxxxxxxxx-0 BlueTooth Address: 00:1C:62:E5:14:D7 Elapsed: 0 secs. Firmware signature in base: 100 Ver: May 19 200702:54:59May 19 200714:00:00U250 Signature detected! Start send loader... Loader startup OK... Flash IC name: hynix_hyc0ueh0mf3 Security backup saved to: C:\Programmi\Z3X\LG\LGQ\Backup\U250_356xxxxxxxxxxx x_11062009_170842.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
