Operation: Unlock Selected model: SM-J500M Selected port: COM241 SAMSUNG Mobile USB Serial Port Software version: 30.9 Reading phone info... Reading IMEI... OK IMEI: 35977xxxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.30.9 |
MS210 FRP Reset LG 2-3G Tool v9.47 supported models: 1555 Port already opened! Elapsed: 0 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Port already opened! Elapsed: 0 secs. --> (v9.47) Port already opened! Elapsed: 0 secs. --> (v9.47) Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Port already opened! Elapsed: 0 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Mode: Normal Model: WX_PROJE Build version: Aug 25 201421:44:37Feb 12 201405:00:00WX_PROJE SW Version: M8610B-AAAANAZM-1.0.6038 IMEI: 01435600129937-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default SPC: 000000 Elapsed: 1 secs. --> (v9.47) Direct unlock Working with security zone Checking phone at COM48 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM49 Reboot phone Done Elapsed: 50 secs. --> (v9.47) Port already opened! Elapsed: 0 secs. --> (v9.47) Mode: Emergency Model: MS210 Read info... Laf Protocol: 01000004 Model name: LGMS210 Software verion: MS21010s Android verion: 7.0 Target operator: MPCS Target country: US Chipset: msm8937 IMEI: 353662089210058 Elapsed: 2 secs. --> (v9.47) Phone mode is DOWNLOAD Start reset FRP... Laf Protocol: 01000004 Model name: LGMS210 Software verion: MS21010s Android verion: 7.0 Target operator: MPCS Target country: US Chipset: msm8937 IMEI: 353662089210058 Init EXT4 ... FRP Reset done! Elapsed: 18 secs. --> (v9.47) |
MS323 unlock easy as 123... LG 2-3G Tool v9.47 supported models: 1555 Port already opened! Elapsed: 0 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Port already opened! Elapsed: 0 secs. --> (v9.47) Port already opened! Elapsed: 0 secs. --> (v9.47) Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Mode: Emergency Model: MS323 Read info... Laf Protocol: 01000001 Model name: LGMS323 Software verion: MS32310c Android verion: 4.4.2 Target operator: MPCS Target country: US Chipset: msm8610 IMEI: 014356001299379 Elapsed: 3 secs. --> (v9.47) Not supported in this mode! Port already opened! Elapsed: 0 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Mode: Normal Model: WX_PROJE Build version: Aug 25 201421:44:37Feb 12 201405:00:00WX_PROJE SW Version: M8610B-AAAANAZM-1.0.6038 IMEI: 01435600129937-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default SPC: 000000 Elapsed: 1 secs. --> (v9.47) Direct unlock Working with security zone Checking phone at COM48 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM49 Reboot phone Done Elapsed: 50 secs. --> (v9.47) |
SM-G925A Imei Repair Done REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925A Software version: 30.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G925A Android version: 6.0.1 Product code: SM-G925AZWAATT Phone version: G925AUCS4CPG1 PDA version: G925AUCS4CPG1 CSC version: G925AATT4CPG1 CSC country code: USA CSC sales code: ATT HW version: REV0.2 Phone SN: R38G30NC30D Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-07-01 RF cal date: 20150326 IMEI: 35.......... Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 9F 14 76 55 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.30.9 |
i get error, when trying to reset frp for my mp450. please help. |
here is the log Mode:Emergency Model: MS210 Read info... Laf Protocol: 01000006 Model name: LGMP450 Software version: MP45010e Android version: 7.0 Target operator: TMO Target country: US Chipset: msm8937 IMEI: 3532 Elapsed: 3 secs. --> (v9.48) Phone mode is DOWNLOAD Start reset FRP... Laf Protocol: 01000006 Model name: LGMP450 Software version: MP45010e Android version: 7.0 Target operator: TMO Target country: US Chipset: msm8937 IMEi: 3532 Init EXT4... Laf cmd info: send LAF_CMD_IOCTL, retry #1 Laf cmd info: send LAF_CMD_IOCTL, retry #2 Laf cmd info: send LAF_CMD_IOCTL, retry #3 Laf cmd error: LAF_CMD_IOCTL could not write. Error reset locks |
LG 2-3G Tool v9.47 supported models: 1555 Mode: Normal Model: LGH830AT Build version: Nov 7 201613:10:56Oct 19 201604:00:00LGH830AT SW Version: MPSS.TH.2.0.c1.4-00042-M8996FAAAANAZM-1.74312.1 IMEI: 35nnnnnnnnnnh Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.47) Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM8 Reading data from phone... OK IMEI: 35nnnnnnnnnnnnnn Checking root rights... OK Writing zTool... OK SW Version: H83020a Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 153 secs. --> (v9.47) |
UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J111F Software version: 31.0 Searching Samsung modem... detected COM23 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQI2/J111FOLB0AQI2/J111FXXU0AQE1/J111FXXU0AQI2 Product code: SM-J111FZBDXME Phone SN: RV8J51EE89E IMEI: 3576590******** Unique number: C8G01286AADD544 Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.31.0 |
LG-K330 TMO App Unlock done Mode: Normal Model: LGK330AT Build version: Nov 21 201614:40:17Nov 17 201500:00:00LGK330AT SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1 IMEI: 35943607320275-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.48) Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM172 Reading data from phone... OK IMEI: 359436073202759 Checking root rights... OK Writing zTool... OK SW Version: K33011e Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done;);) Elapsed: 182 secs. --> (v9.48) |
another one Mode: Normal Model: LGK330AT Build version: Oct 21 201617:11:57Nov 17 201500:00:00LGK330AT SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1 IMEI: 35943607305119-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.48) Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM160 Reading data from phone... OK IMEI: 359436073051198 Checking root rights... OK Writing zTool... OK SW Version: K33011d Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 179 secs. --> (v9.48) |
again and again Mode: Normal Model: LGK330AT Build version: Oct 21 201617:11:57Nov 17 201500:00:00LGK330AT SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1 IMEI: 35943607243376-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.48) Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM162 Reading data from phone... OK IMEI: 359436072433769 Checking root rights... OK Writing zTool... OK SW Version: K33011d Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 160 secs. --> (v9.48) |
Which box are you all using? octo,gcpro, z3x? Thanks |
Guess, I have to wait for solution. Thx |
