lg k430dse frp off LG 2-3G Tool v9.48 supported models: 1555 Start flashing. Start reset Google Account Lock... Laf Protocol: 01000004 Model name: LG-K430dsE Software verion: K43011o Android verion: 6.0 Target operator: GLOBAL Target country: COM Chipset: mt6753 IMEI1: 359123072408757 IMEI2: 359123072408765 Reset ... Reboot... Done. Elapsed: 5 secs. --> (v9.48) |
SAMSUNG SM-G850F unlock ok UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G850F Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G850F Android version: 5.0.2 Product code: SM-G850FZDESFR Phone version: G850FXXU1COJ5 PDA version: G850FXXS2CQD9 CSC version: G850FSFR2COJ2 CSC country code: France CSC sales code: SFR HW version: MP 1.100 Phone SN: RF8xxxxxxxx Modem board: XMM7260 RF cal date: 2014.10.8 IMEI: Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.31.0 |
Lg g stylo (lgms631) 6.0.1 unlock done :)LG 2-3G Tool v9.48 supported models: 1555 Mode: Normal Model: EAAAANVZ Build version: Jul 21 201603:22:06Dec 23 201522:00:00EAAAANVZ SW Version: MPSS.DPM.2.0.c11-00047-M8936FAAAANUZM-1.38601.2 IMEI: 35656707001759-3 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default Elapsed: 1 secs. --> (v9.48) Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM9 Reading data from phone... OK IMEI: 356567070017593 Checking root rights... OK Writing zTool... OK SW Version: MS63120c Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 133 secs. --> (v9.48);) |
Lg g stylo (lgms631) flash done LG 2-3G Tool v9.48 supported models: 1555 Mode: Emergency Model: MS631 Read info... Laf Protocol: 01000003 Model name: LGMS631 Software verion: MS63120c Android verion: 6.0 Target operator: MPCS Target country: US Chipset: msm8916 IMEI: 356567070017593 Elapsed: 4 secs. --> (v9.48) Phone mode is DOWNLOAD Start flashing. Laf Protocol: 01000003 JUL-21-2016+0.tot Model : LGMS631 SwVersion : MS63120c BuildTime : Total Files : 20 Model name: LGMS631 Software verion: MS63120c Android verion: 6.0 Target operator: MPCS Target country: US Chipset: msm8916 IMEI: 356567070017593 Start direct download mode Write "PrimaryGPT" partition #1 of 20 Write "sbl1" partition #2 of 20 Write "tz" partition #3 of 20 Write "hyp" partition #4 of 20 Write "rpm" partition #5 of 20 Write "aboot" partition #6 of 20 Write "sbl1bak" partition #7 of 20 Write "tzbak" partition #8 of 20 Write "hypbak" partition #9 of 20 Write "rpmbak" partition #10 of 20 Write "abootbak" partition #11 of 20 Write "persist" partition #12 of 20 Write "metadata" partition #13 of 20 Write "laf" partition #14 of 20 Write "boot" partition #15 of 20 Write "recovery" partition #16 of 20 Write "sec" partition #17 of 20 Write "factory" partition #18 of 20 Write "modem" partition #19 of 20 Write "system" partition #20 of 20 Erase "rct" partition Done. Elapsed: 238 secs. --> (v9.48) |
Welcome to Z3X LG Multi Platform TOOL Current OS : Windows Seven SP1 BUILD:6/7601 Welcome to Sgold3 Module!! Disconnected. TIP: Please reconnect phone battery / power source. Disconnected. TIP: Please reconnect phone battery / power source. Count supported models - 140 Loading module , please wait... PMB8877 Module 2.0 started. SW: Ver 3.7.1.4 Connecting to LG KP502 in UART Mode (COM1 ,921600) BOOT Failed Disconnected. TIP: Please reconnect phone battery / power source. Access violation at address 00670084 in module 'sgold3_tool.exe'. Write of address 0C5B4171 Selected port (COM3 )TX Buffer:0000 RX Buffer:1000 Loading module , please wait... PMB8877 Module 2.0 started. SW: Ver 3.7.1.4 Connecting to LG KP502 in UART Mode (COM3 ,921600) Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... Flash ID: 0xADBA Force boot mode on! Finished in 15 seconds Reading codes... Sending SEC pack... Reading ... Detailed Phone Information: Phone Model: KP500 Phone Manufacturer: LG Elec. Inc Phone Version: Aug 05 2008 Phone IMEI : 35405203712813200 Phone BT Adress : 20:21:A5:5E:80:3A Detailed Codes Information: Phone NCK Code : 3089-5692 Phone NS Code : 8597-4381 Phone SP Code : 2674-8412 Phone CP Code : 4348-3378 Phone SIM Code : 3033-4978 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): Finished in 3 seconds Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KP502_autobackup_26032018_144513.eep SimLocks Disabled SP Lock Enabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config:21401FFFFFFFFFFFFFFFFFFF SimLock Data Fixed! Writing EEPROM.... Sending SEC pack... Writing EEPROM.... Sending SEC pack... Unlock done! Finished in 11 seconds |
LG G4c h525n unlock done z3x Enable Diag Port 1) 277634#*# 2) Select Port check Test. 3) Set Port check Test to enabled. LG 2-3G Tool v9.48 supported models: 1555 Mode: Normal Model: EAAAANWZ Build version: Dec 22 201518:54:19Mar 31 201501:00:00EAAAANWZ SW Version: MPSS.DPM.2.0.c11-00018-M8936FAAAANUZM-1 IMEI: 35980806274549-5 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default SPC: 000000 Elapsed: 1 secs. --> (v9.48) Direct unlock Working with security zone Checking phone at COM39 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM40 Reboot phone Done Elapsed: 54 secs. --> (v9.48) |
K120 Screen Lock Select model k420n LG 2-3G Tool v9.48 supported models: 1555 Mode: Emergency Model: K420N Read info... Laf Protocol: 01000003 Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US Chipset: msm8909 IMEI: 356541072750360 Elapsed: 5 secs. --> (v9.48) Phone mode is DOWNLOAD Start reset screen locks... Laf Protocol: 01000003 Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US Chipset: msm8909 IMEI: 356541072750360 Init EXT4 ... Truncate file 0... done Truncate file 1... done Truncate file 2... done Truncate file 3... done Truncate file 4... done Truncate file 5... done Save EXT4... Screen locks removed. Elapsed: 19 secs. --> (v9.48) |
If problem, downgrade to 10c. Does not brick phone. Hit thanks button. |
Need unlock key for lg gb250 Hi, Please help me, I need unlock code for lg gb250 imei: 353620032307703 |
Operation: Write CERT Selected model: SM-G925T Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM-G925TZWATMB Phone version: G925TUVS6FRA3 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G522RE2V Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: 20150526 IMEI: 359146060950514 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 F1 43 2E E4 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0346 Checking certificate file... OK KEY ID: 0346 Crypting CERT 1... OK Writing NV data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.31.0 |
lg tp260 unlock ok here is success log Code: Mode: Normal |
LG 2-3G Tool v9.48 supported models: 1555 Repair IMEI... Checking phone at COM20 Detected ID: 00001010 (MSM8996) SW Version: MPSS.TH.2.0.c1.4-00032-M8996FAAAANAZM-1.59525.1.61245.1 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Laf cmd info: send LAF_CMD_HELLO, retry #1 Laf Protocol: 01000004 Model name: LG-H850TR Software verion: H85010i Android verion: 6.0.1 Target operator: GLOBAL Target country: COM Chipset: msm8996 IMEI: 35xx6xx7xxx4xx6 Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\H850TR_35xxxxxxxxxxxx_09042018_020156.lg sb1 Write security zone... Erase part1... done Erase part2... done Erase part3... done Reboot... Phone detected! Reading QCN file... OK Checking phone at COM20 Detected ID: 00001010 (MSM8996) SW Version: MPSS.TH.2.0.c1.4-00032-M8996FAAAANAZM-1.59525.1.61245.1 Read SPC... SPC: 000000 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Repair IMEI... Search LG Modem port... Detected LG Modem port at COM21 Repair done! Elapsed: 351 secs. --> (v9.48) |
LG 2-3G Tool v9.44 supported models: 1553 Not detect phone! Please manual select port or reboot PC! Mode: Emergency Model: D320TR Read info... Laf Protocol: 01000001 Model name: LG-D320TR Software verion: D32010l Android verion: 4.4.2 Target operator: GLOBAL Target country: COM Chipset: msm8610 IMEI: 3529xxxxxxxxxxx Elapsed: 8 secs. --> (v9.44) Mode: Emergency Model: D320TR Read info... Laf Protocol: 01000001 Model name: LG-D320TR Software verion: D32010l Android verion: 4.4.2 Target operator: GLOBAL Target country: COM Chipset: msm8610 IMEI: 35293xxxxxxxxxx Elapsed: 5 secs. --> (v9.44) Phone mode is DOWNLOAD Start flashing. Laf Protocol: 01000001 Open KDZ File : E:\LG\D320tr\D320tr10c_00.kdz Checking file hash... Model : LG-D320 SwVersion : D32010l BuildTime : 0000-00-00 00:00:00 Total Files : 30 Model name: LG-D320TR Software verion: D32010l Android verion: 4.4.2 Target operator: GLOBAL Target country: COM Chipset: msm8610 IMEI: 352xxxxxxxxxxx Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. Start direct download mode Write "PrimaryGPT" partition #1 of 30 Write "modem" partition #2 of 30 Write "sbl1" partition #3 of 30 Write "rpm" partition #4 of 30 Write "tz" partition #5 of 30 Write "sdi" partition #6 of 30 Write "aboot" partition #7 of 30 Write "rpmb" partition #8 of 30 Write "tzb" partition #9 of 30 Write "abootb" partition #10 of 30 Write "persist" partition #11 of 30 Write "laf" partition #12 of 30 Write "boot" partition #13 of 30 Write "recovery" partition #14 of 30 Write "factory" partition #15 of 30 Write "sbl1b" partition #16 of 30 Write "cust" partition #17 of 30 Write "system" partition #18 of 30 Write "system" partition #19 of 30 Write "system" partition #20 of 30 Write "system" partition #21 of 30 Write "system" partition #22 of 30 Write "system" partition #23 of 30 Write "system" partition #24 of 30 Write "system" partition #25 of 30 Write "system" partition #26 of 30 Write "system" partition #27 of 30 Write "system" partition #28 of 30 Write "system" partition #29 of 30 Write "BackupGPT" partition #30 of 30 Erase "rct" partition Done. Elapsed: 522 secs. --> (v9.44) |
LG t-mobile unlock done \par Checking Login and Password... OK \par Ballance: 15 crd. \par You have 15 credit(s) left. This operation takes 10 credits.Continue? Yes \par Searching modem interface... found COM95 \par Reading data from phone... OK \par IMEI: 358269074XXXXXX \par Checking root rights... OK \par Writing zTool... OK \par SW Version: K55020e \par Initialization zTool... (this can take 1-2 minutes) OK \par Reading data from phone... OK \par Calculating... OK \par Searching server... OK \par Waiting for server answer... OK \par Initialization zTool... (this can take 1-2 minutes) OK \par Reading data from phone... OK \par Unlocking done \par Elapsed: 175 secs. --> (v9.48) |
Samsung Galaxy J7 NEXT SM-J701F Costom Binarry Blocked BY FRP LOCK Done Z3X BY Full Flash Latest Firmware J701FXXU3AQL2 FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J701F Software version: 31.4 File analysis... OK Total file size: 0xE0836E14 (3592 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:38) Done with Samsung Tool PRO v.31.4 |
