Old 06-29-2017, 09:10   #1531 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,787
Originally Posted by wdjones817 View Post
LG VS988 - I'm trying to remove frp on the LG G6 (LG vs988) can this be done selecting a different model?
Sent from my SM-G920T using Tapatalk
Hi, Try as G6 H870 for example.
Old 06-29-2017, 14:57   #1532 (permalink)
Member: 2031642
Thanks Meter: 8
ok cool I'll give it a shot. I I'm just unsure of the process that the z3x Box takes to the FRP. Like for example with Samsung devices involves and Engineering bootloader usually that is specific to that model or more specifically each models perspective variant.
Old 07-06-2017, 13:28   #1533 (permalink)
bright hlatini's Avatar
Member: 1614640
Sonork: 100.1625899
Thanks Meter: 235
LG MS395 DIRECT UNlock DONE
LG 2-3G Tool v9.34
supported models: 1445
Mode: Normal
Model: MS395
Build version: Aug 17 201510:42:41Jul 21 201411:00:00MS395
SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1
IMEI: 355xxxxxxxx
BlueTooth Address: 00:00:00:00:00:06
Phone Code:
SPC: 000000
Elapsed: 5 secs. --> (v9.34)
Direct unlock
Working with security zone
Checking phone at COM428
Reboot phone
Phone detected!
Repair IMEI...
Search LG Modem port...
Detected LG Modem port at COM429
Reboot phone
Done
Elapsed: 65 secs. --> (v9.34)
The Following User Says Thank You to bright hlatini For This Useful Post:
Old 07-06-2017, 15:29   #1534 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 111
Thumbs up Lg k580z screen lock remove done
LG K580Z SCREEN LOCK REMOVED IN DOWNLOAD MODE
LG 2-3G Tool v9.32
supported models: 1440
***   Factory reset   ***
Bad answer!
Elapsed: 2 secs. --> (v9.32)
Bad answer!
Start flashing.
Start reset screen locks...
Model name: LG-K580Z
Software verion: K58010l
Android verion: 6.0
IMEI: 358770XXXXXXXX
Init EXT4 ...
Laf flash ext4 error: incorrect superblock magic
Erasing user data partition... done
Screen locks removed.
Done.
The Following User Says Thank You to Safyan sufi For This Useful Post:
Old 07-07-2017, 14:57   #1535 (permalink)
qaiser_ali123's Avatar
Member: 541180
Sonork: 100.1626680
Thanks Meter: 143
LG D850 FIRMWARE WRITE DONE WITH Z3X LG 2G TOOL
The Following User Says Thank You to qaiser_ali123 For This Useful Post:
Old 07-07-2017, 15:00   #1536 (permalink)
Member: 541180
Sonork: 100.1626680
Thanks Meter: 143
LGH811 FLASH DONE VIA Z3X LG 2G TOOL
[CENTER]
LGH811 FRP REMOVE DONE VIA Z3X LG 2G TOOL
[img]
The Following 2 Users Say Thank You to qaiser_ali123 For This Useful Post:
Old 07-07-2017, 17:33   #1537 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 12
LG V20-H918. FRP Done.. 7.0
LG 2-3G Tool v9.37
supported models: 1480
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 3 secs. --> (v9.37)
Mode: Emergency
Model: H918
Read info...
Model name: LG-H918
Software verion: H91810k
Android verion: 7.0
IMEI: 35222708073XXXX
Elapsed: 9 secs. --> (v9.37)
Phone mode is DOWNLOAD
Start reset FRP...
Model name: LG-H918
Android verion: 7.0
FRP Reset done!
Elapsed: 10 secs. --> (v9.37)
Old 07-08-2017, 15:52   #1538 (permalink)
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 13
not supported
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J320AZ
Software version: 28.2
Waiting ADB device... Ok
Reading phone info...
Model: SAMSUNG-SM-J320AZ
Android version: 6.0.1
Product code:
Phone version:
PDA version: J320AZTUS3AQD2
CSC version: J320AZAIO3AQD2
CSC country code: USA
CSC sales code: AIO
HW version:
Phone SN: R28H33SS5KT
Chip name: EXYNOS3475
Modem board:
Security patch: 2017-04-01
RF cal date:
IMEI:
Checking Super user right... false
Root your phone manually and then repeat
Done with Samsung Tool PRO v.28.2
The Following User Says Thank You to creconinfo For This Useful Post:
Old 07-08-2017, 22:52   #1539 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 12
Originally Posted by creconinfo View Post
not supported
Operation: Unlock
Product code:
Phone version:
CSC sales code: AIO
HW version:
Modem board:
RF cal date:
IMEI:
Flash modem Pj2 then unlock by code reading
Enviado desde mi SM-G955U mediante Tapatalk
Old 07-12-2017, 12:11   #1540 (permalink)
Member: 2661200
Thanks Meter: 6
LG 2-3G Tool v9.37
Check adb server status... OK
Found 1 device(s)
Device name: LG-P710
Firmware version: LGP710AT-01-V10d-214-01-MAR-10-2014+0
Android release: 4.1.2
Platform: msm7627a
Start root...
Send exploit: OK!
Install exploit: OK!
Root status: OK!
Read sec zone
Read sec zone OK!
Sec zone saved: C:\Program Files (x86)\Z3X\LG\LGTool\Backup\P710_356116050551708_12 072017_130104.lgsb
Security format: New
IMEI[1] block found!
IMEI[2] block not found!
SimLocks block found!
SimLocksCounter block found!
SimLocks clear OK!
Debug1!
Debug2!
Debug4!
Debug5!
Signature created!
Write sec zone
Write sec zone OK!
Write new signature
Write new signature OK!
Done!
Elapsed: 19 secs. --> (v9.37)
The Following User Says Thank You to evilcloud For This Useful Post:
Old 07-18-2017, 07:48   #1541 (permalink)
Member: 2318226
Thanks Meter: 13
LG 2-3G Tool v9.38
supported models: 1513
Mode: Emergency
Model: M154
Read info...
Model name: LGMS210
Software verion: MS21010g
Android verion: 7.0
Target operator: MPCS
Target country: US
IMEI: 357588081782040
Elapsed: 2 secs. --> (v9.38)
Start FRP remove...
Model name: LGMS210
Android verion: 7.0
Target country: US
Init EXT4 ...
Error reset locks
Mode: Emergency
Model: M154
Read info...
Model name: LG-M154
Software verion: M15410b
Android verion: 6.0.1
Target operator: CRK
Target country: US
IMEI: 355171080681729
Elapsed: 3 secs. --> (v9.38)
Start FRP remove...
Model name: LG-M154
Target country: US
Init EXT4 ...
Error reset locks
Mode: Emergency
Model: M154
Read info...
Model name: LG-M154
Target country: US
Start FRP remove...
Model name: LG-M154
Target country: US
Init EXT4 ...
Error reset locks
Old 07-19-2017, 10:53   #1542 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,787
Originally Posted by cold4501 View Post
LG 2-3G Tool v9.38
Mode: Emergency
Model: M154
Read info...
Model name: LGMS210
Android verion: 7.0
Target country: US
Start FRP remove...
Model name: LGMS210
Android verion: 7.0
Target country: US
Init EXT4 ...
Error reset locks
Mode: Emergency
Model: M154
Read info...
Model name: LG-M154
Target country: US
Start FRP remove...
Model name: LG-M154
Target country: US
Init EXT4 ...
Error reset locks
Mode: Emergency
Model: M154
Read info...
Model name: LG-M154
Target country: US
Start FRP remove...
Model name: LG-M154
Target country: US
Init EXT4 ...
Error reset locks
Make own thread. Try select K520DS and select new algo. Post result.
Old 08-07-2017, 11:13   #1543 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 131
LG 2-3G Tool v9.34
Not detect phone! Please manual select port or reboot PC!
Elapsed: 3 secs. --> (v9.34)
Elapsed: 2 secs. --> (v9.34)
Repair IMEI...
Detected LG Modem port at COM141
Repair done!
Elapsed: 15 secs. --> (v9.34)
The Following User Says Thank You to orhan5 For This Useful Post:
Old 08-10-2017, 12:44   #1544 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,053
LG H901 Flashing Done
Start flashing.
  Open TOT File : C:\Users\M Farhan\Downloads\Compressed\LGH901AT-01-V20l-310-260-OCT-04-2016-ARB02+0\LGH901AT-01-V20l-310-260-OCT-04-2016-ARB02+0.tot
  Model : LG-H901
  SwVersion : H90120l
  BuildTime :
  Total Files : 28
Model name: LG-H901
Software verion: H90120l
Android verion: 6.0
Target operator: TMO
Target country: US
IMEI: 354017074393899
Start direct download mode
Write "PrimaryGPT" partition #1 of 28
Write "modem" partition #2 of 28
Write "pmic" partition #3 of 28
Write "sbl1" partition #4 of 28
Write "tz" partition #5 of 28
Write "sdi" partition #6 of 28
Write "hyp" partition #7 of 28
Write "rpm" partition #8 of 28
Write "aboot" partition #9 of 28
Write "sbl1bak" partition #10 of 28
Write "pmicbak" partition #11 of 28
Write "hypbak" partition #12 of 28
Write "tzbak" partition #13 of 28
Write "rpmbak" partition #14 of 28
Write "abootbak" partition #15 of 28
Write "sdibak" partition #16 of 28
Write "apdp" partition #17 of 28
Write "msadp" partition #18 of 28
Write "persist" partition #19 of 28
Write "sec" partition #20 of 28
Write "laf" partition #21 of 28
Write "boot" partition #22 of 28
Write "recovery" partition #23 of 28
Write "raw_resources" partition #24 of 28
Write "raw_resourcesbak" partition #25 of 28
Write "factory" partition #26 of 28
Write "fau" partition #27 of 28
Write "system" partition #28 of 28
Erase "rct" partition
Done.
Elapsed: 350 secs. --> (v9.38)
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 08-12-2017, 14:50   #1545 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,053
LG H901 Frp Reset
LG 2-3G Tool v9.38
Start FRP remove...
Model name: LG-H901
Android verion: 6.0
Target country: US
Init EXT4 ...
Restore data detected!
Save EXT4...
FRP Restore Done!
Elapsed: 32 secs. --> (v9.38)
Post here successfully unlock or IMEI repair Samsung mk Z3X-Team Products 19275 Today 08:15
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.24422 seconds with 9 queries
