09-04-2009, 15:49 | #46 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | v.1.6.2 supported models: 68 andrew_tm 2009(c) Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK IMEI: 3xxxxxxxxxxxxxx-7 BlueTooth Address: 00:12:56:0A:67:F1 Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK IMEI: 3xxxxxxxxxxxxxxxxxx-7 BlueTooth Address: 00:12:56:0A:67:F1 Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM53 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 87 secs. |
The Following User Says Thank You to laduka For This Useful Post: |
09-05-2009, 07:59 | #47 (permalink) |
Insane Poster Join Date: May 2006 Location: Perú
Member: 282785 Status: Offline Thanks Meter: 13 | Unlock KE990 is ok v.1.6.3 beta supported models: 68 andrew_tm 2009(c) Mode: Normal Model: KE990 Build version: May 07 200809:04:48Feb 11 200814:00:00KE990 SW Version: KE990dAT-01-V10a-730-01-MAR-05-2008 IMEI: 0114760005xxxx-1 BlueTooth Address: 00:1F:E3:AC:59:41 Flash Name: toshiba_tya000bc00bogg Flash Info: 06D3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KE990 Build version: May 07 200809:04:48Feb 11 200814:00:00KE990 KE990dAT-01-V10a-730-01-MAR-05-2008 IMEI: 011476000xxxx5-1 BlueTooth Address: 00:1F:E3:AC:59:41 Flash Name: toshiba_tya000bc00bogg Flash Info: 06D3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KE990 Build version: May 07 200809:04:48Feb 11 200814:00:00KE990 SW Version: KE990dAT-01-V10a-730-01-MAR-05-2008 IMEI: 01147600054445-1 BlueTooth Address: 00:1F:E3:AC:59:41 Flash Name: toshiba_tya000bc00bogg Flash Info: 06D3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 156 Ver: May 07 200809:04:48Feb 11 200814:00:00KE990 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\andrew_tm\Backup\KE990_011476000544451_05092009 _011908.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 9 secs. TK Andrew Ronny Monty |
The Following User Says Thank You to ronnymonty For This Useful Post: |
09-05-2009, 13:31 | #49 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | KF310 NEW unlock ok KF310 done thanks z3x team Mode: Normal Model: KF310 Build version: Jun 02 200816:00:39Feb 26 200808:00:00KF310 SW Version: KF310-MSM6245-V10a-APR-24-2008-XX IMEI: 35423 BlueTooth Address: 00:22:A9:10:FC:82 Flash Name: toshiba_ty9000a800jogg Flash Info: 02FD/0040/0800 Elapsed: 0 secs. Firmware signature in base: 155 Ver: Jun 02 200816:00:39Feb 26 200808:00:00KF310 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_ty9000a80 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\KF310_35*******78_01012004 _074959.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
09-08-2009, 11:20 | #50 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | ku250 unlocked v.1.6.2 supported models: 68 andrew_tm 2009(c) Mode: Normal Model: KU250 Build version: Aug 13 200719:06:36Apr 29 200717:00:00KU250 SW Version: KU250-MSM6245-V10a-MAY-30-2007-XX IMEI: 35638501210769-9 BlueTooth Address: 00:1C:62:42F:91 Flash Name: hynix_hyc0ueh0mf3p Flash Info: 0996/0020/0200 Elapsed: 1 secs. Firmware signature in base: 155 Ver: Aug 13 200719:06:36Apr 29 200717:00:00KU250 Signature detected! Start send loader... Loader startup OK... Flash IC name: hynix_hyc0ueh0mf3 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\KU250_356385012107699_0809 2009_134016.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
09-11-2009, 07:14 | #51 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | v.1.6.2 supported models: 68 andrew_tm 2009(c) Mode: Normal Model: KU450 Build version: Aug 28 200718:21:52Mar 30 200706:00:00KU450 SW Version: KU450-M6250D-V10a-MAY-11-2007-V IMEI: 35658001224076-9 BlueTooth Address: 00:1C:62F:FF:A3 Flash Name: toshiba_ty9000ac10aobg Flash Info: 19B8/0020/0200 Elapsed: 0 secs. Mode: Normal Model: KU450 Build version: Aug 28 200718:21:52Mar 30 200706:00:00KU450 SW Version: KU450-M6250D-V10a-MAY-11-2007-V IMEI: 35658001224076-9 BlueTooth Address: 00:1C:62F:FF:A3 Flash Name: toshiba_ty9000ac10aobg Flash Info: 19B8/0020/0200 Elapsed: 0 secs. Start Unlock... Read data... Unlock data... Write data... Phone reboot! Elapsed: 21 secs. |
09-13-2009, 07:23 | #52 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | lg cu920 unlocked in seconds v.1.6.3 supported models: 68 andrew_tm 2009(c) Not detect phone! Please manual select port or reboot PC! Not detect phone! Please manual select port or reboot PC! Mode: Normal Model: CU920 Build version: Dec 12 200814:36:03Nov 10 200823:00:00CU920 SW Version: CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI: 01184700275291-4 BlueTooth Address: 00:24:83:47:C8:65 Flash Name: toshiba_tya000bc00dogg Flash Info: 0696/0040/0800 Elapsed: 0 secs. Mode: Normal Model: CU920 Build version: Dec 12 200814:36:03Nov 10 200823:00:00CU920 SW Version: CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI: 01184700275291-4 BlueTooth Address: 00:24:83:47:C8:65 Flash Name: toshiba_tya000bc00dogg Flash Info: 0696/0040/0800 Elapsed: 0 secs. Firmware signature in base: 158 Ver: Dec 12 200814:36:03Nov 10 200823:00:00CU920 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU920_011847002752914_1209 2009_153445.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
09-19-2009, 15:36 | #54 (permalink) |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | Mode: Normal Model: KU990 Build version: Aug 15 200815:54:16AUG 15 200817:00:00KU990 SW Version: KU990-MSM6280-V10i-AUG-15-2008-XX IMEI: 35xxxxxxxxxxx BlueTooth Address: 00:1F:E3:9B:BC:EE Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 157 Ver: Aug 15 200815:54:16AUG 15 200817:00:00KU990 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Archivos de programa\Z3X\LG\LGQ\Backup\KU990_354xxxxxx_1809200 9_175623.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
The Following User Says Thank You to mamepap For This Useful Post: |
09-21-2009, 07:03 | #55 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | U890 !!! Mode: Normal Model: U890 Build version: Jun 07 200615:56:10JUN 07 200617:00:00U890 SW Version: U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI: 35921300192642-3 BlueTooth Address: 00:12:56:36:EB:2F Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM13 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 120 secs. |
09-21-2009, 16:12 | #56 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | sucessful repair km900 arena when im open galery phone freeze before repair with z3xx special thanks to @andrew_tm br. |
09-25-2009, 10:52 | #59 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | Mode: Normal unlocked and changed language with languahe editor Model: U370 Build version: Oct 15 200706:42:09May 17 200714:00:00U370 SW Version: U370W-MSM6245-V10a-OCT-15-2007-XX IMEI: 35839101022771-9 BlueTooth Address: 00:1E:75:02:68:EE Flash Name: toshiba_ty9000a800jogg Flash Info: 0308/0040/0800 Elapsed: 0 secs. Firmware signature in base: 164 Ver: Oct 15 200706:42:09May 17 200714:00:00U370 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_ty9000a80 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\U370_358391010227719_25092 009_133443.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. 25.09.2009 13:40:34 > Mode: Normal 25.09.2009 13:40:34 > Model: U370 25.09.2009 13:40:34 > SW Version: U370W-MSM6245-V10a-OCT-15-2007-XX 25.09.2009 13:40:34 > IMEI: 358391-01-022771-9 25.09.2009 13:40:37 > Mode: Normal 25.09.2009 13:40:37 > Model: U370 25.09.2009 13:40:37 > SW Version: U370W-MSM6245-V10a-OCT-15-2007-XX 25.09.2009 13:40:37 > IMEI: 358391-01-022771-9 25.09.2009 13:40:37 > Please wait... 25.09.2009 13:40:38 > Reading language information... 25.09.2009 13:40:40 > Reading language information OK 25.09.2009 13:40:40 > Languages count: 7 25.09.2009 13:40:40 > Frases count: 7792 25.09.2009 13:40:40 > Downloading "Danish" language(1/7)... 25.09.2009 13:40:43 > Downloading "Danish" language OK 25.09.2009 13:40:43 > Downloading "Dutch" language(2/7)... 25.09.2009 13:40:45 > Downloading "Dutch" language OK 25.09.2009 13:40:45 > Downloading "English" language(3/7)... 25.09.2009 13:40:48 > Downloading "English" language OK 25.09.2009 13:40:48 > Downloading "French" language(4/7)... 25.09.2009 13:40:51 > Downloading "French" language OK 25.09.2009 13:40:51 > Downloading "German" language(5/7)... 25.09.2009 13:40:54 > Downloading "German" language OK 25.09.2009 13:40:54 > Downloading "Italian" language(6/7)... 25.09.2009 13:40:57 > Downloading "Italian" language OK 25.09.2009 13:40:57 > Downloading "Swedish" language(7/7)... 25.09.2009 13:40:59 > Downloading "Swedish" language OK 25.09.2009 13:40:59 > Searching XML resources... 25.09.2009 13:41:07 > XML resources count: 0 25.09.2009 13:41:07 > Downloading XML resources... 25.09.2009 13:41:07 > Downloading XML resources OK 25.09.2009 13:41:07 > Updating grid. Please wait... 25.09.2009 13:41:21 > Updating grid OK 25.09.2009 13:41:46 > Translating... 25.09.2009 13:42:39 > Translating successfully complete 25.09.2009 13:42:39 > Not translated: 20 25.09.2009 13:42:59 > Backuping NVM... 25.09.2009 13:43:04 > Backuping NVM OK 25.09.2009 13:43:07 > Checking version... 25.09.2009 13:43:08 > Checking version OK 25.09.2009 13:43:08 > Writing language information... 25.09.2009 13:43:11 > Writing language information OK 25.09.2009 13:43:11 > Packing "Danish" (1/7) language... 25.09.2009 13:43:11 > Packing "Danish" language OK 25.09.2009 13:43:11 > Writing "Danish" (1/7) language... 25.09.2009 13:43:16 > Writing "Danish" language OK 25.09.2009 13:43:16 > Packing "Dutch" (2/7) language... 25.09.2009 13:43:16 > Packing "Dutch" language OK 25.09.2009 13:43:17 > Writing "Dutch" (2/7) language... 25.09.2009 13:43:21 > Writing "Dutch" language OK 25.09.2009 13:43:21 > Packing "English" (3/7) language... 25.09.2009 13:43:22 > Packing "English" language OK 25.09.2009 13:43:22 > Writing "English" (3/7) language... 25.09.2009 13:43:27 > Writing "English" language OK 25.09.2009 13:43:27 > Packing "French" (4/7) language... 25.09.2009 13:43:27 > Packing "French" language OK 25.09.2009 13:43:27 > Writing "French" (4/7) language... 25.09.2009 13:43:32 > Writing "French" language OK 25.09.2009 13:43:32 > Packing "German" (5/7) language... 25.09.2009 13:43:33 > Packing "German" language OK 25.09.2009 13:43:33 > Writing "German" (5/7) language... 25.09.2009 13:43:38 > Writing "German" language OK 25.09.2009 13:43:38 > Packing "Italian" (6/7) language... 25.09.2009 13:43:38 > Packing "Italian" language OK 25.09.2009 13:43:38 > Writing "Italian" (6/7) language... 25.09.2009 13:43:43 > Writing "Italian" language OK 25.09.2009 13:43:43 > Packing "Swedish" (7/7) language... 25.09.2009 13:43:43 > Packing "Swedish" language OK 25.09.2009 13:43:44 > Writing "Swedish" (7/7) language... 25.09.2009 13:43:49 > Writing "Swedish" language OK 25.09.2009 13:43:49 > Rebooting phone |
09-29-2009, 16:11 | #60 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801231409-1 BlueTooth Address: 00:19:A1:63:FF:CA Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Not supported firmware! Flash phone! Elapsed: 0 secs. Reading file as U310... Ok Patch Flash File: U310-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC Lang(ver 1.0): -Russian -Ukrainian Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801231409-1 BlueTooth Address: 00:19:A1:63:FF:CA Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. NV read... NV save:..\backup\U310_352818012314091_29092009_12350 1.cnv Elapsed: 10 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 465 secs. Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801231409-1 BlueTooth Address: 00:19:A1:63:FF:CA Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM268 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 75 secs. |
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
