01-05-2011, 15:34 | #721 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.12 started. SW: Ver 2.2.8.0 Connecting to KP501 in UART Mode (COM45 ,921600) Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... Flash ID: 0xADBA BOOT Stage Finished , sending authority... Sending SEC pack... Reading eeprom ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP501_autobackup_05012011_163212.eep Analising EEPROM... Phone IMEI:351755043335649 Unlock codes: NCK[0]: 86974182 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 4 seconds Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP501_autobackup_05012011_163223.eep Analising EEPROM... Lock MCC+MNC:22610 SP Lock Cleared SIM Lock Cleared Phone IMEI:351755043335649 SimLock Data Cleared! Writing EEPROM.... Sending SEC pack... Unlock done! Finished in 8 seconds |
The Following User Says Thank You to sebY7676 For This Useful Post: |
01-05-2011, 16:10 | #722 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Abcyz.
Member: 1055074 Status: Offline Thanks Meter: 7,096 | Lg bl20 done.thanks andrew+z3x team v.2.1.1a supported models: 161 andrew_tm 2010(c) Mode: Normal Model: BL20 Build version: Feb 11 201016:44:06Jul 28 200924:00:00BL20 SW Version: BL20-QSC6270-V10c-FEB-11-2010-XX IMEI: 35654803126504-2 BlueTooth Address: 00:26:E2:15:B9:24 Elapsed: 0 secs. --> (v.2.1.1a) Selected file: C:\Documents and Settings\\Escritorio\z3x box\lg z3x files\BL20AT-00-V10d-EUR-XXX-SEP-24-2009+1_PATCH_UNLOCK_v2\BL20AT-00-V10d-EUR-XXX-SEP-24-2009+1_PATCH_UNLOCK_v2.crp1 Mode: Normal Model: BL20 Build version: Feb 11 201016:44:06Jul 28 200924:00:00BL20 SW Version: BL20-QSC6270-V10c-FEB-11-2010-XX IMEI: 35654803126504-2 BlueTooth Address: 00:26:E2:15:B9:24 Elapsed: 0 secs. --> (v.2.1.1a) NV read... NV save:..\backup\BL20_356548031265042_05012011_15565 1.cnv Elapsed: 49 secs. --> (v.2.1.1a) Start flashing in Normal Mode Change mode... Phone Detected! Start write AMSS... AMSS write done! Start write BootLogo... Bootlogo write done! Erase EFS Initialize EFS Start write EFS... EFS write done! Reboot phone! Elapsed: 206 secs. --> (v.2.1.1a) Mode: Normal Model: BL20 Build version: Nov 13 200917:06:18Jul 28 200924:00:00BL20 SW Version: BL20-QSC6270-V10d-SEP-24-2009-XX IMEI: 35654803126504-2 BlueTooth Address: 00:26:E2:15:B9:24 Elapsed: 0 secs. --> (v.2.1.1a) Phone in Normal mode! Switch mode! Start send loader... Loader startup OK... Loader Init OK... Sec Pages read OK IMEI pages SignVerify TRUE Lock pages SignVerify TRUE Phone Sec Info: IMEI: 356548031265042 Wtite Sec pages OK Read new data... Sec Pages read OK IMEI pages SignVerify TRUE Lock pages SignVerify TRUE Phone Sec Info: IMEI: 356548031265042 Unlock done! Elapsed: 26 secs. --> (v.2.1.1a) Not detect phone! Please manual select port or reboot PC! Mode: Normal Model: BL20 Build version: Nov 13 200917:06:18Jul 28 200924:00:00BL20 SW Version: BL20-QSC6270-V10d-SEP-24-2009-XX IMEI: 35654803126504-2 BlueTooth Address: 00:26:E2:15:B9:24 Elapsed: 0 secs. --> (v.2.1.1a) Mode: Normal Model: BL20 Build version: Nov 13 200917:06:18Jul 28 200924:00:00BL20 SW Version: BL20-QSC6270-V10d-SEP-24-2009-XX IMEI: 35654803126504-2 BlueTooth Address: 00:26:E2:15:B9:24 Elapsed: 0 secs. --> (v.2.1.1a) Ver: Nov 13 200917:06:18Jul 28 200924:00:00BL20 Unlock done! Elapsed: 1 secs. --> (v.2.1.1a) |
The Following User Says Thank You to dani2080 For This Useful Post: |
01-06-2011, 12:24 | #724 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Loading module , please wait... PMB8877 Module 1.21 started. SW: Ver 2.2.8.0 Connecting to GS290 in UART Mode (COM13 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_06012 011_162121.eep Analising EEPROM... Phone IMEI:359289035313424 Unlock codes: NCK[0]: 5282228775769579 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds |
The Following User Says Thank You to cel_phon For This Useful Post: |
01-06-2011, 12:56 | #725 (permalink) |
Freak Poster Join Date: Mar 2006 Location: philippines
Member: 245748 Status: Offline Thanks Meter: 91 | su410 v.2.1.2 supported models: 166 andrew_tm 2010(c) Mode: Normal Model: SU410905 Build version: Mar 02 201014:16:51Jan 07 200819:00:00SU410905 SW Version: M6281A-KLVZ-4.0.9530T IMEI: 35810903214473-2 BlueTooth Address: 8C:54:1D:33:2DB Phone Code: DEAD Flash Name: samsung_k512h1gaca Flash Info: 05B2/0040/0800 Elapsed: 0 secs. --> (v.2.1.2) Mode: Normal Model: SU410905 Build version: Mar 02 201014:16:51Jan 07 200819:00:00SU410905 SW Version: M6281A-KLVZ-4.0.9530T IMEI: 35810903214473-2 BlueTooth Address: 8C:54:1D:33:2DB Phone Code: DEAD Flash Name: samsung_k512h1gaca Flash Info: 05B2/0040/0800 Elapsed: 0 secs. --> (v.2.1.2) Send preloader... Send loader... Loader startup Ok! Init NAND Ok! Ver: Mar 02 201014:16:51Jan 07 200819:00:00SU410905 page:00002980 Start erase block... Erase done. Write data... Write done! Unlock done. Elapsed: 4 secs. --> (v.2.1.2) |
The Following User Says Thank You to markali2006 For This Useful Post: |
01-06-2011, 14:41 | #726 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | kp500 unlock done by changing imei Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Repairing IMEI... , phone must be powered on! Current IMEI:K Writing new IMEI:35863001238523 Result is: my handset did not unlock through enter code by using test card then i changed imei and my problem solved |
The Following User Says Thank You to neeraj1st For This Useful Post: |
01-06-2011, 16:00 | #727 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.12 started. SW: Ver 2.2.8.0 Connecting to KP500 in UART Mode (COM203 ,921600) Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... Flash ID: 0xADBA BOOT Stage Finished , sending authority... Sending SEC pack... Reading eeprom ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP500_autobackup_06012 011_165741.eep Analising EEPROM... Phone IMEI:351785032357874 Unlock codes: NCK[0]: 77551839 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds Repairing EEPROM... Writing EEPROM.... Sending SEC pack... Repair done! , dont forget to correct IMEI Finished in 4 seconds Unlocking... Sending SEC pack... |
01-06-2011, 16:37 | #728 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | blang what is the wrong of her Analising EEPROM... Phone IMEI:353244030827056 Unlock codes: NCK[0]: 95562806 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 4 seconds Access violation at address 1325978B in module 'sgold3_tool.exe'. Read of address 30303199 Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\TE365_autobackup_06012 011_192739.eep Analising EEPROM... Phone IMEI:353244030827056 SimLock Data Cleared! Writing EEPROM.... Sending SEC pack... Unlock done! Finished in 8 seconds Terminating Work Thread... Canceled by user! but phonr is not unlock |
The Following User Says Thank You to FEATURE GSM™ For This Useful Post: |
01-06-2011, 18:17 | #729 (permalink) |
Member: 1055074 Status: Offline Thanks Meter: 7,096 | Lg gw520 done.thanks andrew tm. Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8878U Module 1.0a started. SW: Ver 2.2.8.0 Connecting to GW520 in USB Mode... Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GW520_autobackup_06 012011_181501.eep Analising EEPROM... Phone IMEI:353638034022038 Unlock codes: NCK[0]: 8434979935126202 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 1 seconds ***Disconnected*** |
01-07-2011, 14:05 | #731 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | gm 205 Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 89887E Flash type: PF38F5060M0Y0BE Flash size: 64Mb IMEI: 359931-03-043104-6 Read eeprom... Patch call. data Write eeprom... Unlock succesfully! Elapsed: 194 secs. --> (v.1.1.5beta) |
The Following User Says Thank You to GSM SKILS For This Useful Post: |
01-07-2011, 14:47 | #732 (permalink) |
Member: 1055074 Status: Offline Thanks Meter: 7,096 | lg km900 arena done TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in UART Mode (COM77 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C: Analising EEPROM... Unlock codes: NCK[0]: 8370935535177056 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 2 seconds |
01-07-2011, 18:56 | #733 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Unlock center
Member: 738696 Status: Offline Sonork: 100.1594145 Thanks Meter: 197 | unlock succeful lg bl20 Phone in Normal mode! Switch mode! Start send loader... Loader startup OK... Loader Init OK... Sec Pages read OK IMEI pages SignVerify TRUE Lock pages SignVerify TRUE Phone Sec Info: IMEI: xxxxxxxxxxxxxxxxxxxxxxx Wtite Sec pages OK Read new data... Sec Pages read OK IMEI pages SignVerify TRUE Lock pages SignVerify TRUE Phone Sec Info: IMEI: xxxxxxxxxxxxxxxxxxxxxx Unlock done! Elapsed: 25 secs. --> (v.2.1.1a) |
The Following User Says Thank You to moha6 For This Useful Post: |
01-08-2011, 12:45 | #734 (permalink) |
Member: 1055074 Status: Offline Thanks Meter: 7,096 | Selected model: GB102 Selected port: COM77 Selected speed: 115200 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader ok! Change BaudRate done! FlashId: 011A0001, flash size: 4Mb IMEI: 359164-03-694868-6 NCK Code: 35585856 SIM Lock enabled: Yes SIM Code Protection enabled: Yes IMEI Protection enabled: No Phone disconnected |
01-08-2011, 12:49 | #735 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | lg kp100n unlock done 1.1.4beta andrew_tm 2010(c) supported models: 198 Selected model: KP100 Selected port: COM10 Selected speed: 921600 Connect phone and press Power ON! Connect error! Selected model: KP100 Selected port: COM10 Selected speed: 921600 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader ok! Change BaudRate done! FlashId: 011A0001, flash size: 4Mb IMEI: 358479-02-895772-2 NCK Code: 06524265 SIM Lock enabled: Yes SIM Code Protection enabled: Yes IMEI Protection enabled: No Start unlock... Unlock done! Elapsed: 5 secs. --> (v.1.1.4beta) |
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
