Old 03-05-2011, 09:53   #886 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 266
u 450 unlock done
v.2.1.1
supported models: 161
andrew_tm 2010(c)
Mode: Normal
Model: U450
Build version: May 04 200712:01:27MAY 09 200617:00:00U450
SW Version: U450-MSM6250-V10a-MAY-04-2007-H3G-IT
IMEI: 35658001054014-5
BlueTooth Address: 00:1C:62:12:AB:BF
Flash Name: toshiba_ty9000ac10aobg
Flash Info: 18D2/0020/0200
Elapsed: 0 secs. --> (v.2.1.1)
Mode: Normal
Model: U450
Start Unlock...
- Unlock stage #1...
- Write data...
- Phone reboot!
- Select Modem Port:COM68
- Unlock stage #2...
- Unlock stage #3...
- Unlock stage #4...
- Start read nand...
- Read nand done...
- Start erase nand...
- Erase done...
- Start write nand...
- Write nand done...
- Read nand done...
- Erase done...
Unlock done!
Phone reboot!
Elapsed: 311 secs. --> (v.2.1.1)
The Following User Says Thank You to neeraj1st For This Useful Post:
Old 03-06-2011, 08:03   #887 (permalink)
kushol's Avatar
Member: 293662
Sonork: 100.1622609
Thanks Meter: 315
Welcome to LG Infineon SGOLD3 TOOL v2x by NoNameŽ
Models count: 88
Current OS : Windows XP
Welcome to Sgold3 Module!!
Count supported models - 88
***Disconnected***
TIP: Please reconnect phone battery / power source.
Port list updated!
Loading module , please wait...
PMB8877 Module 1.3 started. SW: Ver 2.3.0.1
Connecting to GT350 in UART Mode (COM13 ,921600)
Please reconnect battery, press and hold power button...
Phone found! (MCU:PMB8877) prebooting...
Release power button. Booting...
Reading info...
BOOT Stage Finished , sending authority...
Sending SEC pack...
Reading EEPROM...
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GT350_autobackup_07032 011_015257.eep
Analising EEPROM...
Phone IMEI:351625041083790
Unlock codes:
NCK[0]: 9771052349894687 (LOCKED)
TIP: For additional codes , select Read Codes option and click Unlock button
Finished in 2 seconds
The Following User Says Thank You to kushol For This Useful Post:
Old 03-06-2011, 08:42   #888 (permalink)
silicon brj's Avatar
Member: 622060
Thanks Meter: 36
hi i m getting error message when unlocking ku 990 plz, help me,, i m using qualcom tool v2.1.3,with usb cable ku-311 plz give solution
Old 03-06-2011, 13:15   #889 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 221
ku 9100
Mode: Normal
Model: KU910910
Build version: Jan 01 201018:26:00Aug 14 200719:00:00KU910910
SW Version: M6280A-KLRZ-4.0.95T
IMEI: 35256303508888-0
BlueTooth Address: 0D:47:4D:7E:BB:01
Phone Code: default
Flash Name: H8ACS0SJ0MCP
Flash Info: 05AC/0040/0800
Elapsed: 0 secs. --> (v.2.1.4)
Send preloader...
Send loader...
Loader startup Ok!
Init NAND Ok!
Ver: Jan 01 201018:26:00Aug 14 200719:00:00KU910910
page:00002D00
Start erase block...
Erase done.
Write data...
Write done!
Unlock done.
Elapsed: 7 secs. --> (v.2.1.4)
The Following User Says Thank You to GSM SKILS For This Useful Post:
Old 03-07-2011, 10:29   #890 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
Connecting to KP500 in UART Mode (COM10 ,921600)
Reading info...
Flash ID: 0xADBA
Sending SEC pack...
Reading eeprom ...
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP500_autobackup_07032 011_152718.eep
Analising EEPROM...
Phone IMEI:359068027957178
Unlock codes:
NCK[0]: 15595305 (LOCKED)
Finished in 6 seconds
Unlocking...
Sending SEC pack...
Reading EEPROM....
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP500_autobackup_07032 011_152729.eep
Analising EEPROM...
Lock MCC+MNC:23410
SP Lock Cleared
SimLock Data Cleared!
Writing EEPROM....
Sending SEC pack...
Unlock done!
Finished in 10 seconds
The Following User Says Thank You to cel_phon For This Useful Post:
Old 03-07-2011, 12:32   #891 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
>>> LG CU720 Unlocked <<<
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 03-07-2011, 12:33   #892 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,159
>>> Alcatel VM800 Unlocked <<<
Old 03-07-2011, 20:57   #893 (permalink)
Member: 1353395
Sonork: 100.1607424
Thanks Meter: 99
v.2.1.5
supported models: 383
andrew_tm 2010(c)
Mode: Normal
Model: KF310
Build version: Jun 02 200814:43:27Feb 26 200808:00:00KF310
SW Version: KF310-MSM6245-V10b-APR-18-2008-XX
IMEI: 35423902713158-6
BlueTooth Address: 00:22:A9:0A:91:75
Phone Code: default
Flash Name: toshiba_ty9000a800jogg
Flash Info: 02FD/0040/0800
Elapsed: 0 secs. --> (v.2.1.5)
Mode: Normal
Model: KF310
Phone Code: default
Send loader...
Loader startup Ok!
Init NAND Ok!
Security backup saved to:
C:\Archivos de programa\Z3X\LG\LGTool\Backup\KF310_35423902713158 6_07032011_214851.sec
Erase sec. zone...
Write data to Phone..
Reading timeout, check cable
Error Code:
Error Code:
Phone rebooted!
Elapsed: 29 secs. --> (v.2.1.5)
Mode: Normal
Model: KF310
Phone Code: default
Mode: Normal
Model: KF310
Phone Code: default
Elapsed: 1 secs. --> (v.2.1.5)
Send loader...
Loader startup Ok!
Init NAND Ok!
C:\Archivos de programa\Z3X\LG\LGTool\Backup\KF310_35423902713158 6_07032011_215344.sec
Erase sec. zone...
Error Code:
Error Code:
Phone rebooted!
Elapsed: 37 secs. --> (v.2.1.5)
Mode: Normal
Model: KF310
Phone Code: default
Cancel by user!
Send loader...
Loader startup Ok!
Init NAND Ok!
Start read SEC Zone...
File saved to:
C:\Archivos de programa\Z3X\LG\LGTool\Backup\SEC_Zone_KF310_35423 9027131586_07032011_215527.bin
Done!
Elapsed: 20 secs. --> (v.2.1.5)
Mode: Normal
Model: KF310
Phone Code: default
Mode: Normal
Model: KF310
Phone Code: default
Send loader...
Loader startup Ok!
Init NAND Ok!
C:\Archivos de programa\Z3X\LG\LGTool\Backup\KF310_35423902713158 6_07032011_215630.sec
Erase sec. zone...
Error Code:
Error Code:
Phone rebooted!
plz helap mi plz
The Following User Says Thank You to ifi786786 For This Useful Post:
Old 03-07-2011, 20:59   #894 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,420
Phone unlocked. Insert sim card and us.
andrew_tm 2011
Old 03-09-2011, 14:01   #895 (permalink)
asif ali's Avatar
Member: 388647
Sonork: sheerazi
Thanks Meter: 161
LG GS390 unlock sucessfull
Connecting to GS390 in UART Mode (COM13 ,921600)
Reading info...
Sending SEC pack...
Reading EEPROM...
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS390_autobackup_09032 011_185942.eep
Analising EEPROM...
Phone IMEI:012196008685630
Unlock codes:
NCK[0]: 3351271104556745 (LOCKED)
Unlocking...
Sending SEC pack...
Reading ...
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS390_autobackup_09032 011_185951.eep
Analising EEPROM...
Writing ...
Sending SEC pack...
Unlock done!
The Following User Says Thank You to asif ali For This Useful Post:
Old 03-12-2011, 09:59   #896 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
LG U960 Flash and UNLOCK whith new Method
LG U960 TV-PHONE FLASH+UNLOCK OK
08/03/2011 14.39.13: v.2.1.4
08/03/2011 14.39.13: supported models: 171
08/03/2011 14.39.13: andrew_tm 2010(c)
08/03/2011 14.40.00: Reading file as U960...
08/03/2011 14.40.03: Original Flash File:
08/03/2011 14.40.03: U960-V10a-MAY-14-2007-H3G-IT-SEC-OFC+1
08/03/2011 14.40.46: Mode: Normal
08/03/2011 14.40.46: Model: U960
08/03/2011 14.40.46: Build version: May 14 200714:23:56MAY 14 200717:00:00U960
08/03/2011 14.40.46: SW Version: U960-MSM6280-V10a-MAY-14-2007-H3G-IT
08/03/2011 14.40.46: IMEI: 35577301145131-0
08/03/2011 14.40.46: BlueTooth Address: 00:1E:75:3E:C75
08/03/2011 14.40.46: Phone Code: default
08/03/2011 14.40.46: Flash Name: toshiba_tya000bc00bogg
08/03/2011 14.40.46: Flash Info: 0343/0040/0800
08/03/2011 14.40.46: Elapsed: 0 secs. --> (v.2.1.4)
08/03/2011 14.40.46: NV read...
08/03/2011 14.40.47: Block 25 reading failed.
08/03/2011 14.40.47: Block 26 reading failed.
08/03/2011 14.40.47: Block 27 reading failed.
08/03/2011 14.40.47: Block 29 reading failed.
08/03/2011 14.40.51: Block 216 reading failed.
08/03/2011 14.40.52: Block 257 reading failed.
08/03/2011 14.40.53: Block 299 reading failed.
08/03/2011 14.40.54: Block 319 reading failed.
08/03/2011 14.40.57: Block 466 reading failed.
08/03/2011 14.41.00: Block 580 reading failed.
08/03/2011 14.41.07: Block 889 reading failed.
08/03/2011 14.41.07: Block 906 reading failed.
08/03/2011 14.41.07: Block 920 reading failed.
08/03/2011 14.41.14: Block 1192 reading failed.
08/03/2011 14.41.16: Block 1311 reading failed.
08/03/2011 14.42.43: NV save:..\backup\U960_355773011451310_08032011_14404 6.cnv
08/03/2011 14.42.43: Elapsed: 116 secs. --> (v.2.1.4)
08/03/2011 14.42.43: Start Flash...
08/03/2011 14.42.43: Modem Write Start...
08/03/2011 14.47.44: Flash Verify Done.
08/03/2011 14.47.46: EFS Erase Done.
08/03/2011 14.47.46: Modem Write Done.
08/03/2011 14.47.46: Phone Reboot.
08/03/2011 14.48.33: Phone Detected!
08/03/2011 14.48.34: Write NV...
08/03/2011 14.48.47: EFS Write Start...
08/03/2011 14.48.47: Start Write Media...
08/03/2011 14.53.15: Start Write Module...
08/03/2011 14.56.23: EFS Write Done.
08/03/2011 14.56.23: Flash Done.
08/03/2011 14.56.23: Elapsed: 820 secs. --> (v.2.1.4)
08/03/2011 14.57.32: Mode: Normal
08/03/2011 14.57.32: Model: U960
08/03/2011 14.57.32: Build version: May 14 200715:49:46MAY 14 200717:00:00U960
08/03/2011 14.57.32: SW Version: U960-MSM6280-V10a-MAY-14-2007-H3G-IT
08/03/2011 14.57.32: IMEI: 35577301145131-0
08/03/2011 14.57.32: BlueTooth Address: 00:1E:75:3E:C75
08/03/2011 14.57.32: Phone Code: default
08/03/2011 14.57.32: Flash Name: toshiba_tya000bc00bogg
08/03/2011 14.57.32: Flash Info: 0343/0040/0800
08/03/2011 14.57.32: Elapsed: 0 secs. --> (v.2.1.4)
08/03/2011 14.57.35: Send loader...
08/03/2011 14.57.54: Loader startup Ok!
08/03/2011 14.57.54: Init NAND Ok!
08/03/2011 14.57.55: Security backup saved to:
08/03/2011 14.57.55: C:\Programmi\Z3X\LG\LGQ\Backup\U960_35577301145131 0_08032011_145755.sec
08/03/2011 14.57.56: Erase sec. zone...
08/03/2011 14.57.56: Write data to Phone.Qualcomm..
08/03/2011 14.57.59: Phone rebooted!
08/03/2011 14.57.59: Elapsed: 24 secs. --> (v.2.1.4)
ripgsm
The Following 2 Users Say Thank You to .:Ripgsm:. For This Useful Post:
Old 03-13-2011, 08:18   #897 (permalink)
worldlinkmobil's Avatar
Member: 1275418
Thanks Meter: 369
SW Version:Z3X MST Tool v 1.9.0.0 (c) NoNameŽ 2010 LG Version
Phone Model:SFR 114
Phone IMEI:354030042832385
Your NCK:662510066480
The Following User Says Thank You to worldlinkmobil For This Useful Post:
Old 03-14-2011, 08:26   #898 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 262
lg u990 direct unlock
v.2.1.4
andrew_tm 2010(c)
Mode: Normal
Model: U990
Build version: Jul 08 200815:32:15Oct 01 200717:00:00U990
SW Version: U990-MSM6280-V10a-OCT-01-2007-XX
IMEI: 3************
BlueTooth Address: 00:1F:E3:ED:0D:2A
Phone Code: default
Flash Info: 06C3/0040/0800
Mode: Normal
Model: U990
IMEI: 3**********
Phone Code: default
Mode: Normal
Model: U990
IMEI: 3***********
Phone Code: default
Send loader...
Loader startup Ok!
Init NAND Ok!
C:\Program Files\Z3X\LG\LGQ\Backup\U990_3************_1403201 1_124517.sec
Erase sec. zone...
Phone rebooted!
Elapsed: 17 secs. --> (v.2.1.4)
The Following 2 Users Say Thank You to luckymobile jalandhar For This Useful Post:
Old 03-14-2011, 11:06   #899 (permalink)
asif ali's Avatar
Member: 388647
Sonork: sheerazi
Thanks Meter: 161
KS360 unlock sucess
nalising EEPROM...
Lock MCC+MNC:˙˙˙˙˙
SP Lock Cleared
Phone IMEI:355429020349777
Writing EEPROM....
Sending SEC pack...
Unlock done!
Reading codes...
Sending SEC pack...
Reading ...
Analising EEPROM...
For operation finishing,do next :
1. power phone ON with original SIM
2. type 2945#*71001# to enter unlock menu
3. Enter one of this code(s):
NCK[0]: 09421338 (LOCKED)
Security block not found
Finished in 5 seconds
Old 03-15-2011, 07:38   #900 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 499
Cool LG KP500 Unlocking
The Following User Says Thank You to RAVI_SINGH For This Useful Post:
Post here successfully job with Z3X-BOX Samsung (2010-2018) mk Z3X-Team Products 21273 11-19-2018 08:21
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.49993 seconds with 9 queries
