Old 12-16-2009, 06:12   #106 (permalink)
laduka's Avatar
Member: 194939
Sonork: 100.1613858
Thanks Meter: 599
Mode: Normal
Model: KU990i
Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i
SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX
IMEI: 35903603121452-2
BlueTooth Address: 20:21:A5:06:9E:93
Flash Name: toshiba_tya000bc00bogg
Flash Info: 06C3/0040/0800
Elapsed: 0 secs.
Start sending preloader...
- Stage #1...
- Write data...
- Phone reboot!
- Select Modem Port:COM4
- Stage #2...
- Stage #3...
Start write loader
Loader send done
Ping loader #1 Ok!
Ping loader #2 Ok!
NAND Memory init Ok!
Security backup saved to:
C:\Program Files\Z3X\LG\LGQ\Backup\KU990i_359036031214522_151 22009_135324.sec
Erase sec. zone...
Write data to phone...
Phone rebooted!
Elapsed: 62 secs.
The Following User Says Thank You to laduka For This Useful Post:
Old 12-20-2009, 07:44   #107 (permalink)
BackSlash_cu's Avatar
Member: 1020744
Thanks Meter: 419
v1.0.0beta
andrew_tm 2009(c)
supported models: 131
Selected model: KP107A
Selected port: COM3
Selected speed: 115200
Connect phone and press Power ON!
Connect ok!
Send preloader ok!
Send main loader ok!
Change BaudRate done!
FlashId: 011A0001, flash size: 4Mb
IMEI: 3583xxxxxxxxxxxxxx
Start unlock...
Unlock code: 72341294
Elapsed: 4 secs.
Start unlock...
Unlock done!
Elapsed: 3 secs.
The Following User Says Thank You to BackSlash_cu For This Useful Post:
Old 12-20-2009, 16:13   #108 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
CU920 Unlock done
Mode: Normal
Model: CU920
Build version: Dec 12 200814:36:03Nov 10 200823:00:00CU920
SW Version: CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US
IMEI: 01184700354052-4
BlueTooth Address: 00:24:83:65:C8:E4
Flash Name: toshiba_tya000bc00dogg
Flash Info: 0696/0040/0800
Elapsed: 0 secs.
Firmware signature in base: 205
Ver: Dec 12 200814:36:03Nov 10 200823:00:00CU920
Signature detected!
Start send loader...
Loader startup OK..
Flash IC name: toshiba_tya000bc0
C:\Program Files\Z3X\LG\LGQ\Backup\CU920_011847003540524_2012 2009_155201.sec
Erase sec. zone...
Phone rebooted!
Elapsed: 7 secs.
The Following User Says Thank You to hung phong For This Useful Post:
Old 12-21-2009, 19:14   #109 (permalink)
Souhail's Avatar
Member: 173741
Thanks Meter: 985
Succuss repair kp110 Stop in logo
B,R Souhail_gsm
thx team
The Following 2 Users Say Thank You to Souhail For This Useful Post:
Old 12-23-2009, 09:49   #110 (permalink)
Member: 1114818
Thanks Meter: 239
Lg gb220 done
Phone found! (MCU:UNK:AA) prebooting...
Preloader answer failed...
BOOT Failed
Disconnected.
PMB8810 Module 1.0b started. SW: Ver 2.2.1.118
Connecting to GB220 in UART Mode (COM99 ,921600)
Please reconnect battery, press and hold power button...
Phone found! (MCU:PMB8810) prebooting...
Release power button. Booting...
Reading info...
Flash ID: 018903
BOOT Stage Finished , sending authority...
Sending SEC pack...
Reading ...
Sending SEC pack...
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GB220_autobackup_23122 009_104351.eep
Analising EEPROM...
Phone IMEI:355736033205188
Unlock codes:
NCK[0]: 0000000000000000
NCK[1]: 0000000000000000
NCK[2]: 9945075053079918
NCK[3]: 9945075053079918
NCK[4]: 9945075053079918
NCK[5]: 9945075053079918
Unlocking...
Sending SEC pack...
Reading EEPROM....
Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GB220_autobackup_23122 009_104409.eep
Analising EEPROM...
SimLock Data Cleared!
Sending SEC pack...
Erasing EEPROM....
Erasing done!
Writing EEPROM....
Sending SEC pack...
Unlock done!
The Following 3 Users Say Thank You to jbenianamohsen For This Useful Post:
Old 12-24-2009, 10:48   #111 (permalink)
adelgsm's Avatar
Member: 476287
Sonork: 100.1587961
Thanks Meter: 833
km900 Successfully Direct Unlock
Connecting to KM900 in UART Mode (COM4 ,921600)
Phone found! (MCU:PMB8868) prebooting...
Flash ID: FF00FF
Sending SEC pack...
Reading ...
Analising EEPROM...
Unlock codes:
NCK[0]: 9946144404904543 (LOCKED)
Unlocking...
Sending SEC pack...
Reading EEPROM....
Analising EEPROM...
Phone IMEI:352154036565702
Writing EEPROM....
Sending SEC pack...
Unlock done!
The Following 2 Users Say Thank You to adelgsm For This Useful Post:
Old 12-24-2009, 10:49   #112 (permalink)
adelgsm's Avatar
Member: 476287
Sonork: 100.1587961
Thanks Meter: 833
Other km900 Successfully Direct Unlock
Flash ID: FF00FF
Sending SEC pack...
Reading ...
Analising EEPROM...
Unlock codes:
NCK[0]: 5625832040175238 (LOCKED)
Unlocking...
Sending SEC pack...
Reading EEPROM....
Analising EEPROM...
Phone IMEI:352154036137379
Writing EEPROM....
Sending SEC pack...
Unlock done!
Disconnected.
Old 12-24-2009, 15:37   #113 (permalink)
Souhail's Avatar
Member: 173741
Thanks Meter: 985
ku990i
Old 12-25-2009, 12:19   #114 (permalink)
Member: 92776
Thanks Meter: 159
Successfully Direct Unlock LG-KP500 By Z3X
  • Cable Ke500 rj45
  • Open LG infinion SGOLD tools
  • Click connect
  • Press power button
  • Check direct [unlock option]
  • Click unlock[/li]
  • Wait till phone unlock
The Following 2 Users Say Thank You to Audsky For This Useful Post:
Old 12-26-2009, 07:14   #115 (permalink)
Member: 1020744
Thanks Meter: 419
LG KP235 Unlocked by z3x
v1.0.1beta
andrew_tm 2009(c)
supported models: 138
Selected model: KP235
Selected port: COM3
Please press and hold power button!
Phone detected!
Loader startup Ok..
Reading phone info...
Flash ID: 898816
Flash type: PF38F4455LLZBQ0
Flash size: 32Mb
IMEI: 352127-02-287019-5
Start unlock...
Read call. data...
Patch call. data
Write call. data...
Unlock succesfully!
Elapsed: 25 secs.
The Following 2 Users Say Thank You to BackSlash_cu For This Useful Post:
Old 12-29-2009, 09:11   #116 (permalink)
Member: 1114818
Thanks Meter: 239
gb 102 done
Selected model: GB102
Selected port: COM10
Selected speed: 460800
Connect ok!
Send preloader ok!
Flash chip(00000095) not supported, conctact to support!
IMEI: 353999-03-736139-7
Start unlock...
Unlock done!
Elapsed: 5 secs.
The Following 2 Users Say Thank You to jbenianamohsen For This Useful Post:
Old 12-29-2009, 18:55   #117 (permalink)
Bourne.'s Avatar
Member: 1038829
Thanks Meter: 23
U900 Pateched and unlock done
29/12/2009 14:14:24: v.1.7.4
29/12/2009 14:14:24: supported models: 78
29/12/2009 14:14:24: andrew_tm 2009(c)
29/12/2009 14:14:59: Reading file as U900...
29/12/2009 14:15:02: Original Flash File:
29/12/2009 14:15:02: U900-HCLSDR-V11g-Jan-23-2007-H3G-IT
29/12/2009 14:15:04: Select ComPort or use Search Phone button!
29/12/2009 14:15:04: Elapsed: 0 secs.
29/12/2009 14:15:08: Mode: Normal
29/12/2009 14:15:08: Model: U900
29/12/2009 14:15:08: Build version: May 10 200616:23:11MAY 10 200612:00:00U900
29/12/2009 14:15:08: SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT
29/12/2009 14:15:08: IMEI: 35930400301388-8
29/12/2009 14:15:08: BlueTooth Address: 00:12:56:3D:57:A1
29/12/2009 14:15:08: Flash Name: toshiba_ty9000ac10aobg
29/12/2009 14:15:08: Flash Info: 1980/0020/0200
29/12/2009 14:15:08: Elapsed: 0 secs.
29/12/2009 14:15:14: Mode: Normal
29/12/2009 14:15:14: Model: U900
29/12/2009 14:15:14: Build version: May 10 200616:23:11MAY 10 200612:00:00U900
29/12/2009 14:15:14: SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT
29/12/2009 14:15:14: IMEI: 35930400301388-8
29/12/2009 14:15:14: BlueTooth Address: 00:12:56:3D:57:A1
29/12/2009 14:15:14: Flash Name: toshiba_ty9000ac10aobg
29/12/2009 14:15:14: Flash Info: 1980/0020/0200
29/12/2009 14:15:14: Elapsed: 0 secs.
29/12/2009 14:15:14: NV read...
29/12/2009 14:15:35: NV save:..\backup\U900_359304003013888_29122009_14151 4.cnv
29/12/2009 14:15:35: Elapsed: 21 secs.
29/12/2009 14:15:35: Start Flash...
29/12/2009 14:15:35: Modem Write Start...
29/12/2009 14:20:51: Flash Verify Done.
29/12/2009 14:20:59: EFS Erase Done.
29/12/2009 14:20:59: Modem Write Done.
29/12/2009 14:20:59: Phone Reboot.
29/12/2009 14:21:43: Phone Detected!
29/12/2009 14:21:43: Write NV...
29/12/2009 14:21:52: EFS Write Start...
29/12/2009 14:21:52: Start Write Media...
29/12/2009 14:26:58: Start Write Module...
29/12/2009 14:29:47: EFS Write Done.
29/12/2009 14:29:47: Flash Done.
29/12/2009 14:29:47: Elapsed: 851 secs.
29/12/2009 14:30:35: Mode: Normal
29/12/2009 14:30:35: Model: U900
29/12/2009 14:30:35: Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900
29/12/2009 14:30:35: SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT
29/12/2009 14:30:35: IMEI: 35930400301388-8
29/12/2009 14:30:35: BlueTooth Address: 00:12:56:3D:57:A1
29/12/2009 14:30:35: Flash Name: toshiba_ty9000ac10aobg
29/12/2009 14:30:35: Flash Info: 1980/0020/0200
29/12/2009 14:30:35: Elapsed: 0 secs.
29/12/2009 14:30:39: Mode: Normal
29/12/2009 14:30:39: Model: U900
29/12/2009 14:30:39: Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900
29/12/2009 14:30:39: SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT
29/12/2009 14:30:39: IMEI: 35930400301388-8
29/12/2009 14:30:39: BlueTooth Address: 00:12:56:3D:57:A1
29/12/2009 14:30:39: Flash Name: toshiba_ty9000ac10aobg
29/12/2009 14:30:39: Flash Info: 1980/0020/0200
29/12/2009 14:30:39: Elapsed: 0 secs.
29/12/2009 14:30:40: Start Unlock...
29/12/2009 14:30:40: - Unlock stage #1...
29/12/2009 14:30:40: - Write data...
29/12/2009 14:30:47: - Phone reboot!
29/12/2009 14:33:28: - Select Modem Port:COM13
29/12/2009 14:33:28: - Unlock stage #2...
29/12/2009 14:33:56: - Unlock stage #3...
29/12/2009 14:33:58: - Unlock stage #4...
29/12/2009 14:33:58: - Start read nand...
29/12/2009 14:33:59: - Read nand done...
29/12/2009 14:33:59: - Start erase nand...
29/12/2009 14:33:59: - Erase done...
29/12/2009 14:33:59: - Start write nand...
29/12/2009 14:34:00: - Write nand done...
29/12/2009 14:34:00: - Start read nand...
29/12/2009 14:34:00: - Read nand done...
29/12/2009 14:34:00: - Start erase nand...
29/12/2009 14:34:01: - Erase done...
29/12/2009 14:34:01: - Start write nand...
29/12/2009 14:34:01: - Write nand done...
29/12/2009 14:34:01: Unlock done!
29/12/2009 14:34:01: Phone reboot!
29/12/2009 14:34:01: Elapsed: 202 secs.
The Following User Says Thank You to Bourne. For This Useful Post:
Old 12-31-2009, 19:02   #118 (permalink)
Member: 288521
Thanks Meter: 661
Mode: Normal
Model: KU990i
Build version: Mar 22 200914:51:12MAR 12 200917:00:00KU990i
SW Version: KU990i-MSM6280-V10c-MAR-12-2009-XX
IMEI: 35469303244280-2
BlueTooth Address: 00:24:83:0F:75:F9
Elapsed: 0 secs.
Start sending virus...
- Stage #1...
- Write data...
- Phone reboot!
- Stage #2...
- Stage #3...
Start write loader
Loader send done
Ping loader #1 Ok!
Ping loader #2 Ok!
C:\Program Files\Z3X\LG\LGQ\Backup\KU990i_354693032442802_311 22009_185032.isec
New IMEI: 35462834728921
New BT: 01BB7E4D470D
Erase sec. zone...
Phone rebooted!
Elapsed: 56 secs.
fast easy imei repair... thanks z3x
Old 01-01-2010, 11:28   #119 (permalink)
kiken's Avatar
Member: 817951
Sonork: 100.1584874
Thanks Meter: 52
big thanks for y2ksalman and souhail_gsm for help my phone is unlock now!
here is logo
Disconnected.
PMB8877 Module 1.1 started. SW: Ver 2.2.1.121
Connecting to KF600 in UART Mode (COM9 ,921600)
Phone found! (MCU:PMB8877) prebooting...
Reading info...
Sending SEC pack...
Reading ...
Backup Saved AS:C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Rar$EX00.218 \BACKUP\KF600_autobackup_01012010_191017.eep
Analising EEPROM...
Phone IMEI:35200902820xx27
Unlock codes:
NCK[0]: 61409939 (LOCKED)
Unlocking...
Sending SEC pack...
Reading EEPROM....
Backup Saved AS:C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Rar$EX00.218 \BACKUP\KF600_autobackup_01012010_191028.eep
Analising EEPROM...
Writing EEPROM....
Sending SEC pack...
Unlock done!
b.r
kiken
Old 01-01-2010, 12:28   #120 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
Successfully Direct Unlock LG U880 By Z3X
Post here successfully job with Z3X-BOX Samsung mk Z3X-Team Products 21071 Today 12:49
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.42931 seconds with 9 queries
