Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1441 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: pakistan Age: 37
Member: 1275418 Status: Offline Thanks: 86
| Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8810) prebooting... Release power button. Booting... Waiting for loader answer... Reading info... Flash ID: 0x8981 BOOT Stage Finished , sending authority... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG A133_autobackup_14022012_014925.eep Detailed Phone Information: Phone Model: LG A133 Phone Manufacturer: LGE Inc. Phone Version: Unavaiable for this platform. Phone IMEI : 35702804385463700 Phone BT Adress : A8:92:2C:5D:0E:5C Detailed Codes Information: Phone NCK Code : 7912-7801-6121-1904 Phone NS Code : 1877-3208-4942-4143 Phone SP Code : 1894-9343-8701-0579 Phone CP Code : 7185-7506-7564-8173 Phone SIM Code : 6582-1139-3959-6033 SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: Unavaiable for this platform. Finished in 15 seconds |
| The Following User Says Thank You to worldlinkmobil For This Useful Post: |
| | #1442 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: gsmsection Age: 25
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks: 9
| LG 2-3G Tool v2.4 build 00FA supported models: 503 Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400461347-0 BlueTooth Address: 00:12:56:44:80:BF Phone Code: default Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v2.4 build 00FA) Reading file as U900... Ok Original Flash File: U900-HCLSDR-V11g-Jan-23-2007-H3G-IT Mode: Normal Model: U900 Build version: May 10 200616:23:11MAY 10 200612:00:00U900 SW Version: U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI: 35930400461347-0 BlueTooth Address: 00:12:56:44:80:BF Phone Code: default Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v2.4 build 00FA) NV read... NV save:..\backup\U900_359304004613470_18022012_11042 7.cnv Elapsed: 12 secs. --> (v2.4 build 00FA) Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 912 secs. --> (v2.4 build 00FA) Mode: Normal Model: U900 Build version: Jan 23 200710:39:40JAN 23 200712:00:00U900 SW Version: U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI: 35930400461347-0 BlueTooth Address: 00:12:56:44:80:BF Phone Code: default Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. --> (v2.4 build 00FA) Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port: COM46 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 69 secs. --> (v2.4 build 00FA) |
| The Following User Says Thank You to unlock_allgsm For This Useful Post: |
| | #1443 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Karachi pakistan Age: 31
Member: 388647 Status: Offline Sonork: sheerazi Thanks: 63
| LG cu500 unlock done [IMG] [/IMG] |
| The Following User Says Thank You to asif ali For This Useful Post: |
| | #1444 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009
Member: 1064967 Status: Offline Thanks: 56
| Unlock GD330 Done! Code: TIP: Please reconnect phone battery / power source. Loading module , please wait... OMAP v1030 v2 Module 1.0b started. SW: Ver 3.7.1.3 Please reconnect battery, press and hold power button... MCUID : 0x0000FF00 JTAGID : 0x00000104 Booting... Changing speed... Sync Loader... Flash ID: 0xECA1 BOOT Stage Finished , working... IMEI:3589780377 Reading EEPROM... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\LG GD330_autobackup_23022012_144358.eep Finished in 3 seconds Reading Codes are not supported for this model... Finished in 0 seconds Reading EEPROM... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\LG GD330_autobackup_23022012_144420.eep Writing EEPROM Erasing NAND ... Erasing done! Writing block ... Writing block done! Unlock done! Finished in 7 seconds |
| The Following User Says Thank You to dapx For This Useful Post: |
| | #1445 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jan 2010 Location: Paris Age: 37
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks: 495
| Welcome to Z3X LG Multi Platform TOOL Current OS : Windows Seven SP1 BUILD:6/7601 Welcome to Sgold3 Module!! Disconnected. TIP: Please reconnect phone battery / power source. Count supported models - 138 Loading module , please wait... PMB8878 Module 2.0 started. SW: Ver 3.7.1.2 Connecting to LG GB250 in USB Mode... Please connect phone , it must be powered off Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... Unable to read IMEI in this mode Finished in 0 seconds Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG GB250_autobackup_01032012_003610.eep Analising EEPROM... SimLocks Disabled SP Lock Enabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config:20810FFFFFFFFFFFFFFFFFFF64710FFFFFFFFFFFFFF FFFFF SimLock Data Fixed! Writing EEPROM.... Sending SEC pack... Unlock done! Finished in 5 seconds |
| The Following User Says Thank You to Nadoui For This Useful Post: |
| | #1449 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2009 Location: Bangladesh Age: 30
Member: 1162626 Status: Offline Sonork: 100.1591727 Thanks: 2,863
| LG KP270 Dead Set Successful Flash Repair By z3x Code: TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8868 Module 1.1 started. SW: Ver 3.7.1.3 Connecting to LG KP270 in UART Mode (COM10 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Reading info... Flash ID: 018903 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KP270_autobackup_24032012_134624.eep Analising EEPROM... Detailed Phone Information: Phone Model: KP270 Phone Manufacturer: LG Electronics I Phone Version: Oct 10 2008 Phone IMEI : 35795702172578300 Phone BT Adress : 00:22:A9:FF:52:6B Detailed Codes Information: Phone NCK Code : 7699-6115 Phone NS Code : 2117-6704 Phone SP Code : 3521-3184 Phone CP Code : 8038-2771 Phone SIM Code : 4889-1668 SimLocks Disabled SP Lock Disabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config: Finished in 4 seconds Opening "KP270AT-00-V10h-206-01-MAR-05-2009+0.bin"... Writing Firmware... Sending SEC pack... Writing done! Finished in 55 minutes 52 seconds. |
| The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
| | #1450 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 35
Member: 591325 Status: Offline Thanks: 38
| lg s310 read codes done Selected model is:LG S310 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\MTK_AllInOne_DA.bin Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6235B_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : N/A NAND Detected : (1Gb) [SAMSUNG] K9F1G16Q0M Advanced detection information: BBCHIP: "MT6235B_S00", EXT_26M CODE(0x6235), VER(0x8B00), SW(0x8A00) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_ID: "[SAMSUNG] K9F1G16Q0M" NAND_ID: 0x00EC, 0x00B1, 0x0000, 0x0055 Detection Done! Reading NAND : "C:\Program Files\Z3X\MTK\MTKBOOT.TMP", 0x00000000:0x00100000 ReadBack Failed:? Setting NAND buffer size :8000000 PostProcessing Boot File Unknown ROMINFO version :245 Done! Selected model is:LG KM330 Selected model is:LG S310 Starting flasher module.... [UNLOCK_MODE] Reconnect battery and press power button now! S310 Codereader Started; Getting MCUID... Booting... You can release power key now! Project Name: MT6235B_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : N/A NAND Detected : (1Gb) [SAMSUNG] K9F1G16Q0M Advanced detection information: BBCHIP: "MT6235B_S00", EXT_26M CODE(0x6235), VER(0x8B00), SW(0x8A00) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_ID: "[SAMSUNG] K9F1G16Q0M" NAND_ID: 0x00EC, 0x00B1, 0x0000, 0x0055 Detection Done! Reading NAND : "C:\Program Files\Z3X\MTK\FlashPart0.TMP", 0x07000000:0x00800000 SEC Data Detected: IMEI : 354142044934083 Unlock Codes: NCK : 9373381771924404 SPCK : 4961730330740383 NSCK : 8303568133042307 CCK : 9402261355238453 SIM : 9116296784510858 Unlock Done! Operation Done! |
| The Following 3 Users Say Thank You to dimityr.milev For This Useful Post: |
| | #1451 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 637351 Status: Offline Thanks: 100
| KE850 unlocked done... Code: Connecting to LG KE850 in UART Mode (COM9 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8876) prebooting... Release power button. Booting... Reading info... Flash ID: 0x89B0 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Sending SEC pack... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KE850_autobackup_05042012_162515.eep Analising EEPROM... Security block not found Finished in 1 seconds Sending SEC pack... Reading codes ... Sending SEC pack... Analising EEPROM... Security block not found Finished in 1 seconds Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\LG KE850_autobackup_05042012_162528.eep Analising EEPROM... Sending SEC pack... SimLock Data Cleared! Erasing EEPROM.... Erasing done! Writing EEPROM.... Sending SEC pack... Unlock done! Finished in 3 seconds |
| | #1454 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2010 Location: CyberWorld Age: 30
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks: 129
| successfully flashed lg kp130 LG 2-3G Tool v2.4 build 00FA supported models: 503 Selected model: KP130 Selected port: COM30 Selected speed: 460800 Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 012100 Flash type: S71PL129NB0 Flash size: 16Mb IMEI: 011494-15-057183-6 Start erase CodeData... CodeData erase done... Start erase AlchemyData... AlchemyData erase done... Start erase MP3Data... MP3Data erase done... Start write CodeData... Reading MOT file... Reading MOT file succesfully completed ! Start write AlchemyData... Reading MOT file... Reading MOT file succesfully completed ! Start write MP3Data... Reading MOT file... Reading MOT file succesfully completed ! Firmware write done. For operation finishing do next: - press "Disconnect" and power phone ON without SIM - press 2945#*# for entering eng. mode - select "Factory Reset" Elapsed: 749 secs. --> (v2.4 build 00FA) |
| The Following User Says Thank You to dampealdany For This Useful Post: |
| | #1455 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Age: 41
Member: 163755 Status: Offline Thanks: 159
| Susscefully unlock S5369 and 5363 Count supported models - 300 Searching Samsung USB Modem... Detected (COM122) Model: GT-S5360 SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 358858041170886 Done with Samsung Tool ver 12.1 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5369 Phone Version: S5369BUKL3 PDA Version: S5369BUKL3 CSC Version: S5369VDRKL3 IMEI: 358858041170886 Rooting Phones... Error Done with Samsung Tool ver 12.1 Searching Samsung USB Modem... Detected (COM122) Model: GT-S5360 SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 358858041170886 Done with Samsung Tool ver 12.1 Starting ADB Server... OK Checking ROOT... TRUE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5369 Phone Version: S5369BUKL3 PDA Version: S5369BUKL3 CSC Version: S5369VDRKL3 IMEI: 358858041170886 Reading Data From Phone... OK Unlocking... OK Done with Samsung Tool ver 12.1 Searching Samsung USB Modem... Detected (COM122) Model: GT-S5360 SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 358841041695433 Done with Samsung Tool ver 12.1 Starting ADB Server... OK Checking ROOT... TRUE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5363 Phone Version: S5363XXKK3 PDA Version: S5363XXKK3 CSC Version: S5363O2UKK1 IMEI: 358841041695433 Reading Data From Phone... OK Unlocking... OK Done with Samsung Tool ver 12.1 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Post here successfully unlock or IMEI repair Samsung | mk | Z3X-Team Products | 9059 | Today 02:29 |
| Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 16:29 |
| Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 1 | 01-04-2010 13:33 |
