10-09-2016, 10:44 | #16921 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | Fastest & Easiest Action on Old Phone! Selected model: GT-I9100 Software version: 26.9 Code: Waiting ADB device... OK Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: GT-I9100LKAXSG Phone version: I9100XXLS8 PDA version: I9100XWLSD CSC version: I9100OJVLS6 CSC country code: UAE CSC sales code: XSG HW version: MP 1.300 Phone SN: 00000000000 Modem board: RF cal date: 2011.9.9 IMEI: 358490047403580 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading NV data... OK Checking magic... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-09-2016, 13:09 | #16922 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | this also is done FRP SM-G920T Operation: Reset FRP/React/EE Selected model: SM-G920T Software version: 26.9 Searching Samsung USB Flash interface... COM11 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 THANKS |
10-09-2016, 16:48 | #16923 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | g935f Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 26.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM40 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APF3 CSC version: G935FVFG1APF3 CSC country code: Spain CSC sales code: ATL HW version: Phone SN: RF8H32A3M5M Modem board: RF cal date: IMEI: Checking Super user right... true Erasing FRP... OK Restore original kernel? Yes Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.9 thanks z3x i love this box |
10-09-2016, 21:50 | #16924 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | THIS ALSO IS DONE SM-G928A I CLICK Operation: Unlock Selected model: SM-G928A Software version: 26.9 Searching Samsung modem... detected COM114 Reading phone info... OK Model: SM-G928A AP version: G928AUCU2BPE6 CSC version: G928AATT2BPE6 CP version: G928AUCU2BPE6 Product code: SM-G928AZKEATT Phone SN: R38----- Unique number: 0715F78D1ED13F34 Reading IMEI... OK IMEI: 3535-----------4 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 I LOVE IT Z3X THANKS |
10-10-2016, 00:23 | #16925 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | THIS ALSO IS DONE SAMSUNG SC-06D DOCOMO WITH USB CABLE *#0808# DONT WORK FOR THIS PHONE JUST USE THIS 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM + Modem + ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. Operation: Unlock Selected model: SC-06D Selected port: COM6 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 352670059664734 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 Reading phone info... Reading IMEI... OK IMEI: 352670059285415 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 THANKSS LOVE IT Z3X |
10-10-2016, 16:51 | #16929 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G530H Cert Write Code: Operation: Write CERT Selected model: SM-G530H Selected port: COM60 SAMSUNG Mobile USB Serial Port Software version: 26.8 Checking CERT file... OK KEY ID: 0504 Waiting ADB device... OK Reading phone info... Model: SM-G530H Android version: 5.0.2 Product code: Not Active Phone version: G530HXXU2BOH5 PDA version: G530HXXU2BOH5 CSC version: G530HOXE2BOI1 CSC country code: Ukraine CSC sales code: SEK HW version: Phone SN: 00000000000 Modem board: MSM8216 RF cal date: 2014.09.22 IMEI: Initialization AT RIL... OK OK Checking for compatible phone and cert... OK Phone KEY ID: 0504 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.26.8 |
10-10-2016, 17:51 | #16930 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N910T Selected port: COM33 SAMSUNG Mobile USB Serial Port Software version: 23.9 Checking certificate file... OK KEY ID: 0772 Waiting ADB device... OK Reading phone info... Model: SM-N910T Android version: 5.1.1 Product code: SM2N910TZKETMB Phone version: N910TUVU1COD6 flish rest msl then writ cert PDA version: N910TUVU2DOK2 CSC version: N910TTMB2DOK2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone S/N: 00000000000 Modem board: MDM9225M RF cal date: 2015.05.22 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0772 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.23.9 |
10-10-2016, 21:07 | #16931 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected model: S8600 Selected port: COM90 Qualcomm HS-USB Diagnostics 9002 Selected port speed: 115200 Searching Samsung modem... detected COM89 Reading phone info... Software version: T199UVNBA IMEI: 35842005517016 /9 Product code: xxxxxxxxxxxxxx Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.19.1 |
10-11-2016, 09:24 | #16932 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | THIS ALSO IS DONE Unable to get comport information , check system LG 2-3G Tool v9.25 supported models: 1380 Mode: Emergency Model: H650E Elapsed: 3 secs. --> (v9.25) Phone mode is DOWNLOAD Start reset Google Account Lock... Model name: LG-H650E Software verion: H65010i Android verion: 5.1.1 IMEI: 3558------- Reset ... Reboot... Elapsed: 6 secs. --> (v9.25) THANKSSS |
10-11-2016, 16:04 | #16933 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | this also is done Operation: Unlock Selected model: SM-G890A Software version: 26.9 Searching Samsung modem... detected COM122 Reading phone info... OK Model: SM-G890A AP version: G890AUCS3BPDS CSC version: G890AATT3BPDS CP version: G890AUCS3BPDS Product code: SM2G890AZAAATT Phone SN: R38G607D3CL Unique number: 05157DF59DE61911 Reading IMEI... OK IMEI: 35935-------- (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 THANKSSS |
10-11-2016, 17:23 | #16934 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | THIS ALSO IS DONE Operation: Unlock Selected model: SGH-M919N Selected port: COM124 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 357148----- Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-11-2016, 23:34 | #16935 (permalink) |
Member: 2428732 Status: Offline Thanks Meter: 22 | n920a unlock and frp done UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920A Software version: 26.9 Searching Samsung modem... detected COM89 Reading phone info... OK Model: SM-N920A AP version: N920AUCU2AOJ1 CSC version: N920AATT2AOJ1 CP version: N920AUCU2AOJ1 Product code: SM-N920AZKAATT Phone SN: R3xxxxxxxx Unique number: 0715F76DFB021432 Reading IMEI... OK IMEI: 3538xxxxxxxxxxx (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
