Old 10-11-2016, 23:37   #16936 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Reset FRP
Selected model: SM-J700T
Software version: 26.9
Waiting ADB device... OK
Reading phone info...
Model: SM-J700T
Android version: 6.0.1
Product code: SM2J700TZWATMB
Phone version: J700TUVU1APF2
PDA version: FA60_J700TUVU1APF2
CSC version:
CSC country code:
CSC sales code:
HW version: REV0.5
Phone SN: R58H80SF5WR
Modem board: SHANNON310
RF cal date: 20160805
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.26.9
Old 10-12-2016, 00:23   #16937 (permalink)
Member: 2428732
Thanks Meter: 22
Operation: Patch Certificate
Selected model: SM-G925T
Model: SM-G925T
Android version: 5.1.1
Product code: SM2G925TZDATMB
Phone version: G925TUVU3DOJ7
PDA version: G925TUVU3DOJ7
CSC version: G925TTMB3DOJ7
CSC country code: USA
CSC sales code: TMB
HW version: REV0.2
Phone SN: R5xxxxxxxxxx
Modem board: SHANNON333
RF cal date: 20150726
IMEI:
Checking Super user right... true
Initialization zTool... OK
Running zTool, please wait... OK
Reading modem OK
Patching modem... OK
Writing modem... OK
Rebooting phone... OK
Patching CERT check... done
Old 10-12-2016, 11:03   #16938 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 169
Samsung s6 edge g925f DRK repair done
REPAIR INSTRUCTIONS:
Reset EFS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button.
Operation: Repair DRK
Selected model: SM-G925F
Checking local file... not found
Searching server... OK
Downloading file... OK
Checking local file... OK
Searching USB Flash interface... COM47 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Recovery build version: 6.0.1
Boot version: G925FXXS4DPIK
Platform: exynos7420
Boot serial: 1215fc21d1503805
Product board: zerolte
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Checking DRK status... OK
Repairing DMVT key... OK
Repair DRK done
Old 10-12-2016, 17:19   #16939 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,706
g531F imei repair done
Checking CERT file... OK
KEY ID: 0001
Model: SM-G531F
Product code: SM-G531FXXXAMO
Phone version: G531FXXU1APB2
PDA version: G531FXXU1AOF7
CSC version:
CSC country code:
CSC sales code:
HW version: MP 0.200
Phone SN: R58G706VDDJ
Modem board:
RF cal date: 20150704
IMEI:
Reading NV data... OK
Analyzing SEC file... OK
Writing AT RIL... OK
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0001
Writing CERT... OK
Checking CERT status... OK
Write CERT done
b.r.
Old 10-12-2016, 17:30   #16940 (permalink)
Member: 1930570
Thanks Meter: 82
THIS ALSO IS DONE
UNLOCK INSTRUCTIONS:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button.
Operation: Unlock
Selected model: SM-J120A
Searching Samsung modem... detected COM133
Reading phone info... OK
Model: SM-J120A
AP version: J120AUCU1APC8
CSC version: J120AATT1APC8
CP version: J120AUCU1APC8
Product code: SM2J120AZWCATT
Phone SN: R58H71Z78LK
Unique number: CFN0032F9238263
Reading IMEI... OK
IMEI: 35626------ (SIGN: OK)
Unlocking... OK
Unlock done
I LOVE THIS TOOLS Z3X
THANKS
Old 10-12-2016, 23:59   #16941 (permalink)
Member: 2428732
Thanks Meter: 22
FRP AND UNLOCK N920P
BACKUP INSTRUCTIONS:
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Read SEC' button to read security area backup or 'Write SEC' to restore it or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC' (ignore it, if not available).
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Reset FRP/React/EE
Selected model: SM-N920P
Searching Samsung USB Flash interface... COM4 detected
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... OK
Erasing Reactivation lock... OK
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Domestic Unlock:
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
5. Press 'Unlock Domestic' button.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock SPRNT
Model: SM-N920P
Product code: Not Active
Phone version: N920PVPU2AOI6
PDA version: N920PVPU2AOI6
CSC version: N920PSPT2AOI6
CSC sales code: SPR
HW version: N920P.03
Phone SN: 00000000000
Modem board: MDM9635M
RF cal date: 2015.07.24
IMEI:
Unlocking... OK
Unlock done
The Following 2 Users Say Thank You to musa12 For This Useful Post:
Old 10-13-2016, 10:17   #16942 (permalink)
Asad ali khan's Avatar
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 693
g928tf frp reset done
Selected model: SM-G928F
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Model: SM-G928F
Product code: SM-G928FZDANEE
Phone version: G928FXXU2BPF1
PDA version: G928FXXS2BPF1
CSC version: G928FNEE2BPB6
CSC country code: Nordic
CSC sales code: NEE
HW version: MP 0.500
RF cal date: 20150923
IMEI:
Bypass FRP... OK
Old 10-13-2016, 11:10   #16943 (permalink)
Member: 1930570
Thanks Meter: 82
UNLOCK DONE
[ 13-Oct-16 4:53:00 AM ] Waiting ADB device...
[ 13-Oct-16 4:53:00 AM ] Please, allow USB debugging on phone... OK
[ 13-Oct-16 4:54:00 AM ] Reading phone info...
[ 13-Oct-16 4:54:00 AM ] Model: SM-G925P
[ 13-Oct-16 4:54:00 AM ] Android version: 5.1.1
[ 13-Oct-16 4:54:00 AM ] Product code: Not Active
[ 13-Oct-16 4:54:00 AM ] Phone version: G925PVPU3BOJ7
[ 13-Oct-16 4:54:00 AM ] PDA version: G925PVPU3BOJ7
[ 13-Oct-16 4:54:00 AM ] CSC version: G925PSPT3BOJ7
[ 13-Oct-16 4:54:00 AM ] CSC country code: USA
[ 13-Oct-16 4:54:00 AM ] CSC sales code: SPR
[ 13-Oct-16 4:54:00 AM ] HW version: G925P.02
[ 13-Oct-16 4:54:00 AM ] Phone SN: 00000000000
[ 13-Oct-16 4:54:00 AM ] Modem board: MDM9635M
[ 13-Oct-16 4:54:00 AM ] RF cal date: 2015.06.23
[ 13-Oct-16 4:54:00 AM ] IMEI:
[ 13-Oct-16 4:54:00 AM ] Writing AT RIL... OK
[ 13-Oct-16 4:55:00 AM ] Initialization AT RIL... OK
[ 13-Oct-16 4:55:00 AM ] Unlocking... OK
[ 13-Oct-16 4:55:00 AM ] Rebooting phone... OK
[ 13-Oct-16 4:55:00 AM ] Unlock done
[ 13-Oct-16 5:00:00 AM ] Operation: Unlock SPRNT
[ 13-Oct-16 5:00:00 AM ] Selected model: SM-G925P
[ 13-Oct-16 5:00:00 AM ] Software version: 26.9
[ 13-Oct-16 5:00:00 AM ] Waiting ADB device...
[ 13-Oct-16 5:00:00 AM ] Please, allow USB debugging on phone... OK
[ 13-Oct-16 5:00:00 AM ] Reading phone info...
[ 13-Oct-16 5:00:00 AM ] Model: SM-G925P
[ 13-Oct-16 5:00:00 AM ] Android version: 5.1.1
[ 13-Oct-16 5:00:00 AM ] Product code: Not Active
[ 13-Oct-16 5:00:00 AM ] Phone version: G925PVPU3BOI1
[ 13-Oct-16 5:00:00 AM ] PDA version: G925PVPU3BOI1
[ 13-Oct-16 5:00:00 AM ] CSC version: G925PSPT3BOI1
[ 13-Oct-16 5:00:00 AM ] CSC country code: USA
[ 13-Oct-16 5:00:00 AM ] CSC sales code: SPR
[ 13-Oct-16 5:00:00 AM ] HW version: G925P.02
[ 13-Oct-16 5:00:00 AM ] Phone SN: 00000000000
[ 13-Oct-16 5:00:00 AM ] Modem board: MDM9635M
[ 13-Oct-16 5:00:00 AM ] RF cal date: 2015.06.23
[ 13-Oct-16 5:00:00 AM ] IMEI:
[ 13-Oct-16 5:00:00 AM ] Writing AT RIL... OK
[ 13-Oct-16 5:01:00 AM ] Initialization AT RIL... OK
[ 13-Oct-16 5:01:00 AM ] Unlocking... OK
[ 13-Oct-16 5:01:00 AM ] Rebooting phone... OK
[ 13-Oct-16 5:01:00 AM ] Unlock done
THANKSSSS
Old 10-13-2016, 13:42   #16944 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Samsung Galaxy S7 EDGE FRP Reset Done...
Selected model: SM-G935F
Searching USB Flash interface... COM32 detected
Model: SM-G935F
Product code: SM-G935FZDABTU
Phone version: G935FXXU1APB2
PDA version: G935FXXU1APAW
CSC version: G935FBTU1APB2
CSC country code: UK & IRE
CSC sales code: BTU
HW version: MP 0.801
Phone SN: RF8H51HAAAA
Modem board: SHANNONAAA
RF cal date: 20160516
IMEI:
Erasing FRP... OK
Restoring kernel... OK
Reset FRP done
Old 10-13-2016, 14:42   #16945 (permalink)
DZcondor's Avatar
Member: 2516015
Thanks Meter: 100
Cool Samsung E1200R Flash done
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. Choose flash option if needed:
-'Re-write NV' - Warning! This option will erase all calibration data!
-'Single file firmware' - if you have *.pac firmware
3. Press 'Flash' button.
4. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable).
Operation: Flash
Selected model: GT-E1200R
Waiting phone... detected COM14
Sending FDL... OK
Reconnecting phone... OK
Reading NV... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\NV\nvitem_ GT-E1200R_13-10-2016_14-39-49.bin
Sending SSBOOT... OK
Sending PS... OK
Sending CSC... OK
Erasing FLASH... OK
Flashing done (time - 00:01:19)
Old 10-13-2016, 23:16   #16946 (permalink)
Member: 1930570
Thanks Meter: 82
FRP DONE N920W8
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Selected model: SM-N920W8
Searching Samsung USB Flash interface... COM68 detected
Erasing FRP... OK
Reset done
Old 10-14-2016, 02:10   #16947 (permalink)
Member: 1930570
Thanks Meter: 82
FRP DONE G920P
Selected model: SM-G920P
Searching Samsung USB Flash interface... COM69 detected
Erasing FRP... OK
Reset done
THANKS
Old 10-14-2016, 09:48   #16948 (permalink)
mohsinsomeone's Avatar
Member: 1785307
Thanks Meter: 112
Succefully Unlocked FRP S7 Edge G935FD
Software version: 26.5
Searching USB Flash Interface... detected COM150
Model: SM-G935F
Product code: SM-G935FZDUXSG
Phone version: G935FXXU1APEQ
PDA version: G935FXXS1APG3
CSC version: G935FOJV1APF1
CSC country code: UAE
CSC sales code: XSG
Phone S/N: RF8H40GHV8H
Modem board: SHANNON335
RF cal date: 20160406
IMEI:
Erasing FRP... OK
Reset FRP done
Done with Samsung Tool PRO v.26.5
Old 10-14-2016, 10:05   #16949 (permalink)
danisajee's Avatar
Member: 755480
Sonork: 100.1609798
Thanks Meter: 233
g925f unlock done (no root )
Searching Samsung modem... detected COM178
Model: SM-G925F
AP version: G925FXXU4DPGW
CSC version: G925FOXX4DPH1
CP version: G925FXXU4DPGW
Product code: SM-G925FZKAXEF
Phone SN: RF8H51M9R0L
Unique number: 02160228D6B142E3
Reading IMEI... OK
IMEI: 356420076925551 (SIGN: OK)
Unlocking... OK
Unlock done
Old 10-14-2016, 11:26   #16950 (permalink)
-=C.J.S=-'s Avatar
Member: 669596
Sonork: 1657504
Thanks Meter: 136
SM-G531F/DD Unlocked DONE...
  5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
     If phone ask codes after unlocking, use:
     PUK - 12345678
     PIN - 00000000
Operation: Unlock
Selected model: SM-G531F
Model: SM-G531F
Product code: SM-G531FZADINS
Phone version: G531FDDU1AOK2
PDA version: G531FXXU1AOH1
CSC version:
CSC country code:
CSC sales code:
Phone SN: RZ8GA081RGT
Modem board:
RF cal date: 20151007
IMEI:
Bypass MSL... OK
Unlocking... OK
Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.30899 seconds with 11 queries
