07-26-2017, 13:08 | #18781 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Selected model: SM-G531F Software version: 28.8 Searching Samsung USB Flash interface... COM20 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.28.8 |
The Following User Says Thank You to unaiz For This Useful Post: |
07-26-2017, 14:09 | #18782 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | sm n900 done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-N900 Software version: 29.0 File analysis... OK Total file size: 0x8CF0EBFC (2255 Mb) Searching USB Flash interface... COM320 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:30) Done with Samsung Tool PRO v.29.0 |
07-27-2017, 03:10 | #18783 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Operation: Read Codes via Server Selected model: SM-G930A Software version: 29.0 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 6.0.1 Product code: SM-G930AZKAATT Phone version: G930AUCS2APH1 PDA version: G930AUCS2APH1 CSC version: G930AATT2APH1 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R38H30768HN Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-08-01 RF cal date: 2016.03.04 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: ******** NET lock: ******** SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
The Following User Says Thank You to creconinfo For This Useful Post: |
07-27-2017, 09:18 | #18784 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 28.9 Successfully REMOVE FRP(SAMSUNG SM-J200G)USB Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 28.9 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.9 THANKS Z3X-BOX TEAM |
07-27-2017, 14:03 | #18785 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | GT-S5839I unlock done. UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-S5839I Software version: 28.8.1 Waiting ADB device... OK Reading phone info... Model: GT-S5839i Android version: 2.3.6 Product code: Phone version: S5839iBVLK2 PDA version: S5839iBVLK2 CSC version: S5839iFTMLK1 CSC country code: France CSC sales code: FTM HW version: MP 0.000 Phone SN: RF1CC8JBR4M Modem board: RF cal date: 20121226 IMEI: 354955058427599 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.8.1 |
07-27-2017, 18:05 | #18786 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J510F Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J510F Software version: 28.9 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.9 |
07-27-2017, 18:05 | #18787 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J500H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 28.9 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.9 |
07-27-2017, 18:06 | #18788 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G850W Network Unlock Code: Operation: Unlock Selected model: SM-G850W Selected port: COM183 SAMSUNG Mobile USB Serial Port Software version: 28.9 Reading phone info... Reading IMEI... OK IMEI: 355585060481760 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.28.9 |
07-27-2017, 18:06 | #18789 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J200H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J200H Software version: 28.9 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.9 |
07-27-2017, 18:07 | #18790 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung N7100 Patch Certificate Code: Operation: Repair Selected model: GT-N7100 Software version: 28.8.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: GT-N7100 Android version: 4.4.2 Product code: Not Active Phone version: N7100XXUFND3 PDA version: N7100XXUFND4 CSC version: N7100OJVFND3 CSC country code: UAE CSC sales code: XSG HW version: Unknown Phone SN: 00000000000 Modem board: XMM6262 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.28.8.1 |
07-27-2017, 18:08 | #18791 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J327P Frp Reset Code: Operation: Reset FRP Selected model: SM-J327P Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1APL1 PDA version: J327PVPU1APL1 CSC version: CSC country code: CSC sales code: HW version: J327P.03 Phone SN: 00000000000 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2016-11-01 RF cal date: 2016.12.28 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.6 |
07-27-2017, 18:09 | #18792 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung T399 Network Unlock Code: Operation: Unlock Selected model: SGH-T399 Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SGH-T399 Android version: 4.2.2 Product code: SGH2T399DNATMB Phone version: T399UVUAPA1 PDA version: T399UVUAPA1 CSC version: T399TMBAPA1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: RV8F31600NK Chip name: EXYNOS3470 Modem board: SS222 RF cal date: 20140330 IMEI: 358921054688036 Checking Super user right... true Reading NV data... OK Checking NV data... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.6 |
07-27-2017, 18:10 | #18793 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung T399 Patch Certificate Code: Operation: Patch Certificate Selected model: SGH-T399 Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SGH-T399 Android version: 4.2.2 Product code: SGH2T399DNATMB Phone version: T399UVUAPA1 PDA version: T399UVUAPA1 CSC version: T399TMBAPA1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: RV1DB8QWPRK Modem board: SS222 RF cal date: 20131130 IMEI: 358921052235327 Checking Super user right... true Reading modem OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.28.6 |
07-27-2017, 21:19 | #18794 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | G930P unlock done QF3 Operation: Unlock Selected model: SM-G930P Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G930P Android version: 7.0 Product code: Not Active Phone version: G930PVPU4BQF3 PDA version: G930PVPU4BQF3 CSC version: G930PSPT4BQF3 CSC country code: USA CSC sales code: SPR HW version: REV0.6 Phone SN: 00000000000 Modem board: MSM8996 Security patch: 2017-06-01 RF cal date: 2016.08.10 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
07-28-2017, 08:15 | #18795 (permalink) |
Freak Poster Join Date: Jul 2014 Location: 149.3.27.22 Age: 38
Member: 2229851 Status: Offline Thanks Meter: 55 | samsung E1200R read code done Reading phone info... OK IMEI: 355365068XXXXXX Product code: Phone HW: MP 0.300 Phone SN: R21F831EF6 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:16) Freeze code: 39514627 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
