Old 08-02-2017, 17:18   #18856 (permalink)
Member: 907534
Thanks Meter: 67
A510F unlock done
Operation: Read Codes
Selected model: SM-A510F
Software version: 28.7
Searching Samsung modem... detected COM101
Reading phone info... OK
Model: SM-A510F
AP version: A510FXXU3BPK4
CSC version: A510FOXA3BPK4
CP version: A510FXXU3BPK4
Product code: SM2A510FZWAXEO
Phone SN: R58J1316PFH
Unique number: C00008A4E1FF193
Reading IMEI... OK
IMEI: 356374083****** (SIGN: OK)
Please wait, generating hash codes file, this can take few minutes... OK
Reading data from phone... OK
Modem board: SHANNON310
HWID: 3C 16 F8 85 94 C5 85 2F 41 B0 7A D8 44 2F 22 26
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 53159381
NET lock: 68251373
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.28.7
The Following User Says Thank You to ol1978 For This Useful Post:
Old 08-03-2017, 04:22   #18857 (permalink)
mtb116's Avatar
Member: 177568
Thanks Meter: 77
SM-N920S FRP done
Operation: Reset FRP UFS
Selected model: SM-N920S
Selected port: COM7 Z3X BOX Serial Port
Software version: 28.8.1
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM7 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (N920S)
Setup connection... OK
Reseting FRP... OK
Rebooting phone... OK
Reset FRP done
Done with Samsung Tool PRO v.28.8.1
Old 08-03-2017, 08:47   #18858 (permalink)
Member: 1870532
Sonork: 100.1673711
Thanks Meter: 33
Samsung J2 SM-J200h 100% Read and write EFS or CErt by Z3X
https://www.youtube.com/watch?v=5p-YRtoLHc4
Old 08-03-2017, 08:49   #18859 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 593
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press '0' + power buttons 10 seconds).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Read User Lock
Selected model: SM-B350E
Software version: 29.0
Waiting phone... detected COM35
Sending FDL... OK
Reconnecting phone... OK
Sending FDL2... OK
Reading data from phone ... OK
Phone lock: 99665 (ON)
Done with Samsung Tool PRO v.29.0
Old 08-03-2017, 14:06   #18860 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 254
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
If phone ask codes after unlocking, use:
PUK - 12345678
PIN - 11111111
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J320FN
Searching Samsung modem... detected COM114
Model: SM-J320FN
Version: J320FNXXS0APL1/J320FNTSI0API1/J320FNXXU0APH1/J320FNXXS0APL1
Product code: SM-J320FZWNTSI
Phone SN: RF8HB2X3YBH
IMEI: 3540000000000
Unique number: CQN0064A4F260B3
Unlocking... OK
Unlock done
Old 08-03-2017, 14:58   #18861 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 291
g570f reset frp done
Selected model: SM-G570F
Waiting ADB device... OK
Model: SM-G570F
Android version: 6.0.1
Product code: SM-G570FZKDTHR
Phone version: G570FXXU1AQC1
PDA version: G570FXXU1AQC2
CSC version: G570FOJV1AQC2
CSC country code: IRAN
CSC sales code: THR
HW version: MP 0.500
Phone SN: R58J56MCFQF
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-03-01
RF cal date: 20170529
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 08-04-2017, 11:59   #18862 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 274
Unlocking with original MSL code:
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation lock:
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Read Codes via Server
Selected model: SM-J510H
Checking Login and Password... OK
Ballance: 45 crd.
Model: SM-J510H
Product code: SM-J510HZDDMID
Phone version: J510HXXU2AQD2
PDA version: J510HXXU2AQD2
CSC version: J510HOJV2AQD2
CSC country code: Iraq
CSC sales code: MID
HW version: MP 0.300
Phone SN: RV1J40W1BDM
Chip name: MSM8216
Modem board: MSM8916
Security patch: 2017-04-01
RF cal date: 2017.04.25
IMEI:
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Searching Ramdump interface... COM69 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 84605305
NET lock: 82814930
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 08-04-2017, 12:44   #18863 (permalink)
drbilal's Avatar
Member: 213808
Sonork: 100.1615441
Thanks Meter: 104
N920g frp done by UART cable.
Selected model: SM-N920G
Selected port: COM3 Z3X BOX Serial Port
Checking phone at COM3 OK
Comparing selected model... match (N920G)
Reseting FRP... OK
Reset FRP done
Old 08-04-2017, 13:13   #18864 (permalink)
ksm_lovers2000's Avatar
Member: 968250
Sonork: 100.1673266
Thanks Meter: 13
Arrow help g570f
tested solotion plz
[IMG][/IMG]
Old 08-04-2017, 16:06   #18865 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,506
Selected model: E250
Selected com port: COM90
Selected speed port: 115200
Please, connect phone and press shortly power button
Phone Detected
Sending loader1... OK
ARM version 3541
Sending loader2... OK
Flash ID: 00EC2206000100000014
Phone IMEI -> 3578540177AAA8
Phone SW -> E250AEFL1
Langpack-> SFR, France
Phone HW -> REV1.0
Phone BT ADDR -> 0012-47-000001
Phone WI-FI ADDR ->
[NET LOCK]:06866740,
[SIM LOCK]:00000000,
[PHONE LOCK]:00000000,
[SP LOCK]:00000000,
Read Info - ok
Elapsed time: 336 second, sw ver: 3.5.0040
Old 08-04-2017, 16:38   #18866 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 115
SM-G925F 7.0 SP 01.07.2017 Unlock Done
Thank you Z3x Team
Operation: Unlock
Selected model: SM-G925F
Software version: 27.7
Waiting ADB device... Ok
Model: SM-G925F
Android version: 7.0
Product code: SM-G920FZKAXEF
Phone version: G925FXXU5EQD3
PDA version: G925FXXS5EQGA
CSC version: G925FOLB5EQD1
CSC country code: VIETNAM
CSC sales code: XXV
HW version: MP 0.800
Phone SN: RF1D45EJGGR
Chip name: EXYNOS7420
Modem board: SHANNON333
RF cal date: 20150406
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... Ok
Initialization zTool... Ok
Running zTool, please wait... Ok
HWID: 08 9F 22 AD 97 04 00 00 00 00 00 00 00 00 00 00
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Rebooting phone... Ok
Unlock done
Done with Samsung Tool PRO v.27.7
Old 08-05-2017, 06:52   #18867 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 426
Operation: Reset FRP/React/EE
Selected model: SM-J200G
Searching Samsung USB Flash interface... COM21 detected
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
Old 08-05-2017, 08:49   #18868 (permalink)
anis_rainbow's Avatar
Member: 597569
Sonork: 100.1593870
Thanks Meter: 266
SM-G532G Unlock Done
Operation: Unlock
Selected model: SM-G532G
Software version: 28.9
Model: SM-G532G
Product code: SM-G532GZDDTHL
Phone version: G532GDXU1APJ7
PDA version: G532GDXU1APJ7
CSC version: G532GOLB1APJ5
CSC country code: THAILAND
CSC sales code: THL
Phone SN: R58J622NPKE
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2016-10-01
RF cal date: 20170611
IMEI:
Reading security... OK
Unlocking... OK
Writing security... OK
Unlock done
Old 08-05-2017, 14:37   #18869 (permalink)
gsmali40's Avatar
Member: 2707726
Sonork: 100.1675740
Thanks Meter: 118
help me...............................................
Model: SM-G570F
Product code:
Phone version:
PDA version: G570FXXU1APL4
CSC version:
CSC country code:
CSC sales code:
HW version:
Phone SN: R58J340YXJL
Modem board:
Security patch: 2016-12-01
RF cal date:
IMEI:
Reading data... error
Security damaged (4 23)
Start... OK
Reading data from phone... error (0)
Try downgrade modem if possible
Old 08-05-2017, 14:50   #18870 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 426
Selected model: SM-G610F
Model: SM-G610F
Product code: SM-G610FZDDKSA
Phone version: G610FDDU1AQF4
PDA version: G610FDDU1AQE4
CSC version: G610FOJV1AQE3
CSC country code: KSA
CSC sales code: KSA
Phone SN: R58J35085NP
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2017-05-01
RF cal date: 20170323
IMEI:
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: 8F 07 00 00 00 00 00 00 00 00 00 00 C8 65 CD 06
Calculating... OK
Checking hash file... OK
Please wait, calculating codes... OK (time - 00:00:04)
Freeze code: 96146085
NET lock: 60737168
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1595 05-19-2018 14:20
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.39921 seconds with 9 queries
