08-08-2017, 09:34 | #18871 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Software version: 29.0 Checking Login and Password... OK Ballance: 40 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM2J510FZKUAUT Phone version: J510FNXWU2AQG1 PDA version: J510FNXXU2AQG3 CSC version: J510FNAUT2AQG1 CSC country code: Switzerland CSC sales code: AUT HW version: MP 0.300 Phone SN: RV8J527VRVK Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-07-01 RF cal date: 2017.05.28 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM64 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 42919585 NET lock: 96305850 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
08-09-2017, 16:50 | #18872 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 111730 Status: Offline Thanks Meter: 118 | Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G920F Android version: 7.0 Product code: SM-G920FZDFBTU Phone version: G920FXXU5EQCD PDA version: G920FXXS5EQG1 CSC version: G920FBTU5EQF1 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.800 Phone SN: RF8G511MK1P Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20150516 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 31 D7 2E 17 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-10-2017, 08:30 | #18873 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 29.0 Successfully READ USER LOCK(SAMSUNG SM-B350E)USB UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect the phone in flash mode (Press '1' + 'OK' button and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read User Lock Selected model: SM-B350E Software version: 29.0 Waiting phone... detected COM39 Sending FDL... OK Reconnecting phone... OK Sending FDL2... OK Reading data from phone ... OK Phone lock: 1907 (ON) Done with Samsung Tool PRO v.29.0 THANKS Z3X-BOX TEAM |
08-10-2017, 10:05 | #18874 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung Galaxy j1 mini prime unlock done by read code Operation: Read Codes Selected model: SM-J106B Software version: 28.8.1 Searching Samsung modem... detected COM24 Reading phone info... OK Model: SM-J106B Version: J106BDXU0APL3/J110HOJV0AOGB/J106BDXU0APJ2/J106BDXU0APL3 Product code: SM-J106BZDDXME Phone SN: RV1HC0V545A IMEI: 355002081xxxxxx Unique number: C8G0106682D17C3 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:21) Freeze code: 49482708 NET lock: 79029493 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.8.1 Thanks z3x Team |
08-10-2017, 11:28 | #18875 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Patch Certificate Selected model: GT-I9300 Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: GT-I9300RWDTGY Phone version: I9300XXELLA PDA version: I9300ZSEMC1 CSC version: I9300OZSEMC1 CSC country code: Hong Kong CSC sales code: TGY HW version: MP 1.500 Phone SN: RF1D26XAA1Z Modem board: RF cal date: 2013.2.26 IMEI: 004999010640000 Checking Super user right... true Reading modem OK Patching modem... OK Writing modem... OK Reading kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:52 | #18876 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G531H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-G531H Software version: 29.0 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:53 | #18877 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G850W Network Unlock Code: Operation: Unlock Selected model: SM-G850W Selected port: COM226 SAMSUNG Mobile USB Serial Port Software version: 25.2 Reading phone info... Reading IMEI... OK IMEI: 355585060418333 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 |
08-10-2017, 14:53 | #18878 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G920W8 Network Code Read Code: Operation: Read Codes Selected model: SM-G920W8 Software version: 29.0 Searching Samsung modem... detected COM219 Reading phone info... OK Model: SM-G920W8 AP version: G920W8VLS5DQG1 CSC version: G920W8OYA5DQG1 CP version: G920W8VLU5API1 Product code: FMC Phone SN: RF8HA1SKLFA Unique number: 091609ED85354005 Reading IMEI... OK IMEI: 351559079037875 (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... OK Reading data from phone... OK HWID: D8 2D 3F 2E F6 06 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 20947392 NET lock: 04294604 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:54 | #18879 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J500H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 29.0 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:55 | #18880 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung SC-04D Network Unlock Code: Operation: Unlock Selected model: SC-04D Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: Galaxy Nexus Android version: 4.0.1 Product code: Not Active Phone version: SC04DOMKKD PDA version: CSC version: CSC country code: CSC sales code: HW version: MP 1.000 Phone SN: 00000000000 Modem board: RF cal date: 2011.11.30 IMEI: 358938041175760 Checking Super user right... true Reading NV data... OK Checking magic... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:55 | #18881 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G360T1 Frp Reset Code: Operation: Reset FRP Selected model: SM-J500H Selected port: COM58 SAMSUNG Mobile USB Serial Port Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G360T1 Android version: 5.1.1 Product code: SM2G360TRWATMB Phone version: G360T1UVU2AQD1 PDA version: G360T1UVU2AQD1 CSC version: G360T1TMB2AQD1 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R28G70AD52W Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-01-01 RF cal date: 2015.07.04 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 |
08-10-2017, 14:56 | #18882 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J200H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J200H Software version: 28.6 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.6 |
08-10-2017, 16:30 | #18883 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Haiti
Member: 2216186 Status: Offline Sonork: 100.1668130 Thanks Meter: 120 | Samsung Galaxy Mega 2 AT&T SM-G750A Operation: Unlock Selected model: SM-G750A Software version: 29.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G750A Android version: 5.1.1 Product code: SM-G750ANKAATT Phone version: G750AUCS3BOH5 PDA version: G750AUCS3BOH5 CSC version: G750AATT3BOH5 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R38G60E19EB Modem board: DB7450R RF cal date: 2015.06.24 IMEI: Checking Super user right... true Reading NV data... OK Analyzing NV data... OK Writing NV Data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G750A Android version: 5.1.1 Product code: SM-G750ANKAATT Phone version: G750AUCS3BOH5 PDA version: G750AUCS3BOH5 CSC version: G750AATT3BOH5 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R38G60E19EB Modem board: DB7450R RF cal date: 2015.06.24 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-11-2017, 07:24 | #18885 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 29.0 Successfully REMOVE FRP (SAMSUNG SM-J500F)USB Operation: Reset FRP/React/EE Selected model: SM-J500F Software version: 29.0 Searching Samsung USB Flash interface... COM70 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 THANKS Z3X-BOX TEAM |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
