08-25-2017, 11:24 | #18976 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Model: SHV-E160S Country code: ªU Cal date: ªU Factory SW: E160SKSJMH2 Unique number: CKT09DEEB22F27F Memory phone: ªU Phone SN: R33C71FF9F PDA/CSC version: E160SKSJMH2/none Phone version: SW VERSION :None Phone HW: E16.10 Cal date: none Bypass MSL OK Reading IMEI... OK IMEI: 35231805070434 Repairing IMEI... OK Reseting... OK Repair done Done with Samsung Tool PRO v.29.0 |
08-25-2017, 12:15 | #18977 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-A500F Selected port: COM55 SAMSUNG Mobile USB Serial Port Software version: 29.1 Checking CERT file... OK KEY ID: 0756 Waiting ADB device... OK Reading phone info... Model: SM-A500F Android version: 4.4.4 Product code: SM-A500FZKDSKZ Phone version: A500FXXU1ANL1 PDA version: FA44_A500FXXU1AOG1 CSC version: CSC country code: CSC sales code: HW version: MP 1.100 Phone SN: RF8H11TP9VL Modem board: MSM8916 RF cal date: 2016.01.22 IMEI: 356321062970272 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0756 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.29.1 |
08-25-2017, 12:42 | #18978 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Write QCN Selected model: SM-A500F Selected port: COM55 SAMSUNG Mobile USB Serial Port Software version: 29.1 Reading QCN file... OK Reading ID... OK Detected ID: 00000FFE (MSM8916) SW version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 Checking paths... OK Restoring EFS backup... OK Restoring NV items... OK Restoring NV item SIM1... OK Restoring NV item SIM2... OK Restoring Provisioning Item Files... OK Restore QCN done Done with Samsung Tool PRO v.29.1 |
08-26-2017, 08:00 | #18979 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | SM-G891A unlock done Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G891A Selected port: COM578 SAMSUNG Mobile USB Serial Port Software version: 29.1 Checking Login and Password... OK Ballance: 40 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G891A Android version: 6.0.1 Product code: SM-G891AZAAATT Phone version: G891AUCS2API2 PDA version: G891AUCS2API2 CSC version: G891AATT2API2 CSC country code: USA CSC sales code: ATT HW version: REV0.5 Phone SN: R38H60HQ52M Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-09-01 RF cal date: 2016.06.17 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 06946840 NET lock: 75158038 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 |
08-26-2017, 10:05 | #18980 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | g531f unlock Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 29.1 Searching Samsung USB Flash interface... COM4 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.1 |
08-26-2017, 10:13 | #18981 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM26 USB Serial Port Software version: 29.1 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM26 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.1 |
08-26-2017, 14:01 | #18982 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-G532F Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDMID Phone version: G532FXXU1APJ7 PDA version: G532FXWU1APJ3 CSC version: G532FOJV1APJ6 CSC country code: Iraq CSC sales code: MID HW version: MP 0.300 Phone SN: R58HC51X68B Chip name: MT6737T Modem board: MT6737T Security patch: 2016-10-01 RF cal date: 20161224 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 |
08-26-2017, 16:53 | #18983 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G925F Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: SM-G925FZDAMID Phone version: G925FXXU5DQA3 PDA version: G925FXXS5DQA3 CSC version: G925FOJV5DQA3 CSC country code: Iraq CSC sales code: MID HW version: MP 0.710 Phone SN: RF8H93508NA Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20160928 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.1 |
08-26-2017, 17:47 | #18984 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Germany
Member: 1087322 Status: Offline Thanks Meter: 173 | FRP SM-G570F J5 Prime done Download File in z3x Server COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL9218 515_QB10877448_REV00_user_mid_noship.tar Option sboot Flash Code: Operation: Reset FRP Selected model: SM-G570F Software version: 29.1 Waiting ADB device... OK Lese Telefoninfo... Model: SM-G570F Android version: 6.0.1 Produkt Code: SM-G570FZKDXNZ Phone version: G570FXXU1AQE1 PDA version: G570FXXU1AQE1 CSC version: G570FXNZ1AQE1 CSC country code: New Zealand CSC sales code: XNZ HW version: MP 0.500 Phone SN: R58J53ECK7Z Chip Name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-05-01 RF cal date: 20170516 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 Afghanboy |
08-27-2017, 15:26 | #18985 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Operation: Unlock Selected model: SM-G900F Selected port: COM370 SAMSUNG Mobile USB Serial Port Software version: 29.1 Reading phone info... Reading IMEI... OK IMEI: 353421064805766 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.29.1 |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
08-27-2017, 20:18 | #18986 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | FIRST UNLOCK WITH Z3X... FIRST DOWNGRADE MODEM TO OG2 AND THEN MAGIC WITH Z3X Operation: Unlock Selected model: SM-N910T Selected port: COM7 SAMSUNG Mobile USB Serial Port Software version: 29.1 Reading phone info Reading IMEI OK IMEI: 3560950644XXXX Unlocking OK Reseting OK Unlock done THANKS |
08-28-2017, 14:35 | #18987 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-J700F Software version: 29.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 Product code: SM-J700FZKATUR Phone version: J700FXXU4BQC3 PDA version: J700FXXU4BQC6 CSC version: J700FOJV4BQC6 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.701 Phone SN: R28GC0JRQ7L Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20151203 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.1 |
08-28-2017, 14:37 | #18988 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700F Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 Product code: SM-J700FZKATUR Phone version: J700FXXU4BQC3 PDA version: J700FXXU4BQC6 CSC version: J700FOJV4BQC6 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.701 Phone SN: R28GC0JRQ7L Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20151203 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.1 |
08-28-2017, 18:33 | #18989 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Operation: Unlock Selected model: SM-G550T Software version: 29.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: SM2G550TZKATMB Phone version: G550TUVU1APF1 PDA version: G550TUVU1APF1 CSC version: G550TTMB1APF1 CSC country code: USA CSC sales code: TMB HW version: REV0.4 Phone SN: RV8H80AAAAAD Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-06-01 RF cal date: 20160818 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 66 9E B6 76 F2 BC 6A D6 58 A7 54 8A A5 13 00 47 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
08-29-2017, 09:07 | #18990 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-G891A Software version: 29.2 Checking Login and Password... OK Ballance: 20 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G891A Android version: 7.0 Product code: SM-G891AZAAATT Phone version: G891AUCU2BQF2 PDA version: G891AUCU2BQF2 CSC version: G891AATT2BQF2 CSC country code: USA CSC sales code: ATT HW version: REV0.5 Phone SN: R38H90K4KJV Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-06-01 RF cal date: 2016.10.24 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM67 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 39725169 NET lock: 35914290 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
