09-29-2017, 13:37 | #19156 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Patch Certificate Selected model: SM-J120H/DS Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-J120H Android version: 5.1.1 Product code: SM-J120HZWDCAC Phone version: J120HXXU0AQB1 PDA version: J120HXXU0AQE2 CSC version: J120HOXE0AQE1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.400 Phone SN: R51J105ETEH Modem board: SC7727SE Security patch: 2017-05-01 RF cal date: 20170110 IMEI: 2xxxxxxxxxxxxxx Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
09-29-2017, 13:46 | #19157 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung j1ace unlock done Operation: Read Codes Selected model: SM-J111F Software version: 29.4 Searching Samsung modem... detected COM35 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2 Product code: SM-J111FZKDXME Phone SN: RV8J60TB0XT IMEI: 35765908xxxxxxx Unique number: C8G011970488144 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:04) Freeze code: 58571837 NET lock: 31793842 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 Thanks z3x team |
09-29-2017, 14:20 | #19158 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | SM-A710F Remove FRP done First flash phone with this COMBINATION_FAC_FA51_A710FXXU2AQG6_2 second reset FRP Operation: Reset FRP Selected model: SM-A710F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-A710F Android version: 5.1.1 Product code: SM-A710FZDFXSG Phone version: A710FXXU2CQG5 PDA version: FA51_A710FXXU2AQG6 CSC version: CSC country code: CSC sales code: HW version: MP 0.000 Phone SN: RF8H30EY89A Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2015-11-01 RF cal date: 20160304 IMEI: 3568250758xxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
09-29-2017, 16:01 | #19159 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: GT-I9300 Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: ARIZA_V[0.4 PDA version: I9300XXELLB CSC version: I9300OJVELL3 CSC country code: Kenya CSC sales code: AFR HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 000000000000000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
09-29-2017, 16:05 | #19160 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Patch Certificate Selected model: GT-I9300 Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: I9300XXUGNA8 PDA version: I9300XXELLB CSC version: I9300OJVELL3 CSC country code: Kenya CSC sales code: AFR HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 000000000000 Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
09-30-2017, 13:21 | #19162 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | j200f frp lock done Operation: Reset FRP/React/EE Selected model: SM-J200F Software version: 29.2 Searching Samsung USB Flash interface... COM14 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
10-01-2017, 08:30 | #19163 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-G570Y Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G570Y Android version: 6.0.1 Product code: SM-G570YZKA2DX Phone version: G570YDXU1APIA PDA version: G570YDXU1AQH1 CSC version: G570Y2DX1AQH1 CSC country code: New Zealand CSC sales code: 2DX HW version: MP 0.500 Phone SN: R28J22X0G4D Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-08-01 RF cal date: 20170222 IMEI: 353574080868497 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: 96 CD 40 8E 5B A4 9E F1 3B 91 3A C2 0A 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 |
10-02-2017, 12:44 | #19164 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | SM-G930F Patch Certificate Done on 7.0 [Network Okay] Code: Operation: Patch Certificate Selected model: SM-G930F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 7.0 Product code: SM-G930FZKAXEU Phone version: G930FXXU1ZPK1 PDA version: G930FXXU1ZPK4 CSC version: G930FOXA1ZPK4 CSC country code: UK & IRE CSC sales code: XEU HW version: MP 0.700 Phone SN: R58H63HAM7V Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-10-01 RF cal date: 20160624 IMEI: 3597076----------- Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
The Following 3 Users Say Thank You to EjazATF For This Useful Post: |
10-02-2017, 13:34 | #19165 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | j200h ds repair done Waiting ADB device... OK Reading phone info... Model: SM-J200H Android version: 5.1.1 Product code: SM-J200HZKDBTC Phone version: J200HXXU0AOI9 PDA version: J200HXXU0AOIB CSC version: J200HOJV0AOIB CSC country code: Libya CSC sales code: BTC HW version: MP 0.200 Phone SN: RV1H80ZXTYE Modem board: SC7730SE RF cal date: 20160825 IMEI: Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Repairing Slave IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.2 |
10-03-2017, 07:54 | #19166 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM19 Z3X BOX Serial Port Software version: 29.4 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM19 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.4 |
10-03-2017, 09:48 | #19167 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-A310F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-A310F Android version: 6.0.1 Product code: SM-A310FZWATUR Phone version: A310FXXU3AQC1 PDA version: A310FXXU3BQC8 CSC version: A310FOJV3BQC8 CSC country code: syria CSC sales code: damascus HW version: MP 0.200 Phone SN: R28H4075TPZ Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20160406 IMEI: 30000000000000 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
10-03-2017, 10:55 | #19168 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM28 ?USB Serial Port Software version: 29.4 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM28 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.4 |
10-03-2017, 12:15 | #19169 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-G955U Software version: 29.4 Checking Login and Password... OK Ballance: 5 crd. Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 7.0 Product code: SM-G955UZKAATT Phone version: G955USQU1AQGL PDA version: G955USQU1AQGL CSC version: G955UOYN1AQGL CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J60xxxxx Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-08-01 RF cal date: 2017.06.01 IMEI: 355979082xxxxxx Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM82 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 41820515 NET lock: 90852909 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
10-03-2017, 13:45 | #19170 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-J111F Software version: 29.4 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-J111F Android version: 5.1.1 Product code: SM-J111FZKATUR Phone version: J111FXXU0AQG2 PDA version: J111FXXU0AQF3 CSC version: J111FOJW0AQF4 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.200 Phone SN: R58H9349RSY Chip name: SC9830I Modem board: SC9830i Security patch: 2017-06-01 RF cal date: 2016.09.17 IMEI: 200000000000000 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
