10-09-2017, 13:32 | #19201 (permalink) | |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Quote:
are u crazy ???????????????????? | |
10-09-2017, 13:32 | #19202 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G610F Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDBTC Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: Libya CSC sales code: BTC HW version: MP 0.300 Phone SN: R28J300TAXP Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170301 IMEI: 3xxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: F5 05 00 00 00 00 00 00 00 00 00 00 15 3C 17 6B Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
10-09-2017, 13:33 | #19203 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G610F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDBTC Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: Libya CSC sales code: BTC HW version: MP 0.300 Phone SN: R28J300TAXP Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170301 IMEI: 3xxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
10-09-2017, 15:30 | #19204 (permalink) |
Major Poster Join Date: Nov 2016
Member: 2648193 Status: Offline Thanks Meter: 3 | just unlock one NOTE 8 and still locked this code not working Waiting ADB device... OK Reading phone info... Model: SM-N950W Android version: 7.1.1 Product code: SM-N950WZKARWC Phone version: N950WVLU1AQI5 PDA version: N950WVLU1AQI5 CSC version: N950WOYV1AQI5 CSC country code: Canada CSC sales code: RWC HW version: REV1.0 Phone SN: R28J82C5PQA Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-08-01 RF cal date: 2017.08.17 IMEI: 358511080172442 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM16 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 00000000 NET lock: 01234567 SUB lock: 01234567 SP lock: 01234567 CP lock: 01234567 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
10-09-2017, 15:42 | #19206 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Samsung j111f unlock success (read codes) Operation: Read Codes Selected model: SM-J111F Software version: 29.4 Searching Samsung modem... detected COM180 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2 Product code: SM-J111FZKDXME Phone SN: RV8J60H6TGA IMEI: 357659086120559 Unique number: C8G010B4B30DE44 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:45) Freeze code: 09173906 NET lock: 42968424 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
10-09-2017, 17:07 | #19207 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | g610m frp no flash needed Operation: Reset FRP Selected model: SM-G610M Software version: 29.4 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G610M Android version: 6.0.1 Product code: SM-G610MZKACDR Phone version: G610MUBU1AQG2 PDA version: G610MUBU1AQG2 CSC version: G610MUWA1AQH2 CSC country code: Dominican Republic CSC sales code: CDR HW version: MP 0.100 Phone SN: R58J73C7SAE Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170718 IMEI: 35771308xxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4k |
10-10-2017, 05:39 | #19208 (permalink) |
Junior Member Join Date: Mar 2017 Location: London, UK
Member: 2692434 Status: Offline Thanks Meter: 25 | Operation: Reset FRP/React/EE Selected model: SM-G935T Software version: 29.4 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935T Android version: 6.0.1 Product code: SM-G935TZBATMB Phone version: G935TUVU4APK1 PDA version: G935TUVU4APK1 CSC version: G935TTMB4APK1 CSC country code: USA CSC sales code: TMB HW version: REV0.7 Phone SN: RF8HB2LK4JW Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.11.21 IMEI: 355018080842878 Checking Super user right... true Erasing FRP... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.4 |
10-10-2017, 08:54 | #19209 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1817738 Status: Offline Thanks Meter: 27 | j730g 100% unlocking done tested...... Operation: Unlock Selected model: SM-J730G Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-J730G Android version: 7.0 Product code: SM-J730GZDGXME Phone version: J730GDXU1AQF5 PDA version: J730GDXU1AQF6 CSC version: J730GOLB1AQF6 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.400 Phone SN: R58J71NMKDH Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20170711 IMEI: 356446083305768 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 60 44 B3 EB 05 9D 77 D4 7E D1 D1 70 31 29 58 C4 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 root https://www.4shared.com/archive/VdR-...-j730ggmf.html |
10-10-2017, 10:36 | #19210 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500FN Selected port: COM179 ?SAMSUNG Mobile USB Serial Port Software version: 29.4 Checking CERT file... OK KEY ID: 0151 Waiting ADB device... OK Reading phone info... Model: SM-J500FN Android version: 6.0.1 Product code: SM-J500FZWAWIN Phone version: J500FNXXU1AOF9 PDA version: J500FNXXU1BQA3 CSC version: J500FNWIN1BPL1 CSC country code: ITALY CSC sales code: WIN HW version: MP 0.400 Phone SN: RV8GA0CQB6Z Modem board: MSM8916 Security patch: 2017-01-01 RF cal date: 2015.10.21 IMEI: 3xxxxxxxxxxxxx Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0151 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.29.4 |
10-10-2017, 11:03 | #19211 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-J200F Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZKATUR Phone version: J200FXXU1AOI5 PDA version: J200FXXU1AOI6 CSC version: J200FOJV1AOI6 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.300 Phone SN: 00000000000 Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20151211 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON308 HWID: 17 52 DF 77 E9 7F 0C 66 90 2F 32 CF 5D 9B 0D 50 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
10-10-2017, 11:03 | #19212 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-J200F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZKATUR Phone version: J200FXXU1AOI5 PDA version: J200FXXU1AOI6 CSC version: J200FOJV1AOI6 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.300 Phone SN: 00000000000 Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20151211 IMEI: 3XXXXXXXXXXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
10-10-2017, 15:35 | #19213 (permalink) |
Freak Poster Join Date: Dec 2011 Location: ALGERIA
Member: 1706377 Status: Offline Thanks Meter: 61 | sm-g570f frp reset done: Operation: Reset FRP Selected model: SM-G570F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZDDWTL Phone version: G570FXXU1AQF4 PDA version: G570FXXU1AQG3 CSC version: G570FOJV1AQG3 CSC country code: Algeria CSC sales code: WTL HW version: MP 0.500 Phone SN: R28HB3EBD9X Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-07-01 RF cal date: 20161124 IMEI: 355248081344158 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
